[GRASS-SVN] r42780 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jul 13 14:27:05 EDT 2010
Author: martinl
Date: 2010-07-13 18:27:05 +0000 (Tue, 13 Jul 2010)
New Revision: 42780
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: work in progress (loops & if/else statements)
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-13 07:44:46 UTC (rev 42779)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-07-13 18:27:05 UTC (rev 42780)
@@ -21,10 +21,12 @@
- ModelListCtrl
- VariablePanel
- ValiableListCtrl
+ - ModelItem
- ModelLoop
- ModelLoopDialog
- - ActionPanel
- - ActionListCtrl
+ - ItemPanel
+ - ItemListCtrl
+ - ItemCheckListCtrl
- ModelCondition
(C) 2010 by the GRASS Development Team
@@ -95,42 +97,42 @@
"""!Get canvas or None"""
return self.canvas
- def GetItems(self):
- """!Get list of model items"""
- return self.items
- def GetActions(self):
- """!Get list of model actions"""
- result = list()
- for item in self.items:
- if isinstance(item, ModelAction):
- result.append(item)
+ def GetItems(self, objType = None):
+ """!Get list of model items
+ @param objType Object type to filter model objects
+ if not objType:
+ return self.items
- return result
- def GetLoops(self):
- """!Get list of model loops"""
result = list()
- if isinstance(item, ModelLoop):
+ if isinstance(item, objType):
result.append(item)
return result
- def GetAction(self, aId):
- """!Get action of given id
+ def GetItem(self, aId):
+ """!Get item of given id
- @param aId action id
+ @param aId item id
- @return ModelAction instance
- @return None if no action found
+ @return Model* instance
+ @return None if no item found
- alist = self.GetActions()
- for action in alist:
- if action.GetId() == aId:
- return action
+ ilist = self.GetItems()
+ for item in ilist:
+ if item.GetId() == aId:
+ return item
return None
+ def GetNumItems(self, actionOnly = False):
+ """!Get number of items"""
+ if actionOnly:
+ return len(self.GetItems(objType = ModelAction))
+ return len(self.GetItems())
def GetProperties(self):
"""!Get model properties"""
@@ -157,22 +159,28 @@
@return list of related items
relList = list()
+ if not isinstance(item, ModelData):
+ self.items.remove(item)
- self.actions.remove(item)
- for data in self.data:
- for rel in data.GetRelations(direction = 'to'):
- relList.append(rel)
- relList.append(data)
- self.data.remove(data)
+ for rel in item.GetRelations():
+ relList.append(rel)
+ data = rel.GetData()
+ relList.append(data)
elif isinstance(item, ModelData):
- self.data.remove(item)
+ if rel.GetFrom() == self:
+ relList.append(rel.GetTo())
+ else:
+ relList.append(rel.GetFrom())
return relList
def FindAction(self, aId):
"""!Find action by id"""
+ alist = self.GetItems(objType = ModelAction)
return action
@@ -182,7 +190,7 @@
def GetData(self):
"""!Get list of data items"""
result = list()
- for action in self.GetActions():
+ for action in self.GetItems(objType = ModelAction):
for rel in action.GetRelations():
dataItem = rel.GetData()
if dataItem not in result:
@@ -291,24 +299,41 @@
# load loops
for loop in gxmXml.loops:
- alist = list()
- for aId in loop['actions']:
- action = self.GetAction(aId)
- alist.append(action)
loopItem = ModelLoop(parent = self,
x = loop['pos'][0],
y = loop['pos'][1],
width = loop['size'][0],
height = loop['size'][1],
text = loop['text'],
- items = alist,
id = loop['id'])
+ self.AddItem(loopItem)
