[GRASS-SVN] r42920 - grass-addons/vector/v.krige
Wed Jul 28 09:17:26 EDT 2010
Author: neteler
Date: 2010-07-28 13:17:26 +0000 (Wed, 28 Jul 2010)
New Revision: 42920
Added:
   grass-addons/vector/v.krige/Makefile
   grass-addons/vector/v.krige/description.html
   grass-addons/vector/v.krige/v.krige.py
   grass-addons/vector/v.krige/vkrige_gui.py
   grass-addons/vector/v.krige/README
aghisla: backport to GRASS 6.4
Added: grass-addons/vector/v.krige/Makefile
--- grass-addons/vector/v.krige/Makefile	                        (rev 0)
+++ grass-addons/vector/v.krige/Makefile	2010-07-28 13:17:26 UTC (rev 42920)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+ETCDIR = $(ETC)/wxpython
+PGM = v.krige.py
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
+	${INSTALL} vkrige_gui.py ${ETCDIR}/scripts/
Property changes on: grass-addons/vector/v.krige/Makefile
___________________________________________________________________
Added: svn:eol-style
   + native
Modified: grass-addons/vector/v.krige/README
--- grass-addons/vector/v.krige/README	2010-07-28 11:30:13 UTC (rev 42919)
+++ grass-addons/vector/v.krige/README	2010-07-28 13:17:26 UTC (rev 42920)
@@ -1,4 +1,4 @@
-v.krige has been moved to trunk (GRASS 7.0) and devbr6 (GRASS
-6.5). Please install GRASS 6.5+ to use v.krige module.
+The latest version of v.krige is available and developed in trunk (GRASS 7.0) and
+devbr6 (GRASS 6.5).
-Martin Landa, 2009-12-18
+Anne Ghisla, 7/2010
Added: grass-addons/vector/v.krige/description.html
--- grass-addons/vector/v.krige/description.html	                        (rev 0)
+++ grass-addons/vector/v.krige/description.html	2010-07-28 13:17:26 UTC (rev 42920)
@@ -0,0 +1,191 @@
+<h2>DESCRIPTION</h2>
+<em>v.krige</em> allows to perform kriging operations in GRASS
+environment, using R software functions in background.
+<h2>NOTES</h2>
+<em>v.krige</em> is just a front-end to R. The options and parameters
+are the same offered by packages <i>automap</i> and <i>gstat</i>.
+<p>
+Kriging, like other interpolation methods, is fully dependent on input
+data features. Exploratory analysis of data is encouraged to find out
+outliers, trends, anisotropies, uneven distributions and consequently
+choose the kriging algorithm that will give the most acceptable
+result. Good knowledge of the dataset is more valuable than hundreds
+of parameters or powerful hardware. See Isaaks and Srivastava's book,
+exhaustive and clear even if a bit outdated.
+<h3>Dependencies</h3>
+<dl>
+<dt><b>R software >= 2.x</b></dt>
+<dd></dd>
+<dt><b>rpy2</b></dt>
+<dd>Python binding to R. Note! <tt>rpy</tt> version 1 is not supported.</dd>
+<dt><b>R packages automap and gstat. </b></dt>
+<dd>automap is optional (provides automatic variogram fit).</dd>
+</dl>
+<h4>Notes for Debian GNU/Linux</h4>
+Install the dependiencies. <b>Attention! python-rpy IS NOT
+SUITABLE.</b>:
+<div class="code"><pre>
+  aptitude install R python-rpy2
+</pre></div>
+To install R packages, use either R's function (as root):
+  install.packages("gstat", dep=T)
+  install.packages("spgrass6", dep=T)
+</pre></div>
+either the brand new Debian packages [5], add to repositories' list
+for 32bit or 64bit (pick up the suitable line):
+  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-i386">http://debian.cran.r-project.org/cran2deb/debian-i386</a> testing/
+  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-amd64">http://debian.cran.r-project.org/cran2deb/debian-amd64</a> testing/
+</pre></div>
+and get the packages via aptitude:
+  aptitude install r-cran-gstat r-cran-spgrass6
+</pre></div>
+<h4>Notes for Windows</h4>
+Compile GRASS following this
+<a href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">guide</a>.
+You could also use Linux in a virtual machine. Or install Linux in a
+separate partition of the HD. This is not as painful as it appears,
+there are lots of guides over the Internet to help you.
+<h3>Computation time issues</h3>
+Please note that kriging calculation is slown down both by high number
+of input data points and/or high region resolution, even if they both
+contribute to a better output.
+<h2>EXAMPLES</h2>
+Kriging example based on elevation map (Spearfish data set).
+<p>
+<b>Part 1: random sampling</b> of 2000 vector points from known
+elevation map. Each point will receive the elevation value from the
+elevation raster, as if it came from a point survey.
+ g.region rast=elevation.10m -p
+ v.random output=rand2k_elev n=2000
+ v.db.addtable map=rand2k_elev column="elevation double precision"
+ v.what.rast vect=rand2k_elev rast=elevation.10m column=elevation
+</pre></div>
+<b>Part 2: remove points lacking elevation attributes</b>. Points
+sampled at the border of the elevation map didn't receive any
+value. v.krige has no preferred action to cope with no data values, so
+the user must check for them and decide what to do (remove points,
+fill with the value of the nearest point, fill with the global/local
+mean...). In the following line of code, points with no data are
+removed from the map.
