[GRASS-SVN] r42749 - in grass/trunk/gui/wxpython: gui_modules xml
svn_grass at osgeo.org
Fri Jul 9 17:02:13 EDT 2010
Author: martinl
Date: 2010-07-09 21:02:13 +0000 (Fri, 09 Jul 2010)
New Revision: 42749
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/xml/menudata_modeler.xml
wxGUI/modeler: conditions implemented (initial)
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-09 20:58:44 UTC (rev 42748)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-09 21:02:13 UTC (rev 42749)
@@ -25,6 +25,7 @@
- ModelLoopDialog
- ActionPanel
- ActionListCtrl
+ - ModelCondition
(C) 2010 by the GRASS Development Team
This program is free software under the GNU General Public License
@@ -304,7 +305,7 @@
actions = alist,
id = loop['id'])
- for action in loopItem.GetActions():
+ for action in loopItem.GetItems():
action.SetLoop(loopItem)
self.AddItem(loopItem)
@@ -895,7 +896,7 @@
# split condition
condVar, condText = re.split('\s*in\s*', cond)
- for action in item.GetActions():
+ for action in item.GetItems():
for vars()[condVar] in eval(condText):
self._runAction(action, params)
@@ -1101,14 +1102,28 @@
fd.write(' pass\n')
fd.write("\ndef main():\n")
+ indent = 4
for item in self.model.GetItems():
if isinstance(item, ModelAction):
- self._writePythonAction(fd, item)
+ if item.GetLoopId():
+ continue
+ self._writePythonAction(fd, item, indent)
elif isinstance(item, ModelLoop):
- # for action in item.GetActions():
- # fd.write('for %s:\n' % item.GetText())
- # self._writePythonAction(fd, action)
- pass
+ # substitute conditiond
+ variables = self.model.GetVariables()
+ cond = item.GetText()
+ for variable in variables:
+ pattern= re.compile('%' + variable)
+ if pattern.search(cond):
+ value = variables[variable].get('value', '')
+ if variables[variable].get('type', 'string') == 'string':
+ value = '"' + value + '"'
+ cond = pattern.sub(value, cond)
+ fd.write('%sfor %s:\n' % (' ' * indent, cond))
+ indent += 4
+ self._writePythonAction(fd, action, indent)
+ indent -= 4
fd.write("\n return 0\n")
@@ -1120,14 +1135,14 @@
sys.exit(main())
- def _writePythonAction(self, fd, item):
+ def _writePythonAction(self, fd, item, indent):
task = menuform.GUI().ParseCommand(cmd = item.GetLog(string = False),
show = None)
opts = task.get_options()
flags = ''
params = list()
- strcmd = " grass.run_command("
- indent = len(strcmd)
+ strcmd = "%sgrass.run_command(" % (' ' * indent)
+ cmdIndent = len(strcmd)
for f in opts['flags']:
if f.get('value', False) == True:
name = f.get('name', '')
@@ -1148,12 +1163,12 @@
fd.write(strcmd + '"%s"' % task.get_name())
if flags:
- fd.write(",\n%sflags = '%s'" % (' ' * indent, flags))
+ fd.write(",\n%sflags = '%s'" % (' ' * cmdIndent, flags))
if len(params) > 0:
fd.write(",\n")
for opt in params[:-1]:
- fd.write("%s%s,\n" % (' ' * indent, opt))
- fd.write("%s%s)\n" % (' ' * indent, params[-1]))
+ fd.write("%s%s,\n" % (' ' * cmdIndent, opt))
+ fd.write("%s%s)\n" % (' ' * cmdIndent, params[-1]))
else:
fd.write(")\n")
@@ -1178,14 +1193,29 @@
self.ModelChanged()
width, height = self.canvas.GetSize()
- loop = ModelLoop(self, x = width/2, y = height/2)
+ loop = ModelLoop(self, x = width/2, y = height/2,
+ id = len(self.model.GetActions()) + 1)
self.canvas.diagram.AddShape(loop)
loop.Show(True)
self._addEvent(loop)
self.canvas.Refresh()
+ def OnDefineCondition(self, event):
+ """!Define new condition in the model"""
+ self.ModelChanged()
+ width, height = self.canvas.GetSize()
+ cond = ModelCondition(self, x = width/2, y = height/2,
+ self.canvas.diagram.AddShape(cond)
+ loop.Show(True)
+ self._addEvent(cond)
+ self.canvas.Refresh()
def OnAddAction(self, event):
"""!Add action to model"""
if self.searchDialog is None:
@@ -1461,17 +1491,17 @@
def DefineLoop(self, loop):
"""!Define loop with given list of actions"""
parent = loop
- actions = loop.GetActions()
+ actions = loop.GetItems()
if not actions:
return
- for action in loop.GetActions():
+ for action in loop.GetItems():
rel = ModelRelation(parent, action)
self.AddLine(rel)
parent = action
# close loop
- action = loop.GetActions()[-1]
+ action = loop.GetItems()[-1]
rel = ModelRelation(action, loop)
self.AddLine(rel)
