[GRASS-SVN] r42803 - grass/trunk/gui/wxpython/gui_modules
Fri Jul 16 03:02:06 EDT 2010
Author: mmetz
Date: 2010-07-16 07:02:05 +0000 (Fri, 16 Jul 2010)
New Revision: 42803
   grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
   grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
wxGUI GCP Manager: reorganize code
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmanager.py	2010-07-15 12:21:10 UTC (rev 42802)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmanager.py	2010-07-16 07:02:05 UTC (rev 42803)
@@ -193,23 +193,24 @@
             self.SrcMap.AddLayer(type=rendertype, command=cmdlist, l_active=True,
                               name=utils.GetLayerNameFromCmd(cmdlist),
                               l_hidden=False, l_opacity=1.0, l_render=False)
+            if tgt_map:
+                # add layer to target map
+                if maptype == 'cell':
+                    rendertype = 'raster'
+                    cmdlist = ['d.rast', 'map=%s' % tgt_map]
+                else: # -> vector layer
+                    rendertype = 'vector'
+                    cmdlist = ['d.vect', 'map=%s' % tgt_map]
+                self.SwitchEnv('target')
+                self.TgtMap.AddLayer(type=rendertype, command=cmdlist, l_active=True,
+                                  name=utils.GetLayerNameFromCmd(cmdlist),
+                                  l_hidden=False, l_opacity=1.0, l_render=False)
-            # add layer to target map
-            if maptype == 'cell':
-                rendertype = 'raster'
-                cmdlist = ['d.rast', 'map=%s' % tgt_map]
-            else: # -> vector layer
-                rendertype = 'vector'
-                cmdlist = ['d.vect', 'map=%s' % tgt_map]
-            self.SwitchEnv('target')
-            self.TgtMap.AddLayer(type=rendertype, command=cmdlist, l_active=True,
-                              name=utils.GetLayerNameFromCmd(cmdlist),
-                              l_hidden=False, l_opacity=1.0, l_render=False)
             # start GCP Manager
             self.gcpmgr = GCP(self.parent, grwiz=self, size=globalvar.MAP_WINDOW_SIZE,
@@ -628,7 +629,7 @@
         src_map = event.GetString()
-        if src_map == '' or tgt_map == '':
+        if src_map == '':
             wx.FindWindowById(wx.ID_FORWARD).Enable(False)
         else:
             wx.FindWindowById(wx.ID_FORWARD).Enable(True)
@@ -652,7 +653,7 @@
         tgt_map = event.GetString()
+        if src_map == '':
         else:
@@ -661,8 +662,8 @@
         global src_map
         global tgt_map
-        if event.GetDirection() and (src_map == '' or tgt_map == ''):
-            wx.MessageBox(_('You must select maps in order to continue'))
+        if event.GetDirection() and (src_map == ''):
+            wx.MessageBox(_('You must select a source map in order to continue'))
             event.Veto()
             return
@@ -709,11 +710,17 @@
     Manages ground control points for georectifying. Calculates RMS statics.
     Calls i.rectify or v.transform to georectify map.