+ v.extract rand2k_elev output=rand2k_elev_filt where="elevation not NULL"
+</pre></div>
+Check the result of previous line ("number of NULL attributes" must be
+0):
+ v.univar rand2k_elev_filt type=point column=elevation
+</pre></div>
+<b>Part 3: reconstruct DEM through kriging</b>. Using automatic
+variogram fit is the simplest way to run v.krige from CLI (note:
+requires R's automap package). Output map name is optional, the
+modules creates it automatically appending "_kriging" the the input
+map name and also checks for overwrite. If output_var is specified,
+the variance map is also created. Automatic variogram fit is provided
+by R package automap, the variogram models tested by the fitting
+functions are: exponential, spherical, Gaussian, Matern, M.Stein's
+parametrisation. A wider range of models is available from gstat
+package and can be tested on the GUI via the variogram plotting. If
+model is specified in the CLI, also sill, nugget and range values are
+to be provided, otherwise an error is raised (see second example of
+v.krige command).
+ v.krige input=rand2k_elev_filt column=elevation output=rand2k_elev_kriging \
+         output_var=rand2k_elev_kriging_var
+         output_var=rand2k_elev_kriging_var model=Lin sill=2500 nugget=0 range=1000 \
+         --overwrite
+</pre></div>
+Or run wxGUI, to interactively fit the variogram and explore options:
+  v.krige
+</pre></div>
+<b>Calculate prediction error</b>:
+ r.mapcalc "rand2k_elev_kriging_pe = sqrt(rand2k_elev_kriging_var)"
+ r.univar elevation.10m
+ r.univar rand2k_elev_kriging
+ r.univar rand2k_elev_kriging_pe
+</pre></div>
+The results show high errors, as the kriging techniques (ordinary and
+block kriging) are unable to handle a dataset with a trend, like the
+one used in this example: elevation is higher in the southwest corner
+and lower on northeast corner. Universal kriging can give far better
+results in these cases as it can handle the trend. It is available in
+R package gstat and will be part of a future v.krige release.
+<h2>SEE ALSO</h2>
+R package <a href="http://cran.r-project.org/web/packages/gstat/index.html">gstat</a>,
+mantained by Edzer J. Pebesma and others
+<br>
+R
+package <a href="http://cran.r-project.org/web/packages/spgrass6/index.html">spgrass6</a>,
+mantained by Roger Bivand
+<br>
+The <a href="http://grass.osgeo.org/statsgrass/grass6_r_install.html">Short
+Introduction to Geostatistical and Spatial Data Analysis with GRASS 6
+and R statistical data language</a> at the GRASS website. (includes
+installation tips)
+<br><br>
+v.krige's <a href="http://grass.osgeo.org/wiki/V.krige_GSoC_2009">wiki page</a>
+<h2>REFERENCES</h2>
+Isaaks and Srivastava, 1989: "An Introduction to Applied Geostatistics"
+ (ISBN 0-19-505013-4)
+<h2>AUTHOR</h2>
+Anne Ghisla, Google Summer of Code 2009
+<p>
+<i>Last changed: $Date: 2010-02-21 05:37:13 +0100 (Sun, 21 Feb 2010) $</i>
Added: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py	                        (rev 0)
+++ grass-addons/vector/v.krige/v.krige.py	2010-07-28 13:17:26 UTC (rev 42920)
@@ -0,0 +1,422 @@
+#!/usr/bin/env python
+MODULE:    v.krige
+AUTHOR(S): Anne Ghisla <a.ghisla AT gmail.com>
+PURPOSE:   Performs ordinary or block kriging
+DEPENDS:   R 2.x, packages gstat, maptools and spgrass6, optional: automap
+COPYRIGHT: (C) 2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+## g.parser informations
+#%module
+#% description: Performs ordinary or block kriging.
+#% keywords: vector, interpolation, kriging
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of point vector map containing sample data
+#% required: yes
+#%end
+#%option
+#% key: column
+#% type: string
+#% gisprompt: old,dbcolumn,dbcolumn
+#% description: Name of attribute column with numerical value to be interpolated
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% label: Name for output raster map
+#% description: If omitted, will be <input name>_kriging
+#% required : no
+#%end
+#%option
+#% key: package
+#% type: string
+#% options: gstat
+#% answer: gstat
+#% description: R package to use
+#% required: no
+#%end
+#%option
+#% key: model
+#% type: string
+#% options: Exp,Sph,Gau,Mat,Lin
+#% multiple: yes
+#% label: Variogram model(s)
+#% description: Leave empty to test all models (requires automap)
+#% required: no
+#%end
+#%option
+#% key: block
+#% type: integer
+#% multiple: no
+#% label: Block size (square block)
+#% description: Block size. Used by block kriging.
+#% required: no
+#%end
+#%option
+#% key: range
+#% type: integer
+#% label: Range value
+#% description: Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: nugget
+#% type: integer
+#% label: Nugget value
+#% required : no
+#%end
+#%option
+#% key: sill
+#% type: integer
+#% label: Sill value
+#% required : no
+#%end
+#%option
+#% key: output_var
+#% type: string
+#% label: Name for output variance raster map
+#% description: If omitted, will be <input name>_kriging_var
+#% required : no
+#%end
+import os, sys
+from tempfile import gettempdir
+import time
+import thread
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules")
+sys.path.append(GUIModulesPath)
+GUIPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "scripts")
+sys.path.append(GUIPath)
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+### dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
+# GRASS binding
+try:
+    import grass.script as grass
+except ImportError:
+    sys.exit(_("No GRASS-python library found"))
+# move other checks in functions, as R?
