[GRASS-SVN] r42796 - in grass/branches/releasebranch_6_4/scripts: . g.extension
Thu Jul 15 05:21:09 EDT 2010
Author: neteler
Date: 2010-07-15 09:21:09 +0000 (Thu, 15 Jul 2010)
New Revision: 42796
Added:
   grass/branches/releasebranch_6_4/scripts/g.extension/
   grass/branches/releasebranch_6_4/scripts/g.extension/Makefile
   grass/branches/releasebranch_6_4/scripts/g.extension/description.html
   grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
   grass/branches/releasebranch_6_4/scripts/Makefile
added
Modified: grass/branches/releasebranch_6_4/scripts/Makefile
--- grass/branches/releasebranch_6_4/scripts/Makefile	2010-07-15 09:04:36 UTC (rev 42795)
+++ grass/branches/releasebranch_6_4/scripts/Makefile	2010-07-15 09:21:09 UTC (rev 42796)
@@ -26,6 +26,7 @@
 	db.out.ogr \
 	db.test \
 	g.manual \
+	g.extension \
 	i.fusion.brovey \
 	i.image.mosaic \
 	i.in.spotvgt \
Added: grass/branches/releasebranch_6_4/scripts/g.extension/Makefile
--- grass/branches/releasebranch_6_4/scripts/g.extension/Makefile	                        (rev 0)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/Makefile	2010-07-15 09:21:09 UTC (rev 42796)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = g.extension
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass/branches/releasebranch_6_4/scripts/g.extension/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass/branches/releasebranch_6_4/scripts/g.extension/description.html
--- grass/branches/releasebranch_6_4/scripts/g.extension/description.html	                        (rev 0)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/description.html	2010-07-15 09:21:09 UTC (rev 42796)
@@ -0,0 +1,20 @@
+<h2>DESCRIPTION</h2>
+<em>g.extension</em> downloads and installs extensions from
+GRASS Addons SVN repository into the local GRASS installation.
+<p>
+Re-running the script on an installed GRASS Addon re-installs
+the requested extension which may include updates.
+<h2>EXAMPLES</h2>
+Download and install <em>i.landsat.toar</em> into current GRASS installation:
+<div class="code"><pre>
+g.extension extension=i.landsat.toar
+</pre></div>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p><i>Last changed: $Date$</i>
Property changes on: grass/branches/releasebranch_6_4/scripts/g.extension/description.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
--- grass/branches/releasebranch_6_4/scripts/g.extension/g.extension	                        (rev 0)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/g.extension	2010-07-15 09:21:09 UTC (rev 42796)
@@ -0,0 +1,285 @@
+#!/bin/sh
+# MODULE:       g.extension
+# AUTHOR(S):   	Markus Neteler
+# PURPOSE:      Tool to download and install extensions from GRASS Addons SVN into
+#               local GRASS installation
+# COPYRIGHT:    (C) 2009-2010 by the Markus Neteler, GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#% label: Tool to maintain GRASS extensions in local GRASS installation.
+#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
+#% keywords: general, extensions
+#%End
+#%option
+#% key: extension
+#% type: string
+#% key_desc: name
+#% description: Name of extension to install/remove
+#% required: no
+#%end
+#%option
+#% key: operation
+#% type: string
+#% key_desc: name
+#% description: Operation to be performed
+#% required: no
+#% options: add,remove
+#% answer: add
+#%end
+#%option
+#% key: svnurl
+#% type: string
+#% key_desc: url
+#% description: SVN Addons repository URL
+#% required: yes
+#% answer: https://svn.osgeo.org/grass/grass-addons/
+#%end
+#%option
+#% key: prefix
+#% type: string
+#% key_desc: path
+#% description: Prefix where to install extension
+#% answer: $GRASS_ADDON_PATH
+#% required: yes
+#%end
+#%flag
+#% key: l
+#% description: List available modules in the GRASS Addons SVN repository
+#% guisection: Print
+#%end
+if  [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." >&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+  exec g.parser "$0" "$@"
+fi
+# definitions
+SVNURL_ADDONS=${GIS_OPT_SVNURL}
+MODULE="$GIS_OPT_EXTENSION"
+PREFIX="$GIS_OPT_PREFIX"
+#make a temporary directory
+TMPDIR="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMPDIR" ] ; then
+    g.message -e "Unable to create temporary files"
+    exit 1
+fi
+rm -f "$TMPDIR"
+mkdir "$TMPDIR"
+# check if we have the svn client
+if [ ! -x "`which svn`" ] ; then
+    g.message -e "svn client required. Please install Subversion first."