dx = loop.GetWidth() / 2 + 50
@@ -2083,7 +2113,7 @@
alist = list()
for aId in dlg.GetActions():
alist.append(self.frame.GetModel().GetAction(aId))
- shape.SetActions(alist)
+ shape.SetItems(alist)
self.frame.DefineLoop(shape)
self.frame.GetCanvas().Refresh()
@@ -2823,7 +2853,7 @@
if text:
self.fd.write('%s<condition>%s</condition>\n' %
(' ' * self.indent, self._filterValue(text)))
self.fd.write('%s<loop-action>%d</loop-action>\n' %
(' ' * self.indent, action.GetId()))
self.indent -= 4
@@ -3625,7 +3655,7 @@
menu.Destroy()
class ModelLoop(ModelObject, ogl.RectangleShape):
- def __init__(self, parent, x, y, id = -1, width = None, height = None, text = None, actions = []):
+ def __init__(self, parent, x, y, id = -1, width = None, height = None, text = None, items = []):
"""!Defines a loop"""
ModelObject.__init__(self, id)
@@ -3635,7 +3665,7 @@
width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
if not height:
height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
- self.actions = actions # list of actions in the loop
+ self.items = items # list of items in the loop
if self.parent.GetCanvas():
ogl.RectangleShape.__init__(self, width, height)
@@ -3645,23 +3675,26 @@
self.SetY(y)
self.SetPen(wx.BLACK_PEN)
self.SetCornerRadius(100)
- self.AddText('(' + str(self.id) + ') ' + text)
+ if text:
+ self.AddText('(' + str(self.id) + ') ' + text)
+ else:
+ self.AddText('(' + str(self.id) + ')')
def GetText(self):
"""!Get loop text"""
return self.text
- def GetActions(self):
- """!Get actions (id)"""
- return self.actions
+ def GetItems(self):
+ """!Get items (id)"""
+ return self.items
def SetId(self, id):
"""!Set loop id"""
self.id = id
- def SetActions(self, actions):
- """!Set actions (id)"""
+ def SetItems(self, items):
+ """!Set items (id)"""
def SetText(self, cond):
"""!Set loop text (condition)"""
@@ -3685,7 +3718,7 @@
self.condText = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
value = shape.GetText())
self.listBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label=" %s " % _("List of actions in loop"))
+ label=" %s " % _("List of items in loop"))
self.actionList = ActionCheckListCtrl(parent = self.panel,
columns = [_("ID"), _("Name"),
_("Command")])
@@ -3948,7 +3981,35 @@
def OnBeginEdit(self, event):
"""!Disable editing"""
event.Veto()
+class ModelCondition(ModelObject, ogl.PolygonShape):
+ """!Defines a condition"""
+ ModelObject.__init__(self, id)
+ self.parent = parent
+ self.text = text
+ if not width:
+ width = UserSettings.Get(group='modeler', key='condition', subkey=('size', 'width'))
+ if not height:
+ height = UserSettings.Get(group='modeler', key='condition', subkey=('size', 'height'))
+ if self.parent.GetCanvas():
+ ogl.PolygonShape.__init__(self)
+ points = [(x, y - height / 2),
+ (x + width / 2, y),
+ (x, y + height / 2),
+ (x - width / 2, y)]
+ self.Create(points)
+ self.SetCanvas(self.parent)
+ self.SetPen(wx.BLACK_PEN)
+ if text:
+ else:
def main():
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-07-09 20:58:44 UTC (rev 42748)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-07-09 21:02:13 UTC (rev 42749)
@@ -558,6 +558,12 @@
'height' : 50,
+ 'condition' : {
+ 'size' : {
+ 'width' : 100,
+ 'height' : 50,
Modified: grass/trunk/gui/wxpython/xml/menudata_modeler.xml
--- grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-07-09 20:58:44 UTC (rev 42748)
+++ grass/trunk/gui/wxpython/xml/menudata_modeler.xml 2010-07-09 21:02:13 UTC (rev 42749)
@@ -41,6 +41,7 @@
<label>Export to Python</label>
<help>Export model to Python script</help>
<handler>OnExportPython</handler>
+ <shortcut>Ctrl+E</shortcut>
</menuitem>
<separator />
<menuitem>
@@ -83,11 +84,17 @@
</menuitem>
<menuitem>
<label>Add loop</label>
- <help>Adds loop to model</help>
+ <help>Adds loop (for) to model</help>
<handler>OnDefineLoop</handler>
<shortcut>Ctrl+L</shortcut>
</menuitem>
<menuitem>
+ <label>Add condition</label>
+ <help>Adds condition (if/else) to model</help>
+ <handler>OnDefineCondition</handler>
+ <shortcut>Ctrl+I</shortcut>
+ </menuitem>
+ <menuitem>
<label>Remove item</label>
<help>Remove action/data from model</help>
<handler>OnRemoveItem</handler>