-    def __init__(self, parent, grwiz = None, mapdisp = None, id = wx.ID_ANY,
+    def __init__(self, parent, grwiz = None, id = wx.ID_ANY,
                  title = _("Manage Ground Control Points"),
                  size = (700, 300), toolbars=["gcpdisp"], Map=None, lmgr=None):
         self.grwiz = grwiz # GR Wizard
+        if tgt_map == '':
+            self.show_target = False
+        else:
+            self.show_target = True
         #wx.Frame.__init__(self, parent, id, title, size = size, name = "GCPFrame")
         MapFrame.__init__(self, parent, id, title, size = size,
                             Map=Map, toolbars=["gcpdisp"], lmgr=lmgr, name='GCPMapWindow')
@@ -723,8 +730,6 @@
         self.parent = parent # GMFrame
         self.parent.gcpmanagement = self
-        self.mapdisp = self # XY-location Map Display
         self.grassdatabase = self.grwiz.grassdatabase
@@ -780,6 +785,8 @@
         # polynomial order transformation for georectification
         self.gr_order = 1
+        # region clipping for georectified map
+        self.clip_to_region = False
         # number of GCPs selected to be used for georectification (checked)
         self.GCPcount = 0
         # forward RMS error
@@ -795,8 +802,7 @@
                                    0.0,      # target north
                                    0.0,      # forward error
                                    0.0 ] )   # backward error
-        # region clipping for georectified map
-        self.clip_to_region = False
         # init vars to highlight high RMS errors
         self.highest_only = True
         self.show_unused =  True
@@ -915,8 +921,8 @@
-        if self.mapdisp.statusbarWin['toggle'].GetSelection() == 7: # go to
-            self.mapdisp.StatusbarUpdate()
+        if self.statusbarWin['toggle'].GetSelection() == 7: # go to
+            self.StatusbarUpdate()
     def DeleteGCP(self, event):
@@ -929,13 +935,39 @@
                           caption=_("Delete GCP"), style=wx.OK | wx.ICON_INFORMATION)
             return
-        item = self.list.DeleteGCPItem()
-        del self.mapcoordlist[item]
+        key = self.list.DeleteGCPItem()
+        del self.mapcoordlist[key]
-            self.statusbarWin['goto'].SetValue(0)
+        # update key and GCP number
+        for newkey in range(key, len(self.mapcoordlist)):
+            index = self.list.FindItemData(-1, newkey + 1)
+            self.mapcoordlist[newkey][0] = newkey
+            self.list.SetStringItem(index, 0, str(newkey))
+            self.list.SetItemData(index, newkey)
+        # update selected
+        if self.list.GetItemCount() > 0:
+            if self.list.selected < self.list.GetItemCount():
+                self.list.selectedkey = self.list.GetItemData(self.list.selected)
+            else:
+                self.list.selected = self.list.GetItemCount() - 1
+            self.list.SetItemState(self.list.selected,
+                              wx.LIST_STATE_SELECTED,
+                              wx.LIST_STATE_SELECTED)
+        else:
+            self.list.selected = wx.NOT_FOUND
+            self.list.selectedkey = -1
+        self.UpdateColours()
+            if self.list.selectedkey > 0:
+                self.statusbarWin['goto'].SetValue(self.list.selectedkey)
+            #self.statusbarWin['goto'].SetValue(0)
     def ClearGCP(self, event):
         Clears all values in selected item of GCP list and unchecks it
@@ -978,11 +1010,11 @@
         mapWin = None
         if coordtype == 'source':
-            mapWin = self.mapdisp.SrcMapWindow
+            mapWin = self.SrcMapWindow
             e_idx = 1
             n_idx = 2
         elif coordtype == 'target':
-            mapWin = self.mapdisp.TgtMapWindow
+            mapWin = self.TgtMapWindow
             e_idx = 3
             n_idx = 4
@@ -1058,7 +1090,7 @@
         key = self.list.GetItemData(index)
         if confirm:
-            if self.mapdisp.MapWindow == self.mapdisp.SrcMapWindow:
+            if self.MapWindow == self.SrcMapWindow:
                 currloc = _("source")
             else:
                 currloc = _("target")
@@ -1141,8 +1173,8 @@
         self.GCPcount = 0
-        sourceMapWin = self.mapdisp.SrcMapWindow
-        targetMapWin = self.mapdisp.TgtMapWindow
+        sourceMapWin = self.SrcMapWindow
