[GRASS-SVN] r42713 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 7 19:25:22 EDT 2010
Author: martinl
Date: 2010-07-07 23:25:22 +0000 (Wed, 07 Jul 2010)
New Revision: 42713
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: redesign Model class
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-07 18:35:03 UTC (rev 42712)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-07 23:25:22 UTC (rev 42713)
@@ -78,9 +78,7 @@
class Model(object):
"""!Class representing the model"""
def __init__(self, canvas = None):
- self.actions = list() # list of recorded actions
- self.data = list() # list of recorded data items
- self.loops = list() # list of recorded loops
+ self.items = list() # list of actions/loops/...
# model properties
self.properties = { 'name' : _("model"),
@@ -96,10 +94,28 @@
"""!Get canvas or None"""
return self.canvas
+ def GetItems(self):
+ """!Get list of model items"""
+ return self.items
def GetActions(self):
- """!Return list of actions"""
- return self.actions
+ """!Get list of model actions"""
+ result = list()
+ for item in self.items:
+ if isinstance(item, ModelAction):
+ result.append(item)
+ return result
+ def GetLoops(self):
+ """!Get list of model loops"""
+ result = list()
+ if isinstance(item, ModelLoop):
+ return result
def GetAction(self, aId):
"""!Get action of given id
@@ -108,16 +124,13 @@
@return ModelAction instance
@return None if no action found
- for action in self.actions:
+ alist = self.GetActions()
+ for action in alist:
if action.GetId() == aId:
return action
return None
- def GetLoops(self):
- """!Return list of loops"""
- return self.loops
def GetProperties(self):
"""!Get model properties"""
return self.properties
@@ -133,23 +146,10 @@
"""!Set model variables"""
self.variables = data
- def GetData(self):
- """!Return list of data"""
- return self.data
def Reset(self):
"""!Reset model"""
- def AddAction(self, item):
- """!Add action to the model"""
- self.actions.append(item)
- def AddData(self, item):
- """!Add data to the model"""
- self.data.append(item)
def RemoveItem(self, item):
"""!Remove item from model
@@ -169,23 +169,15 @@
return relList
- def FindAction(self, id):
+ def FindAction(self, aId):
"""!Find action by id"""
- if action.GetId() == id:
+ if action.GetId() == aId:
return action
return None
- def FindData(self, value, prompt):
- """!Find data by value, and prompt"""
- for data in self.data:
- if data.GetValue() == value and \
- data.GetPrompt() == prompt:
- return data
- return None
def LoadModel(self, filename):
"""!Load model definition stored in GRASS Model XML file (gxm)
@@ -225,7 +217,7 @@
if action['disabled']:
actionItem.Enable(False)
- self.actions.append(actionItem)
+ self.AddItem(actionItem)
task = actionItem.GetTask()
parameterized = False
@@ -264,26 +256,41 @@
else:
relation = ModelRelation(actionItem, dataItem, rel['name'])
relation.SetControlPoints(rel['points'])
- dataItem.AddRelation(relation, direction = rel['dir'])
+ dataItem.AddRelation(relation)
+ actionItem.AddRelation(relation)
dataItem.Update()
- self.data.append(dataItem)
- actionItem.AddData(dataItem)
# load loops
for loop in gxmXml.loops:
+ alist = list()
+ for aId in loop['actions']:
+ alist.append(self.GetAction(aId))
loopItem = ModelLoop(parent = self,
x = loop['pos'][0],
y = loop['pos'][1],
width = loop['size'][0],
height = loop['size'][1],
text = loop['text'],
- actions = loop['actions'],
+ actions = alist,
id = loop['id'])
