[GRASS-SVN] r42764 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Mon Jul 12 05:06:32 EDT 2010
Author: aghisla
Date: 2010-07-12 09:06:32 +0000 (Mon, 12 Jul 2010)
New Revision: 42764
grass/trunk/imagery/i.atcorr/Iwave.cpp
grass/trunk/imagery/i.atcorr/create_iwave.py
small edits in create_iwave.py, cleaned up code block for AVNIR in Iwave.cpp
Modified: grass/trunk/imagery/i.atcorr/Iwave.cpp
--- grass/trunk/imagery/i.atcorr/Iwave.cpp 2010-07-12 08:19:32 UTC (rev 42763)
+++ grass/trunk/imagery/i.atcorr/Iwave.cpp 2010-07-12 09:06:32 UTC (rev 42764)
@@ -1958,70 +1958,68 @@
+/* Following filter function created using create_iwave.py */
void IWave::avnir(int iwa)
- /* band 1 of avnir */
+ /* "band 1" of AVNIR */
static const float sr1[64] = {
- 0.00, 0.00, 0.00, 0.00, 0.00, 0.01, 0.01,
- 0.02, 0.03, 0.08, 0.13, 0.27, 0.40, 0.54,
- 0.67, 0.70, 0.72, 0.72, 0.73, 0.72, 0.72,
- 0.77, 0.82, 0.85, 0.88, 0.91, 0.93, 0.93,
- 0.93, 0.93, 0.93, 0.93, 0.94, 0.94, 0.94,
- 0.94, 0.94, 0.94, 0.94, 0.96, 0.98, 0.96,
- 0.94, 0.89, 0.85, 0.80, 0.75, 0.70, 0.66,
- 0.61, 0.56, 0.52, 0.47, 0.42, 0.38, 0.33,
- 0.28, 0.24, 0.19, 0.14, 0.09, 0.05, 0.00,
- 0.00 };
+ .0000, .0000, .0000, .0008, .0017, .0049, .0080,
+ .0293, .0776, .1260, .2609, .3958, .5315, .6672,
+ .7223, .7262, .7300, .7272, .7245, .7717, .8189,
+ .8815, .9068, .9322, .9496, .9669, .9708, .9747,
+ 1.0000, .9849, .9699, .9507, .9316, .9365, .9415,
+ .9849, .9600, .9351, .7552, .5754, .3911, .2068,
+ .0655, .0440, .0226, .0150, .0075, .0046, .0018,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0000
- /* band 2 of avnir */
- static const float sr2[84] = {
- 0.00, 0.00, 0.00, 0.00, 0.00, 0.04, 0.09,
- 0.13, 0.17, 0.22, 0.26, 0.30, 0.35, 0.39,
- 0.43, 0.48, 0.52, 0.57, 0.61, 0.65, 0.70,
- 0.74, 0.78, 0.83, 0.87, 0.87, 0.87, 0.89,
- 0.90, 0.93, 0.95, 0.96, 0.98, 0.99, 1.00,
- 0.99, 0.98, 0.94, 0.89, 0.83, 0.78, 0.77,
- 0.75, 0.72, 0.69, 0.56, 0.44, 0.30, 0.16,
- 0.10, 0.04, 0.03, 0.01, 0.01, 0.00, 0.00,
- 0.00, 0.01, 0.03, 0.04, 0.06, 0.07, 0.09,
- 0.11, 0.12, 0.14, 0.15, 0.17, 0.18, 0.20,
- 0.21, 0.23, 0.24, 0.26, 0.27, 0.29, 0.30,
- 0.32, 0.33, 0.35, 0.36, 0.38, 0.39, 0.41 };
+ /* "band 2" of AVNIR */
+ static const float sr2[56] = {
+ .0000, .0000, .0000, .0008, .0015, .0030, .0045,
+ .0202, .0470, .0739, .1358, .1977, .3205, .4433,
+ .6832, .7137, .7442, .7594, .7746, .8089, .8432,
+ .8719, .8721, .8724, .8873, .9022, .9254, .9486,
+ .9764, .9882, 1.0000, .9904, .9808, .9349, .8890,
+ .7843, .7651, .7458, .7156, .6854, .5639, .4425,
+ .1586, .0985, .0384, .0236, .0088, .0053, .0017
- /* band 3 of avnir */
+ /* "band 3" of AVNIR */
static const float sr3[80] = {
- 0.00, 0.00, 0.00, 0.00, 0.00, 0.00, 0.00,
- 0.00, 0.00, 0.00, 0.00, 0.01, 0.01, 0.01,
- 0.01, 0.01, 0.02, 0.03, 0.03, 0.04, 0.06,
- 0.10, 0.14, 0.21, 0.28, 0.39, 0.49, 0.57,
- 0.66, 0.72, 0.78, 0.79, 0.80, 0.78, 0.76,
- 0.74, 0.72, 0.70, 0.68, 0.66, 0.64, 0.62,
- 0.60, 0.58, 0.56, 0.54, 0.52, 0.50, 0.48,
- 0.46, 0.44, 0.42, 0.40, 0.38, 0.36, 0.34,
- 0.32, 0.30, 0.28, 0.26, 0.24, 0.22, 0.20,
- 0.15, 0.09, 0.07, 0.04, 0.03, 0.02, 0.01,
- 0.01, 0.01, 0.01, 0.01, 0.00, 0.00, 0.00,
- 0.00, 0.00, 0.00 };
+ .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+ .0016, .0025, .0034, .0043, .0051, .0075, .0099,
+ .0153, .0228, .0304, .0462, .0620, .0995, .1370,
+ .2844, .3857, .4871, .5747, .6624, .7198, .7771,
+ .8021, .7991, .7960, .7989, .8017, .8312, .8606,
+ .9359, .9592, .9825, .9912, 1.0000, .9931, .9862,