+ # load conditions
+ for condition in gxmXml.conditions:
+ conditionItem = ModelCondition(parent = self,
+ x = condition['pos'][0],
+ y = condition['pos'][1],
+ width = condition['size'][0],
+ height = condition['size'][1],
+ text = condition['text'],
+ id = condition['id'])
+ # for action in conditionItem.GetItems():
+ # action.SetCondition(conditionItem)
+ self.AddItem(conditionItem)
+ # define loops & if/else items
+ for loop in gxmXml.loops:
+ alist = list()
+ for aId in loop['items']:
+ action = self.GetItem(aId)
+ alist.append(action)
+ loopItem = self.GetItem(loop['id'])
+ print alist
+ loopItem.SetItems(alist)
for action in loopItem.GetItems():
action.SetLoop(loopItem)
- self.AddItem(loopItem)
def AddItem(self, newItem):
"""!Add item to the list"""
@@ -334,7 +359,7 @@
"""!Validate model, return None if model is valid otherwise
error string"""
errList = list()
task = menuform.GUI().ParseCommand(cmd = action.GetLog(string = False),
show = None)
errList += task.getCmdError()
@@ -450,7 +475,7 @@
idx += 1
if not action.IsEnabled():
continue
name = action.GetName()
@@ -527,13 +552,13 @@
self.variablePanel = VariablePanel(parent = self)
- self.actionPanel = ActionPanel(parent = self)
+ self.itemPanel = ItemPanel(parent = self)
self.goutput = goutput.GMConsole(parent = self, pageid = 3,
notebook = self.notebook)
self.notebook.AddPage(self.canvas, text=_('Model'))
- self.notebook.AddPage(self.actionPanel, text=_('Actions'))
+ self.notebook.AddPage(self.itemPanel, text=_('Items'))
self.notebook.AddPage(self.variablePanel, text=_('Variables'))
self.notebook.AddPage(self.goutput, text=_('Command output'))
wx.CallAfter(self.notebook.SetSelection, 0)
@@ -654,7 +679,7 @@
self.ModelChanged()
for key, value in dlg.GetValues().iteritems():
properties[key] = value
- for action in self.model.GetActions():
+ for action in self.model.GetItems(objType = ModelAction):
action.GetTask().set_flag('overwrite', properties['overwrite'])
dlg.Destroy()
@@ -699,7 +724,7 @@
if self.modelFile and self.modelChanged:
self.OnModelSave()
elif self.modelFile is None and \
- (len(self.model.GetActions()) > 0 or len(self.model.GetData()) > 0):
+ (self.model.GetNumItems() > 0 or len(self.model.GetData()) > 0):
dlg = wx.MessageDialog(self, message=_("Current model is not empty. "
"Do you want to store current settings "
"to model file?"),
@@ -746,7 +771,8 @@
self.modelFile = filename
self.SetTitle(self.baseTitle + " - " + os.path.basename(self.modelFile))
- self.SetStatusText(_('%d actions loaded into model') % len(self.model.GetActions()), 0)
+ self.SetStatusText(_('%d items (%d actions) loaded into model') % \
+ (self.model.GetNumItems(), self.model.GetNumItems(actionOnly = True)), 0)
def OnModelSave(self, event = None):
"""!Save model to file"""
@@ -810,7 +836,7 @@
self.OnModelSave()
"to model file?"),
@@ -836,7 +862,7 @@
def OnRunModel(self, event):
"""!Run entire model"""
- if len(self.model.GetActions()) < 1:
+ if self.model.GetNumItems() < 1:
GMessage(parent = self,
message = _('Model is empty. Nothing to run.'),
msgType = 'info')
@@ -923,7 +949,7 @@
def OnValidateModel(self, event, showMsg = True):
"""!Validate entire model"""
message = _('Model is empty. Nothing to validate.'),
msgType = 'info')
@@ -1194,11 +1220,12 @@
width, height = self.canvas.GetSize()
loop = ModelLoop(self, x = width/2, y = height/2,
- id = len(self.model.GetActions()) + 1)
