[GRASS-SVN] r42913 -
grass/branches/develbranch_6/scripts/g.extension
svn_grass at osgeo.org
Tue Jul 27 17:26:31 EDT 2010
Author: neteler
Date: 2010-07-27 21:26:31 +0000 (Tue, 27 Jul 2010)
New Revision: 42913
grass/branches/develbranch_6/scripts/g.extension/g.extension
fix install dir; predefine install target
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-07-27 21:25:59 UTC (rev 42912)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension 2010-07-27 21:26:31 UTC (rev 42913)
@@ -50,7 +50,7 @@
#% type: string
#% key_desc: path
#% description: Prefix where to install extension
-#% answer: $GRASS_ADDON_PATH
+#% answer: $GISBASE
#% required: yes
#%end
#%flag
@@ -191,12 +191,8 @@
exit 1
fi
-if [ "$PREFIX" == '$GRASS_ADDON_PATH' ] ; then
- if [ -z "$GRASS_ADDON_PATH" ] ; then
- g.message -e "GRASS_ADDON_PATH is not defined"
- exit 1
- fi
- PREFIX=$GRASS_ADDON_PATH
+if [ "$PREFIX" == '$GISBASE' ] ; then
+ PREFIX=$GISBASE
fi
if [ -d "$PREFIX" ] ; then
@@ -242,12 +238,20 @@
exit 1
else
g.message message="Installing ${MODULE}..."
+ # is it a script?
+ grep "default: script" $TMPDIR/${MODULE}/Makefile 2>&1 >/dev/null
+ if [ $? -eq 0 ] ; then
+ PROGTYPE=scripts
+ else
+ PROGTYPE=bin
+ fi
# can we write? Install dir present?
if test ! -d "${MYINST_DIR}" ; then
mkdir -p "${MYINST_DIR}"
fi
- if test ! -d "${MYINST_DIR}/bin" ; then
- mkdir -p "${MYINST_DIR}/bin"
+ if test ! -d "${MYINST_DIR}/$PROGTYPE" ; then
+ mkdir -p "${MYINST_DIR}/$PROGTYPE"
fi
if test ! -d "${MYINST_DIR}/docs/html" ; then
mkdir -p "${MYINST_DIR}/docs/html"
@@ -261,8 +265,8 @@
exit 1
else
rm -f "${MYINST_DIR}/`basename $0`.$$"
- if test -f "${MYINST_DIR}/bin/${MODULE}" ; then
- rm -f "${MYINST_DIR}/bin/${MODULE}"
+ if test -f "${MYINST_DIR}/$PROGTYPE/${MODULE}" ; then
+ rm -f "${MYINST_DIR}/$PROGTYPE/${MODULE}"
fi
make MODULE_TOPDIR="$GISBASE" INST_DIR="$MYINST_DIR" install
if [ $? -ne 0 ] ; then
@@ -270,7 +274,7 @@
cleanup
exit 1
fi
- if [ ! -x "${MYINST_DIR}/bin/${MODULE}" ] ; then
+ if [ ! -x "${MYINST_DIR}/$PROGTYPE/${MODULE}" ] ; then
g.message -e "Module did not install properly"
cleanup
exit 1
