[GRASS-SVN] r42951 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules
Thu Jul 29 15:34:56 EDT 2010
Author: martinl
Date: 2010-07-29 19:34:56 +0000 (Thu, 29 Jul 2010)
New Revision: 42951
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: clean up gcmd.<error message> classes
(merge r42950 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -93,8 +93,9 @@
         try:
             keyColumn = self.LoadData(layer)
-        except gcmd.DBMError, e:
-            e.Show()
+        except gcmd.GException, e:
+            GError(parent = self,
+                   message = e)
             return
@@ -150,10 +151,9 @@
         try:
             self.columns = self.mapDBInfo.tables[tableName]
         except KeyError:
-            raise gcmd.DBMError(message=_("Attribute table <%s> not found. "
-                                          "For creating the table switch to "
-                                          "'Manage layers' tab.") % tableName,
-                                parent=self.parent)
+            raise gcmd.GException(_("Attribute table <%s> not found. "
+                                    "For creating the table switch to "
+                                    "'Manage layers' tab.") % tableName)
         if not columns:
             columns = self.mapDBInfo.GetColumns(tableName)
@@ -303,13 +303,13 @@
                     cat = self.columns[columns[j]]['ctype'] (value)
                 except ValueError, e:
                     cat = -1
-                    gcmd.GMessage(parent = self,
-                                  message=_("Error loading attribute data. "
-                                            "Record number: %(rec)d. Unable to convert value '%(val)s' in "
-                                            "key column (%(key)s) to integer.\n\n"
-                                            "Details: %(detail)s") % \
-                                      { 'rec' : i + 1, 'val' : value,
-                                        'key' : keyColumn, 'detail' : e})
+                    gcmd.GError(parent = self,
+                                message=_("Error loading attribute data. "
+                                          "Record number: %(rec)d. Unable to convert value '%(val)s' in "
+                                          "key column (%(key)s) to integer.\n\n"
+                                          "Details: %(detail)s") % \
+                                    { 'rec' : i + 1, 'val' : value,
+                                      'key' : keyColumn, 'detail' : e})
             j += 1
         self.itemIndexMap.append(i)
@@ -1927,10 +1927,9 @@
                     keyColumn = listWin.LoadData(self.layer, where=whereCol + whereVal)
                 else:
                     keyColumn = listWin.LoadData(self.layer)
-            except gcmd.CmdError, e:
-                wx.MessageBox(parent=self,
-                              message=_("Loading attribute data failed.\n\n%s") % e.message,
-                              caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+                            message = _("Loading attribute data failed.\n\n%s") % e.value)
                 self.FindWindowById(self.layerPage[self.layer]['where']).SetValue('')
         else:
             # advanced sql statement
@@ -1952,10 +1951,9 @@
                 try:
                     keyColumn = listWin.LoadData(self.layer, columns=cols,
                                                  where=where, sql=sql)
                     win.SetValue("SELECT * FROM %s" % self.mapDBInfo.layers[self.layer]['table'])
         # sort by key column
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -4,13 +4,10 @@
 @brief wxGUI command interface
 Classes:
+ - GError
+ - GWarning
+ - GMessage
  - GException
- - GStdError
- - CmdError
- - SettingsError
- - DigitError
- - DBMError
- - NvizError
  - Popen (from http://aspn.activestate.com/ASPN/Cookbook/Python/Recipe/440554)
  - Command
  - CommandThread
@@ -60,117 +57,57 @@
 import utils
 from debug import Debug as Debug
-class GMessage:
-    def __init__(self, parent, message, msgType = 'error'):
-        if msgType == 'error':
-            caption = _('Error')
-            style = wx.OK | wx.ICON_ERROR | wx.CENTRE
-        elif msgType == 'info':
-            caption = _('Message')
-            style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE
-        elif msgType == 'warning':
-            caption = _('Warning')
-            style = wx.OK | wx.ICON_WARNING | wx.CENTRE
+class GError:
+    def __init__(self, message, parent = None):
+        caption = _('Error')
+        style = wx.OK | wx.ICON_ERROR | wx.CENTRE
-        if msgType != 'error':
