[GRASS-SVN] r42915 - grass/trunk/scripts/v.db.univar
svn_grass at osgeo.org
Wed Jul 28 03:49:16 EDT 2010
Author: mmetz
Date: 2010-07-28 07:49:16 +0000 (Wed, 28 Jul 2010)
New Revision: 42915
grass/trunk/scripts/v.db.univar/v.db.univar.py
sync to r.univar etc
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py 2010-07-28 04:34:47 UTC (rev 42914)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py 2010-07-28 07:49:16 UTC (rev 42915)
@@ -5,6 +5,7 @@
# MODULE: v.db.univar (formerly called v.univar.sh)
# AUTHOR(S): Michael Barton, Arizona State University
# Converted to Python by Glynn Clements
+# Sync'ed to r.univar by Markus Metz
# PURPOSE: Calculates univariate statistics from a GRASS vector map attribute column.
# Based on r.univar.sh by Markus Neteler
# COPYRIGHT: (C) 2005, 2007, 2008 by the GRASS Development Team
@@ -64,6 +65,15 @@
#% description: WHERE conditions of SQL statement without 'where' keyword
#% required : no
#%end
+#%option
+#% key: percentile
+#% type: double
+#% description: Percentile to calculate (requires extended statistics flag)
+#% required : no
+#% answer: 90
+#% options: 0-100
+#% multiple: yes
+#%end
import sys
import os
@@ -105,9 +115,13 @@
database = options['database']
driver = options['driver']
where = options['where']
+ perc = options['percentile']
+ perc = [float(p) for p in perc.split(',')]
- grass.message(_("Calculation for column <%s> of table <%s>...") % (column, table))
- grass.message(_("Reading column values..."))
+ if not shellstyle:
+ grass.message(_("Calculation for column <%s> of table <%s>...") % (column, table))
+ grass.message(_("Reading column values..."))
sql = "SELECT %s FROM %s" % (column, table)
if where:
@@ -132,7 +146,8 @@
tmpf.close()
# calculate statistics
- grass.message(_("Calculating statistics..."))
+ grass.message(_("Calculating statistics..."))
N = 0
sum = 0.0
@@ -157,32 +172,34 @@
if not shellstyle:
print ""
- print "Number of values:", N
- print "Minimum:", minv
- print "Maximum:", maxv
- print "Range:", maxv - minv
+ print "Number of values: %d" % N
+ print "Minimum: %g" % minv
+ print "Maximum: %g" % maxv
+ print "Range: %g" % (maxv - minv)
print "-----"
- print "Mean:", sum/N
- print "Arithmetic mean of absolute values:", sum3/N
- print "Variance:", (sum2 - sum*sum/N)/N
- print "Standard deviation:", math.sqrt((sum2 - sum*sum/N)/N)
- print "Coefficient of variation:", (math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N)
+ print "Mean: %g" % (sum/N)
+ print "Arithmetic mean of absolute values: %g" % (sum3/N)
+ print "Variance: %g" % ((sum2 - sum*sum/N)/N)
+ print "Standard deviation: %g" % (math.sqrt((sum2 - sum*sum/N)/N))
+ print "Coefficient of variation: %g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
+ print "Sum: %g" % sum
print "-----"
else:
print "n=%d" % N
- print "min=%f" % minv
- print "max=%f" % maxv
- print "range=%f" % (maxv - minv)
- print "mean=%f" % (sum/N)
- print "mean_abs=%f" % (sum3/N)
- print "variance=%f" % ((sum2 - sum*sum/N)/N)
- print "stddev=%f" % (math.sqrt((sum2 - sum*sum/N)/N))
- print "coeff_var=%f" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
+ print "min=%.15g" % minv
+ print "max=%.15g" % maxv
+ print "range=%.15g" % (maxv - minv)
+ print "mean=%.15g" % (sum/N)
+ print "mean_abs=%.15g" % (sum3/N)
+ print "variance=%.15g" % ((sum2 - sum*sum/N)/N)
+ print "stddev=%.15g" % (math.sqrt((sum2 - sum*sum/N)/N))
+ print "coeff_var=%.15g" % ((math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N))
+ print "sum=%.15g" % sum
if not extend:
return
- #preparations:
+ # preparations:
sortfile(tmp, tmp + ".sort")
number = N
@@ -193,8 +210,13 @@
q50apos = round(N * 0.50)
q50bpos = q50apos + (1 - odd)
q75pos = round(N * 0.75)
- q90pos = round(N * 0.90)
+ ppos = {}
+ pval = {}
+ for i in range(len(perc)):
+ ppos[i] = round(N * perc[i] / 100)
+ pval[i] = 0
inf = file(tmp + ".sort")
l = 1
for line in inf:
@@ -206,22 +228,37 @@
q50b = float(line.rstrip('\r\n'))
if l == q75pos:
q75 = float(line.rstrip('\r\n'))
- if l == q90pos:
- q90 = float(line.rstrip('\r\n'))
+ for i in range(len(ppos)):
+ if l == ppos[i]:
+ pval[i] = float(line.rstrip('\r\n'))
l += 1
q50 = (q50a + q50b) / 2
if not shellstyle:
- print "1st Quartile: %f" % q25
- print "Median (%s N): %f" % (eostr, q50)
- print "3rd Quartile: %f" % q75
- print "90th Percentile: %f" % q90
+ print "1st Quartile: %g" % q25
+ print "Median (%s N): %g" % (eostr, q50)
+ print "3rd Quartile: %g" % q75
+ if perc[i] == int(perc[i]): # integer
+ if int(perc[i]) % 10 == 1 and int(perc[i]) != 11:
+ print "%dst Percentile: %g" % (int(perc[i]), pval[i])
+ elif int(perc[i]) % 10 == 2 and int(perc[i]) != 12:
+ print "%dnd Percentile: %g" % (int(perc[i]), pval[i])
+ elif int(perc[i]) % 10 == 3 and int(perc[i]) != 13:
+ print "%drd Percentile: %g" % (int(perc[i]), pval[i])
+ else:
+ print "%dth Percentile: %g" % (int(perc[i]), pval[i])
+ else:
+ print "%.15g Percentile: %g" % (perc[i], pval[i])
else:
- print "first_quartile=%f" % q25
- print "median=%f" % q50
- print "third_quartile=%f" % q75
- print "percentile_90==%f" % q90
+ print "first_quartile=%g" % q25
+ print "median=%g" % q50
+ print "third_quartile=%g" % q75
+ percstr = "%.15g" % perc[i]
+ percstr = percstr.replace('.','_')
+ print "percentile_%s=%g" % (percstr, pval[i])
if __name__ == "__main__":
options, flags = grass.parser()