+# globals
+Command = None
+InputData = None
+Variogram = None
+VariogramFunction = None
+robjects = None
+rinterface = None
+#classes in alphabetical order. methods in logical order :)
+# <2.5 class definition, without () - please test
+class Controller:
+    """ Executes analysis. For the moment, only with gstat functions."""
+    def ImportMap(self, map, column):
+        """ Imports GRASS map as SpatialPointsDataFrame and adds x/y columns to attribute table.
+        Checks for NULL values in the provided column and exits if they are present."""
+        #@NOTE: new way with R - as it doesn't alter original data
+        Rpointmap = robjects.r.readVECT6(map, type =  'point')
+        # checks if x,y columns are present in dataframe. If they do are present, but with different names,
+        # they'll be duplicated.
+        if "x" not in robjects.r.names(Rpointmap):
+            # extract coordinates with S4 method
+            coordinatesPreDF = robjects.r['as.data.frame'](robjects.r.coordinates(Rpointmap))
+            coordinatesDF = robjects.r['data.frame'](x = coordinatesPreDF.rx('coords.x1')[0],
+                                                     y = coordinatesPreDF.rx('coords.x2')[0])
+            # match coordinates with data slot of SpatialPointsDataFrame - maptools function
+            # match is done on row.names
+            Rpointmap = robjects.r.spCbind(Rpointmap, coordinatesDF)
+        # GRASS checks for null values in the chosen column. R can hardly handle column as a variable,
+        # looks for a hardcoded string.
+        cols = grass.vector_columns(map=map, layer=1)
+        nulls = int(grass.parse_command('v.univar',
+                                        map=map,
+                                        column=column,
+                                        type='point',
+                                        parse = (grass.parse_key_val,
+                                                 {'sep':': '}
+                                        )['number of NULL attributes'])
+        if nulls > 0:
+            grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
+        return Rpointmap
+    def CreateGrid(self, inputdata):
+        Region = grass.region()
+        Grid = robjects.r.gmeta2grd()
+        # addition of coordinates columns into dataframe.
+        coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
+        data = robjects.r['data.frame'](x = coordinatesDF.rx('s1')[0],
+                                        y = coordinatesDF.rx('s2')[0],
+                                        k = robjects.r.rep(1, Region['cols']*Region['rows']))
+        GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
+                                                        data,
+                                                        proj4string =  robjects.r.CRS(robjects.r.proj4string(inputdata)))
+        return GridPredicted
+    def ComposeFormula(self, column, isblock, inputdata):
+        if isblock is True:
+            predictor = 'x+y'
+        else:
+            predictor = '1'
+        Formula = robjects.Formula(column + "~" + predictor)
+        #print Formula
+        return Formula
+    def FitVariogram(self, formula, inputdata, sill, nugget, range, model = ''):
+        """ Fits variogram either automagically either specifying all parameters.
+        Returns a list containing data and model variograms. """
+        Variograms = {}
+        if model is '':
+            robjects.r.require('automap')
+            DottedParams = {}
+            #print (nugget.r_repr(), sill, range)
+            DottedParams['fix.values'] = robjects.r.c(nugget, range, sill)
+            VariogramModel = robjects.r.autofitVariogram(formula, inputdata, **DottedParams)
+            #print robjects.r.warnings()
+            Variograms['datavariogram'] = VariogramModel.rx('exp_var')[0]
+            Variograms['variogrammodel'] = VariogramModel.rx('var_model')[0]
+            # obtain the model name. *Too* complicated to get the string instead of level, unlike R does.
+            VariogramAsDF = robjects.r['as.data.frame'](VariogramModel.rx('var_model')[0]) # force conversion
+            ModelDF = VariogramAsDF.rx('model')[0]
+            #Variograms['model'] = robjects.r.levels(ModelDF).subset(ModelDF[1])[0]
+            Variograms['model'] = ModelDF.levels[ModelDF[1] - 1]
+        else:
+            DataVariogram = robjects.r['variogram'](formula, inputdata)
+            VariogramModel = robjects.r['fit.variogram'](DataVariogram,
+                                                         model = robjects.r.vgm(psill = sill,
+        model = model,
+        nugget = nugget,
+        range = range))
+            Variograms['datavariogram'] = DataVariogram
+            Variograms['model'] = model
+        return Variograms
+    def DoKriging(self, formula, inputdata, grid, model, block):
+        DottedParams = {'debug.level': -1} # let krige() print percentage status
+        if block is not '': #@FIXME(anne): but it's a string!! and krige accepts it!!
+            DottedParams['block'] = block
+        #print DottedParams
+        KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
+        return KrigingResult
+    def ExportMap(self, map, column, name, overwrite, command, variograms):
+        # add kriging parameters to raster map history
+        robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
+        grass.run_command('r.support',
+                          map = name,
+                          title = 'Kriging output',
+                          history = 'Issued from command v.krige ' + command)
+        if command.find('model') is -1: # if the command has no model option, add automap chosen model
+                                      map = name,
+                                      history = 'Model chosen by automatic fitting: ' + variograms['model'])
+    def Run(self, input, column, output, package, sill, nugget, range, logger, \
+            overwrite, model, block, output_var, command, **kwargs):
+        """ Wrapper for all functions above. """
+        logger.message(_("Processing %d cells. Computing time raises "
+                         "exponentially with resolution." % grass.region()['cells']))
+        logger.message(_("Importing data..."))