- self.loops.append(loopItem)
+ self.AddItem(loopItem)
+ def AddItem(self, newItem):
+ """!Add item to the list"""
+ iId = newItem.GetId()
+ i = 0
+ if item.GetId() > iId:
+ self.items.insert(i, newItem)
+ return
+ i += 1
+ self.items.append(newItem)
def IsValid(self):
"""Return True if model is valid"""
if self.Validate():
@@ -295,7 +302,7 @@
"""!Validate model, return None if model is valid otherwise
error string"""
errList = list()
+ for action in self.GetActions():
task = menuform.GUI().ParseCommand(cmd = action.GetLog(string = False),
show = None)
errList += task.getCmdError()
@@ -411,7 +418,7 @@
idx += 1
if not action.IsEnabled():
continue
name = action.GetName()
@@ -490,7 +497,7 @@
self.actionPanel = ActionPanel(parent = self)
- self.goutput = goutput.GMConsole(parent = self, pageid = 2,
+ self.goutput = goutput.GMConsole(parent = self, pageid = 3,
notebook = self.notebook)
self.notebook.AddPage(self.canvas, text=_('Model'))
@@ -833,24 +840,34 @@
return
self.goutput.cmdThread.SetId(-1)
- for action in self.model.GetActions():
- if not action.IsEnabled():
+ for item in self.model.GetItems():
+ print item
+ if not item.IsEnabled():
continue
- name = action.GetName()
- if params.has_key(name):
- paramsOrig = action.GetParams(dcopy = True)
- action.MergeParams(params[name])
- self.SetStatusText(_('Running model...'), 0)
- self.goutput.RunCmd(command = action.GetLog(string = False),
- onDone = self.OnDone)
- action.SetParams(paramsOrig)
+ self._runAction(item, params)
+ elif isinstance(item, ModelLoop):
+ print item.GetText()
+ for action in item.GetActions():
+ self._runAction(action, params)
if params:
dlg.Destroy()
+ def _runAction(self, item, params):
+ """!Run given action"""
+ name = item.GetName()
+ if params.has_key(name):
+ paramsOrig = item.GetParams(dcopy = True)
+ item.MergeParams(params[name])
+ self.SetStatusText(_('Running model...'), 0)
+ self.goutput.RunCmd(command = item.GetLog(string = False),
+ onDone = self.OnDone)
+ item.SetParams(paramsOrig)
def OnDone(self, returncode):
"""!Computation finished"""
self.SetStatusText('', 0)
@@ -1096,14 +1113,13 @@
def OnDefineLoop(self, event):
"""!Define new loop in the model"""
self.ModelChanged()
width, height = self.canvas.GetSize()
loop = ModelLoop(self, x = width/2, y = height/2)
self.canvas.diagram.AddShape(loop)
loop.Show(True)
self._addEvent(loop)
- # self.model.AddAction(action)
self.canvas.Refresh()
@@ -1136,7 +1152,7 @@
action.Show(True)
self._addEvent(action)
- self.model.AddAction(action)
+ self.model.AddItem(action)
time.sleep(.1)
@@ -1321,29 +1337,30 @@
self.SetStatusText(_("Please wait, loading model..."), 0)
# load actions
- self._addEvent(action)
- self.canvas.diagram.AddShape(action)
- action.Show(True)
- # load data & relations
- for data in self.model.GetData():
- self._addEvent(data)
- self.canvas.diagram.AddShape(data)
- data.Show(True)
- for rel in data.GetRelations():
+ for item in self.model.GetActions():
+ self._addEvent(item)
+ self.canvas.diagram.AddShape(item)
+ item.Show(True)
+ # relations/data
+ for rel in item.GetRelations():
+ if rel.GetFrom() == item:
+ dataItem = rel.GetTo()
+ else:
+ dataItem = rel.GetFrom()
+ self._addEvent(dataItem)
+ self.canvas.diagram.AddShape(dataItem)
self.AddLine(rel)
+ dataItem.Show(True)
# load loops
- for loop in self.model.GetLoops():
- self._addEvent(loop)
- self.canvas.diagram.AddShape(loop)
- loop.Show(True)
+ for item in self.model.GetLoops():
+ item.Show(True)
