[GRASS-SVN] r42740 - grass/trunk/mswindows
svn_grass at osgeo.org
Fri Jul 9 10:38:38 EDT 2010
Author: hellik
Date: 2010-07-09 14:38:38 +0000 (Fri, 09 Jul 2010)
New Revision: 42740
grass/trunk/mswindows/GRASS-Installer.nsi
#1092 R's installation path in %PATH%
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2010-07-09 14:35:14 UTC (rev 42739)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2010-07-09 14:38:38 UTC (rev 42740)
@@ -186,11 +186,17 @@
Var /GLOBAL MESSAGE_2_
Var /GLOBAL MESSAGE_3_
+ Var /GLOBAL R_HKLM_INSTALL_PATH
+ Var /GLOBAL R_HKCU_INSTALL_PATH
ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
+ ReadRegStr $R_HKLM_INSTALL_PATH HKLM "Software\R-core\R" "InstallPath"
+ ReadRegStr $R_HKCU_INSTALL_PATH HKCU "Software\R-core\R" "InstallPath"
${If} $INSTALLED_SVN_REVISION == ""
ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
${EndIf}
@@ -697,6 +703,12 @@
FileWrite $0 'set PATH=%GISBASE%\msys\bin;%PATH%$\r$\n'
FileWrite $0 'set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%$\r$\n'
FileWrite $0 'set PATH=%GISBASE%\tcl-tk\bin;%GISBASE%\sqlite\bin;%GISBASE%\gpsbabel;%PATH%$\r$\n'
+ ${If} $R_HKLM_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
+ ${EndIf}
+ ${If} $R_HKCU_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
+ ${EndIf}
FileWrite $0 '$\r$\n'
FileWrite $0 'rem Set Path to default web browser$\r$\n'
FileWrite $0 'set GRASS_HTML_BROWSER=explorer$\r$\n'