+ id = self.model.GetNumItems() + 1)
self.canvas.diagram.AddShape(loop)
loop.Show(True)
self._addEvent(loop)
+ self.model.AddItem(loop)
self.canvas.Refresh()
@@ -1208,11 +1235,12 @@
cond = ModelCondition(self, x = width/2, y = height/2,
self.canvas.diagram.AddShape(cond)
cond.Show(True)
self._addEvent(cond)
+ self.model.AddItem(cond)
@@ -1236,7 +1264,7 @@
# add action to canvas
action = ModelAction(self.model, cmd = cmd, x = width/2, y = height/2,
overwrite = self.model.GetProperties().get('overwrite', None)
if overwrite is not None:
action.GetTask().set_flag('overwrite', overwrite)
@@ -1247,7 +1275,7 @@
self._addEvent(action)
self.model.AddItem(action)
- self.actionPanel.Update()
+ self.itemPanel.Update()
time.sleep(.1)
@@ -1407,7 +1435,7 @@
rel.InsertLineControlPoint(point = wx.RealPoint(x, y))
self._addEvent(rel)
+ print fromShape, toShape, rel
fromShape.AddLine(rel, toShape)
self.canvas.diagram.AddShape(rel)
@@ -1429,7 +1457,7 @@
self.SetStatusText(_("Please wait, loading model..."), 0)
# load actions
- for item in self.model.GetActions():
+ for item in self.model.GetItems(objType = ModelAction):
self._addEvent(item)
self.canvas.diagram.AddShape(item)
item.Show(True)
@@ -1445,17 +1473,26 @@
dataItem.Show(True)
# load loops
- for item in self.model.GetLoops():
+ for item in self.model.GetItems(objType = ModelLoop):
item.Show(True)
- # connect actions in the loop
+ # connect items in the loop
self.DefineLoop(item)
+ # load conditions
+ for item in self.model.GetItems(objType = ModelCondition):
+ self._addEvent(item)
+ self.canvas.diagram.AddShape(item)
+ item.Show(True)
+ # connect items in the condition
+ # self.DefineCondition(item)
# load variables
self.variablePanel.Update()
self.SetStatusText('', 0)
self.canvas.Refresh(True)
@@ -1492,25 +1529,45 @@
return True
def DefineLoop(self, loop):
- """!Define loop with given list of actions"""
+ """!Define loop with given list of items"""
parent = loop
- actions = loop.GetItems()
- if not actions:
+ items = loop.GetItems()
+ if not items:
return
+ # remove defined relations first
+ for rel in loop.GetRelations():
+ self.canvas.GetDiagram().RemoveShape(rel)
+ loop.Clear()
for action in loop.GetItems():
rel = ModelRelation(parent, action)
+ dx = action.GetX() - parent.GetX()
+ dy = action.GetY() - parent.GetY()
+ loop.AddRelation(rel)
self.AddLine(rel)
+ if dx != 0:
+ rel.MakeLineControlPoints(0)
+ rel.InsertLineControlPoint(point = wx.RealPoint(parent.GetX(),
+ parent.GetY() + parent.GetHeight() / 2))
+ rel.InsertLineControlPoint(point = wx.RealPoint(action.GetX(),
+ action.GetY() - action.GetHeight() / 2))
+ parent.GetY() + dy / 2))
+ rel.InsertLineControlPoint(point = wx.RealPoint(parent.GetX() + dx,
parent = action
# close loop
action = loop.GetItems()[-1]
rel = ModelRelation(action, loop)
self.AddLine(rel)
- dx = loop.GetWidth() / 2 + 50
+ dx = (action.GetX() - loop.GetX()) + loop.GetWidth() / 2 + 50
dy = action.GetHeight() / 2 + 50
- rel.InsertLineControlPoint(point = wx.RealPoint(loop.GetX() - loop.GetWidth() / 2,
+ rel.InsertLineControlPoint(point = wx.RealPoint(loop.GetX() - loop.GetWidth() / 2 ,
loop.GetY()))
action.GetY() + action.GetHeight() / 2))
@@ -1566,7 +1623,8 @@
self.rels = list() # list of ModelRelations
self.isEnabled = True
+ self.inLoop = None
def GetId(self):
"""!Get id"""
return self.id
@@ -1606,7 +1664,29 @@
def Update(self):