+    exit 1
+fi
+# check if we have the make program
+if [ ! -x "`which make`" ] ; then
+    g.message -e "'make' program required. Please install first."
+    exit 1
+fi
+# check if we have wget or curl
+if [ ! -x "`which wget`" ] ; then
+    if [ ! -x "`which curl`" ] ; then
+        g.message -e "Either 'wget' or 'curl' is required, please install one first"
+        exit 1
+    else
+        g.message -v "Using CURL for downloading data."
+        USE_CURL=1
+    fi
+else
+    g.message -v "Using WGET for downloading data."
+    USE_WGET=1
+fi
+expand_module_class_name()
+# $1: module class
+ if [ "$1" = "d" ]  ; then
+    echo "display"
+  elif [ "$1" = "db" ] ; then
+    echo "database"
+  elif [ "$1" = "g" ]  ; then
+    echo "general"
+  elif [ "$1" = "i" ]  ; then
+    echo "imagery"
+  elif [ "$1" = "m" ]  ; then
+    echo "misc"
+  elif [ "$1" = "ps" ] ; then
+    echo "postscript"
+#  elif [ "$1" = "p" ]  ; then
+#    echo "paint"
+  elif [ "$1" = "r" ]  ; then
+    echo "raster"
+  elif [ "$1" = "r3" ]  ; then
+    echo "raster3D"
+#  elif [ "$1" = "s" ]  ; then
+#    echo "sites"
+  elif [ "$1" = "v" ]  ; then
+    echo "vector"
+  else
+    echo "$1"
+ fi
+if [ `echo "$MODULE" | grep -c '/'` -eq 0 ] ; then
+   CLASSCHAR=`echo $MODULE | cut -d'.' -f1`
+   MODULECLASS=`expand_module_class_name $CLASSCHAR`
+else
+   # handle vector/adehabitat/ or just vector/v.module ...
+   TOPLEVEL=`echo $MODULE | cut -d'/' -f1`
+   MODULECLASS="$TOPLEVEL"
+   MODULE=`echo "$MODULE" | sed -e "s+^$MODULECLASS/++"`
+fi
+list_available_modules()
+ # a very dirty hack
+ g.message message="Fetching list of modules from GRASS-Addons SVN (be patient)..."
+ for d in d db g i m ps p r r3 v ; do
+     MODCLASS=`expand_module_class_name $d`
+     cd "$TMPDIR"
+     rm -f index.html
+     if [ "$USE_WGET" ] ; then
+        wget --quiet -nv "$SVNURL_ADDONS/$MODCLASS"
+     else
+        curl -silent --location "$SVNURL_ADDONS/$MODCLASS" -o index.html
+     fi
+     grep '<li>' index.html 2> /dev/null | grep -v '\.\.' | \
+        cut -d'"' -f2 | sed 's+/$++g' >> list_$$.txt
+     rm -f index.html
+ done
+ cat list_$$.txt
+ rm -f list_$$.txt
+ # so why save to a file at all instead of cat'ing directly?
