[GRASS-SVN] r42947 - in grass/branches/develbranch_6/scripts:
m.proj v.in.garmin v.in.gpsbabel
svn_grass at osgeo.org
Thu Jul 29 11:54:50 EDT 2010
Author: hamish
Date: 2010-07-29 15:54:50 +0000 (Thu, 29 Jul 2010)
New Revision: 42947
grass/branches/develbranch_6/scripts/m.proj/m.proj
grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
quote +proj terms for cs2cs in case +nadgrids has a space in the path name
Modified: grass/branches/develbranch_6/scripts/m.proj/m.proj
--- grass/branches/develbranch_6/scripts/m.proj/m.proj 2010-07-29 15:24:48 UTC (rev 42946)
+++ grass/branches/develbranch_6/scripts/m.proj/m.proj 2010-07-29 15:54:50 UTC (rev 42947)
@@ -157,7 +157,13 @@
g.message -v "Assuming LL WGS84 as input, current projection as output."
fi
if [ $GIS_FLAG_O -eq 1 ] ; then
- IN_PROJ="`g.proj -jf`"
+ IN_PROJ=`g.proj -j | (
+ IN_PROJ=
+ while read line ; do
+ IN_PROJ="$IN_PROJ '$line'"
+ done
+ echo "$IN_PROJ"
fi
if [ -n "$GIS_OPT_PROJ_IN" ] ; then
IN_PROJ="$GIS_OPT_PROJ_IN"
@@ -173,7 +179,13 @@
g.message -v "Assuming current projection as input, LL WGS84 as output."
fi
if [ $GIS_FLAG_I -eq 1 ] ; then
- OUT_PROJ="`g.proj -jf`"
+ OUT_PROJ=`g.proj -j | (
+ OUT_PROJ=
+ OUT_PROJ="$OUT_PROJ '$line'"
+ done
+ echo "$OUT_PROJ"
fi
if [ -n "$GIS_OPT_PROJ_OUT" ] ; then
OUT_PROJ="$GIS_OPT_PROJ_OUT"
Modified: grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin
--- grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin 2010-07-29 15:24:48 UTC (rev 42946)
+++ grass/branches/develbranch_6/scripts/v.in.garmin/v.in.garmin 2010-07-29 15:54:50 UTC (rev 42947)
@@ -241,7 +241,15 @@
#### set up projection info
IN_PROJ="+proj=longlat +datum=WGS84"
-OUT_PROJ="`g.proj -jf`"
+OUT_PROJ=`g.proj -j | (
+ OUT_PROJ=
+ done
+ echo "$OUT_PROJ"
PROJ_TYPE=`g.region -p | grep 'projection' | cut -f2 -d" "`
if [ $PROJ_TYPE -eq 0 ] && [ $KEEP_WGS84 -ne 1 ] ; then
g.message -e "Cannot project to a XY location."
Modified: grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel
--- grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel 2010-07-29 15:24:48 UTC (rev 42946)
+++ grass/branches/develbranch_6/scripts/v.in.gpsbabel/v.in.gpsbabel 2010-07-29 15:54:50 UTC (rev 42947)
@@ -223,7 +223,15 @@
else
fi
+ OUT_PROJ=
+ done
+ echo "$OUT_PROJ"
