[GRASS-SVN] r42742 - grass/branches/develbranch_6/mswindows
svn_grass at osgeo.org
Fri Jul 9 10:42:21 EDT 2010
Author: hellik
Date: 2010-07-09 14:42:21 +0000 (Fri, 09 Jul 2010)
New Revision: 42742
grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
#1092 R's installation path in %PATH%
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2010-07-09 14:39:49 UTC (rev 42741)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi 2010-07-09 14:42:21 UTC (rev 42742)
@@ -187,11 +187,17 @@
Var /GLOBAL MESSAGE_2_
Var /GLOBAL MESSAGE_3_
+ Var /GLOBAL R_HKLM_INSTALL_PATH
+ Var /GLOBAL R_HKCU_INSTALL_PATH
ReadRegStr $UNINSTALL_STRING HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "UninstallString"
ReadRegStr $INSTALL_PATH HKLM "Software\${GRASS_BASE}" "InstallPath"
ReadRegStr $INSTALLED_VERSION_NUMBER HKLM "Software\${GRASS_BASE}" "VersionNumber"
ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "SvnRevision"
+ ReadRegStr $R_HKLM_INSTALL_PATH HKLM "Software\R-core\R" "InstallPath"
+ ReadRegStr $R_HKCU_INSTALL_PATH HKCU "Software\R-core\R" "InstallPath"
${If} $INSTALLED_SVN_REVISION == ""
ReadRegStr $INSTALLED_SVN_REVISION HKLM "Software\${GRASS_BASE}" "Revision"
${EndIf}
@@ -629,6 +635,12 @@
FileWrite $0 'set PATH=%GRASSDIR%\msys\bin;%PATH%$\r$\n'
FileWrite $0 'set PATH=%GRASSDIR%\extrabin;%GRASSDIR%\extralib;%PATH%$\r$\n'
FileWrite $0 'set PATH=%GRASSDIR%\tcl-tk\bin;%GRASSDIR%\sqlite\bin;%GRASSDIR%\gpsbabel;%PATH%$\r$\n'
+ ${If} $R_HKLM_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKLM_INSTALL_PATH\bin;%PATH%$\r$\n'
+ ${EndIf}
+ ${If} $R_HKCU_INSTALL_PATH != ""
+ FileWrite $0 'set PATH=$R_HKCU_INSTALL_PATH\bin;%PATH%$\r$\n'
+ ${EndIf}
FileWrite $0 '$\r$\n'
FileWrite $0 'rem Set Path to default web browser$\r$\n'
FileWrite $0 'set GRASS_HTML_BROWSER=explorer$\r$\n'