+ .9275, .9046, .8818, .8607, .8395, .8344, .8293,
+ .8136, .7470, .6804, .5481, .4158, .3100, .2043,
+ .0898, .0634, .0369, .0273, .0177, .0135, .0093,
+ .0060, .0045, .0030, .0023, .0015, .0016, .0016
- /* band 4 of avnir */
- static const float sr4[90] = {
- 0.00, 0.00, 0.00, 0.00, 0.00, 0.00, 0.01,
- 0.01, 0.02, 0.03, 0.05, 0.07, 0.12, 0.16,
- 0.23, 0.31, 0.44, 0.57, 0.72, 0.88, 0.94,
- 1.00, 0.99, 0.98, 0.96, 0.93, 0.91, 0.89,
- 0.88, 0.86, 0.86, 0.86, 0.88, 0.89, 0.92,
- 0.94, 0.94, 0.95, 0.95, 0.96, 0.94, 0.92,
- 0.90, 0.87, 0.84, 0.82, 0.78, 0.75, 0.73,
- 0.71, 0.69, 0.67, 0.66, 0.64, 0.64, 0.63,
- 0.63, 0.62, 0.62, 0.62, 0.60, 0.58, 0.58,
- 0.59, 0.59, 0.59, 0.57, 0.55, 0.53, 0.50,
- 0.45, 0.39, 0.32, 0.25, 0.19, 0.13, 0.10,
- 0.07, 0.06, 0.04, 0.03, 0.02, 0.01 };
+ /* "band 4" of AVNIR */
+ static const float sr4[120] = {
+ .0023, .0023, .0022, .0033, .0045, .0080, .0115,
+ .0264, .0484, .0704, .1138, .1572, .2351, .3129,
+ .5733, .7244, .8754, .9377, 1.0000, .9884, .9768,
+ .9288, .9091, .8894, .8763, .8633, .8627, .8622,
+ .8885, .9136, .9388, .9437, .9486, .9531, .9576,
+ .9247, .8969, .8691, .8467, .8242, .7893, .7545,
+ .7117, .6911, .6705, .6560, .6414, .6357, .6299,
+ .6217, .6227, .6237, .6025, .5812, .5843, .5874,
+ .5860, .5696, .5532, .5251, .4969, .4438, .3908,
+ .2475, .1906, .1338, .1033, .0727, .0543, .0359,
+ .0224, .0161, .0097, .0069, .0040, .0038, .0036,
+ .0025, .0024, .0024, .0015, .0007, .0004, .0000,
+ .0007, .0006, .0006, .0006, .0006, .0003, .0000,
static const float wli[4] = {0.390, 0.485, 0.545, 0.700};
- static const float wls[4] = {0.550, 0.695, 0.745, 0.925};
+ static const float wls[4] = {0.550, 0.625, 0.745, 1.000};
ffu.wlinf = (float)wli[iwa-1];
ffu.wlsup = (float)wls[iwa-1];
@@ -2031,13 +2029,13 @@
switch(iwa)
- case 1: for(i = 0; i < 64; i++) ffu.s[56+i] = sr1[i];
+ case 1: for(i = 0; i < 64; i++) ffu.s[56+i] = sr1[i];
break;
- case 2: for(i = 0; i < 84; i++) ffu.s[94+i] = sr2[i];
+ case 2: for(i = 0; i < 56; i++) ffu.s[94+i] = sr2[i];
break;
case 3: for(i = 0; i < 80; i++) ffu.s[118+i] = sr3[i];
break;
- case 4: for(i = 0; i < 90; i++) ffu.s[180+i] = sr4[i];
+ case 4: for(i = 0; i < 120; i++) ffu.s[180+i] = sr4[i];
break;
Modified: grass/trunk/imagery/i.atcorr/create_iwave.py
--- grass/trunk/imagery/i.atcorr/create_iwave.py 2010-07-12 08:19:32 UTC (rev 42763)
+++ grass/trunk/imagery/i.atcorr/create_iwave.py 2010-07-12 09:06:32 UTC (rev 42764)
@@ -155,9 +155,9 @@
outfile.write('/* Following filter function created using create_iwave.py */\n\n')
if len(bands) == 1:
- outfile.write('void IWave::%s()\n{\n\n' % (sensor))
+ outfile.write('void IWave::%s()\n{\n\n' % (sensor.lower()))
else:
- outfile.write('void IWave::%s(int iwa)\n{\n\n' % (sensor))
+ outfile.write('void IWave::%s(int iwa)\n{\n\n' % (sensor.lower()))
# single band case
if len(bands) == 1:
@@ -168,7 +168,7 @@
# calculate wl slot for band start
# slots range from 250 to 4000 at 2.5 increments (total 1500)
- s_start = int((limits[0] - 0.250)/2.5)
+ s_start = int((limits[0]*1000 - 250)/2.5)
outfile.write('\n')
outfile.write(' ffu.wlinf = %.4ff;\n' % (limits[0]))
@@ -191,10 +191,6 @@
for b in range(len(bands)):
inf = ", ".join(["%.3f" % i[0] for i in limits])
sup = ", ".join(["%.3f" % i[1] for i in limits])
-# for j in zip(['[',']'],['{','}']):
-# inf = inf.replace(j[0],j[1])
-# sup = sup.replace(j[0],j[1])
outfile.write(' static const float wli[%i] = {%s};\n' % (len(bands), inf))
outfile.write(' static const float wls[%i] = {%s};\n' % (len(bands), sup))