+        exc_type, exc_value, exc_traceback = sys.exc_info()
+        if exc_traceback:
+            exception = traceback.format_exc()
+            reason = exception.splitlines()[-2].split(':', 1)[-1].strip()
+        if Debug.get_level() > 0 and exc_traceback:
+            sys.stderr.write(exception)
+        if exc_traceback:
             wx.MessageBox(parent = parent,
-                          message = message,
+                          message = message + '\n\n%s: %s\n\n%s' % \
+                              (_('Reason'),
+                               reason, exception),
                           caption = caption,
                           style = style)
         else:
-            exc_type, exc_value, exc_traceback = sys.exc_info()
-            if exc_traceback:
-                exception = traceback.format_exc()
-                reason = exception.splitlines()[-2].split(':', 1)[-1].strip()
-            if Debug.get_level() > 0 and exc_traceback:
-                sys.stderr.write(exception)
-            if exc_traceback:
-                wx.MessageBox(parent = parent,
-                              message = message + '\n\n%s: %s\n\n%s' % \
-                                  (_('Reason'),
-                                   reason, exception),
-                              caption = caption,
-                              style = style)
-            else:
-                              style = style)
-class GError(Exception):
+            wx.MessageBox(parent = parent,
+                          message = message,
+                          caption = caption,
+                          style = style)
+class GWarning:
+        caption = _('Warning')
+        style = wx.OK | wx.ICON_WARNING | wx.CENTRE
+                      style = style)
+class GMessage:
+        caption = _('Message')
+        style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE
+                      style = style)
+class GException(Exception):
     def __init__(self, value):
         self.value = value
     def __str__(self):
         return str(self.value)
-class GException(Exception):
-    """!Generic exception"""
-    def __init__(self, message, title = _("Error"), parent = None):
-        self.msg = message
-        self.parent = parent
-        self.title = title
-    def Show(self):
-        GMessage(parent  = self.parent,
-                 message = self.msg,
-                 msgType = 'error')
-    def GetMessage(self):
-        return self.msg
-    def __str__(self):
-        self.Show()
-        return ''
-class GStdError(GException):
-        GException.__init__(self, message, title=title, parent=parent)
-class CmdError(GException):
-    """!Exception used for GRASS commands.
-    See Command class (command exits with EXIT_FAILURE,
-    G_fatal_error() is called)."""
-    def __init__(self, cmd, message, parent=None):
-                            title=_("Error in command execution '%s'" % cmd),
-                            parent=parent)
-class SettingsError(GException):
-    """!Exception used for GRASS settings, see
-    gui_modules/preferences.py."""
-    def __init__(self, message, parent=None):
-                            title=_("Preferences error"),
-                            parent=parent)
-class DigitError(GException):
-    """!Exception raised during digitization session"""
-                            title=_("Vector digitizer error"),
-                            parent=parent)
-class DBMError(GException):
-    """!Attribute Table Manager exception class"""
-                            title=_("Attribute table manager error"),
-                            parent=parent)
-class NvizError(GException):
-    """!Nviz exception class"""
-                            title=_("Nviz error"),
-                            parent=parent)
 class Popen(subprocess.Popen):
     """!Subclass subprocess.Popen"""
     def __init__(self, *args, **kwargs):
@@ -361,7 +298,6 @@
     def __init__ (self, cmd, stdin=None,
                   verbose=None, wait=True, rerr=False,
                   stdout=None, stderr=None):
         Debug.msg(1, "gcmd.Command(): %s" % ' '.join(cmd))
         self.cmd = cmd
         self.stderr = stderr
@@ -404,14 +340,13 @@
                            (' '.join(cmd), wait, self.returncode, self.cmdThread.isAlive()))
             if rerr is not None and self.returncode != 0:
                 if rerr is False: # GUI dialog
-                    raise CmdError(cmd=self.cmd,
-                                   message="%s '%s'%s%s%s %s%s" %
-                                   (_("Execution failed:"),
-                                    ' '.join(self.cmd),
-                                    os.linesep, os.linesep,