+cleanup(){
+ if  [ ! -z "${TMPDIR}" ] ; then
+     rm -rf "${TMPDIR}"
+ fi
+if [ $GIS_FLAG_L -eq 1 ] ; then
+   list_available_modules
+   rmdir "$TMPDIR"
+   exit 0
+fi
+if [ -z "$GIS_OPT_EXTENSION" -a $GIS_FLAG_L -eq 0 ] ; then
+   g.message message="You need to define an extension name or use -l"
+   exit 1
+fi
+if [ "$PREFIX" == '$GRASS_ADDON_PATH' ] ; then
+    if [ -z "$GRASS_ADDON_PATH" ] ; then
+        g.message -e "GRASS_ADDON_PATH is not defined"
+        exit 1
+    fi
+    PREFIX=$GRASS_ADDON_PATH
+fi
+if [ -d "$PREFIX" ] ; then
+    MYINST_DIR="$PREFIX"
+else
+    g.message -e "'$PREFIX' does not exist"
+    exit 1
+fi
+if [ "$GIS_OPT_OPERATION" == "remove" ] ; then
+   g.message message="Removing <$MODULE>..."
+   if test -f "${MYINST_DIR}/bin/${MODULE}" ; then
+       rm -f "${MYINST_DIR}/bin/${MODULE}"
+   fi
+   if test -f "${MYINST_DIR}/docs/html/${MODULE}.html" ; then
+       rm -f "${MYINST_DIR}/docs/html/${MODULE}.html"
+   fi
+   if test -f "${MYINST_DIR}/man/man1/${MODULE}.1" ; then
+       rm -f "${MYINST_DIR}/man/man1/${MODULE}.1"
+   fi
+   exit 0
+fi
+g.message -d "svn co [$SVNURL_ADDONS]/[$MODULECLASS]/[$MODULE]"
+cd "$TMPDIR"
+g.message message="Fetching <$MODULE> from GRASS-Addons SVN (be patient)..."
+svn co ${SVNURL_ADDONS}/${MODULECLASS}/${MODULE}
+if [ $? -ne 0 ] ; then
+   g.message -e message="GRASS Addon ${MODULE} not found in repository or no network connection or another problem"
+   exit 1
+fi
+cd "$TMPDIR/$MODULE"
+g.message message="Compiling <${MODULE}>..."
+make MODULE_TOPDIR="$GISBASE"
+   g.message -e message="Compilation failed, sorry. Please check above error messages."
+   cleanup
+   exit 1
+else
+   g.message message="Installing ${MODULE}..."
+   # can we write? Install dir present?
+   if test ! -d "${MYINST_DIR}" ; then
+      mkdir -p "${MYINST_DIR}"
+   fi
+   if test ! -d "${MYINST_DIR}/bin" ; then
+      mkdir -p "${MYINST_DIR}/bin"
+   fi
+   if test ! -d "${MYINST_DIR}/docs/html" ; then
+      mkdir -p "${MYINST_DIR}/docs/html"
+   fi
+   if test ! -d "${MYINST_DIR}/man/man1" ; then
+      mkdir -p "${MYINST_DIR}/man/man1"
+   fi
+   touch "${MYINST_DIR}/`basename $0`.$$"
+   if [ $? -ne 0 ] ; then
+      g.message -e message="Cannot write to <${MYINST_DIR}>, installation failed"
+      exit 1
+   else
+      rm -f "${MYINST_DIR}/`basename $0`.$$"
+      fi
+      make MODULE_TOPDIR="$GISBASE" INST_DIR="$MYINST_DIR" install
+         g.message -e message="Installation failed, sorry. Please check above error messages."
+         cleanup
+         exit 1
+      fi
+      if [ ! -x "${MYINST_DIR}/bin/${MODULE}" ] ; then
+	g.message -e "Module did not install properly"
+	cleanup
+	exit 1
+      fi
+   fi
+fi
+cleanup
+g.message message=""
+g.message message="Installation of <$MODULE> in <$MYINST_DIR> successfully finished."
+exit 0
Property changes on: grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
Added: svn:executable
   + text/x-sh
   + native