+        if globals()["InputData"] is None:
+            globals()["InputData"] = self.ImportMap(input, column)
+        # and from here over, InputData refers to the global variable
+        #print(robjects.r.slot(InputData, 'data').names)
+        logger.message(_("Data successfully imported."))
+        GridPredicted = self.CreateGrid(InputData)
+        logger.message(_("Fitting variogram..."))
+        isblock = block is not ''
+        logger.message(column)
+        Formula = self.ComposeFormula(column, isblock, InputData)
+        logger.message(Formula)
+        if globals()["Variogram"] is None:
+            globals()["Variogram"] = self.FitVariogram(Formula,
+                                          InputData,
+                                          model = model,
+                                          sill = sill,
+                                          nugget = nugget,
+                                          range = range)
+        logger.message(_("Variogram fitted."))
+        logger.message(_("Kriging..."))
+        KrigingResult = self.DoKriging(Formula, InputData, GridPredicted, Variogram['variogrammodel'], block) # using global ones
+        logger.message(_("Kriging performed."))
+        self.ExportMap(map = KrigingResult,
+                       column='var1.pred',
+                       name = output,
+                       overwrite = overwrite,
+                       command = command,
+                       variograms = Variogram)
+        if output_var is not '':
+                           column='var1.var',
+                           name = output_var,
+def main(argv = None):
+    """ Main. Calls either GUI or CLI, depending on arguments provided. """
+    #@FIXME: solve this double ifelse. the control should not be done twice.
+    controller = Controller()
+    if argv is None:
+        importR()
+        argv = sys.argv[1:] # stripping first item, the full name of this script
+        # wxGUI call
+        import globalvar
+        if not os.getenv("GRASS_WXBUNDLED"):
+            globalvar.CheckForWx()
+        import vkrige as GUI
+        import wx
+        app = wx.App()
+        KrigingFrame = GUI.KrigingModule(parent = None,
+                                         Rinstance = robjects,
+                                         controller = controller)
+        KrigingFrame.Centre()
+        KrigingFrame.Show()
+        app.MainLoop()
+    else:
+        #CLI
+        options, flags = argv
+        #@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
+        if grass.find_file(options['input'], element = 'vector')['fullname'] is '':
+            grass.fatal(_("option: <input>: Vector map not found.")) #TODO cosmetics, insert real map name
+        #@TODO: elaborate input string, if contains mapset or not.. thanks again to Bob for testing on 64bit.
+        # create output map name, if not specified
+        if options['output'] is '':
+            try: # to strip mapset name from fullname. Ugh.
+                options['input'] = options['input'].split("@")[0]
+            except:
+                pass
+            options['output'] = options['input'] + '_kriging'
+        # check for output map with same name. g.parser can't handle this, afaik.
+        if grass.find_file(options['output'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None:
+            grass.fatal(_("option: <output>: Raster map already exists."))
+        if options['output_var'] is not '' and (grass.find_file(options['output_var'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None):
+            grass.fatal(_("option: <output>: Variance raster map already exists."))
+        importR()
+        if options['model'] is '':
+            try:
+                robjects.r.require("automap")
+            except ImportError, e:
+                grass.fatal(_("R package automap is missing, no variogram autofit available."))
+        else:
+            if options['sill'] is '' or options['nugget'] is '' or options['range'] is '':
+                grass.fatal(_("You have specified model, but forgot at least one of sill, nugget and range."))
+        #@TODO: let GRASS remount its commandstring. Until then, keep that 4 lines below.
+        #print grass.write_command(argv)
+        command = ""
+        notnulloptions = {}
+        for k, v in options.items():
+            if v is not '':
+                notnulloptions[k] = v
+        command = command.join("%s=%s " % (k, v) for k, v in notnulloptions.items())
+        #print command
+        # re-cast integers from strings, as parser() cast everything to string.
+        for each in ("sill","nugget","range"):
+            if options[each] is not '':
+                options[each] = int(options[each])
+            else:
+                options[each] = robjects.r('''NA''')
+        #controller = Controller()
+        controller.Run(input = options['input'],
+                       column = options['column'],
+                       output = options['output'],
+                       overwrite = os.getenv("GRASS_OVERWRITE") == 1,
+                       package = options['package'],
+                       model = options['model'],
+                       block = options['block'],
+                       sill = options['sill'],
+                       nugget = options['nugget'],
+                       range = options['range'],
+                       output_var = options['output_var'],
+                       logger = grass)
+def importR():
+    # R
+    # unuseful since rpy2 will complain adequately.
+    # try:
+    #    #@FIXME: in Windows, it launches R terminal
+    #    grass.find_program('R')
+    # except:
+    #    sys.exit(_("R is not installed. Install it and re-run, or modify environment variables."))
+    # rpy2
+    global robjects
+    global rinterface
+    grass.message(_('Loading packages, please wait...'))
+    try:
+        import rpy2.robjects as robjects
+        import rpy2.rinterface as rinterface #to speed up kriging? for plots.
+        haveRpy2 = True
+    except ImportError:
+        print >> sys.stderr, _("Python module 'Rpy2' not found. Please install it and re-run v.krige.") # ok for other OSes?
+        haveRpy2 = False
+        if not haveRpy2:
+            sys.exit(1)
+    # R packages check.
