[GRASS-SVN] r42900 - grass-addons/raster/r.stream.distance
Mon Jul 26 11:42:14 EDT 2010
Author: neteler
Date: 2010-07-26 15:42:14 +0000 (Mon, 26 Jul 2010)
New Revision: 42900
   grass-addons/raster/r.stream.distance/global.h
jarek: fix definitions for compliation
Modified: grass-addons/raster/r.stream.distance/global.h
--- grass-addons/raster/r.stream.distance/global.h	2010-07-26 14:44:21 UTC (rev 42899)
+++ grass-addons/raster/r.stream.distance/global.h	2010-07-26 15:42:14 UTC (rev 42900)
@@ -22,30 +22,30 @@
 #define RELATIVE 2
 POINT {
-    int r, c;
-    float cur_dist;
-    float target_elev;
+	int r, c;
+float cur_dist;
+float target_elev;
 #define OUTLET struct outs
 OUTLET {
-    int r, c;
-    float easting;
-    float northing;
+	int r, c;
+	float easting;
+	float northing;
 					/* functions.c */
 /* io.c */
-int open_raster(char *);
+int open_raster(char *mapname);
 int create_maps(void);
-int write_maps(char *, FCELL **);
 void free_streams (void);
 int write_distance(void);
 int write_elevation(void);
-int set_null(FCELL **);
+int set_null_elev(void);
 /* inits */
+int find_chatchment_outlets(void);
 int fill_catchments(OUTLET outlet);
 int find_outlets(void);
 int reset_distance(void);
@@ -76,13 +76,13 @@
 GLOBAL int nrows, ncols;
-POINT *fifo_outlet;
-int tail, head;
-int outlets_num;
-int fifo_max;
+GLOBAL POINT *fifo_outlet;
+GLOBAL int tail, head;
+GLOBAL int outlets_num;
+GLOBAL int fifo_max;
 GLOBAL int out; /* number of strahler and horton outlets: index */
-OUTLET *outlets;
+GLOBAL OUTLET *outlets;
 GLOBAL struct History history;	/* holds meta-data (title, comments,..) */
 GLOBAL struct Cell_head window;