pass
+ def SetLoop(self, loop):
+ """!Register loop"""
+ self.inLoop = loop
+ def GetLoop(self):
+ """!Get related loop
+ @return ModelLoop instance
+ @return None if no loop defined
+ return self.inLoop
+ def GetLoopId(self):
+ """!Get id of the loop
+ @return loop id
+ @return '' if action is not in the loop
+ if self.inLoop:
+ return self.inLoop.GetId()
+ return ''
class ModelAction(ModelObject, ogl.RectangleShape):
"""!Action class (GRASS module)"""
def __init__(self, parent, x, y, id = -1, cmd = None, task = None, width = None, height = None):
@@ -1635,7 +1715,6 @@
self.isValid = False
self.isParameterized = False
- self.inLoop = None
if self.parent.GetCanvas():
ogl.RectangleShape.__init__(self, width, height)
@@ -1687,21 +1766,7 @@
self.AddText('(%d) %s' % (self.id, cmd[0]))
else:
self.AddText('(%d) <<%s>>' % (self.id, _("unknown")))
- def SetLoop(self, loop):
- """!Register loop"""
- self.inLoop = loop
- def GetLoopId(self):
- """!Get id of the loop
- @return loop id
- @return '' if action is not in the loop
- if self.inLoop:
- return self.inLoop.GetId()
- return ''
def SetProperties(self, params, propwin):
"""!Record properties dialog"""
self.task.params = params['params']
@@ -2114,8 +2179,10 @@
if dlg.ShowModal() == wx.ID_OK:
shape.SetText(dlg.GetCondition())
alist = list()
- for aId in dlg.GetActions():
- alist.append(self.frame.GetModel().GetAction(aId))
+ for aId in dlg.GetItems():
+ action = self.frame.GetModel().GetItem(aId)
+ if action:
shape.SetItems(alist)
self.frame.DefineLoop(shape)
self.frame.GetCanvas().Refresh()
@@ -2123,10 +2190,21 @@
dlg.Destroy()
def OnBeginDragLeft(self, x, y, keys = 0, attachment = 0):
- """!Drag shape"""
+ """!Drag shape (begining)"""
self.frame.ModelChanged()
if self._previousHandler:
self._previousHandler.OnBeginDragLeft(x, y, keys, attachment)
+ def OnEndDragLeft(self, x, y, keys = 0, attachment = 0):
+ """!Drag shape (end)"""
+ if self._previousHandler:
+ self._previousHandler.OnEndDragLeft(x, y, keys, attachment)
+ shape = self.GetShape()
+ if isinstance(shape, ModelAction):
+ loop = shape.GetLoop()
+ if loop:
+ self.frame.DefineLoop(loop)
def OnEndSize(self, x, y):
"""!Resize shape"""
@@ -2237,7 +2315,7 @@
"""!Remove shape
self.frame.GetCanvas().RemoveSelected()
- self.frame.actionPanel.Update()
+ self.frame.itemPanel.Update()
class ModelSearchDialog(wx.Dialog):
def __init__(self, parent, id = wx.ID_ANY, title = _("Add new GRASS module to the model"),
@@ -2438,13 +2516,13 @@
self.actions = list()
self.data = list()
self.loops = list()
+ self.conditions = list()
self._processWindow()
self._processProperties()
self._processVariables()
- self._processActions()
+ self._processItems()
self._processData()
- self._processLoops()
def _filterValue(self, value):
"""!Filter value
@@ -2516,6 +2594,12 @@
if node is not None:
if node.text:
self.variables[name][key] = node.text
+ def _processItems(self):
+ """!Process model items (actions, loops, conditions)"""
+ self._processActions()
+ self._processLoops()
+ self._processConditions()
def _processActions(self):
"""!Process model file"""
@@ -2646,7 +2730,7 @@
pos, size = self._getDim(node)
text = self._filterValue(self._getNodeText(node, 'condition')).strip()
aid = list()
- for anode in node.findall('loop-action'):
+ for anode in node.findall('loop-item'):
try:
aid.append(int(anode.text))
except ValueError:
@@ -2656,8 +2740,21 @@
