[GRASS-SVN] r42897 - grass/trunk/imagery/i.rectify
svn_grass at osgeo.org
Mon Jul 26 05:14:12 EDT 2010
Author: mmetz
Date: 2010-07-26 09:14:12 +0000 (Mon, 26 Jul 2010)
New Revision: 42897
grass/trunk/imagery/i.rectify/main.c
grass/trunk/imagery/i.rectify/rectify.c
grass/trunk/imagery/i.rectify/write.c
adjust to r42876
Modified: grass/trunk/imagery/i.rectify/main.c
--- grass/trunk/imagery/i.rectify/main.c 2010-07-25 21:25:09 UTC (rev 42896)
+++ grass/trunk/imagery/i.rectify/main.c 2010-07-26 09:14:12 UTC (rev 42897)
@@ -187,7 +187,9 @@
if (c->answer) {
/* Use current Region */
- G_get_window(&target_window);
+ select_target_env();
+ G__get_window(&target_window, "", "WIND", G_mapset());
+ select_current_env();
else {
/* Calculate smallest region */
Modified: grass/trunk/imagery/i.rectify/rectify.c
--- grass/trunk/imagery/i.rectify/rectify.c 2010-07-25 21:25:09 UTC (rev 42896)
+++ grass/trunk/imagery/i.rectify/rectify.c 2010-07-26 09:14:12 UTC (rev 42897)
@@ -41,8 +41,8 @@
Rast_set_input_window(&cellhd);
infd = Rast_open_old(name, mapset);
map_type = Rast_get_map_type(infd);
- rast = (void *)G_calloc(Rast_window_cols() + 1, Rast_cell_size(map_type));
- Rast_set_null_value(rast, Rast_window_cols() + 1, map_type);
+ rast = (void *)G_calloc(cellhd.cols + 1, Rast_cell_size(map_type));
+ Rast_set_null_value(rast, cellhd.cols + 1, map_type);
win = target_window;
Modified: grass/trunk/imagery/i.rectify/write.c
--- grass/trunk/imagery/i.rectify/write.c 2010-07-25 21:25:09 UTC (rev 42896)
+++ grass/trunk/imagery/i.rectify/write.c 2010-07-26 09:14:12 UTC (rev 42897)
@@ -43,7 +43,8 @@
Rast_set_output_window(&target_window);
- rast = Rast_allocate_buf(map_type);
+ /* working with split windows, can not use Rast_allocate_buf(map_type); */
+ rast = G_malloc(target_window.cols * Rast_cell_size(map_type));
close(temp_fd);
temp_fd = open(temp_name, 0);
fd = Rast_open_new(name, map_type);
@@ -57,6 +58,7 @@
close(temp_fd);
unlink(temp_name);
Rast_close(fd);
+ G_free(rast);
return 0;