+        targetMapWin = self.TgtMapWindow
         #targetMapWin = self.parent.curr_page.maptree.mapdisplay.MapWindow
         if not sourceMapWin:
@@ -1437,10 +1469,11 @@
         if self.highest_only and highest_fwd_err > 0.0:
             self.list.SetItemTextColour(highest_idx, wx.RED)
         sourceMapWin.UpdateMap(render=srcrender, renderVector=srcrenderVector)
-        targetMapWin.UpdateMap(render=tgtrender, renderVector=tgtrenderVector)
+        if self.show_target:
+            targetMapWin.UpdateMap(render=tgtrender, renderVector=tgtrenderVector)
     def OnQuit(self, event):
         """!Quit georectifier"""
@@ -1588,10 +1621,11 @@
         self.bkw_rmserror = round((sumsq_bkw_err/GCPcount)**0.5,4)
         self.list.ResizeColumns()
         sourceMapWin.UpdateMap(render=False, renderVector=False)
-        targetMapWin.UpdateMap(render=False, renderVector=False)
+            targetMapWin.UpdateMap(render=False, renderVector=False)
     def GetNewExtend(self, region, map = None):
@@ -1689,7 +1723,128 @@
                         quiet = True,
                         parent = self,
                         entry = 'wxGUI.GCP_Manager')
+    def OnUpdateActive(self, event):
+        if self.activemap.GetSelection() == 0:
+            self.MapWindow = self.SrcMapWindow
+            self.Map = self.SrcMap
+        else:
+            self.MapWindow = self.TgtMapWindow
+            self.Map = self.TgtMap
+        self.UpdateActive(self.MapWindow)
+    def UpdateActive(self, win):
+        # optionally disable tool zoomback tool
+        self.toolbars['gcpdisp'].Enable('zoomback', enable = (len(self.MapWindow.zoomhistory) > 1))
+        self.activemap.SetSelection(win == self.TgtMapWindow)
+    def AdjustMap(self, newreg):
+        """!Adjust map window to new extents
+        # adjust map window
+        self.Map.region['n'] = newreg['n']
+        self.Map.region['s'] = newreg['s']
+        self.Map.region['e'] = newreg['e']
+        self.Map.region['w'] = newreg['w']
+        self.MapWindow.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
+                 self.Map.region['e'], self.Map.region['w'])
+        # LL locations
+        if self.Map.projinfo['proj'] == 'll':
+            if newreg['n'] > 90.0:
+                newreg['n'] = 90.0
+            if newreg['s'] < -90.0:
+                newreg['s'] = -90.0
+        ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
+        cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
+        # calculate new center point and display resolution
+        self.Map.region['center_easting'] = ce
+        self.Map.region['center_northing'] = cn
+        self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
+        self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
+        self.Map.AlignExtentFromDisplay()
+        if self.MapWindow.redrawAll is False:
+            self.MapWindow.redrawAll = True
+        self.MapWindow.UpdateMap()
+    def OnZoomToSource(self, event):
+        """!Set target map window to match extents of source map window
+        if not self.MapWindow == self.TgtMapWindow:
+            self.UpdateActive(self.TgtMapWindow)
+        # get new N, S, E, W for target
+        newreg = self.GetNewExtend(self.SrcMap.region, 'source')
+        self.AdjustMap(newreg)
+    def OnZoomToTarget(self, event):
+        """!Set source map window to match extents of target map window
+        if not self.MapWindow == self.SrcMapWindow:
+            self.UpdateActive(self.SrcMapWindow)
+        newreg = self.GetNewExtend(self.TgtMap.region, 'target')
+    def OnZoomMenuGCP(self, event):
+        """!Popup Zoom menu
+        point = wx.GetMousePosition()
+        zoommenu = wx.Menu()
+        # Add items to the menu
+        zoomsource = wx.MenuItem(zoommenu, wx.ID_ANY, _('Adjust source display to target display'))
+        zoommenu.AppendItem(zoomsource)
+        self.Bind(wx.EVT_MENU, self.OnZoomToTarget, zoomsource)
+        zoomtarget = wx.MenuItem(zoommenu, wx.ID_ANY, _('Adjust target display to source display'))
+        zoommenu.AppendItem(zoomtarget)
+        self.Bind(wx.EVT_MENU, self.OnZoomToSource, zoomtarget)
+        # Popup the menu. If an item is selected then its handler
+        # will be called before PopupMenu returns.
