[GRASS-SVN] r42888 - grass/trunk/lib/raster
svn_grass at osgeo.org
Sat Jul 24 19:54:11 EDT 2010
Author: huhabla
Date: 2010-07-24 23:54:11 +0000 (Sat, 24 Jul 2010)
New Revision: 42888
grass/trunk/lib/raster/history.c
Doxygen documentation update.
Modified: grass/trunk/lib/raster/history.c
--- grass/trunk/lib/raster/history.c 2010-07-24 08:45:00 UTC (rev 42887)
+++ grass/trunk/lib/raster/history.c 2010-07-24 23:54:11 UTC (rev 42888)
@@ -17,12 +17,31 @@
#include <grass/raster.h>
#include <grass/glocale.h>
+ * \brief Append a string to a History structure
+ * \param hist pointer to History structure which holds history info
+ * \param str string to append
+ * \return void
void Rast_append_history(struct History *hist, const char *str)
hist->lines = G_realloc(hist->lines, (hist->nlines + 1) * sizeof(char *));
hist->lines[hist->nlines++] = G_store(str);
+ * \brief Append a formated string to a History structure
+ * \param fmt a string of format characters
+ * \param ... the arguments associated with the format characters
+ * \return void
void Rast_append_format_history(struct History *hist, const char *fmt, ...)
va_list ap;
@@ -145,11 +164,31 @@
Rast__write_history(hist, fp);
+ * \brief Set the string of a specific history field
+ * \param field number of a specific history field, should be accessed with macros (HIST_MAPID, ...)
+ * \return string of the history field
const char *Rast_get_history(struct History *hist, int field)
return hist->fields[field];
+ * \param str string of the history field
+ * \return void
void Rast_set_history(struct History *hist, int field, const char *str)
if (hist->fields[field])