+    # @FIXME: it leaves a Rtmpxxxx folder into the make tempfolder and causes make complain. [markus]
+    for each in ["gstat", "spgrass6", "maptools"]:
+        if not robjects.r.require(each, quietly = True)[0]:
+            sys.exit(_("R package '%s' is missing. Install it and re-run v.krige.") % each)
+if __name__ == '__main__':
+    if len(sys.argv) > 1:
+        sys.exit(main(argv = grass.parser()))
+    else:
+        main()
Added: grass-addons/vector/v.krige/vkrige_gui.py
--- grass-addons/vector/v.krige/vkrige_gui.py	                        (rev 0)
+++ grass-addons/vector/v.krige/vkrige_gui.py	2010-07-28 13:17:26 UTC (rev 42920)
@@ -0,0 +1,499 @@
+MODULE:    v_krige_wxGUI
+PURPOSE:   Dedicated GUI for v.krige script.
+for details.
+#@TODO move here imports related to wxGUI
+### generic imports
+import os, sys
+import time
+import thread
+## i18N
+import gettext
+# GRASS binding
+try:
+    sys.exit(_("No GRASS-python library found."))
+### wxGUI imports
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+import gselect
+import goutput
+import menuform
+from preferences import globalSettings as UserSettings
+#import help
+import wx
+import wx.lib.flatnotebook as FN
+#import wx.lib.plot as plot # for plotting the variogram.
+# global variables
+maxint = 1e6 # instead of sys.maxint, not working with SpinCtrl on 64bit [reported by Bob Moskovitz]
+#@TODO move away functions not regarding the GUI
+class KrigingPanel(wx.Panel):
+    """ Main panel. Contains all widgets except Menus and Statusbar. """
+    def __init__(self, parent, Rinstance, controller, *args, **kwargs):
+        wx.Panel.__init__(self, parent, *args, **kwargs)
+        self.parent = parent
+        self.border = 4
+        #    1. Input data
+        InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Input Data")),
+                                          orient = wx.HORIZONTAL)
+        flexSizer = wx.FlexGridSizer(cols = 3, hgap = 5, vgap = 5)
+        flexSizer.AddGrowableCol(1)
+        flexSizer.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Point dataset:")),
+                      flag = wx.ALIGN_CENTER_VERTICAL)
+        self.InputDataMap = gselect.VectorSelect(parent = self,
+                                                 ftype = 'points')
+        self.InputDataMap.SetFocus()
+        flexSizer.Add(item = self.InputDataMap, flag = wx.ALIGN_CENTER_VERTICAL)
+        RefreshButton = wx.Button(self, id = wx.ID_REFRESH)
+        RefreshButton.Bind(wx.EVT_BUTTON, self.OnButtonRefresh)
+        flexSizer.Add(item = RefreshButton, flag = wx.ALIGN_CENTER_VERTICAL)
+        flexSizer.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Numeric column:")),
+        self.InputDataColumn = gselect.ColumnSelect(self, id = wx.ID_ANY)
+        self.InputDataColumn.SetSelection(0)
+        flexSizer.Add(item = self.InputDataColumn)
+        self.InputDataMap.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnInputDataChanged)
+        InputBoxSizer.Add(item = flexSizer)
+        #    2. Kriging. In book pages one for each R package. Includes variogram fit.
+        KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Kriging")), wx.HORIZONTAL)
+        self.RPackagesBook = FN.FlatNotebook(parent = self, id = wx.ID_ANY,
+                                        style = FN.FNB_BOTTOM |
+                                        FN.FNB_NO_NAV_BUTTONS |
+                                        FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
+        for Rpackage in ["gstat"]: # , "geoR"]: #@TODO: enable it if/when it'll be implemented.
+            self.CreatePage(package = Rpackage, Rinstance = Rinstance, controller = controller)
+        ## Command output. From menuform module, cmdPanel class
+        self.goutput = goutput.GMConsole(parent = self, margin = False,
+                                         pageid = self.RPackagesBook.GetPageCount(),
+					 notebook = self.RPackagesBook)
+        self.goutputId = self.RPackagesBook.GetPageCount()
+        self.outpage = self.RPackagesBook.AddPage(self.goutput, text = _("Command output"))
+        self.RPackagesBook.SetSelection(0)
+        KrigingSizer.Add(self.RPackagesBook, proportion = 1, flag = wx.EXPAND)
+        #    3. Output Parameters.
+        OutputSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Output")), wx.HORIZONTAL)
+        OutputParameters = wx.GridBagSizer(hgap = 5, vgap = 5)
+        OutputParameters.AddGrowableCol(1)
+        OutputParameters.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Name for the output raster map:")),
+                             flag = wx.ALIGN_CENTER_VERTICAL,
+                             pos = (0, 0))
+        self.OutputMapName = gselect.Select(parent = self, id = wx.ID_ANY,
+                                            type = 'raster',
+                                            mapsets = [grass.gisenv()['MAPSET']])
+        OutputParameters.Add(item = self.OutputMapName, flag = wx.EXPAND | wx.ALL,
+                             pos = (0, 1))
+        self.VarianceRasterCheckbox = wx.CheckBox(self, id = wx.ID_ANY, label = _("Export variance map as well: "))
+        self.VarianceRasterCheckbox.SetValue(state = True)
+        OutputParameters.Add(item = self.VarianceRasterCheckbox,
+                             pos = (1, 0))
+        self.OutputVarianceMapName = gselect.Select(parent = self, id = wx.ID_ANY,
+                                            type = 'raster',
+        self.VarianceRasterCheckbox.Bind(wx.EVT_CHECKBOX, self.OnVarianceCBChecked)
+        OutputParameters.Add(item = self.OutputVarianceMapName, flag = wx.EXPAND | wx.ALL,
+                             pos = (1, 1))
+        self.OverwriteCheckBox = wx.CheckBox(self, id = wx.ID_ANY,
+                                             label = _("Allow output files to overwrite existing files"))
+        self.OverwriteCheckBox.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
+        OutputParameters.Add(item = self.OverwriteCheckBox,
+                             pos = (2, 0), span = (1, 2))
+        OutputSizer.Add(OutputParameters, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
+        #    4. Run Button and Quit Button
+        ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
+        HelpButton = wx.Button(self, id = wx.ID_HELP)
+        HelpButton.Bind(wx.EVT_BUTTON, self.OnHelpButton)
+        QuitButton = wx.Button(self, id = wx.ID_EXIT)
+        QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
+        self.RunButton = wx.Button(self, id = wx.ID_ANY, label = _("&Run")) # no stock ID for Run button..