-                                    _("Details:"),
-                                    os.linesep,
-                                    _("Error: ") + self.__GetError()))
+                    raise GException("%s '%s'%s%s%s %s%s" % \
+                                         (_("Execution failed:"),
+                                          ' '.join(self.cmd),
+                                          os.linesep, os.linesep,
+                                          _("Details:"),
+                                          os.linesep,
+                                          _("Error: ") + self.__GetError()))
                 elif rerr == sys.stderr: # redirect message to sys
                     stderr.write("Execution failed: '%s'" % (' '.join(self.cmd)))
                     stderr.write("%sDetails:%s%s" % (os.linesep,
@@ -632,12 +567,10 @@
     ret = ps.returncode
-    if ret != 0 and parent:
-        e = CmdError(cmd = prog,
-                     message = stderr,
-                     parent = parent)
-        e.Show()
+    if ret != 0 and parent:
+        GError(parent = parent,
+               message = stderr)
     if not read:
         if not getErrorMsg:
             return ret
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -287,10 +287,11 @@
             gcmd.RunCommand(prog = cmd[0],
                             overwrite = overwrite,
                             **cmd[1])
-            e.Show()
+                        message = e)
             return None
         # create attribute table
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -71,7 +71,7 @@
 import goutput
 import gselect
-from gcmd         import GMessage, GError
+from gcmd         import GMessage, GException, GWarning, GError
 from gdialogs     import ElementDialog, GetImageHandlers
 from preferences  import PreferencesBaseDialog, globalSettings as UserSettings
 from ghelp        import SearchModuleWindow
@@ -227,7 +227,7 @@
         try:
             gxmXml = ProcessModelFile(etree.parse(filename))
         except StandardError, e:
-            raise GError(e)
+            raise GException(e)
         if self.canvas:
             win = self.canvas.parent
@@ -689,8 +689,7 @@
         if not rast and not vect and not rast3d:
-                     message = _('Nothing to delete.'),
-                     msgType = 'info')
+                     message = _('Nothing to delete.'))
             return
         dlg = wx.MessageDialog(parent = self,
@@ -863,8 +862,7 @@
         """!Run entire model"""
         if self.model.GetNumItems() < 1:
-                     message = _('Model is empty. Nothing to run.'),
-                     msgType = 'info')
+                     message = _('Model is empty. Nothing to run.'))
             return
         # validation
@@ -894,8 +892,8 @@
             err = dlg.GetErrors()
             if err:
-                GMessage(parent = self,
-                         message = unicode('\n'.join(err)))
+                       message = unicode('\n'.join(err)))
                 return
         self.goutput.cmdThread.SetId(-1)
@@ -950,20 +948,17 @@
         """!Validate entire model"""
-                     message = _('Model is empty. Nothing to validate.'),
-                     msgType = 'info')
+                     message = _('Model is empty. Nothing to validate.'))
             return
         errList = self._validateModel()
         if errList:
-                     message = _('Model is not valid.\n\n%s') % '\n'.join(errList),
-                     msgType = 'warning')
+            GWarning(parent = self,
+                     message = _('Model is not valid.\n\n%s') % '\n'.join(errList))
         else:
-                     message = _('Model is valid.'),
-                     msgType = 'info')
+                     message = _('Model is valid.'))
     def OnExportImage(self, event):
         """!Export model to image (default image)
@@ -1452,10 +1447,10 @@
         try:
             self.model.LoadModel(filename)
-        except GError, e:
-                     message = _("Reading model file <%s> failed.\n"
-                                 "Invalid file, unable to parse XML document.") % filename)
+        except GException, e:
+                   message = _("Reading model file <%s> failed.\n"
+                               "Invalid file, unable to parse XML document.") % filename)
         self.modelFile = filename
         self.SetTitle(self.baseTitle + " - " +  os.path.basename(self.modelFile))
@@ -1514,8 +1509,8 @@
         try:
             WriteModelFile(fd = tmpfile, model = self.model)
         except StandardError:
-                     message = _("Writing current settings to model file failed."))