+        self.PopupMenu(zoommenu)
+        zoommenu.Destroy()
+    def OnDispResize(self, event):
+        """!GCP Map Display resized, adjust Map Windows
+        if self.toolbars['gcpdisp']:
+            srcwidth, srcheight = self.SrcMapWindow.GetSize()
+            tgtwidth, tgtheight = self.TgtMapWindow.GetSize()
+            tgtwidth = (srcwidth + tgtwidth) / 2
+            self._mgr.GetPane("target").Hide()
+            self._mgr.Update()
+            self.TgtMapWindow.SetSize((tgtwidth, tgtheight))
+            self._mgr.GetPane("source").BestSize((tgtwidth, srcheight))
+            self._mgr.GetPane("target").BestSize((tgtwidth, tgtheight))
+                self._mgr.GetPane("target").Show()
+        pass
 class GCPList(wx.ListCtrl,
               CheckListCtrlMixin,
               ListCtrlAutoWidthMixin):
@@ -1781,10 +1936,11 @@
         if self.render:
             # redraw points
-            sourceMapWin = self.gcp.mapdisp.SrcMapWindow
-            targetMapWin = self.gcp.mapdisp.TgtMapWindow
+            sourceMapWin = self.gcp.SrcMapWindow
+            if self.gcp.show_target:
+                targetMapWin = self.gcp.TgtMapWindow
         pass
@@ -1820,17 +1976,10 @@
         if self.selected == wx.NOT_FOUND:
             return
+        key = self.GetItemData(self.selected)
         self.DeleteItem(self.selected)
-        if self.GetItemCount() > 0:
-            self.selected = self.GetItemCount() - 1
-            self.SetItemState(self.selected,
-                              wx.LIST_STATE_SELECTED,
-                              wx.LIST_STATE_SELECTED)
-        else:
-            self.selected = wx.NOT_FOUND
-        return self.selected
+        return key
     def ResizeColumns(self):
         """!Resize columns"""
@@ -1855,10 +2004,11 @@
         if self.render and self.selected != event.GetIndex():
             self.selected = event.GetIndex()
             self.selectedkey = self.GetItemData(self.selected)
         event.Skip()
@@ -2150,8 +2300,8 @@
         # initialize variables
-        self.new_src_map = None
-        self.new_tgt_map = None
+        self.new_src_map = src_map
+        self.new_tgt_map = tgt_map
         self.sdfactor = 0
         self.symbol = {}
@@ -2462,7 +2612,7 @@
         tmp_map = event.GetString()
-        if not tmp_map == '' and not tmp_map == tgt_map:
+        if not tmp_map == tgt_map:
             self.new_tgt_map = tmp_map
     def OnClipRegion(self, event):
@@ -2506,7 +2656,7 @@
         srcrenderVector = False
         tgtrender = False
         tgtrenderVector = False
-        if self.new_src_map:
+        if self.new_src_map != src_map:
             # remove old layer
             layers = self.parent.grwiz.SrcMap.GetListOfLayers()
             self.parent.grwiz.SrcMap.DeleteLayer(layers[0])
@@ -2521,18 +2671,32 @@
             self.parent.grwiz.SwitchEnv('target')
             srcrender = True
-        if self.new_tgt_map:
+        if self.new_tgt_map != tgt_map:
             # remove old layer
             layers = self.parent.grwiz.TgtMap.GetListOfLayers()
-            self.parent.grwiz.TgtMap.DeleteLayer(layers[0])
+            if layers:
+                self.parent.grwiz.TgtMap.DeleteLayer(layers[0])
             tgt_map = self.new_tgt_map
-            self.parent.grwiz.TgtMap.AddLayer(type='raster', command=cmdlist, l_active=True,
-            tgtrender = True
+            if tgt_map != '':
+                self.parent.grwiz.TgtMap.AddLayer(type='raster', command=cmdlist, l_active=True,
+                tgtrender = True
+                if self.parent.show_target == False:
+                    self.parent.show_target = True
+                    self.parent._mgr.GetPane("target").Show()
+                    self.parent._mgr.Update()
+                    self.parent.toolbars['gcpdisp'].Enable('zoommenu', enable = True)
+            else: # tgt_map == ''
+                if self.parent.show_target == True:
+                    self.parent.show_target = False
+                    self.parent._mgr.GetPane("target").Hide()
+                    self.parent.toolbars['gcpdisp'].Enable('zoommenu', enable = False)
         self.parent.UpdateColours(srcrender, srcrenderVector, tgtrender, tgtrenderVector)
     def OnSave(self, event):
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py	2010-07-15 12:21:10 UTC (rev 42802)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py	2010-07-16 07:02:05 UTC (rev 42803)
@@ -146,7 +146,7 @@
                           'gcpdisp' : None,
                           'gcpman' : None,
                           'nviz' : None }
-        self.activemap = None
         for toolb in toolbars:
             self.AddToolbar(toolb)
@@ -238,8 +238,8 @@
             self.statusbarWin['goto'] = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
                                                    value="", style=wx.TE_PROCESS_ENTER,
                                                     size=(100, -1))
-        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
         self.statusbarWin['goto'].Hide()
+        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
         # projection
         self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
@@ -306,7 +306,6 @@
         # Update fancy gui style
-        #if (0):
             # AuiManager wants a CentrePane , workaround to get two equally sized windows
             self.list = self.CreateGCPList()
@@ -335,7 +334,8 @@
             self._mgr.GetPane("source").BestSize((tgtwidth, tgtheight))
-            self._mgr.GetPane("target").Show()
         else:
             self._mgr.AddPane(self.MapWindow, wx.aui.AuiPaneInfo().CentrePane().