+ # connect actions in the loop
+ self.DefineLoop(item)
- # connect action in the loop
- self.DefineLoop(loop)
# load variables
self.variablePanel.Update()
self.actionPanel.Update()
@@ -1389,29 +1406,13 @@
if not actions:
return
- minId = None
- aId = action.GetId()
- if aId not in actions:
- continue
- if aId < minId or minId is None:
- minId = aId
+ for action in loop.GetActions():
rel = ModelRelation(parent, action)
self.AddLine(rel)
parent = action
- loop.SetId(minId)
- if aId >= minId:
- action.SetId(aId + 1)
- try:
- idx = actions.index(aId)
- actions[idx] = aId + 1
- except ValueError:
- pass
# close loop
+ action = loop.GetActions()[-1]
rel = ModelRelation(action, loop)
self.AddLine(rel)
dx = loop.GetWidth() / 2 + 50
@@ -1467,11 +1468,61 @@
self.Refresh()
-class ModelAction(ogl.RectangleShape):
+class ModelObject:
+ def __init__(self, id = -1):
+ self.id = id
+ self.rels = list() # list of ModelRelations
+ self.isEnabled = True
+ def GetId(self):
+ """!Get id"""
+ return self.id
+ def AddRelation(self, rel):
+ """!Record new relation
+ self.rels.append(rel)
+ def GetRelations(self, fdir = None):
+ """!Get list of relations
+ @param fdir True for 'from'
+ if fdir is None:
+ return self.rels
+ result = list()
+ for rel in self.rels:
+ if fdir == 'from':
+ if rel.GetFrom() == self:
+ result.append(rel)
+ else:
+ if rel.GetTo() == self:
+ return result
+ def IsEnabled(self):
+ """!Get True if action is enabled, otherwise False"""
+ return self.isEnabled
+ def Enable(self, enabled = True):
+ """!Enable/disable action"""
+ self.isEnabled = enabled
+ self.Update()
+ def Update(self):
+ pass
+class ModelAction(ModelObject, ogl.RectangleShape):
"""!Action class (GRASS module)"""
def __init__(self, parent, x, y, id = -1, cmd = None, task = None, width = None, height = None):
+ ModelObject.__init__(self, id)
self.parent = parent
self.task = task
if not width:
width = UserSettings.Get(group='modeler', key='action', subkey=('size', 'width'))
if not height:
@@ -1487,13 +1538,11 @@
self.task = None
self.propWin = None
- self.id = id
self.data = list() # list of connected data items
self.isValid = False
self.isParameterized = False
- self.isEnabled = True
if self.parent.GetCanvas():
ogl.RectangleShape.__init__(self, width, height)
@@ -1536,19 +1585,6 @@
pen.SetWidth(width)
self.SetPen(pen)
- def Enable(self, enabled = True):
- """!Enable/disable action"""
- self.isEnabled = enabled
- self.Update()
- def IsEnabled(self):
- """!Get True if action is enabled, otherwise False"""
- return self.isEnabled
- def GetId(self):
- """!Get id"""
- return self.id
def SetId(self, id):
"""!Set id"""
self.id = id
@@ -1657,11 +1693,6 @@
"""!Check if action is parameterized"""
return self.isParameterized
- """!Register new data item"""
- if item not in self.data:
def FindData(self, name):
"""!Find data item by name"""
for d in self.data:
@@ -1684,7 +1715,7 @@
self._setPen()
ogl.RectangleShape.OnDraw(self, dc)
-class ModelData(ogl.EllipseShape):
+class ModelData(ModelObject, ogl.EllipseShape):
def __init__(self, parent, x, y, value = '', prompt = '', width = None, height = None):
"""Data item class
@@ -1695,6 +1726,8 @@
@param prompt type of GIS element
@param width, height dimension of the shape
+ ModelObject.__init__(self)
self.value = value
self.prompt = prompt
@@ -1705,8 +1738,6 @@
if not height:
height = UserSettings.Get(group='modeler', key='data', subkey=('size', 'height'))
- self.rels = { 'from' : list(), 'to' : list() } # list of recorded relations