'size' : size,
'text' : text,
'id' : int(node.get('id', -1)),
- 'actions' : aid })
+ 'items' : aid })
+ def _processConditions(self):
+ """!Process model conditions"""
+ for node in self.root.findall('if-else'):
+ pos, size = self._getDim(node)
+ text = self._filterValue(self._getNodeText(node, 'condition')).strip()
+ aid = list()
+ self.conditions.append({ 'pos' : pos,
+ 'size' : size,
+ 'text' : text,
+ 'id' : int(node.get('id', -1)),
+ 'items' : aid })
class WriteModelFile:
"""!Generic class for writing model file"""
def __init__(self, fd, model):
@@ -2677,7 +2774,7 @@
self._items()
dataList = list()
- for action in model.GetActions():
+ for action in model.GetItems(objType = ModelAction):
if dataItem not in dataList:
@@ -2755,12 +2852,14 @@
self.fd.write('%s</variables>\n' % (' ' * self.indent))
def _items(self):
- """!Write actions/loops"""
+ """!Write actions/loops/conditions"""
self._action(item)
elif isinstance(item, ModelLoop):
self._loop(item)
+ elif isinstance(item, ModelCondition):
+ self._condition(item)
def _action(self, action):
"""!Write actions"""
@@ -2856,12 +2955,29 @@
if text:
self.fd.write('%s<condition>%s</condition>\n' %
(' ' * self.indent, self._filterValue(text)))
- for action in loop.GetItems():
- self.fd.write('%s<loop-action>%d</loop-action>\n' %
- (' ' * self.indent, action.GetId()))
+ for item in loop.GetItems():
+ self.fd.write('%s<loop-item>%d</loop-item>\n' %
+ (' ' * self.indent, item.GetId()))
self.indent -= 4
self.fd.write('%s</loop>\n' % (' ' * self.indent))
+ def _condition(self, condition):
+ """!Write conditions"""
+ bbox = condition.GetBoundingBoxMin()
+ self.fd.write('%s<if-else id="%d" pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, condition.GetId(), condition.GetX(), condition.GetY(),
+ bbox[0], bbox[1]))
+ text = condition.GetText()
+ self.indent += 4
+ if text:
+ self.fd.write('%s<condition>%s</condition>\n' %
+ (' ' * self.indent, self._filterValue(text)))
+ for item in condition.GetItems():
+ self.fd.write('%s<condition-item>%d</condition-item>\n' %
+ self.indent -= 4
+ self.fd.write('%s</if-else>\n' % (' ' * self.indent))
class PreferencesDialog(PreferencesBaseDialog):
"""!User preferences dialog"""
def __init__(self, parent, settings = UserSettings,
@@ -3352,13 +3468,14 @@
listmix.ListCtrlAutoWidthMixin,
listmix.TextEditMixin,
listmix.ColumnSorterMixin):
- def __init__(self, parent, columns, id = wx.ID_ANY,
+ def __init__(self, parent, columns, excludeId = [], id = wx.ID_ANY,
style = wx.LC_REPORT | wx.BORDER_NONE |
wx.LC_SORT_ASCENDING |wx.LC_HRULES |
wx.LC_VRULES, **kwargs):
"""!List of model variables"""
self.parent = parent
self.columns = columns
+ self.excludeId = excludeId
try:
self.frame = parent.parent
except AttributeError:
@@ -3658,32 +3775,14 @@
self.PopupMenu(menu)
menu.Destroy()
-class ModelLoop(ModelObject, ogl.RectangleShape):
+class ModelItem(ModelObject):
def __init__(self, parent, x, y, id = -1, width = None, height = None, text = '', items = []):
- """!Defines a loop"""
+ """!Abstract class for loops and conditions"""
ModelObject.__init__(self, id)
self.text = text
- if not width:
- width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
- if not height:
- height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
- self.items = items # list of items in the loop
+ self.items = items # list of items in the loop
- if self.parent.GetCanvas():