+                   message = _("Writing current settings to model file failed."))
             return False
         try:
@@ -2403,15 +2398,15 @@
         cmd = self.GetCmd()
         if len(cmd) < 1:
-                     message = _("Command not defined.\n\n"
-                                 "Unable to add new action to the model."))
+                   message = _("Command not defined.\n\n"
+                               "Unable to add new action to the model."))
             return
         if cmd[0] not in globalvar.grassCmd['all']:
-                     message = _("'%s' is not a GRASS module.\n\n"
-                                 "Unable to add new action to the model.") % cmd[0])
+                   message = _("'%s' is not a GRASS module.\n\n"
+                               "Unable to add new action to the model.") % cmd[0])
             return
         self.EndModal(wx.ID_OK)
@@ -3624,8 +3619,8 @@
         self.name.SetFocus()
         if msg:
-                     message = msg)
+                   message = msg)
         else:
             self.type.SetSelection(0)
             self.value.SetValue('')
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -47,7 +47,7 @@
 from icon import Icons as Icons
 from preferences import globalSettings as UserSettings
 from vdigit import haveVDigit
+from gcmd import GError
 try:
     import subprocess
 except:
@@ -1315,8 +1315,8 @@
             mapname = utils.GetLayerNameFromCmd(dcmd, layerType=mapLayer.type,
                                                 fullyQualified=True)
             if not mapname:
-                GMessage(parent=self,
-                         message=_("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd))
+                GError(parent=self,
+                       message=_("Map <%s> not found.") % utils.GetLayerNameFromCmd(dcmd))
                 return
             self.SetItemText(layer, mapname + ' (opacity: ' + str(opacity) + '%)')
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -1099,8 +1099,7 @@
             img = self.MapWindow.img
             if not img:
-                              message = _("Nothing to render (empty map). Operation canceled."),
-                              msgType = 'info')
+                              message = _("Nothing to render (empty map). Operation canceled."))
                 return
             filetype, ltype = gdialogs.GetImageHandlers(img)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mcalc_builder.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -393,15 +393,13 @@
         name = self.newmaptxt.GetValue().strip()
         if not name:
-                          message = _("You must enter the name of a new map to create"),
-                          msgType = 'info')
+                        message = _("You must enter the name of a new map to create"))
             return
         if not self.text_mcalc.GetValue().strip():
-                          message = _("You must enter a mapcalc statement to create a new map"),
-                          msgType = 'info')
+                        message = _("You must enter a mapcalc statement to create a new map"))
             return
         mctxt = self.text_mcalc.GetValue().strip().replace("\n"," ")
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -413,8 +413,9 @@
                         self.LoadRaster(item)
                     elif type ==  '3d-raster':
                         self.LoadRaster3d(item)
-                except gcmd.NvizError, e:
-                    print >> sys.stderr, "Nviz:" + e.message
+                           message = e)
                 try:
                     if type ==  'vector':
@@ -425,8 +426,9 @@
                                 if data['vector'][v]:
                                     vecType.append(v)
                         self.LoadVector(item, vecType)
+                           message = e)
                 self.init = False
         stop = time.time()
@@ -462,8 +464,9 @@
                         self.UnloadVector(layer, vecType)
                     self.UpdateView(None)
+                                message = e)
                 self.lmgr.nviz.UpdateSettings()
@@ -1045,8 +1048,7 @@
                 error = _("Unable to set data layer properties (id = %d)") % id
             if error:
-                raise gcmd.NvizError(parent = self.parent,
-                                     message = _("Setting data layer properties failed.\n\n%s") % error)
+                raise gcmd.GException(_("Setting data layer properties failed.\n\n%s") % error)
             for prop in ('size', 'width', 'marker', 'color'):
                 if data[prop].has_key('update'):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -583,8 +583,8 @@
         self.userSettings = copy.deepcopy(self.defaultSettings)
         try:
             self.ReadSettingsFile()
-        except gcmd.SettingsError, e:
-            print >> sys.stderr, e.message
+            print >> sys.stderr, e.value
         # internal settings (based on user settings)
@@ -766,11 +766,11 @@
                                 file.write('%s' % self.sep)
                     file.write(os.linesep)
         except IOError, e:
-            raise gcmd.SettingsError(message=e)
+            raise gcmd.GException(e)
-            raise gcmd.SettingsError(message=_('Writing settings to file <%(file)s> failed.'