ogl.EllipseShape.__init__(self, width, height)
@@ -1740,7 +1771,7 @@
def GetLog(self, string = True):
"""!Get logging info"""
name = list()
- for rel in self.rels['from'] + self.rels['to']:
+ for rel in self.GetRelations():
name.append(rel.GetName())
if name:
return '/'.join(name) + '=' + self.value + ' (' + self.prompt + ')'
@@ -1750,7 +1781,7 @@
def GetName(self):
"""!Get list of names"""
name = list()
return name
@@ -1768,7 +1799,7 @@
self.value = value
self._setText()
for direction in ('from', 'to'):
- for rel in self.rels[direction]:
+ for rel in self.GetRelations(direction):
if direction == 'from':
action = rel.GetTo()
else:
@@ -1779,20 +1810,6 @@
task.set_param(rel.GetName(), self.value)
action.SetParams(params = task.get_options())
- def GetRelations(self, direction = None):
- """!Get relations from/to"""
- if not direction:
- return self.rels['from'] + self.rels['to']
- return self.rels[direction]
- def AddRelation(self, rel, direction):
- """!Record new relation
- @param direction direction - 'from' or 'to'
- self.rels[direction].append(rel)
def AddName(self, name, direction):
"""!Record new name (parameter)
@@ -1828,12 +1845,12 @@
def _setPen(self):
"""!Set pen"""
- for rel in self.rels['from']:
+ for rel in self.GetRelations('from'):
if rel.GetTo().IsParameterized():
isParameterized = True
break
if not isParameterized:
- for rel in self.rels['to']:
+ for rel in self.GetRelations('to'):
if rel.GetFrom().IsParameterized():
break
@@ -1852,7 +1869,7 @@
"""!Update text"""
self.ClearText()
name = []
- for rel in self.rels['to'] + self.rels['from']:
self.AddText('/'.join(name))
self.AddText(self.value)
@@ -2517,11 +2534,9 @@
def __init__(self, fd, model):
self.fd = fd
self.model = model
- self.actions = model.GetActions()
- self.data = model.GetData()
self.properties = model.GetProperties()
self.variables = model.GetVariables()
- self.loops = model.GetLoops()
+ self.items = model.GetItems()
self.indent = 0
@@ -2530,10 +2545,19 @@
self._window()
self._properties()
self._variables()
- self._actions()
- self._data()
- self._loops()
+ self._items()
+ dataList = list()
+ for action in model.GetActions():
+ for rel in action.GetRelations():
+ if rel.GetFrom() == action:
+ else:
+ if dataItem not in dataList:
+ dataList.append(dataItem)
+ self._data(dataList)
self._footer()
def _filterValue(self, value):
@@ -2602,58 +2626,62 @@
self.indent -= 4
self.fd.write('%s</variables>\n' % (' ' * self.indent))
- def _actions(self):
+ def _items(self):
+ """!Write actions/loops"""
+ self.indent += 4
+ self._action(item)
+ self._loop(item)
+ self.indent -= 4
+ def _action(self, action):
"""!Write actions"""
- id = 1
- action.SetId(id)
- self.fd.write('%s<action id="%d" name="%s" pos="%d,%d" size="%d,%d">\n' % \
- (' ' * self.indent, id, action.GetName(), action.GetX(), action.GetY(),
- action.GetWidth(), action.GetHeight()))
- self.indent += 4
- self.fd.write('%s<task name="%s">\n' % (' ' * self.indent, action.GetLog(string = False)[0]))
- self.indent += 4
- self.fd.write('%s<disabled />\n' % (' ' * self.indent))
- for key, val in action.GetParams().iteritems():
- if key == 'flags':
- for f in val:
- if f.get('value', False) or f.get('parameterized', False):
- if f.get('parameterized', False):
- if f.get('value', False) == False:
- self.fd.write('%s<flag name="%s" value="0" parameterized="1" />\n' %
- (' ' * self.indent, f.get('name', '')))
- else:
- self.fd.write('%s<flag name="%s" parameterized="1" />\n' %
+ self.fd.write('%s<action id="%d" name="%s" pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, action.GetId(), action.GetName(), action.GetX(), action.GetY(),
+ action.GetWidth(), action.GetHeight()))
+ self.indent += 4
+ self.fd.write('%s<task name="%s">\n' % (' ' * self.indent, action.GetLog(string = False)[0]))
+ self.indent += 4
+ if not action.IsEnabled():
+ self.fd.write('%s<disabled />\n' % (' ' * self.indent))
+ for key, val in action.GetParams().iteritems():
+ if key == 'flags':
+ for f in val:
+ if f.get('value', False) or f.get('parameterized', False):
+ if f.get('parameterized', False):
+ if f.get('value', False) == False:
+ self.fd.write('%s<flag name="%s" value="0" parameterized="1" />\n' %
+ (' ' * self.indent, f.get('name', '')))
else:
- self.fd.write('%s<flag name="%s" />\n' %
+ self.fd.write('%s<flag name="%s" parameterized="1" />\n' %
- else: # parameter
- for p in val:
- if not p.get('value', ''):
- continue
- self.fd.write('%s<parameter name="%s">\n' %
- (' ' * self.indent, p.get('name', '')))
- self.indent += 4
- if p.get('parameterized', False):
- self.fd.write('%s<parameterized />\n' % (' ' * self.indent))
- self.fd.write('%s<value>%s</value>\n' %
- (' ' * self.indent, self._filterValue(p.get('value', ''))))
- self.indent -= 4
- self.fd.write('%s</parameter>\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</task>\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</action>\n' % (' ' * self.indent))
- id += 1
+ else:
+ self.fd.write('%s<flag name="%s" />\n' %
+ else: # parameter
+ for p in val:
+ if not p.get('value', ''):
+ continue
+ self.fd.write('%s<parameter name="%s">\n' %
+ (' ' * self.indent, p.get('name', '')))
+ self.indent += 4
+ if p.get('parameterized', False):
+ self.fd.write('%s<parameterized />\n' % (' ' * self.indent))
+ self.fd.write('%s<value>%s</value>\n' %
+ (' ' * self.indent, self._filterValue(p.get('value', ''))))
+ self.indent -= 4
+ self.fd.write('%s</parameter>\n' % (' ' * self.indent))
self.indent -= 4
- def _data(self):
+ self.fd.write('%s</task>\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</action>\n' % (' ' * self.indent))
+ def _data(self, dataList):
"""!Write data"""
self.indent += 4
+ for data in dataList:
self.fd.write('%s<data pos="%d,%d" size="%d,%d">\n' % \
(' ' * self.indent, data.GetX(), data.GetY(),
data.GetWidth(), data.GetHeight()))
@@ -2671,7 +2699,7 @@
# relations
for ft in ('from', 'to'):
- for rel in data.GetRelations(direction = ft):
+ for rel in data.GetRelations(ft):
if ft == 'from':
aid = rel.GetTo().GetId()
else:
@@ -2693,24 +2721,23 @@
self.indent -= 4
self.fd.write('%s</data>\n' % (' ' * self.indent))
- def _loops(self):
+ def _loop(self, loop):
"""!Write loops"""
- for loop in self.loops:
- self.fd.write('%s<loop id="%d" pos="%d,%d" size="%d,%d">\n' % \
- (' ' * self.indent, loop.GetId(), loop.GetX(), loop.GetY(),
- loop.GetWidth(), loop.GetHeight()))
- text = loop.GetText()
- self.indent += 4
- if text:
- self.fd.write('%s<condition>%s</condition>\n' %
- (' ' * self.indent, self._filterValue(text)))
- for action in loop.GetActions():
- self.fd.write('%s<loop-action>%d</loop-action>\n' %
- (' ' * self.indent, action))
- self.indent -= 4
+ self.fd.write('%s<loop id="%d" pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, loop.GetId(), loop.GetX(), loop.GetY(),
+ loop.GetWidth(), loop.GetHeight()))
+ text = loop.GetText()
+ self.indent += 4
+ if text:
+ self.fd.write('%s<condition>%s</condition>\n' %
+ (' ' * self.indent, self._filterValue(text)))
+ self.fd.write('%s<loop-action>%d</loop-action>\n' %
+ (' ' * self.indent, action))
+ self.indent -= 4
+ self.fd.write('%s</loop>\n' % (' ' * self.indent))
- self.fd.write('%s</loop>\n' % (' ' * self.indent))
class PreferencesDialog(PreferencesBaseDialog):
"""!User preferences dialog"""
def __init__(self, parent, settings = UserSettings,
@@ -3127,7 +3154,7 @@
FN.FNB_NO_X_BUTTON)
else:
self.notebook = FN.FlatNotebook(self, id = wx.ID_ANY,
- agwStyle = FN.FNB_FANCY_TABS |
+ style = FN.FNB_FANCY_TABS |
FN.FNB_BOTTOM |
FN.FNB_NO_NAV_BUTTONS |
FN.FNB_NO_X_BUTTON)
@@ -3207,8 +3234,11 @@
wx.LC_VRULES, **kwargs):
"""!List of model variables"""
- self.frame = parent.parent
+ try:
+ self.frame = parent.parent
+ except AttributeError:
+ self.frame = None
wx.ListCtrl.__init__(self, parent, id = id, style = style, **kwargs)
listmix.ListCtrlAutoWidthMixin.__init__(self)
listmix.TextEditMixin.__init__(self)
@@ -3503,17 +3533,18 @@
self.PopupMenu(menu)
menu.Destroy()
-class ModelLoop(ogl.RectangleShape):
+class ModelLoop(ModelObject, ogl.RectangleShape):
def __init__(self, parent, x, y, id = -1, width = None, height = None, text = None, actions = []):
"""!Defines a loop"""
self.text = text
if not width:
width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
if not height:
height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
- self.actions = actions
- self.id = id
+ self.actions = actions # list of actions in the loop
@@ -3525,10 +3556,6 @@
self.SetCornerRadius(100)
self.AddText('(' + str(self.id) + ') ' + text)
- def GetId(self):
- """!Get loop id"""
- return self.id
def GetText(self):
"""!Get loop text"""
return self.text
@@ -3630,7 +3657,7 @@
self.list = ActionListCtrl(parent = self,
columns = [_("ID"), _("Name"),
- _("Type"), _("Command")])
+ _("Command")])
self._layout()
@@ -3671,38 +3698,22 @@
self.itemDataMap = dict()
i = 0
for action in data:
- if self.GetColumnCount() == 4:
- self.itemDataMap[i] = [str(action.GetId()),
- action.GetName(),
- "module",
- action.GetLog()]
- else:
- action.GetName(),
- action.GetLog()]
+ self.itemDataMap[i] = [str(action.GetId()),
+ action.GetName(),
+ action.GetLog()]
i += 1
self.itemCount = len(self.itemDataMap.keys())
self.DeleteAllItems()
i = 0
- for aid, name, atype, desc in self.itemDataMap.itervalues():
- index = self.InsertStringItem(sys.maxint, aid)
- self.SetStringItem(index, 0, aid)
- self.SetStringItem(index, 1, name)
- self.SetStringItem(index, 2, atype)
- self.SetStringItem(index, 3, desc)
- self.SetItemData(index, i)
- i += 1
- else:
- for aid, name, desc in self.itemDataMap.itervalues():
- self.SetStringItem(index, 2, desc)
- i += 1
+ for aid, name, desc in self.itemDataMap.itervalues():
+ index = self.InsertStringItem(sys.maxint, aid)
+ self.SetStringItem(index, 0, aid)
+ self.SetStringItem(index, 1, name)
+ self.SetStringItem(index, 2, desc)
+ self.SetItemData(index, i)
+ i += 1
def OnRemove(self, event):
"""!Remove selected action(s) from the model"""
@@ -3719,7 +3730,7 @@
if not action:
item = self.GetFirstSelected()
continue
- print aId, action
model.RemoveItem(action)
canvas.GetDiagram().RemoveShape(action)
self.frame.ModelChanged()
@@ -3798,8 +3809,9 @@
model = self.frame.GetModel()
aId = 1
- for action in model.GetActions():
- action.SetId(aId)
+ for item in model.GetItems():
+ print item
+ item.SetId(aId)
aId += 1
self.OnReload(None)