- ogl.RectangleShape.__init__(self, width, height)
- self.SetCanvas(self.parent)
- self.SetX(x)
- self.SetY(y)
- self.SetPen(wx.BLACK_PEN)
- self.SetCornerRadius(100)
- if text:
- self.AddText('(' + str(self.id) + ') ' + text)
- else:
- self.AddText('(' + str(self.id) + ')')
def GetText(self):
"""!Get loop text"""
return self.text
@@ -3712,7 +3811,42 @@
return _("Condition: ") + self.text
else:
return _("Condition: not defined")
+ def AddRelation(self, rel):
+ """!Record relation"""
+ self.rels.append(rel)
+ def Clear(self):
+ """!Clear object, remove rels"""
+ self.rels = list()
+class ModelLoop(ModelItem, ogl.RectangleShape):
+ def __init__(self, parent, x, y, id = -1, width = None, height = None, text = '', items = []):
+ """!Defines a loop"""
+ ModelItem.__init__(self, parent, x, y, id, width, height, text, items)
+ if not width:
+ width = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'width'))
+ if not height:
+ height = UserSettings.Get(group='modeler', key='loop', subkey=('size', 'height'))
+ if self.parent.GetCanvas():
+ ogl.RectangleShape.__init__(self, width, height)
+ self.SetCanvas(self.parent)
+ self.SetX(x)
+ self.SetY(y)
+ self.SetPen(wx.BLACK_PEN)
+ self.SetCornerRadius(100)
+ if text:
+ self.AddText('(' + str(self.id) + ') ' + text)
+ else:
+ self.AddText('(' + str(self.id) + ')')
+ def GetName(self):
+ """!Get name"""
+ return _("loop")
class ModelLoopDialog(wx.Dialog):
"""!Loop properties dialog"""
def __init__(self, parent, shape, id = wx.ID_ANY, title = _("Loop properties"),
@@ -3730,10 +3864,11 @@
value = shape.GetText())
self.listBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label=" %s " % _("List of items in loop"))
- self.actionList = ActionCheckListCtrl(parent = self.panel,
- columns = [_("ID"), _("Name"),
- _("Command")])
- self.actionList.Populate(self.parent.GetModel().GetActions())
+ self.itemList = ItemCheckListCtrl(parent = self.panel,
+ columns = [_("ID"), _("Name"),
+ _("Command")],
+ excludeId = [shape.GetId()])
+ self.itemList.Populate(self.parent.GetModel().GetItems())
self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
self.btnOk = wx.Button(parent = self.panel, id = wx.ID_OK)
@@ -3744,6 +3879,7 @@
self._layout()
self.SetMinSize(self.GetSize())
+ self.SetSize((500, 400))
def _layout(self):
"""!Do layout"""
@@ -3754,7 +3890,7 @@
flag = wx.EXPAND)
listSizer = wx.StaticBoxSizer(self.listBox, wx.VERTICAL)
- listSizer.Add(item = self.actionList, proportion = 1,
+ listSizer.Add(item = self.itemList, proportion = 1,
flag = wx.EXPAND)
btnSizer = wx.StdDialogButtonSizer()
@@ -3774,12 +3910,12 @@
self.Layout()
+ def GetItems(self):
"""!Get list of selected actions"""
ids = list()
- for i in range(self.actionList.GetItemCount()):
- if self.actionList.IsChecked(i):
- ids.append(i + 1) # starts at 1
+ for i in range(self.itemList.GetItemCount()):
+ if self.itemList.IsChecked(i):
+ ids.append(int(self.itemList.GetItem(i, 0).GetText()))
return ids
@@ -3787,21 +3923,21 @@
"""!Get loop condition"""
return self.condText.GetValue()
-class ActionPanel(wx.Panel):
+class ItemPanel(wx.Panel):
**kwargs):
- """!Manage model actions
+ """!Manage model items
wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
self.listBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label=" %s " % _("List of actions - right-click to delete"))
+ label=" %s " % _("List of items - right-click to delete"))