+        self.RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
+        self.RunButton.Enable(False) # disable it on loading the interface, as input map is not set
+        ButtonSizer.Add(HelpButton, proportion = 0, flag = wx.ALIGN_LEFT | wx.ALL, border = self.border)
+        ButtonSizer.Add(QuitButton, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
+        ButtonSizer.Add(self.RunButton, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
+        #    Main Sizer. Add each child sizer as soon as it is ready.
+        Sizer = wx.BoxSizer(wx.VERTICAL)
+        Sizer.Add(InputBoxSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
+        Sizer.Add(KrigingSizer, proportion = 1, flag = wx.EXPAND | wx.ALL, border = self.border)
+        Sizer.Add(OutputSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
+        Sizer.Add(ButtonSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
+        self.SetSizerAndFit(Sizer)
+        # last action of __init__: update imput data list.
+        # it's performed in the few seconds gap while user examines interface before clicking anything.
+        #@TODO: implement a splashcreen IF the maps cause a noticeable lag [markus' suggestion]
+        #needs 6.5+: self.InputDataMap.GetElementList()
+    def CreatePage(self, package, Rinstance, controller):
+        """ Creates the three notebook pages, one for each R package """
+        for package in ["gstat"]:
+            classobj = eval("RBook"+package+"Panel")
+            setattr(self, "RBook"+package+"Panel", (classobj(self,
+                                                             id = wx.ID_ANY,
+                                                             Rinstance = Rinstance,
+                                                             controller = controller)))
+            self.RPackagesBook.AddPage(page = getattr(self, "RBook"+package+"Panel"), text = package)
+    def OnButtonRefresh(self, event):
+        """ Forces refresh of list of available layers. """
+        self.InputDataMap.GetElementList()
+    def OnCloseWindow(self, event):
+        """ Cancel button pressed"""
+        self.parent.Close()
+        event.Skip()
+    def OnHelpButton(self, event):
+        # file = os.path.join(os.getenv("GISBASE"), "docs", "html", "v.krige.html")
+        # file = os.path.join(os.path.curdir, "description.html")
+        # @TODO fix HelpWindow
+        # helpFrame = help.HelpWindow(parent=self, id=wx.ID_ANY,
+        #                            title=_("GRASS - Help page for v.krige"),
+        #                            size=(640, 480),
+        #                            file=file)
+        # helpFrame.Show(True)
+        grass.run_command('g.manual', entry = 'v.krige')
+        event.Skip()
+    def OnInputDataChanged(self, event):
+        """ Refreshes list of columns and fills output map name TextCtrl """
+        MapName = event.GetString()
+        self.InputDataColumn.InsertColumns(vector = MapName,
+                                   layer = 1,
+                                   type = ['integer', 'double precision'])
+        self.RunButton.Enable(self.InputDataColumn.GetSelection() is not -1)
+        self.RBookgstatPanel.PlotButton.Enable(self.InputDataColumn.GetSelection() is not -1)
+        if self.InputDataColumn.GetSelection() is not -1:
+            self.OutputMapName.SetValue(MapName.split("@")[0]+"_kriging")
+            self.OutputVarianceMapName.SetValue(MapName.split("@")[0]+"_kriging_var")
+        else:
+            self.OutputMapName.SetValue('')
+            self.OutputVarianceMapName.SetValue('')
+    def OnRunButton(self,event):
+        """ Execute R analysis. """
+        #@FIXME: send data to main method instead of running it here.
+        #-1: get the selected notebook page. The user shall know that [s]he can modify settings in all
+        # pages, but only the selected one will be executed when Run is pressed.
+        SelectedPanel = self.RPackagesBook.GetCurrentPage()
+        if self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection()) == 'Command output':
+            self.goutput.WriteError("No parameters for running. Please select \"gstat\" tab, check parameters and re-run.")
+            return False # no break invoked by above function
+        # mount command string as it would have been written on CLI
+        command = ["v.krige.py", "input=" + self.InputDataMap.GetValue(),
+                   "column=" + self.InputDataColumn.GetValue(),
+                   "output=" + self.OutputMapName.GetValue(),
+                   "package=" + '%s' % self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection())]
+        if not hasattr(SelectedPanel, 'VariogramCheckBox') or not SelectedPanel.VariogramCheckBox.IsChecked():
+            command.append("model=" + '%s' % SelectedPanel.ModelChoicebox.GetStringSelection().split(" ")[0])
+        for i in ['Sill', 'Nugget', 'Range']:
+            if getattr(SelectedPanel, i+"ChextBox").IsChecked():
+                command.append(i.lower() + "=" + '%s' % getattr(SelectedPanel, i+'Ctrl').GetValue())
+        if SelectedPanel.KrigingRadioBox.GetStringSelection() == "Block kriging":
+            command.append("block=" + '%s' % SelectedPanel.BlockSpinBox.GetValue())
+        if self.OverwriteCheckBox.IsChecked():
+            command.append("--overwrite")
+        if self.VarianceRasterCheckbox.IsChecked():
+            command.append("output_var=" + self.OutputVarianceMapName.GetValue())
+        # give it to the output console
+        #@FIXME: it runs the command as a NEW instance. Reimports data, recalculates variogram fit..
