[GRASS-SVN] r42926 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 28 17:43:58 EDT 2010
Author: martinl
Date: 2010-07-28 21:43:58 +0000 (Wed, 28 Jul 2010)
New Revision: 42926
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
wxGUI: various changes required by v.krige from AddOns (patch provided my
Markus Neteler)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2010-07-28 18:23:24 UTC (rev 42925)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/goutput.py 2010-07-28 21:43:58 UTC (rev 42926)
@@ -113,6 +113,7 @@
GIS Manager command line.
def __init__(self, parent, id=wx.ID_ANY, margin=False, pageid=0,
+ notebook = None,
pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.TAB_TRAVERSAL | wx.FULL_REPAINT_ON_RESIZE):
wx.Panel.__init__(self, parent, id, pos, size, style)
@@ -121,6 +122,8 @@
# initialize variables
self.Map = None
self.parent = parent # GMFrame | CmdPanel
+ if notebook:
+ self.parent.notebook = notebook
self.lineWidth = 80
self.pageid = pageid
# remember position of line begining (used for '\r')
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2010-07-28 18:23:24 UTC (rev 42925)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2010-07-28 21:43:58 UTC (rev 42926)
@@ -5,6 +5,7 @@
Classes:
- Select
+ - VectorSelect
- TreeCrtlComboPopup
- VectorDBInfo
- LayerSelect
@@ -35,8 +36,8 @@
from preferences import globalSettings as UserSettings
class Select(wx.combo.ComboCtrl):
- def __init__(self, parent, id, size,
- type=None, multiple=False, mapsets=None, exceptOf=[]):
+ def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
+ type = None, multiple = False, mapsets = None, exceptOf = []):
Custom control to create a ComboBox with a tree control
to display and select GIS elements within acessible mapsets.
@@ -62,6 +63,32 @@
self.tcp.SetData(type = type, mapsets = mapsets,
exceptOf = exceptOf)
+class VectorSelect(Select):
+ def __init__(self, parent, ftype, **kwargs):
+ """!Custom to create a ComboBox with a tree control to display and
+ select vector maps. Control allows to filter vector maps. If you
+ don't need this feature use Select class instead
+ @ftype filter vector maps based on feature type
+ Select.__init__(self, parent = parent, id = wx.ID_ANY,
+ type = 'vector', **kwargs)
+ self.ftype = ftype
+ # remove vector maps which do not contain given feature type
+ self.tcp.SetFilter(self._isElement)
+ def _isElement(self, vectorName):
+ """!Check if element should be filtered out"""
+ try:
+ if int(grass.vector_info_topo(vectorName)[self.ftype]) < 1:
+ return False
+ except KeyError:
+ return False
+ return True
class TreeCtrlComboPopup(wx.combo.ComboPopup):
Create a tree ComboBox for selecting maps and other GIS elements
@@ -77,6 +104,8 @@
self.mapsets = []
self.exceptOf = []
+ self.SetFilter(None)
def Create(self, parent):
self.seltree = wx.TreeCtrl(parent, style=wx.TR_HIDE_ROOT
|wx.TR_HAS_BUTTONS
@@ -118,6 +147,10 @@
return str
+ def SetFilter(self, filter):
+ """!Set filter for GIS elements, see e.g. VectorSelect"""
+ self.filterElements = filter
def OnPopup(self):
"""Limited only for first selected"""
# update list
@@ -603,11 +636,13 @@
if vector:
self.InsertColumns(vector, layer)
- def InsertColumns(self, vector, layer, dbInfo = None):
+ def InsertColumns(self, vector, layer, type = None, dbInfo = None):
"""!Insert columns for a vector attribute table into the columns combobox
@param vector vector name
@param layer vector layer number
+ @param type only columns of given type (given as list)
+ @param dbInfo reference to VectorDbInfo instance or None
if not dbInfo:
dbInfo = VectorDBInfo(vector)
@@ -618,6 +653,10 @@
columns = len(columnchoices.keys()) * ['']
for key, val in columnchoices.iteritems():
columns[val['index']] = key
+ if type: # only selected column types
+ for key, value in columnchoices.iteritems():
+ if value['type'] not in type:
+ columns.remove(key)
except (KeyError, ValueError):
columns = list()