- self.list = ActionListCtrl(parent = self,
- columns = [_("ID"), _("Name"), _("In loop"),
- _("Command")])
+ self.list = ItemListCtrl(parent = self,
+ columns = [_("ID"), _("Name"), _("In item"),
+ _("Command / condition")])
self._layout()
@@ -3822,12 +3958,13 @@
"""!Reload list of variables"""
self.list.OnReload(None)
-class ActionListCtrl(ModelListCtrl):
- def __init__(self, parent, columns, disablePopup = False, **kwargs):
+class ItemListCtrl(ModelListCtrl):
+ def __init__(self, parent, columns, excludeId = [], disablePopup = False, **kwargs):
"""!List of model actions"""
self.disablePopup = disablePopup
- ModelListCtrl.__init__(self, parent, columns, **kwargs)
+ ModelListCtrl.__init__(self, parent, columns, excludeId, **kwargs)
self.SetColumnWidth(1, 100)
self.SetColumnWidth(2, 65)
@@ -3846,6 +3983,8 @@
if len(self.columns) == 3:
checked = list()
for action in data:
+ if action.GetId() in self.excludeId:
+ continue
self.itemDataMap[i] = [str(action.GetId()),
action.GetName(),
@@ -3893,7 +4032,7 @@
del self.itemDataMap[item]
aId = self.GetItem(item, 0).GetText()
- action = model.GetAction(int(aId))
+ action = model.GetItem(int(aId))
if not action:
item = self.GetFirstSelected()
continue
@@ -3932,7 +4071,7 @@
self.itemDataMap[itemIndex][columnIndex] = event.GetText()
aId = int(self.GetItem(itemIndex, 0).GetText())
- action = self.frame.GetModel().GetAction(aId)
if not action:
event.Veto()
if columnIndex == 0:
@@ -3942,7 +4081,7 @@
def OnReload(self, event = None):
"""!Reload list of actions"""
- self.Populate(self.frame.GetModel().GetActions())
+ self.Populate(self.frame.GetModel().GetItems())
def OnRightUp(self, event):
"""!Mouse right button up"""
@@ -3987,9 +4126,9 @@
-class ActionCheckListCtrl(ActionListCtrl, listmix.CheckListCtrlMixin):
- def __init__(self, parent, columns, **kwargs):
- ActionListCtrl.__init__(self, parent, columns, disablePopup = True, **kwargs)
+class ItemCheckListCtrl(ItemListCtrl, listmix.CheckListCtrlMixin):
+ def __init__(self, parent, columns, excludeId = [], **kwargs):
+ ItemListCtrl.__init__(self, parent, columns, excludeId, disablePopup = True, **kwargs)
listmix.CheckListCtrlMixin.__init__(self)
self.SetColumnWidth(0, 50)
@@ -3997,21 +4136,23 @@
"""!Disable editing"""
event.Veto()
-class ModelCondition(ModelObject, ogl.PolygonShape):
+class ModelCondition(ModelItem, ogl.PolygonShape):
def __init__(self, parent, x, y, id = -1, width = None, height = None, text = None, items = []):
"""!Defines a condition"""
- ModelObject.__init__(self, id)
- self.parent = parent
- self.text = text
if not width:
- width = UserSettings.Get(group='modeler', key='condition', subkey=('size', 'width'))
+ self.width = UserSettings.Get(group='modeler', key='condition', subkey=('size', 'width'))
+ else:
+ self.width = width
if not height:
- height = UserSettings.Get(group='modeler', key='condition', subkey=('size', 'height'))
+ self.height = UserSettings.Get(group='modeler', key='condition', subkey=('size', 'height'))
+ else:
+ self.height = height
ogl.PolygonShape.__init__(self)
self.SetX(x)
self.SetY(y)
@@ -4027,7 +4168,19 @@
else:
+ """!Get name"""
+ return _("if-else")
+ def GetWidth(self):
+ """!Get object width"""
+ return self.width
+ def GetHeight(self):
+ """!Get object height"""
+ return self.height
def main():
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