                           Dockable(False).BestSize((-1,-1)).
@@ -389,7 +389,8 @@
         Currently known toolbars are:
          - 'map'     - basic map toolbar
          - 'vdigit'  - vector digitizer
-         - 'gcpdisp'  - GCP Manager
+         - 'gcpdisp' - GCP Manager, Display
+         - 'gcpman'  - GCP Manager, points management
          - 'georect' - georectifier
          - 'nviz'    - 3D view mode
@@ -456,6 +457,9 @@
                               BottomDockable(False).TopDockable(True).
                               CloseButton(False).Layer(2))
+            if self.show_target == False:
+                self.toolbars['gcpdisp'].Enable('zoommenu', enable = False)
             self.toolbars['gcpman'] = toolbars.GCPManToolbar(self)
             self._mgr.AddPane(self.toolbars['gcpman'],
@@ -637,9 +641,14 @@
         if self._layerManager and \
                 self._layerManager.georectifying:
-            # in georectifying session; display used to get get geographic
+            # in georectifying session; display used to get geographic
             # coordinates for GCPs
             self.OnPointer(event)
+        elif self._layerManager and \
+                self._layerManager.gcpmanagement:
+            # coordinates for GCPs
+            self.OnPointer(event)
         else:
             # change bookcontrol page to page associated with display
             if self.page:
@@ -678,25 +687,6 @@
         # update statusbar
-    def OnDispResize(self, event):
-        """!GCP Map Display resized, adjust Map Windows
-        if self.toolbars['gcpdisp']:
-            # FIXME: does not work when reducing Map Display width
-            # tried a lot of MinSize, BestSize, also for both source and target map window
-            srcwidth, srcheight = self.SrcMapWindow.GetSize()
-            tgtwidth, tgtheight = self.TgtMapWindow.GetSize()
-            tgtwidth = (srcwidth + tgtwidth) / 2
-            self._mgr.GetPane("target").Hide()
-            self._mgr.Update()
-            self.TgtMapWindow.SetSize((tgtwidth, tgtheight))
-            self._mgr.GetPane("source").BestSize((tgtwidth, srcheight))
-            self._mgr.GetPane("target").BestSize((tgtwidth, tgtheight))
-        pass
     def OnPointer(self, event):
         """!Pointer button clicked
@@ -969,14 +959,15 @@
             # redraw map
             self.SrcMapWindow.UpdateMap()
-            # Target MapWindow:
-            begin = (self.mapcoordlist[GCPNo][3], self.mapcoordlist[GCPNo][4])
-            begin = self.TgtMapWindow.Cell2Pixel(begin)
-            end = begin
-            self.TgtMapWindow.Zoom(begin, end, 0)
+                # Target MapWindow:
+                begin = (self.mapcoordlist[GCPNo][3], self.mapcoordlist[GCPNo][4])
+                begin = self.TgtMapWindow.Cell2Pixel(begin)
+                end = begin
+                self.TgtMapWindow.Zoom(begin, end, 0)
-            # redraw map
-            self.TgtMapWindow.UpdateMap()
+                # redraw map
+                self.TgtMapWindow.UpdateMap()
         else:
             try:
@@ -1352,12 +1343,12 @@
             ltype = [{ 'ext' : 'ppm', 'type' : -1 },
                      { 'ext' : 'tif', 'type' : wx.BITMAP_TYPE_TIF }]
         else:
-            img = self.MapWindow.img
-            if not img:
-                gcmd.GMessage(parent = self,
-                              message = _("Nothing to render (empty map). Operation canceled."),
-                              msgType = 'info')
-                return
+            img = self.MapWindow.img
+            if not img:
+                gcmd.GMessage(parent = self,
+                              message = _("Nothing to render (empty map). Operation canceled."),
+                              msgType = 'info')
+                return
             filetype, ltype = gdialogs.GetImageHandlers(img)
         # get size
@@ -1553,7 +1544,7 @@
                         continue
                     vect.append(vector)
                 vectstr = ','.join(vect)
             if len(vectstr) <= 1:
                 self._layerManager.goutput.WriteCmdLog("Nothing to query.")