+        #otherwise I can use Controller() and mimic RunCmd behaviour.
+        self.goutput.RunCmd(command, switchPage = True)
+    def OnVarianceCBChecked(self, event):
+        self.OutputVarianceMapName.Enable(event.IsChecked())
+class KrigingModule(wx.Frame):
+    """ Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR. """
+        wx.Frame.__init__(self, parent, *args, **kwargs)
+        # setting properties and all widgettery
+        self.SetTitle(_("Kriging Module"))
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
+        self.log = Log(self)
+        self.CreateStatusBar()
+        self.log.message(_("Ready."))
+        self.Panel = KrigingPanel(self, Rinstance, controller)
+        self.SetMinSize(self.GetBestSize())
+        self.SetSize(self.GetBestSize())
+class Log:
+    """ The log output is redirected to the status bar of the containing frame. """
+    def __init__(self, parent):
+    def message(self, text_string):
+        """ Updates status bar """
+        self.parent.SetStatusText(text_string.strip())
+class RBookPanel(wx.Panel):
+    """ Generic notebook page with shared widgets and empty kriging functions. """
+    def __init__(self, parent, *args, **kwargs):
+        self.VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self,
+                                                             id = wx.ID_ANY,
+                                                             label = _("Variogram fitting")),
+                                                wx.HORIZONTAL)
+        self.LeftSizer = wx.BoxSizer(wx.VERTICAL)
+        self.RightSizer = wx.BoxSizer(wx.VERTICAL)
+        self.ParametersSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
+        self.VariogramSizer.Add(self.LeftSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+        self.VariogramSizer.Add(self.RightSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+        # left side of Variogram fitting. The checkboxes and spinctrls.
+        self.PlotButton = wx.Button(self, id = wx.ID_ANY, label = _("Plot/refresh variogram")) # no stock ID for Run button..
+        self.PlotButton.Bind(wx.EVT_BUTTON, self.OnPlotButton)
+        self.PlotButton.Enable(False) # grey it out until a suitable layer is available
+        self.LeftSizer.Add(self.PlotButton, proportion = 0, flag =  wx.ALL, border = parent.border)
+        self.LeftSizer.Add(self.ParametersSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+        self.ParametersList = ["Sill", "Nugget", "Range"]
+        MinValues = [0,0,1]
+        for n in self.ParametersList:
+            setattr(self, n+"ChextBox", wx.CheckBox(self,
+                                                    id = self.ParametersList.index(n),
+                                                    label = _(n + ":")))
+            setattr(self, n+"Ctrl", (wx.SpinCtrl(self,
+                                                 id = wx.ID_ANY,
+                                                 min = MinValues[self.ParametersList.index(n)],
+                                                 max = maxint)))
+            getattr(self, n+"ChextBox").Bind(wx.EVT_CHECKBOX,
+                                             self.UseValue,
+                                             id = self.ParametersList.index(n))
+            setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
+            self.ParametersSizer.Add(getattr(self, n+"ChextBox"),
+                                     pos = (self.ParametersList.index(n),0))
+            self.ParametersSizer.Add(getattr(self, n+"Ctrl"),
+                                     flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL,
+                                     pos = (self.ParametersList.index(n),1))
+        # right side of the Variogram fitting. The plot area.
+        #Plot = wx.StaticText(self, id= wx.ID_ANY, label = "Check Plot Variogram to interactively fit model.")
+        #PlotPanel = wx.Panel(self)
+        #self.PlotArea = plot.PlotCanvas(PlotPanel)
+        #self.PlotArea.SetInitialSize(size = (250,250))
+        #self.RightSizer.Add(PlotPanel, proportion=0, flag= wx.EXPAND|wx.ALL, border=parent.border)
+        self.KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self,
+                                                             id = wx.ID_ANY,
+                                                             label = _("Kriging techniques")),
+                                                wx.VERTICAL)
+        KrigingList = ["Ordinary kriging", "Block kriging"]#, "Universal kriging"] #@FIXME: i18n on the list?
+        self.KrigingRadioBox = wx.RadioBox(self,
+                                           id = wx.ID_ANY,
+                                           choices = KrigingList,
+                                           majorDimension = 1,
+                                           style = wx.RA_SPECIFY_COLS)
+        self.KrigingRadioBox.Bind(wx.EVT_RADIOBOX, self.HideBlockOptions)
+        self.KrigingSizer.Add(self.KrigingRadioBox, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+        # block kriging parameters. Size.
+        BlockSizer = wx.BoxSizer(wx.HORIZONTAL)
+        BlockLabel = wx.StaticText(self, id = wx.ID_ANY, label = _("Block size:"))
+        self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min = 1, max = maxint)
+        self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging so block param is disabled
+        BlockSizer.Add(BlockLabel, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
+        BlockSizer.Add(self.BlockSpinBox, flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
+        self.KrigingSizer.Add(BlockSizer, flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
+        self.Sizer = wx.BoxSizer(wx.VERTICAL)
+        self.Sizer.Add(self.VariogramSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+        self.Sizer.Add(self.KrigingSizer,  proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+    def HideBlockOptions(self, event):
+        self.BlockSpinBox.Enable(event.GetInt() == 1)
+    def OnPlotButton(self,event):
+        """ Plots variogram with current options. """
+        pass
+    def UseValue(self, event):
+        """ Enables/Disables the SpinCtrl in respect of the checkbox. """
+        n = self.ParametersList[event.GetId()]
+        getattr(self, n+"Ctrl").Enable(event.IsChecked())
+class RBookgstatPanel(RBookPanel):
+    """ Subclass of RBookPanel, with specific gstat options and kriging functions. """
+        RBookPanel.__init__(self, parent, *args, **kwargs)
+        # assigns Rinstance, that comes from the GUI call of v.krige.py.
+        robjects = Rinstance
+        self.controller = controller
+        if robjects.r.require('automap')[0]:
+            self.VariogramCheckBox = wx.CheckBox(self, id = wx.ID_ANY, label = _("Auto-fit variogram"))
+            self.LeftSizer.Insert(0,
+                                  self.VariogramCheckBox,
+                                  proportion = 0,
+                                  flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
+                                  border = 4)
+            self.SetSizerAndFit(self.Sizer)
+            self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
+            self.VariogramCheckBox.SetValue(state = True) # check it by default
+        ModelFactor = robjects.r.vgm().rx('long')
+        ModelList = robjects.r.levels(ModelFactor[0])
+        #@FIXME: no other way to let the Python pick it up..
+        # and this is te wrong place where to load this list. should be at the very beginning.
+        self.ModelChoicebox = wx.Choice(self, id = wx.ID_ANY, choices = ModelList)
+        # disable model parameters' widgets by default
+        for n in ["Sill", "Nugget", "Range"]:
+            getattr(self, n+"Ctrl").Enable(False)
+        self.ModelChoicebox.Enable(False)
+        VariogramSubSizer = wx.BoxSizer(wx.HORIZONTAL)
+        VariogramSubSizer.Add(item = wx.StaticText(self,
+                                                 id =  wx.ID_ANY,
+                                                 label = _("Model: ")),
+                              flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL,
+                              border = 4)
+        VariogramSubSizer.Add(item = self.ModelChoicebox,
+                              border = 4)
+        self.LeftSizer.Insert(2, item = VariogramSubSizer)
+    def HideOptions(self, event):
+        self.ModelChoicebox.Enable(not event.IsChecked())
+            if not event.IsChecked():
+                getattr(self, n+"Ctrl").Enable(True)
+                getattr(self, n+ "ChextBox").SetValue(True)
+                getattr(self, n+ "ChextBox").Enable(False) # grey it out keeping it checked.. improvable
+            else:
+                getattr(self, n+ "ChextBox").SetValue(False)
+                getattr(self, n+ "ChextBox").Enable(True)
+        #@FIXME: was for n in self.ParametersSizer.GetChildren(): n.Enable(False) but doesn't work
+        ## BIG WARNING: smell of code duplication. Fix this asap. emminchia!
+        #controller = Controller() # sed, if needed,
+        #controller = self.controller
+        map = self.parent.InputDataMap.GetValue()
+        column = self.parent.InputDataColumn.GetValue()
+        # import data or pick them up
+            globals()["InputData"] = controller.ImportMap(map = map,
+                                                          column = column)
+        # fit the variogram or pick it up
+        Formula = controller.ComposeFormula(column = column,
+                                            isblock = self.KrigingRadioBox.GetStringSelection() == "Block kriging",
+                                            inputdata = globals()['InputData'])
+        #if globals()["Variogram"] is None:
+        if hasattr(self, 'VariogramCheckBox') and self.VariogramCheckBox.IsChecked():
+            self.model = ''
+            for each in ("Sill","Nugget","Range"):
+                if getattr(self, each+'ChextBox').IsChecked():
+                    setattr(self, each.lower(), getattr(self, each+"Ctrl").GetValue())
+                else:
+                    setattr(self, each.lower(), robjects.r('''NA'''))
+        else:
+            self.model = self.ModelChoicebox.GetStringSelection().split(" ")[0]
+                if getattr(self, each+'ChextBox').IsChecked(): #@FIXME will be removed when chextboxes will be frozen
+        globals()["Variogram"] = controller.FitVariogram(Formula,
+                                                         InputData,
+                                                         model = self.model,
+                                                         sill = self.sill,
+                                                         nugget = self.nugget,
+                                                         range = self.range)
+        # use R plot function, in a separate window.
+        thread.start_new_thread(self.plot, ())
+    def plot(self):
+        #robjects.r.X11()
+        #robjects.r.png("variogram.png")
+        textplot = robjects.r.plot(Variogram['datavariogram'], Variogram['variogrammodel'])
+        print textplot
+        self.refresh()
+        #robjects.r['dev.off']()
+    def refresh(self):
+        while True:
+            rinterface.process_revents()
+            time.sleep(0.1)
+class RBookgeoRPanel(RBookPanel):
+    """ Subclass of RBookPanel, with specific geoR options and kriging functions. """
+        #@TODO: change these two lines as soon as geoR f(x)s are integrated.
+        for n in self.GetChildren():
+            n.Hide()
+        self.Sizer.Add(wx.StaticText(self, id = wx.ID_ANY, label = _("Work in progress! No functionality provided.")))