-                                               '\n\nDetails: %(detail)s') % { 'file' : filePath,
-        'detail' : e })
+            raise gcmd.GException(_('Writing settings to file <%(file)s> failed.'
+                                    '\n\nDetails: %(detail)s') % { 'file' : filePath,
+        'detail' : e })
         file.close()
@@ -837,8 +837,6 @@
                     return settings[group][key][subkey]
         except KeyError:
-            #raise gcmd.SettingsError("%s %s:%s:%s." % (_("Unable to get value"),
-            #                                           group, key, subkey))
             print >> sys.stderr, "Settings: unable to get value '%s:%s:%s'\n" % \
                 (group, key, subkey)
@@ -871,7 +869,7 @@
                 else:
                     settings[group][key][subkey] = value
         except KeyError:
-            raise gcmd.SettingsError("%s '%s:%s:%s'" % (_("Unable to set "), group, key, subkey))
+            raise gcmd.GException("%s '%s:%s:%s'" % (_("Unable to set "), group, key, subkey))
     def Append(self, dict, group, key, subkey, value):
         """!Set value of key/subkey
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -437,8 +437,9 @@
                     datalist.append((dist,elev))
             return datalist
-            print e
+                        message = e)
             return None
     def OnCreateProfile(self, event):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -41,6 +41,7 @@
 import globalvar
 import utils
 import gcmd
+from gcmd import GException
@@ -131,8 +132,8 @@
                       'overlay')
         if self.type not in layertypes:
-            raise gcmd.GStdError(_("<%(name)s>: layer type <%(type)s> is not supported yet.") % \
-                                     {'type' : self.type, 'name' : self.name})
+            raise gcmd.GException(_("<%(name)s>: layer type <%(type)s> is not supported yet.") % \
+                                      {'type' : self.type, 'name' : self.name})
         # start monitor
@@ -188,7 +189,7 @@
                 self.mapfile = None
                 self.maskfile = None
             # clean up after problems
             try:
@@ -278,7 +279,7 @@
                         'shaded', 'rgb', 'his', 'rastarrow', 'rastnum',
                         'thememap', 'themechart', 'grid', 'labels',
                         'geodesic','rhumb'):
-            raise gcmd.GStdError(_("Unsupported map layer type '%s'") % str(type))
+            raise gcmd.GException(_("Unsupported map layer type '%s'") % str(type))
         self.type = type
@@ -630,18 +631,17 @@
                               read = True,
                               **cmd)
         if not ret:
-            e  = gcmd.CmdError(cmd = 'g.region', message = '')
             if rast:
-                e.message = _("Unable to zoom to raster map <%s>.") % rast[0] + \
-                '%s%s' % (os.linesep, os.linesep) + e.message
+                message = _("Unable to zoom to raster map <%s>.") % rast[0] + \
+                    '%s%s' % (os.linesep, os.linesep) + e.message
             elif vect:
-                e.message = _("Unable to zoom to vector map <%s>.") % vect[0] + \
+                message = _("Unable to zoom to vector map <%s>.") % vect[0] + \
             else:
-                e.message = _("Unable to get current geographic extent. "
-                              "Force quiting wxGUI. Please run manually g.region to "
-                              "fix the problem.")
-            e.Show()
+                message = _("Unable to get current geographic extent. "
+                            "Force quiting wxGUI. Please run manually g.region to "
+                            "fix the problem.")
+            GError(message)
             return self.region
         for reg in ret.splitlines():
@@ -968,7 +968,7 @@
         Debug.msg (3, "Map.AddLayer(): layer=%s" % layer.name)
         if l_render:
             if not layer.Render():
-                raise gcmd.GStdError(_("Unable to render map layer <%s>.") % (name))
+                raise gcmd.GException(_("Unable to render map layer <%s>.") % (name))
         return layer
@@ -1050,8 +1050,8 @@
             layer.SetOpacity(kargs['opacity'])
         if render and not layer.Render():
-            raise gcmd.GException(_("Unable to render map layer <%s>.") %
-                                  (name))
+            raise GException(_("Unable to render map layer <%s>.") %
+                             (name))
         return layer
@@ -1159,8 +1159,8 @@
         self.overlays.append(overlay)
         if l_render and command != '' and not overlay.Render():
-            raise gcmd.GException(_("Unable render overlay <%s>.") %
-                                  (name))
+            raise GException(_("Unable render overlay <%s>.") %
+                             (name))
         return self.overlays[-1]
@@ -1198,8 +1198,8 @@
             overlay.SetOpacity(kargs['opacity'])
         if render and command != [] and not overlay.Render():
-            raise gcmd.GException(_("Unable render overlay <%s>") %
-                                  (name))
+            raise GException(_("Unable render overlay <%s>") %
+                             (name))
         return overlay
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -1157,12 +1157,16 @@
         self.mapLayer = mapLayer
         # open vector map
-        if not self.parent.MapWindow.CheckPseudoDC():
-            # gcmd.GMessage(parent = self.parent,
-            #              message = _("Unable to initialize display driver of vector "
-            #                          "digitizer. See 'Command output' for details."))
+        try:
+            if not self.parent.MapWindow.CheckPseudoDC():
+                raise gcmd.GException(_("Unable to initialize display driver of vector "
+                                        "digitizer. See 'Command output' for details."))
+            self.parent.digit.SetMapName(mapLayer.GetName())
             self.mapLayer = None
             self.StopEditing()
+            GError(parent = self.parent,
+                   message = e)
             return False
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -111,26 +111,23 @@
         try:
             ret = self.driver.Reset(self.map)
-            raise gcmd.DigitError(parent=self.mapWindow.parent,
-                                  message="%s %s (%s)" % (_("Unable to initialize display driver of vector "
-                                                            "digitizer. See 'Command output' for details.\n\n"
-                                                            "Details:"), e, errorMsg))
+                              "digitizer. See 'Command output' for details.\n\n"
+                              "Details: ") + e)
         if map and ret == -1:
-                                  message=_('Unable to open vector map <%s> for editing.\n\n'
-                                            'Data are probably corrupted, '
-                                            'try to run v.build to rebuild '
-                                            'the topology (Vector->Develop vector map->'
-                                            'Create/rebuild topology).') % map)
+            raise gcmd.GException(_('Unable to open vector map <%s> for editing.\n\n'
+                                    'Data are probably corrupted, '
+                                    'try to run v.build to rebuild '
+                                    'the topology (Vector->Develop vector map->'
+                                    'Create/rebuild topology).') % map)
         if not map and ret != 0:
         if self.digit:
             self.digit.InitCats()
@@ -684,7 +681,7 @@
             ret = -2
         if ret == -2:
-            raise gcmd.DigitError, _("Undo failed, data corrupted.")
+            raise gcmd.GException(_("Undo failed, data corrupted."))
         self.mapWindow.UpdateMap(render=False)
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-07-29 19:25:06 UTC (rev 42950)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-07-29 19:34:56 UTC (rev 42951)
@@ -188,7 +188,8 @@
         self.workspaceChanged = False
         # start with layer manager on top
-        self.curr_page.maptree.mapdisplay.Raise()
+        if self.curr_page:
+            self.curr_page.maptree.mapdisplay.Raise()
         wx.CallAfter(self.Raise)
     def __createNoteBook(self):
@@ -616,12 +617,11 @@
         # parse workspace file
         try:
             gxwXml = workspace.ProcessWorkspaceFile(etree.parse(filename))
-        except Exception, err:
-            raise gcmd.GStdError(_("Reading workspace file <%(file)s> failed.\n"
-                                   "\n\n%(err)s") % \
-                                     { 'file' : filename, 'err' : err },
-                                 parent = self)
+        except Exception, e:
+            gcmd.GError(parent = self.parent,
+                        message = _("Reading workspace file <%s> failed.\n"
+            return
         busy = wx.BusyInfo(message=_("Please wait, loading workspace..."),
                            parent=self)