                 return
@@ -2146,71 +2137,6 @@
         self.MapWindow.SaveDisplayRegion()
-    def AdjustMap(self, newreg):
-        """!Adjust map window to new extents
-        # adjust map window
-        self.Map.region['n'] = newreg['n']
-        self.Map.region['s'] = newreg['s']
-        self.Map.region['e'] = newreg['e']
-        self.Map.region['w'] = newreg['w']
-        self.MapWindow.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
-                 self.Map.region['e'], self.Map.region['w'])
-        # LL locations
-        if self.Map.projinfo['proj'] == 'll':
-            if newreg['n'] > 90.0:
-                newreg['n'] = 90.0
-            if newreg['s'] < -90.0:
-                newreg['s'] = -90.0
-        ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
-        cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
-        # calculate new center point and display resolution
-        self.Map.region['center_easting'] = ce
-        self.Map.region['center_northing'] = cn
-        self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
-        self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
-        self.Map.AlignExtentFromDisplay()
-        if self.MapWindow.redrawAll is False:
-            self.MapWindow.redrawAll = True
-        self.MapWindow.UpdateMap()
-        self.StatusbarUpdate()
-    def OnZoomToSource(self, event):
-        """!Set target map window to match extents of source map window
-        if not self.MapWindow == self.TgtMapWindow:
-            self.MapWindow = self.TgtMapWindow
-            self.Map = self.TgtMap
-            self.UpdateActive(self.TgtMapWindow)
-        # get new N, S, E, W for target
-        newreg = self.GetNewExtend(self.SrcMap.region, 'source')
-        self.AdjustMap(newreg)
-    def OnZoomToTarget(self, event):
-        """!Set source map window to match extents of target map window
-        if not self.MapWindow == self.SrcMapWindow:
-            self.MapWindow = self.SrcMapWindow
-            self.Map = self.SrcMap
-            self.UpdateActive(self.SrcMapWindow)
-        newreg = self.GetNewExtend(self.TgtMap.region, 'target')
     def OnZoomMenu(self, event):
         """!Popup Zoom menu
@@ -2243,26 +2169,6 @@
         zoommenu.Destroy()
-    def OnZoomMenuGCP(self, event):
-        """!Popup Zoom menu
-        point = wx.GetMousePosition()
-        zoommenu = wx.Menu()
-        # Add items to the menu
-        zoomsource = wx.MenuItem(zoommenu, wx.ID_ANY, _('Adjust source display to target display'))
-        zoommenu.AppendItem(zoomsource)
-        self.Bind(wx.EVT_MENU, self.OnZoomToTarget, zoomsource)
-        zoomtarget = wx.MenuItem(zoommenu, wx.ID_ANY, _('Adjust target display to source display'))
-        zoommenu.AppendItem(zoomtarget)
-        self.Bind(wx.EVT_MENU, self.OnZoomToSource, zoomtarget)
-        # Popup the menu. If an item is selected then its handler
-        # will be called before PopupMenu returns.
-        self.PopupMenu(zoommenu)
-        zoommenu.Destroy()
     def SetProperties(self, render=False, mode=0, showCompExtent=False,
                       constrainRes=False, projection=False):
         """!Set properies of map display window"""
@@ -2275,25 +2181,6 @@
         if showCompExtent:
             self.MapWindow.regionCoords = []
-    def OnUpdateActive(self, event):
-        if self.activemap.GetSelection() == 0:
-        else:
-        self.UpdateActive(self.MapWindow)
-    def UpdateActive(self, win):
-        # optionally disable tool zoomback tool
-        self.toolbars['gcpdisp'].Enable('zoomback', enable = (len(self.MapWindow.zoomhistory) > 1))
-        self.activemap.SetSelection(win == self.TgtMapWindow)
     def IsStandalone(self):
         """!Check if Map display is standalone"""
         if self._layerManager:
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-07-15 12:21:10 UTC (rev 42802)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-07-16 07:02:05 UTC (rev 42803)
@@ -520,14 +520,9 @@
-        elif self._layerManager and \
-                self._layerManager.gcpmanagement:
-            # coordinates for GCPs
-            self.OnPointer(event)
         else:
             if self.page:
