[GRASS-SVN] r42954 - in grass-addons/raster/r.pi: r.pi.corrwin r.pi.index r.pi.rectangle
Fri Jul 30 04:30:00 EDT 2010
Author: wegmann
Date: 2010-07-30 08:30:00 +0000 (Fri, 30 Jul 2010)
New Revision: 42954
   grass-addons/raster/r.pi/r.pi.corrwin/bufs.c
   grass-addons/raster/r.pi/r.pi.corrwin/divr_cats.c
   grass-addons/raster/r.pi/r.pi.corrwin/gather.c
   grass-addons/raster/r.pi/r.pi.corrwin/intr_cats.c
   grass-addons/raster/r.pi/r.pi.corrwin/local_proto.h
   grass-addons/raster/r.pi/r.pi.corrwin/main.c
   grass-addons/raster/r.pi/r.pi.corrwin/ncb.h
   grass-addons/raster/r.pi/r.pi.corrwin/null_cats.c
   grass-addons/raster/r.pi/r.pi.corrwin/readcell.c
   grass-addons/raster/r.pi/r.pi.index/frag.c
   grass-addons/raster/r.pi/r.pi.index/func.c
   grass-addons/raster/r.pi/r.pi.index/local_proto.h
   grass-addons/raster/r.pi/r.pi.index/main.c
   grass-addons/raster/r.pi/r.pi.rectangle/buffer.c
   grass-addons/raster/r.pi/r.pi.rectangle/local_proto.h
   grass-addons/raster/r.pi/r.pi.rectangle/main.c
applied grass_indent.sh
Modified: grass-addons/raster/r.pi/r.pi.corrwin/bufs.c
--- grass-addons/raster/r.pi/r.pi.corrwin/bufs.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/bufs.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -9,51 +9,53 @@
-int allocate_bufs (void)
+int allocate_bufs(void)
     int i;
     int bufsize;
-    bufsize = (G_window_cols() + 2 * ncb.nsize) * sizeof (DCELL);
+    bufsize = (G_window_cols() + 2 * ncb.nsize) * sizeof(DCELL);
-    ncb.buf1   = (DCELL **) G_malloc (ncb.nsize * sizeof(DCELL *));
-    ncb.buf2   = (DCELL **) G_malloc (ncb.nsize * sizeof(DCELL *));
-    for (i = 0; i < ncb.nsize; i++)
-		ncb.buf1[i] = (DCELL *) G_malloc (bufsize) ;
-		ncb.buf2[i] = (DCELL *) G_malloc (bufsize) ;
-		G_set_d_null_value(ncb.buf1[i], G_window_cols() + 2 * ncb.nsize);
-		G_set_d_null_value(ncb.buf2[i], G_window_cols() + 2 * ncb.nsize);
+    ncb.buf1 = (DCELL **) G_malloc(ncb.nsize * sizeof(DCELL *));
+    ncb.buf2 = (DCELL **) G_malloc(ncb.nsize * sizeof(DCELL *));
+    for (i = 0; i < ncb.nsize; i++) {
+	ncb.buf1[i] = (DCELL *) G_malloc(bufsize);
+	ncb.buf2[i] = (DCELL *) G_malloc(bufsize);
+	G_set_d_null_value(ncb.buf1[i], G_window_cols() + 2 * ncb.nsize);
+	G_set_d_null_value(ncb.buf2[i], G_window_cols() + 2 * ncb.nsize);
     return 0;
-int rotate_bufs (int bufnumber)
+int rotate_bufs(int bufnumber)
     DCELL *temp;
     int i;
-	if (bufnumber < 1 || bufnumber > 2)
-		return -1;
-	if (bufnumber == 1) {
-    	temp = ncb.buf1[0];
-    	for (i = 1; i < ncb.nsize; i++) {
-			ncb.buf1[i-1] = ncb.buf1[i];
-    	ncb.buf1[ncb.nsize-1] = temp;
-	} else {
-		temp = ncb.buf2[0];
-			ncb.buf2[i-1] = ncb.buf2[i];
-		ncb.buf2[ncb.nsize-1] = temp;
+    if (bufnumber < 1 || bufnumber > 2)
+	return -1;
+    if (bufnumber == 1) {
+	temp = ncb.buf1[0];
+	for (i = 1; i < ncb.nsize; i++) {
+	    ncb.buf1[i - 1] = ncb.buf1[i];
+	ncb.buf1[ncb.nsize - 1] = temp;
+    else {
+	temp = ncb.buf2[0];
+	    ncb.buf2[i - 1] = ncb.buf2[i];
+	ncb.buf2[ncb.nsize - 1] = temp;
     return 0;
Modified: grass-addons/raster/r.pi/r.pi.corrwin/divr_cats.c
--- grass-addons/raster/r.pi/r.pi.corrwin/divr_cats.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/divr_cats.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -1,9 +1,9 @@
 #include <grass/gis.h>
 #include "ncb.h"
-int
-divr_cats (void)
+int divr_cats(void)
-    G_set_cats_fmt ("$1 $?different categories$category$", 1.0, 0.0, 0.0, 0.0, &ncb.cats);
+    G_set_cats_fmt("$1 $?different categories$category$", 1.0, 0.0, 0.0, 0.0,
+		   &ncb.cats);
     return 0;
Modified: grass-addons/raster/r.pi/r.pi.corrwin/gather.c
--- grass-addons/raster/r.pi/r.pi.corrwin/gather.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/gather.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -5,35 +5,35 @@
    given the starting col of the neighborhood,
    copy the cell values from the bufs into the array of values
    and return the number of values copied.
-int gather(DCELL *values, int bufnumber, int offset)
+int gather(DCELL * values, int bufnumber, int offset)
-		return -1;
+	return -1;
     int row, col;
     int n = 0;
     *values = 0;
     for (row = 0; row < ncb.nsize; row++)
-		for (col = 0; col < ncb.nsize; col++)
-			DCELL *c;
-	    		c = &ncb.buf1[row][offset + col];
-			else
-				c = &ncb.buf2[row][offset + col];
+	for (col = 0; col < ncb.nsize; col++) {
+	    DCELL *c;
-			if (G_is_d_null_value(c))
-				G_set_d_null_value(&values[n], 1);
-			else
-				values[n] = *c;
+		c = &ncb.buf1[row][offset + col];
+	    else
+		c = &ncb.buf2[row][offset + col];
-			n++;
+	    if (G_is_d_null_value(c))
+		G_set_d_null_value(&values[n], 1);
+	    else
+		values[n] = *c;
+	    n++;
     return n ? n : -1;
Modified: grass-addons/raster/r.pi/r.pi.corrwin/intr_cats.c
--- grass-addons/raster/r.pi/r.pi.corrwin/intr_cats.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/intr_cats.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -1,9 +1,9 @@
 #include "ncb.h"
-int intr_cats (void)
+int intr_cats(void)
-    G_set_cats_fmt ("$1% dispersion", 1.0, -1.0, 0.0, 0.0, &ncb.cats);
+    G_set_cats_fmt("$1% dispersion", 1.0, -1.0, 0.0, 0.0, &ncb.cats);
     return 0;
Modified: grass-addons/raster/r.pi/r.pi.corrwin/local_proto.h
--- grass-addons/raster/r.pi/r.pi.corrwin/local_proto.h	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/local_proto.h	2010-07-30 08:30:00 UTC (rev 42954)
@@ -1,13 +1,19 @@
 /* bufs.c */
 extern int allocate_bufs(void);
 extern int rotate_bufs(int);
 /* gather */
-extern int gather(DCELL *,int, int);
+extern int gather(DCELL *, int, int);
 /* readcell.c */
 extern int readcell(int, int, int, int, int);
 /* divr_cats.c */
 extern int divr_cats(void);
 /* intr_cats.c */
 extern int intr_cats(void);
 /* null_cats.c */
 extern int null_cats(void);
Modified: grass-addons/raster/r.pi/r.pi.corrwin/main.c
--- grass-addons/raster/r.pi/r.pi.corrwin/main.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/main.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -9,266 +9,286 @@
 #include <math.h>
-	Moving window correlation analyse.
-	Put together from pieces of r.covar and r.neighbors by Elshad Shirinov.
+   Moving window correlation analyse.
-typedef int (*ifunc)(void);
+   Put together from pieces of r.covar and r.neighbors by Elshad Shirinov.
+typedef int (*ifunc) (void);
 struct ncb ncb;
-int main (int argc, char *argv[])
+int main(int argc, char *argv[])
-	char *p, *p1, *p2;
-	int verbose;
-	// in and out file pointers
-	int in_fd1, in_fd2;
-	int out_fd;
-	DCELL *result;
-	RASTER_MAP_TYPE map_type1, map_type2;
-	int row, col, i, j;
-	int readrow;
-	int maxval;
-	int nrows, ncols;
-	int n;
-	int copycolr;
-	struct Colors colr;
-	struct GModule *module;
-	struct
-		struct Option *input1, *input2, *output;
-		struct Option *size, *max;
-		struct Option *title;
-	} parm;
-	struct
-		struct Flag *quiet;
-	} flag;
+    char *p, *p1, *p2;
-	DCELL *values1, *values2;   /* list of neighborhood values */
+    int verbose;
-	G_gisinit (argv[0]);
+    // in and out file pointers
+    int in_fd1, in_fd2;
-	module = G_define_module();
-	module->keywords = _("raster");
+    int out_fd;
+    DCELL *result;
+    RASTER_MAP_TYPE map_type1, map_type2;
+    int row, col, i, j;
+    int readrow;
+    int maxval;
+    int nrows, ncols;
+    int n;
+    int copycolr;
+    struct Colors colr;
+    struct GModule *module;
+    struct
+	struct Option *input1, *input2, *output;
+	struct Option *size, *max;
+	struct Option *title;
+    } parm;
+    struct
+	struct Flag *quiet;
+    } flag;
+    DCELL *values1, *values2;	/* list of neighborhood values */
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("raster");
     module->description =
-		_("Calculates correlation of two raster maps "
-		  "by calculating correlation function of two "
-		  "corresponding rectangular areas for each "
-		  "raster point and writing the result into a new raster map.");
+	_("Calculates correlation of two raster maps "
+	  "by calculating correlation function of two "
+	  "corresponding rectangular areas for each "
+	  "raster point and writing the result into a new raster map.");
-	parm.input1 = G_define_option() ;
-	parm.input1->key        = "input1" ;
-	parm.input1->type       = TYPE_STRING ;
-	parm.input1->required   = YES ;
-	parm.input1->gisprompt  = "old,cell,raster,1" ;
-	parm.input1->description= _("Name of existing raster file") ;
+    parm.input1 = G_define_option();
+    parm.input1->key = "input1";
+    parm.input1->type = TYPE_STRING;
+    parm.input1->required = YES;
+    parm.input1->gisprompt = "old,cell,raster,1";
+    parm.input1->description = _("Name of existing raster file");
-	parm.input2 = G_define_option() ;
-	parm.input2->key        = "input2" ;
-	parm.input2->type       = TYPE_STRING ;
-	parm.input2->required   = YES ;
-	parm.input2->gisprompt  = "old,cell,raster,2" ;
-	parm.input2->description= _("Name of existing raster file") ;
+    parm.input2 = G_define_option();
+    parm.input2->key = "input2";
+    parm.input2->type = TYPE_STRING;
+    parm.input2->required = YES;
+    parm.input2->gisprompt = "old,cell,raster,2";
+    parm.input2->description = _("Name of existing raster file");
-	parm.output = G_define_option() ;
-	parm.output->key        = "output" ;
-	parm.output->type       = TYPE_STRING ;
-	parm.output->required   = YES ;
-	parm.output->gisprompt  = "new,cell,raster" ;
-	parm.output->description= _("Name of the new raster file") ;
+    parm.output = G_define_option();
+    parm.output->key = "output";
+    parm.output->type = TYPE_STRING;
+    parm.output->required = YES;
+    parm.output->gisprompt = "new,cell,raster";
+    parm.output->description = _("Name of the new raster file");
-	parm.size = G_define_option() ;
-	parm.size->key        = "size" ;
-	parm.size->type       = TYPE_INTEGER ;
-	parm.size->required   = YES ;
-	parm.size->options    = "1,3,5,7,9,11,13,15,17,19,21,23,25" ;
-	parm.size->description= _("Neighborhood size") ;
+    parm.size = G_define_option();
+    parm.size->key = "size";
+    parm.size->type = TYPE_INTEGER;
+    parm.size->required = YES;
+    parm.size->options = "1,3,5,7,9,11,13,15,17,19,21,23,25";
+    parm.size->description = _("Neighborhood size");
-	parm.max = G_define_option() ;
-	parm.max->key        = "max" ;
-	parm.max->type       = TYPE_INTEGER ;
-	parm.max->required   = YES ;
-	parm.max->description= _("Value to be set for the correlation value 1.0 in order to receive more information of the decimal places, e.g. set it to 1000") ;
+    parm.max = G_define_option();
+    parm.max->key = "max";
+    parm.max->type = TYPE_INTEGER;
+    parm.max->required = YES;
+    parm.max->description =
+	_("Value to be set for the correlation value 1.0 in order to receive more information of the decimal places, e.g. set it to 1000");
-	parm.title = G_define_option() ;
-	parm.title->key        = "title" ;
-	parm.title->key_desc   = "\"phrase\"" ;
-	parm.title->type       = TYPE_STRING ;
-	parm.title->required   = NO ;
-	parm.title->description= _("Title of the output raster file") ;
+    parm.title = G_define_option();
+    parm.title->key = "title";
+    parm.title->key_desc = "\"phrase\"";
+    parm.title->type = TYPE_STRING;
+    parm.title->required = NO;
+    parm.title->description = _("Title of the output raster file");
-	flag.quiet = G_define_flag();
-	flag.quiet->key = 'q';
-	flag.quiet->description = _("Run quietly");
+    flag.quiet = G_define_flag();
+    flag.quiet->key = 'q';
+    flag.quiet->description = _("Run quietly");
-	if (G_parser(argc,argv))
-		exit(1);
+    if (G_parser(argc, argv))
+	exit(1);
-	// get names of input files
-	p1 = ncb.oldcell1.name = parm.input1->answer;
-	p2 = ncb.oldcell2.name = parm.input2->answer;
-	// test input files existance
-	if(NULL == (ncb.oldcell1.mapset = G_find_cell2(p1,"")))
-		fprintf (stderr, "%s: <%s> raster file not found\n",
-			 G_program_name(), p1);
-		exit(1);
-	if(NULL == (ncb.oldcell2.mapset = G_find_cell2(p2,"")))
-			 G_program_name(), p2);
-		exit(1);
-	// check if new file name is correct
-	p = ncb.newcell.name = parm.output->answer;
-	if (G_legal_filename(p) < 0)
-		fprintf (stderr, "%s: <%s> illegal file name\n",
-			 G_program_name(), p);
-		exit(1);
-	ncb.newcell.mapset = G_mapset();
+    // get names of input files
+    p1 = ncb.oldcell1.name = parm.input1->answer;
+    p2 = ncb.oldcell2.name = parm.input2->answer;
+    // test input files existance
+    if (NULL == (ncb.oldcell1.mapset = G_find_cell2(p1, ""))) {
+	fprintf(stderr, "%s: <%s> raster file not found\n",
+		G_program_name(), p1);
+	exit(1);
+    if (NULL == (ncb.oldcell2.mapset = G_find_cell2(p2, ""))) {
+		G_program_name(), p2);
+	exit(1);
+    // check if new file name is correct
+    p = ncb.newcell.name = parm.output->answer;
+    if (G_legal_filename(p) < 0) {
+	fprintf(stderr, "%s: <%s> illegal file name\n", G_program_name(), p);
+	exit(1);
+    ncb.newcell.mapset = G_mapset();
-	// get window size
-	nrows = G_window_rows();
-	ncols = G_window_cols();
-	fprintf(stderr, "%d x %d ", nrows, ncols);
+    // get window size
+    nrows = G_window_rows();
+    ncols = G_window_cols();
-	/* open cell files */
-	if ((in_fd1 = G_open_cell_old (ncb.oldcell1.name, ncb.oldcell1.mapset)) < 0)
-		char msg[200];
-		sprintf(msg,"can't open cell file <%s> in mapset %s\n",
-			ncb.oldcell1.name, ncb.oldcell1.mapset);
-		G_fatal_error (msg);
-		exit(-1);
-	if ((in_fd2 = G_open_cell_old (ncb.oldcell2.name, ncb.oldcell2.mapset)) < 0)
-		char msg[200];
-			ncb.oldcell2.name, ncb.oldcell2.mapset);
-		exit(-1);
-	// get map types
-	map_type1 = G_raster_map_type(ncb.oldcell1.name, ncb.oldcell1.mapset);
-	map_type2 = G_raster_map_type(ncb.oldcell2.name, ncb.oldcell2.mapset);
+    fprintf(stderr, "%d x %d ", nrows, ncols);
-	/* copy color table? */
-	copycolr = (G_read_colors (ncb.oldcell1.name, ncb.oldcell1.mapset, &colr) > 0);
-	/* get the neighborhood size */
-	sscanf (parm.size->answer, "%d", &ncb.nsize);
-	ncb.dist = ncb.nsize/2;
-	/* get correlation maximum */
-	sscanf(parm.max->answer, "%d", &maxval);
-	/* allocate the cell buffers */
-	allocate_bufs ();
-	values1 = (DCELL *) G_malloc (ncb.nsize * ncb.nsize * sizeof (DCELL));
-	values2 = (DCELL *) G_malloc (ncb.nsize * ncb.nsize * sizeof (DCELL));
-	result = G_allocate_d_raster_buf();
+    /* open cell files */
+    if ((in_fd1 =
+	 G_open_cell_old(ncb.oldcell1.name, ncb.oldcell1.mapset)) < 0) {
+	char msg[200];
-	/* get title, initialize the category and stat info */
-	if (parm.title->answer)
-		strcpy (ncb.title, parm.title->answer);
-	else
-		sprintf (ncb.title,"%dx%d neighborhood correlation: %s and %s",
-			 ncb.nsize, ncb.nsize, ncb.oldcell1.name, ncb.oldcell2.name);
+	sprintf(msg, "can't open cell file <%s> in mapset %s\n",
+		ncb.oldcell1.name, ncb.oldcell1.mapset);
+	G_fatal_error(msg);
+	exit(-1);
+    if ((in_fd2 =
+	 G_open_cell_old(ncb.oldcell2.name, ncb.oldcell2.mapset)) < 0) {
+	char msg[200];
+		ncb.oldcell2.name, ncb.oldcell2.mapset);
+	exit(-1);
-	/* initialize the cell bufs with 'dist' rows of the old cellfile */
+    // get map types
+    map_type1 = G_raster_map_type(ncb.oldcell1.name, ncb.oldcell1.mapset);
+    map_type2 = G_raster_map_type(ncb.oldcell2.name, ncb.oldcell2.mapset);
-	readrow = 0;
-	for (row = 0; row < ncb.dist; row++) {
-		readcell (in_fd1, 1, readrow, nrows, ncols);
-		readcell (in_fd2, 2, readrow, nrows, ncols);
-		readrow++;
+    /* copy color table? */
+    copycolr =
+	(G_read_colors(ncb.oldcell1.name, ncb.oldcell1.mapset, &colr) > 0);
-	/*open the new cellfile */
-	out_fd = G_open_raster_new (ncb.newcell.name, map_type1);
-	if (out_fd < 0)
-		exit(1);
+    /* get the neighborhood size */
+    sscanf(parm.size->answer, "%d", &ncb.nsize);
+    ncb.dist = ncb.nsize / 2;
-	if (verbose = !flag.quiet->answer)
-		fprintf (stderr, "Percent complete ... ");
-	for (row = 0; row < nrows; row++)
-		if (verbose)
-			G_percent (row, nrows, 2);
-		// read the next row into buffer
-		readrow++;
-		for (col = 0; col < ncols; col++)
-			DCELL sum1 = 0;
-			DCELL sum2 = 0;
-			DCELL mul, mul1, mul2;
-			mul = mul1 = mul2 = 0;
-			double count = 0;
-			DCELL ii, jj;
+    /* get correlation maximum */
+    sscanf(parm.max->answer, "%d", &maxval);
-			// set pointer to actual position in the result
-			DCELL *rp = &result[col];
-			// gather values from actual window
-			gather(values1, 1, col);
-			gather(values2, 2, col);
-			// go through all values of the window
-			for (i = 0; i < ncb.nsize * ncb.nsize; i++) {
-				// ignore values if both are nan
-				if (!(G_is_d_null_value(&values1[i]) && G_is_d_null_value(&values2[i]))) {
-					if (!G_is_d_null_value(&values1[i])) {
-						sum1 += values1[i];
-						mul1 += values1[i] * values1[i];
-					if (!G_is_d_null_value(&values2[i])) {
-						sum2 += values2[i];
-						mul2 += values2[i] * values2[i];
-					if (!G_is_d_null_value(&values1[i]) && !G_is_d_null_value(&values2[i]))
-						mul += values1[i] * values2[i];
-					// count the number of values actually processed
-					count++;
-			if (count <= 1.1) {
-				*rp = 0;
-				continue;
-			// calculate normalization
-			ii = sqrt((mul1 - sum1 * sum1 / count) / (count - 1.0));
-			jj = sqrt((mul2 - sum2 * sum2 / count) / (count - 1.0));
-			// set result
-			*rp = maxval * (mul - sum1 * sum2 / count) / (ii * jj * (count - 1.0));
-			if (G_is_d_null_value(rp))
-				G_set_d_null_value(rp, 1);
+    /* allocate the cell buffers */
+    allocate_bufs();
+    values1 = (DCELL *) G_malloc(ncb.nsize * ncb.nsize * sizeof(DCELL));
+    values2 = (DCELL *) G_malloc(ncb.nsize * ncb.nsize * sizeof(DCELL));
+    result = G_allocate_d_raster_buf();
+    /* get title, initialize the category and stat info */
+    if (parm.title->answer)
+	strcpy(ncb.title, parm.title->answer);
+    else
+	sprintf(ncb.title, "%dx%d neighborhood correlation: %s and %s",
+		ncb.nsize, ncb.nsize, ncb.oldcell1.name, ncb.oldcell2.name);
+    /* initialize the cell bufs with 'dist' rows of the old cellfile */
+    readrow = 0;
+    for (row = 0; row < ncb.dist; row++) {
+	readcell(in_fd1, 1, readrow, nrows, ncols);
+	readcell(in_fd2, 2, readrow, nrows, ncols);
+	readrow++;
+    /*open the new cellfile */
+    out_fd = G_open_raster_new(ncb.newcell.name, map_type1);
+    if (out_fd < 0)
+	exit(1);
+    if (verbose = !flag.quiet->answer)
+	fprintf(stderr, "Percent complete ... ");
+    for (row = 0; row < nrows; row++) {
+	if (verbose)
+	    G_percent(row, nrows, 2);
+	// read the next row into buffer
+	readrow++;
+	for (col = 0; col < ncols; col++) {
+	    DCELL sum1 = 0;
+	    DCELL sum2 = 0;
+	    DCELL mul, mul1, mul2;
+	    mul = mul1 = mul2 = 0;
+	    double count = 0;
+	    DCELL ii, jj;
+	    // set pointer to actual position in the result
+	    DCELL *rp = &result[col];
+	    // gather values from actual window
+	    gather(values1, 1, col);
+	    gather(values2, 2, col);
+	    // go through all values of the window
+	    for (i = 0; i < ncb.nsize * ncb.nsize; i++) {
+		// ignore values if both are nan
+		if (!
+		    (G_is_d_null_value(&values1[i]) &&
+		     G_is_d_null_value(&values2[i]))) {
+		    if (!G_is_d_null_value(&values1[i])) {
+			sum1 += values1[i];
+			mul1 += values1[i] * values1[i];
+		    if (!G_is_d_null_value(&values2[i])) {
+			sum2 += values2[i];
+			mul2 += values2[i] * values2[i];
+		    if (!G_is_d_null_value(&values1[i]) &&
+			!G_is_d_null_value(&values2[i]))
+			mul += values1[i] * values2[i];
+		    // count the number of values actually processed
+		    count++;
-		// write actual result row to the output file
-		G_put_d_raster_row(out_fd, result);
+	    if (count <= 1.1) {
+		*rp = 0;
+		continue;
+	    // calculate normalization
+	    ii = sqrt((mul1 - sum1 * sum1 / count) / (count - 1.0));
+	    jj = sqrt((mul2 - sum2 * sum2 / count) / (count - 1.0));
+	    // set result
+	    *rp =
+		maxval * (mul -
+			  sum1 * sum2 / count) / (ii * jj * (count - 1.0));
+	    if (G_is_d_null_value(rp))
+		G_set_d_null_value(rp, 1);
-	if (verbose)
+	// write actual result row to the output file
+	G_put_d_raster_row(out_fd, result);
+    if (verbose)
-	G_close_cell (out_fd);
-	G_close_cell (in_fd1);
-	G_close_cell (in_fd2);
+    G_close_cell(out_fd);
+    G_close_cell(in_fd1);
+    G_close_cell(in_fd2);
-	if(copycolr)
-		G_write_colors (ncb.newcell.name, ncb.newcell.mapset, &colr);
+    if (copycolr)
+	G_write_colors(ncb.newcell.name, ncb.newcell.mapset, &colr);
-	exit(0);
+    exit(0);
Modified: grass-addons/raster/r.pi/r.pi.corrwin/ncb.h
--- grass-addons/raster/r.pi/r.pi.corrwin/ncb.h	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/ncb.h	2010-07-30 08:30:00 UTC (rev 42954)
@@ -1,10 +1,10 @@
-struct ncb  /* neighborhood control block */
+struct ncb			/* neighborhood control block */
-    DCELL **buf1, **buf2;     /* for reading cell file */
-    int *value;     /* neighborhood values */
-    int nsize;      /* size of the neighborhood */
-    int dist;       /* nsize/2 */
+    DCELL **buf1, **buf2;	/* for reading cell file */
+    int *value;			/* neighborhood values */
+    int nsize;			/* size of the neighborhood */
+    int dist;			/* nsize/2 */
     struct Categories cats;
     char title[1024];
     FILE *out;
@@ -17,4 +17,3 @@
 extern struct ncb ncb;
Modified: grass-addons/raster/r.pi/r.pi.corrwin/null_cats.c
--- grass-addons/raster/r.pi/r.pi.corrwin/null_cats.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/null_cats.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -1,12 +1,12 @@
 #include "ncb.h"
-int null_cats (void)
+int null_cats(void)
     int ncats;
-    ncats = G_number_of_cats (ncb.newcell.name, ncb.newcell.mapset);
-    G_init_cats (ncats, ncb.title, &ncb.cats);
+    ncats = G_number_of_cats(ncb.newcell.name, ncb.newcell.mapset);
+    G_init_cats(ncats, ncb.title, &ncb.cats);
     return 0;
Modified: grass-addons/raster/r.pi/r.pi.corrwin/readcell.c
--- grass-addons/raster/r.pi/r.pi.corrwin/readcell.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.corrwin/readcell.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -3,26 +3,25 @@
 #include "ncb.h"
 #include "local_proto.h"
-int readcell (int fd, int bufnumber, int row, int nrows, int ncols)
-		return -1;
+int readcell(int fd, int bufnumber, int row, int nrows, int ncols)
+	return -1;
+	rotate_bufs(1);
+    else
+	rotate_bufs(2);
+    if (row < nrows)
 	if (bufnumber == 1)
-		rotate_bufs(1);
+	    G_get_d_raster_row(fd, ncb.buf1[ncb.nsize - 1] + ncb.dist, row);
 	else
-		rotate_bufs(2);
+	    G_get_d_raster_row(fd, ncb.buf2[ncb.nsize - 1] + ncb.dist, row);
+    else if (bufnumber == 1)
+	G_set_d_null_value(ncb.buf1[ncb.nsize - 1] + ncb.dist, ncols);
+    else
+	G_set_d_null_value(ncb.buf2[ncb.nsize - 1] + ncb.dist, ncols);
-	if (row < nrows)
-			G_get_d_raster_row (fd, ncb.buf1[ncb.nsize-1] + ncb.dist, row);
-		else
-			G_get_d_raster_row (fd, ncb.buf2[ncb.nsize-1] + ncb.dist, row);
-	else
-			G_set_d_null_value(ncb.buf1[ncb.nsize-1] + ncb.dist, ncols);
-		else
-			G_set_d_null_value(ncb.buf2[ncb.nsize-1] + ncb.dist, ncols);
     return 0;
Modified: grass-addons/raster/r.pi/r.pi.index/frag.c
--- grass-addons/raster/r.pi/r.pi.index/frag.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.index/frag.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -7,102 +7,148 @@
 #include <math.h>
-typedef struct {
-		int x, y;
-	} Position;
+typedef struct
+    int x, y;
+} Position;
-int getNeighbors(Position* res, int x, int y, int nx, int ny, int nbr_cnt);
-int getNeighbors(Position* res, int x, int y, int nx, int ny, int nbr_cnt) {
-	int left, right, top, bottom;
-	int i, j;
-	int cnt = 0;
-	switch(nbr_cnt) {
-		case 4: /* von Neumann neighborhood */
-			if (x > 0 && flagbuf[y * nx + x - 1] == 1) {
-				res[cnt].x = x - 1; res[cnt].y = y; cnt++;
-			if (y > 0 && flagbuf[(y - 1) * nx + x] == 1) {
-				res[cnt].x = x; res[cnt].y = y - 1; cnt++;
-			if (x < nx - 1 && flagbuf[y * nx + x + 1] == 1) {
-				res[cnt].x = x + 1; res[cnt].y = y; cnt++;
-			if (y < ny - 1 && flagbuf[(y + 1) * nx + x] == 1) {
-				res[cnt].x = x; res[cnt].y = y + 1; cnt++;
-			break;
-		case 8: /* Moore neighborhood */
-			left = x > 0 ? x - 1 : 0;
-			top = y > 0 ? y - 1 : 0;
-			right = x < nx - 1 ? x + 1 : nx - 1;
-			bottom = y < ny - 1 ? y + 1 : ny - 1;
-			for (i = left; i <= right; i++) {
-				for (j = top; j <= bottom; j++) {
-					if(!(i == x && j == y) && flagbuf[j * nx + i] == 1) {
-						res[cnt].x = i; res[cnt].y = j; cnt++;
-			break;
-	return cnt;
-void writeFrag(int row, int col, int nbr_cnt) {
-	int x, y, i;
-	Position* list = (Position *) G_malloc(nrows * ncols * sizeof (Position));
-	Position* first = list;
-	Position* last = list;
-	Position* nbr_list = (Position *) G_malloc(8 * sizeof (Position));
-	/* count neighbors */
-	int neighbors = 0;
-	if (col > 0 && flagbuf[row * ncols + col - 1] != 0) neighbors++;
-	if (row > 0 && flagbuf[(row - 1) * ncols + col] != 0) neighbors++;
-	if (col < ncols - 1 && flagbuf[row * ncols + col + 1] != 0) neighbors++;
-	if (row < nrows - 1 && flagbuf[(row + 1) * ncols + col] != 0) neighbors++;
-	/* write first cell */
-	actpos->x = col; actpos->y = row; actpos->neighbors = neighbors; actpos++;
-	flagbuf[row * ncols + col] = -1;
+int getNeighbors(Position * res, int x, int y, int nx, int ny, int nbr_cnt);
-	/* push position on fifo-list */
-	last->x = col; last->y = row; last++;
+    int left, right, top, bottom;
-	while (first < last) {
-		/* get position from fifo-list */
-		int r = first->y; int c = first->x; first++;
-		int left = c > 0 ? c - 1 : 0;
-		int top = r > 0 ? r - 1 : 0;
-		int right = c < ncols - 1 ? c + 1 : ncols - 1;
-		int bottom = r < nrows - 1 ? r + 1 : nrows - 1;
-		/* add neighbors to fifo-list */
-		int cnt = getNeighbors(nbr_list, c, r, ncols, nrows, nbr_cnt);
-		for(i = 0; i < cnt; i++) {
-			x = nbr_list[i].x; y = nbr_list[i].y;
-			/* add position to fifo-list */
-			last->x = x; last->y = y; last++;
-			neighbors = 0;
-			if (x > 0 && flagbuf[y * ncols + x - 1] != 0) neighbors++;
-			if (y > 0 && flagbuf[(y - 1) * ncols + x] != 0) neighbors++;
-			if (x < ncols - 1 && flagbuf[y * ncols + x + 1] != 0) neighbors++;
-			if (y < nrows - 1 && flagbuf[(y + 1) * ncols + x] != 0) neighbors++;
-			/* set values */
-			actpos->x = x; actpos->y = y; actpos->neighbors = neighbors; actpos++;
-			flagbuf[y * ncols + x] = -1;
+    int i, j;
+    int cnt = 0;
+    switch (nbr_cnt) {
+    case 4:			/* von Neumann neighborhood */
+	if (x > 0 && flagbuf[y * nx + x - 1] == 1) {
+	    res[cnt].x = x - 1;
+	    res[cnt].y = y;
+	    cnt++;
+	if (y > 0 && flagbuf[(y - 1) * nx + x] == 1) {
+	    res[cnt].x = x;
+	    res[cnt].y = y - 1;
+	    cnt++;
+	if (x < nx - 1 && flagbuf[y * nx + x + 1] == 1) {
+	    res[cnt].x = x + 1;
+	    res[cnt].y = y;
+	    cnt++;
+	if (y < ny - 1 && flagbuf[(y + 1) * nx + x] == 1) {
+	    res[cnt].x = x;
+	    res[cnt].y = y + 1;
+	    cnt++;
+	break;
+    case 8:			/* Moore neighborhood */
+	left = x > 0 ? x - 1 : 0;
+	top = y > 0 ? y - 1 : 0;
+	right = x < nx - 1 ? x + 1 : nx - 1;
+	bottom = y < ny - 1 ? y + 1 : ny - 1;
+	for (i = left; i <= right; i++) {
+	    for (j = top; j <= bottom; j++) {
+		if (!(i == x && j == y) && flagbuf[j * nx + i] == 1) {
+		    res[cnt].x = i;
+		    res[cnt].y = j;
+		    cnt++;
-	G_free(list);
-	G_free(nbr_list);
+	break;
+    return cnt;
+void writeFrag(int row, int col, int nbr_cnt)
+    int x, y, i;
+    Position *list = (Position *) G_malloc(nrows * ncols * sizeof(Position));
+    Position *first = list;
+    Position *last = list;
+    Position *nbr_list = (Position *) G_malloc(8 * sizeof(Position));
+    /* count neighbors */
+    int neighbors = 0;
+    if (col > 0 && flagbuf[row * ncols + col - 1] != 0)
+	neighbors++;
+    if (row > 0 && flagbuf[(row - 1) * ncols + col] != 0)
+	neighbors++;
+    if (col < ncols - 1 && flagbuf[row * ncols + col + 1] != 0)
+	neighbors++;
+    if (row < nrows - 1 && flagbuf[(row + 1) * ncols + col] != 0)
+	neighbors++;
+    /* write first cell */
+    actpos->x = col;
+    actpos->y = row;
+    actpos->neighbors = neighbors;
+    actpos++;
+    flagbuf[row * ncols + col] = -1;
+    /* push position on fifo-list */
+    last->x = col;
+    last->y = row;
+    last++;
+    while (first < last) {
+	/* get position from fifo-list */
+	int r = first->y;
+	int c = first->x;
+	first++;
+	int left = c > 0 ? c - 1 : 0;
+	int top = r > 0 ? r - 1 : 0;
+	int right = c < ncols - 1 ? c + 1 : ncols - 1;
+	int bottom = r < nrows - 1 ? r + 1 : nrows - 1;
+	/* add neighbors to fifo-list */
+	int cnt = getNeighbors(nbr_list, c, r, ncols, nrows, nbr_cnt);
+	for (i = 0; i < cnt; i++) {
+	    x = nbr_list[i].x;
+	    y = nbr_list[i].y;
+	    /* add position to fifo-list */
+	    last->x = x;
+	    last->y = y;
+	    last++;
+	    neighbors = 0;
+	    if (x > 0 && flagbuf[y * ncols + x - 1] != 0)
+		neighbors++;
+	    if (y > 0 && flagbuf[(y - 1) * ncols + x] != 0)
+		neighbors++;
+	    if (x < ncols - 1 && flagbuf[y * ncols + x + 1] != 0)
+		neighbors++;
+	    if (y < nrows - 1 && flagbuf[(y + 1) * ncols + x] != 0)
+		neighbors++;
+	    /* set values */
+	    actpos->x = x;
+	    actpos->y = y;
+	    actpos++;
+	    flagbuf[y * ncols + x] = -1;
+    G_free(list);
+    G_free(nbr_list);
Modified: grass-addons/raster/r.pi/r.pi.index/func.c
--- grass-addons/raster/r.pi/r.pi.index/func.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.index/func.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -7,258 +7,331 @@
 #include <math.h>
-int f_area(DCELL *vals, Coords **frags, int count) {
-	int i;
-	/* for all patches */
-	for(i = 0; i < count; i++) {
-		// display progress
-		if (verbose)
-			G_percent (i, count, 2);
-		vals[i] = (DCELL) (frags[i+1] - frags[i]);
+int f_area(DCELL * vals, Coords ** frags, int count)
+    int i;
-	return 0;
+    /* for all patches */
+    for (i = 0; i < count; i++) {
+	// display progress
+	if (verbose)
+	    G_percent(i, count, 2);
+	vals[i] = (DCELL) (frags[i + 1] - frags[i]);
+    return 0;
-int f_perim(DCELL *vals, Coords **frags, int count) {
-	Coords *p;
-	int i;
-		if (verbose)
-		int border = 0;
-		/* for all cells in a patch */
-		for(p = frags[i]; p < frags[i+1]; p++) {
-			border+= 4 - p->neighbors;
-		vals[i] = (DCELL) border;
+int f_perim(DCELL * vals, Coords ** frags, int count)
+    Coords *p;
+    int i;
+	if (verbose)
+	int border = 0;
+	/* for all cells in a patch */
+	for (p = frags[i]; p < frags[i + 1]; p++) {
+	    border += 4 - p->neighbors;
-	return 0;
+	vals[i] = (DCELL) border;
+    return 0;
-int f_shapeindex(DCELL *vals, Coords **frags, int count) {
-	Coords *p;
-	int i;
-		if (verbose)
-		int border = 0;
-		int area = (DCELL) (frags[i+1] - frags[i]);
-		vals[i] = (DCELL) border / ( 4 * sqrt((DCELL) area) );
+int f_shapeindex(DCELL * vals, Coords ** frags, int count)
+    Coords *p;
+    int i;
+	if (verbose)
+	int border = 0;
+	int area = (DCELL) (frags[i + 1] - frags[i]);
-	return 0;
+	vals[i] = (DCELL) border / (4 * sqrt((DCELL) area));
+    return 0;
-int f_borderindex(DCELL *vals, Coords **frags, int count) {
-	Coords *p;
-	int i;
-		if (verbose)
-		int border = 0;
-		int maxx, maxy, minx, miny;
-		int l = 0;
-		int w = 0;
-		maxx = minx = frags[i]->x;
-		maxy = miny = frags[i]->y;
-			maxx = p->x > maxx ? p->x : maxx;
-			minx = p->x < minx ? p->x : minx;
-			maxy = p->y > maxy ? p->y : maxy;
-			miny = p->y < miny ? p->y : miny;
-		l = maxx - minx + 1; w = maxy - miny + 1;
-		vals[i] = (DCELL) border / ( 2 * ( (DCELL)l + (DCELL)w ) );
+int f_borderindex(DCELL * vals, Coords ** frags, int count)
+    Coords *p;
+    int i;
+	if (verbose)
+	int border = 0;
+	int maxx, maxy, minx, miny;
+	int l = 0;
+	int w = 0;
+	maxx = minx = frags[i]->x;
+	maxy = miny = frags[i]->y;
+	    maxx = p->x > maxx ? p->x : maxx;
+	    minx = p->x < minx ? p->x : minx;
+	    maxy = p->y > maxy ? p->y : maxy;
+	    miny = p->y < miny ? p->y : miny;
-	return 0;
+	l = maxx - minx + 1;
+	w = maxy - miny + 1;
+	vals[i] = (DCELL) border / (2 * ((DCELL) l + (DCELL) w));
+    return 0;
-int f_compactness(DCELL *vals, Coords **frags, int count) {
-	Coords *p;
-	int i;
-		if (verbose)
-		int area = 0;
-		int l = 0;
-		int w = 0;
-			area++;
-		vals[i] = (DCELL)l * (DCELL)w / (DCELL) area;
+int f_compactness(DCELL * vals, Coords ** frags, int count)
+    Coords *p;
+    int i;
+	if (verbose)
+	int area = 0;
+	int l = 0;
+	int w = 0;
+	    area++;
-	return 0;
+	vals[i] = (DCELL) l *(DCELL) w / (DCELL) area;
+    return 0;
-int f_asymmetry(DCELL *vals, Coords **frags, int count) {
-	Coords *p;
-	int i;
-		if (verbose)
-		/* compute variance for x,y and xy in the patch */
-		/* formula: a(x) = sum(x_i), b(x) = sum(x_i²), var(x) = (b(x) - a(x)² / n) / n */
-		/* covar(x*y) = (a(x * y) - a(x) * a(y) / n) /n */
-		int ax, ay, axy;
-		int bx, by;
-		DCELL vx, vy, vxy, vsum, invn;
-		int n = 0;
-		ax = ay = axy = 0; bx = by = 0;
-//		fprintf(stderr, "\npatch %d: ", i);
-		for(p = frags[i]; p < frags[i+1]; p++, n++) {
-			int x = p->x; int y = p->y; int xy = p->x * p->y;
-			ax += x; ay += y; axy += xy;
-			bx += x * x; by += y * y;
-//			fprintf(stderr, "x_%d = %d, y_%d = %d; ", n, x, n, y);
-		invn = 1.0 / (DCELL)n;
-		vx = ( (DCELL)bx - (DCELL)ax * (DCELL)ax * invn ) * invn;
-		vy = ( (DCELL)by - (DCELL)ay * (DCELL)ay * invn ) * invn;
-		vxy = ( (DCELL)axy - (DCELL)ax * (DCELL)ay * invn ) * invn;
-//		fprintf(stderr, " axy = %d, ax = %d, ay = %d, n = %d", axy, ax, ay, n);
-		vsum = vx + vy;
-		vals[i] = 2 * sqrt(0.25 * vsum * vsum + vxy * vxy - vx * vy) / vsum;
+int f_asymmetry(DCELL * vals, Coords ** frags, int count)
+    Coords *p;
+    int i;
+	if (verbose)
+	/* compute variance for x,y and xy in the patch */
+	/* formula: a(x) = sum(x_i), b(x) = sum(x_i²), var(x) = (b(x) - a(x)² / n) / n */
+	/* covar(x*y) = (a(x * y) - a(x) * a(y) / n) /n */
+	int ax, ay, axy;
+	int bx, by;
+	DCELL vx, vy, vxy, vsum, invn;
+	int n = 0;
+	ax = ay = axy = 0;
+	bx = by = 0;
+	//              fprintf(stderr, "\npatch %d: ", i);
+	for (p = frags[i]; p < frags[i + 1]; p++, n++) {
+	    int x = p->x;
+	    int y = p->y;
+	    int xy = p->x * p->y;
+	    ax += x;
+	    ay += y;
+	    axy += xy;
+	    bx += x * x;
+	    by += y * y;
+	    //                      fprintf(stderr, "x_%d = %d, y_%d = %d; ", n, x, n, y);
+	invn = 1.0 / (DCELL) n;
+	vx = ((DCELL) bx - (DCELL) ax * (DCELL) ax * invn) * invn;
+	vy = ((DCELL) by - (DCELL) ay * (DCELL) ay * invn) * invn;
+	vxy = ((DCELL) axy - (DCELL) ax * (DCELL) ay * invn) * invn;
+	//              fprintf(stderr, " axy = %d, ax = %d, ay = %d, n = %d", axy, ax, ay, n);
+	vsum = vx + vy;
+	vals[i] = 2 * sqrt(0.25 * vsum * vsum + vxy * vxy - vx * vy) / vsum;
-int f_area_perim_ratio(DCELL *vals, Coords **frags, int count) {
-	Coords *p;
-	int i;
-		if (verbose)
-		int border = 0;
-		vals[i] = (DCELL) area / (DCELL) border;
+int f_area_perim_ratio(DCELL * vals, Coords ** frags, int count)
+    Coords *p;
+    int i;
+	if (verbose)
+	int border = 0;
-	return 0;
+	vals[i] = (DCELL) area / (DCELL) border;
+    return 0;
-int f_frac_dim(DCELL *vals, Coords **frags, int count) {
-	Coords *p;
-	int i;
-		if (verbose)
-		int border = 0;
-		vals[i] = 2 * log(0.25 * (DCELL) border) / log((DCELL) area);
+int f_frac_dim(DCELL * vals, Coords ** frags, int count)
+    Coords *p;
+    int i;
+	if (verbose)
+	int border = 0;
-	return 0;
+	vals[i] = 2 * log(0.25 * (DCELL) border) / log((DCELL) area);
+    return 0;
-DCELL dist(Coords *p1, Coords *p2) {
-	int x1 = p1->x; int y1 = p1->y;
-	int x2 = p2->x; int y2 = p2->y;
-	int dx = x2 - x1; int dy = y2 - y1;
-	return sqrt(dx * dx + dy * dy);
+DCELL dist(Coords * p1, Coords * p2)
+    int x1 = p1->x;
+    int y1 = p1->y;
+    int x2 = p2->x;
+    int y2 = p2->y;
+    int dx = x2 - x1;
+    int dy = y2 - y1;
+    return sqrt(dx * dx + dy * dy);
-DCELL min_dist(Coords **frags, int n1, int n2) {
-	Coords *p1, *p2;
-	DCELL min = 1000000.0;
-	// for all cells in the first patch
-	for (p1 = frags[n1]; p1 < frags[n1+1]; p1++) {
+DCELL min_dist(Coords ** frags, int n1, int n2)
+    Coords *p1, *p2;
+    DCELL min = 1000000.0;
+    // for all cells in the first patch
+    for (p1 = frags[n1]; p1 < frags[n1 + 1]; p1++) {
+	// if cell at the border
+	if (p1->neighbors < 4) {
+	    // for all cells in the second patch
+	    for (p2 = frags[n2]; p2 < frags[n2 + 1]; p2++) {
-		if (p1->neighbors < 4) {
-			// for all cells in the second patch
-			for (p2 = frags[n2]; p2 < frags[n2+1]; p2++) {
-				// if cell at the border
-				if (p2->neighbors < 4) {
-					DCELL d = dist(p1, p2);
-					if (d < min) {
-						min = d;
+		if (p2->neighbors < 4) {
+		    DCELL d = dist(p1, p2);
+		    if (d < min) {
+			min = d;
-	return min;
+    return min;
-int f_nearest_dist(DCELL *vals, Coords **frags, int count) {
-	int i, j;
-	for (i = 0; i < count; i++) {
-		if (verbose)
-		for (j = 0; j < count; j++) {
-			if (i != j) {
-				DCELL d = min_dist(frags, i, j);
-				if (d < min) {
-					min = d;
+int f_nearest_dist(DCELL * vals, Coords ** frags, int count)
+    int i, j;
+	if (verbose)
+	for (j = 0; j < count; j++) {
+	    if (i != j) {
+		DCELL d = min_dist(frags, i, j);
+		if (d < min) {
+		    min = d;
-		vals[i] = min;
+	vals[i] = min;
-	return 0;
+    return 0;
-int f_proximity(DCELL *vals, Coords **frags, int count, DCELL param) {
-	int i, j;
-			if (i != j) {
+int f_proximity(DCELL * vals, Coords ** frags, int count, DCELL param)
+    int i, j;
+	    if (i != j) {
-	return 0;
+    return 0;
Modified: grass-addons/raster/r.pi/r.pi.index/local_proto.h
--- grass-addons/raster/r.pi/r.pi.index/local_proto.h	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.index/local_proto.h	2010-07-30 08:30:00 UTC (rev 42954)
@@ -3,28 +3,41 @@
 #define MAX_DOUBLE 1000000.0
-typedef struct {
-		int x, y;
-		int neighbors;
-	} Coords;
+typedef struct
+    int x, y;
+    int neighbors;
+} Coords;
 extern void writeFrag(int row, int col, int nbr_cnt);
-extern int f_area(DCELL *vals, Coords **frags, int);
-extern int f_perim(DCELL *vals, Coords **frags, int);
-extern int f_shapeindex(DCELL*, Coords**, int);
-extern int f_borderindex(DCELL*, Coords**, int);
-extern int f_compactness(DCELL*, Coords**, int);
-extern int f_asymmetry(DCELL*, Coords**, int);
-extern int f_area_perim_ratio(DCELL*, Coords**, int);
-extern int f_frac_dim(DCELL*, Coords**, int);
-extern int f_nearest_dist(DCELL*, Coords**, int);
+extern int f_area(DCELL * vals, Coords ** frags, int);
+extern int f_perim(DCELL * vals, Coords ** frags, int);
+extern int f_shapeindex(DCELL *, Coords **, int);
+extern int f_borderindex(DCELL *, Coords **, int);
+extern int f_compactness(DCELL *, Coords **, int);
+extern int f_asymmetry(DCELL *, Coords **, int);
+extern int f_area_perim_ratio(DCELL *, Coords **, int);
+extern int f_frac_dim(DCELL *, Coords **, int);
+extern int f_nearest_dist(DCELL *, Coords **, int);
 /* global variables */
 int nrows, ncols;
-Coords ** fragments;
+Coords **fragments;
 int *flagbuf;
-Coords * actpos;
+Coords *actpos;
 int verbose;
 #endif /* LOCAL_PROTO_H */
Modified: grass-addons/raster/r.pi/r.pi.index/main.c
--- grass-addons/raster/r.pi/r.pi.index/main.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.index/main.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -8,299 +8,312 @@
-	Fragmentation analysis - basic indices in r.pi.index
-	by Elshad Shirinov.
+   Fragmentation analysis - basic indices in r.pi.index
-typedef int (*f_func)(DCELL*, Coords**, int);
+   by Elshad Shirinov.
+typedef int (*f_func) (DCELL *, Coords **, int);
 struct menu
-	f_func method;		/* routine to compute new value */
-	char *name;		/* method name */
-	char *text;		/* menu display - full description */
+    f_func method;		/* routine to compute new value */
+    char *name;			/* method name */
+    char *text;			/* menu display - full description */
-static struct menu menu[] =
-	{f_area, "area", "area of specified patches"},
-	{f_perim, "perimeter", "perimeter of specified patches"},
-	{f_shapeindex, "shape", "shape index of specified patches"},
-	{f_borderindex, "border", "border index of specified patches"},
-	{f_compactness, "compactness", "compactness of specified patches"},
-	{f_asymmetry, "asymmetry", "asymmetry of specified patches"},
-	{f_area_perim_ratio, "area-perimeter", "area-perimeter ratio of specified patches"},
-	{f_frac_dim, "fractal", "fractal dimension of specified patches"},
-	{f_nearest_dist, "ENN", "euclidean distance to nearest patch"},
-	{0,0,0}
+static struct menu menu[] = {
+    {f_area, "area", "area of specified patches"},
+    {f_perim, "perimeter", "perimeter of specified patches"},
+    {f_shapeindex, "shape", "shape index of specified patches"},
+    {f_borderindex, "border", "border index of specified patches"},
+    {f_compactness, "compactness", "compactness of specified patches"},
+    {f_asymmetry, "asymmetry", "asymmetry of specified patches"},
+    {f_area_perim_ratio, "area-perimeter",
+     "area-perimeter ratio of specified patches"},
+    {f_frac_dim, "fractal", "fractal dimension of specified patches"},
+    {f_nearest_dist, "ENN", "euclidean distance to nearest patch"},
+    {0, 0, 0}
-	/* input */
-	char *newname, *oldname, *newmapset, *oldmapset;
-	char title[1024];
+    /* input */
+    char *newname, *oldname, *newmapset, *oldmapset;
-	/* in and out file pointers */
-	int in_fd;
-	int out_fd;
-	DCELL *result, res[30];
-	/* map_type and categories */
-	RASTER_MAP_TYPE map_type;
-	struct Categories cats;
-	int method;
-	f_func compute_values;
-	/* neighbors count */
-	int neighb_count;
+    char title[1024];
-	char *p;
+    /* in and out file pointers */
+    int in_fd;
-	int readrow;
-	int keyval;
-	DCELL range = MAX_DOUBLE;
-	int n;
-	int copycolr;
-	struct
-		struct Option *input, *output;
-		struct Option *keyval, *method;
-	} parm;
-	struct
-		struct Flag *adjacent, *quiet;
-	} flag;
+    int out_fd;
-	DCELL *values;
-	Coords *cells;
-	int fragcount = 0;
-	struct Cell_head ch, window;
+    DCELL *result, res[30];
+    /* map_type and categories */
+    RASTER_MAP_TYPE map_type;
-	module->description =
-		_("Provides basic patch based indices, like area, SHAPE or Nearest Neighbour distance.");
+    struct Categories cats;
-	parm.input = G_define_option() ;
-	parm.input->key        = "input" ;
-	parm.input->type       = TYPE_STRING ;
-	parm.input->required   = YES ;
-	parm.input->gisprompt  = "old,cell,raster" ;
-	parm.input->description= _("Raster map containing categories") ;
+    int method;
-	parm.output->description= _("Output patch-based result as raster map") ;
+    f_func compute_values;
-	parm.keyval = G_define_option() ;
-	parm.keyval->key        = "keyval" ;
-	parm.keyval->type       = TYPE_INTEGER ;
-	parm.keyval->required   = YES ;
-	parm.keyval->description= _("The value of the class to be analysed") ;
+    /* neighbors count */
+    int neighb_count;
-	parm.method = G_define_option() ;
-	parm.method->key        = "method" ;
-	parm.method->type       = TYPE_STRING ;
-	parm.method->required   = YES ;
-	p = parm.method->options  = G_malloc(1024);
-	for (n = 0; menu[n].name; n++)
-		if (n)
-			strcat (p, ",");
-		else
-			*p = 0;
-		strcat (p, menu[n].name);
-	parm.method->description= _("Operation to perform on fragments") ;
+    char *p;
-	flag.adjacent = G_define_flag() ;
-	flag.adjacent->key        = 'a' ;
-	flag.adjacent->description= _("Set for 8 cell-neighbors. 4 cell-neighbors are default.") ;
+    int readrow;
-		exit(1);
+    int keyval;
-	/* get names of input files */
-	oldname = parm.input->answer;
+    DCELL range = MAX_DOUBLE;
-	/* test input files existance */
-	if(NULL == (oldmapset = G_find_cell2(oldname,"")))
-			 G_program_name(), oldname);
-		exit(1);
+    int n;
-	/* check if the new file name is correct */
-	newname = parm.output->answer;
-	if (G_legal_filename(newname) < 0)
-			 G_program_name(), newname);
-		exit(1);
-	newmapset = G_mapset();
+    int copycolr;
-	/* get size */
-	if ((in_fd = G_open_cell_old (oldname, oldmapset)) < 0)
-		char msg[200];
-			oldname, oldmapset);
-		exit(-1);
-	/* get map type */
-	map_type = DCELL_TYPE;//G_raster_map_type(oldname, oldmapset);
-	/* copy color table */
-	copycolr = (G_read_colors (oldname, oldmapset, &colr) > 0);
-	/* get key value */
-	sscanf(parm.keyval->answer, "%d", &keyval);
+    struct
+	struct Option *input, *output;
+	struct Option *keyval, *method;
+    } parm;
-	/* get the method */
-	for (method = 0; (p = menu[method].name); method++)
-		if ((strcmp(p, parm.method->answer) == 0))
-			break;
-	if (!p)
-		G_warning (_("<%s=%s> unknown %s"),
-			 parm.method->key, parm.method->answer, parm.method->key);
-		G_usage();
-		exit(EXIT_FAILURE);
+    struct
+	struct Flag *adjacent, *quiet;
+    } flag;
-	/* establish the newvalue routine */
-	compute_values = menu[method].method;
-	/* get number of cell-neighbors */
-	neighb_count = flag.adjacent->answer ? 8 : 4;
-	cells = (Coords *) G_malloc ( nrows * ncols * sizeof(Coords));
-	actpos = cells;
-	fragments = (Coords **) G_malloc (nrows * ncols * sizeof (Coords*));
-	fragments[0] = cells;
-	flagbuf = (int *) G_malloc (nrows * ncols * sizeof (int));
+    DCELL *values;
-		strcpy (title, parm.title->answer);
+    Coords *cells;
+    int fragcount = 0;
+    struct Cell_head ch, window;
+    module->description =
+	_("Provides basic patch based indices, like area, SHAPE or Nearest Neighbour distance.");
+    parm.input = G_define_option();
+    parm.input->key = "input";
+    parm.input->type = TYPE_STRING;
+    parm.input->required = YES;
+    parm.input->gisprompt = "old,cell,raster";
+    parm.input->description = _("Raster map containing categories");
+    parm.output->description = _("Output patch-based result as raster map");
+    parm.keyval = G_define_option();
+    parm.keyval->key = "keyval";
+    parm.keyval->type = TYPE_INTEGER;
+    parm.keyval->required = YES;
+    parm.keyval->description = _("The value of the class to be analysed");
+    parm.method = G_define_option();
+    parm.method->key = "method";
+    parm.method->type = TYPE_STRING;
+    parm.method->required = YES;
+    p = parm.method->options = G_malloc(1024);
+    for (n = 0; menu[n].name; n++) {
+	if (n)
+	    strcat(p, ",");
 	else
-		sprintf (title,"Fragmentation of file: %s", oldname);
+	    *p = 0;
+	strcat(p, menu[n].name);
+    parm.method->description = _("Operation to perform on fragments");
-	/* open the new cellfile  */
-	out_fd = G_open_raster_new (newname, map_type);
-	if (out_fd < 0) {
-		char msg[200];
-		sprintf(msg,"can't create new cell file <%s> in mapset %s\n",
-			newname, newmapset);
-		exit(1);
+    flag.adjacent = G_define_flag();
+    flag.adjacent->key = 'a';
+    flag.adjacent->description =
+	_("Set for 8 cell-neighbors. 4 cell-neighbors are default.");
+	exit(1);
+    /* get names of input files */
+    oldname = parm.input->answer;
+    /* test input files existance */
+    if (NULL == (oldmapset = G_find_cell2(oldname, ""))) {
+		G_program_name(), oldname);
+	exit(1);
+    /* check if the new file name is correct */
+    newname = parm.output->answer;
+    if (G_legal_filename(newname) < 0) {
+		G_program_name(), newname);
+	exit(1);
+    newmapset = G_mapset();
+    /* get size */
+    if ((in_fd = G_open_cell_old(oldname, oldmapset)) < 0) {
+	char msg[200];
+		oldname, oldmapset);
+	exit(-1);
+    /* get map type */
+    map_type = DCELL_TYPE;	//G_raster_map_type(oldname, oldmapset);
+    /* copy color table */
+    copycolr = (G_read_colors(oldname, oldmapset, &colr) > 0);
+    /* get key value */
+    sscanf(parm.keyval->answer, "%d", &keyval);
+    /* get the method */
+    for (method = 0; (p = menu[method].name); method++)
+	if ((strcmp(p, parm.method->answer) == 0))
+	    break;
+    if (!p) {
+	G_warning(_("<%s=%s> unknown %s"),
+		  parm.method->key, parm.method->answer, parm.method->key);
+	G_usage();
+	exit(EXIT_FAILURE);
+    /* establish the newvalue routine */
+    compute_values = menu[method].method;
+    /* get number of cell-neighbors */
+    neighb_count = flag.adjacent->answer ? 8 : 4;
+    cells = (Coords *) G_malloc(nrows * ncols * sizeof(Coords));
+    actpos = cells;
+    fragments = (Coords **) G_malloc(nrows * ncols * sizeof(Coords *));
+    fragments[0] = cells;
+    flagbuf = (int *)G_malloc(nrows * ncols * sizeof(int));
+	strcpy(title, parm.title->answer);
+    else
+	sprintf(title, "Fragmentation of file: %s", oldname);
+    /* open the new cellfile  */
+    out_fd = G_open_raster_new(newname, map_type);
+    if (out_fd < 0) {
+	char msg[200];
+	sprintf(msg, "can't create new cell file <%s> in mapset %s\n",
+		newname, newmapset);
+	exit(1);
+	fprintf(stderr, "Loading Patches ... ");
+    /* find fragments */
+	G_get_d_raster_row(in_fd, result, row);
+	    if (result[col] == keyval)
+		flagbuf[row * ncols + col] = 1;
-		fprintf (stderr, "Loading Patches ... ");
+	if (verbose)
-	/* find fragments */
-	for (row = 0; row < nrows; row++) {
-		G_get_d_raster_row (in_fd, result, row);
-		for (col = 0; col < ncols; col++) {
-			if(result[col] == keyval)
-				flagbuf[row * ncols + col] = 1;
-		if (verbose)
+	    if (flagbuf[row * ncols + col] == 1) {
+		fragcount++;
+		writeFrag(row, col, neighb_count);
+		fragments[fragcount] = actpos;
+    if (verbose)
+	G_percent(nrows, nrows, 2);
-	for(row = 0; row < nrows; row++) {
-		for(col = 0; col < ncols; col++) {
-			if(flagbuf[row * ncols + col] == 1) {
-				fragcount++;
-				writeFrag(row, col, neighb_count);
-				fragments[fragcount] = actpos;
+    /* perform actual function on the patches */
+	fprintf(stderr, "Performing operation ... ");
+    values = (DCELL *) G_malloc(fragcount * sizeof(DCELL));
+    compute_values(values, fragments, fragcount);
+    if (verbose)
+	G_percent(fragcount, fragcount, 2);
+    /* write the output file */
+	fprintf(stderr, "Writing output ... ");
+	G_set_d_null_value(result, ncols);
+	for (i = 0; i < fragcount; i++) {
+	    for (actpos = fragments[i]; actpos < fragments[i + 1]; actpos++) {
+		if (actpos->y == row) {
+		    result[actpos->x] = values[i];
-	if (verbose)
-		G_percent (nrows, nrows, 2);
-	/* perform actual function on the patches */
-		fprintf (stderr, "Performing operation ... ");
-	values = (DCELL *) G_malloc ( fragcount * sizeof(DCELL));
-	compute_values(values, fragments, fragcount);
-	if (verbose)
-		G_percent (fragcount, fragcount, 2);
-	/* write the output file */
-		fprintf (stderr, "Writing output ... ");
-		G_set_d_null_value(result, ncols);
-		for(i = 0; i < fragcount; i++) {
-			for(actpos = fragments[i]; actpos < fragments[i+1]; actpos++) {
-				if(actpos->y == row) {
-					result[actpos->x] = values[i];
-		if (verbose)
 	if (verbose)
-	G_close_cell (in_fd);
-	G_free(cells);
-	G_free(fragments);
-	G_free(flagbuf);
+    if (verbose)
-	G_init_cats (0, title, &cats);
-	G_write_cats (newname, &cats);
+    G_close_cell(in_fd);
-	if(copycolr)
-		G_write_colors (newname, newmapset, &colr);
+    G_free(cells);
+    G_free(fragments);
+    G_free(flagbuf);
-	exit(0);
+    G_init_cats(0, title, &cats);
+    G_write_cats(newname, &cats);
+    if (copycolr)
+	G_write_colors(newname, newmapset, &colr);
+    exit(0);
Modified: grass-addons/raster/r.pi/r.pi.rectangle/buffer.c
--- grass-addons/raster/r.pi/r.pi.rectangle/buffer.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.rectangle/buffer.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -1,59 +1,62 @@
-void set_buffer(CELL* buffer, int x, int y, int width, int height, int sx, int sy, int align) {
-	int l, r, t, b;
-	int i, j;
-	int dx, dy;
-	switch(align) {
-		case 0: /* center */
-			dx = width / 2;
-			dy = height / 2;
-			l = x - dx;
-			r = x + dx;
-			t = y - dy;
-			b = y + dy;
-			break;
-		case 1: /* top-left */
-			l = x;
-			r = x + width - 1;
-			t = y;
-			b = y + height - 1;
-			break;
-		case 2: /* top-right */
-			l = x - width + 1;
-			r = x;
-			t = y;
-			break;
-		case 3: /* bottom-left */
-			l = x;
-			t = y - height + 1;
-			b = y;
-			break;
-		case 4: /* bottom-right */
-			r = x;
-			b = y;
-			break;
-		default:
-			l = t = 0;
-			r = b = 1;
-			break;
+void set_buffer(CELL * buffer, int x, int y, int width, int height, int sx,
+		int sy, int align)
+    int l, r, t, b;
+    int i, j;
+    int dx, dy;
+    switch (align) {
+    case 0:			/* center */
+	dx = width / 2;
+	dy = height / 2;
+	l = x - dx;
+	r = x + dx;
+	t = y - dy;
+	b = y + dy;
+	break;
+    case 1:			/* top-left */
+	l = x;
+	r = x + width - 1;
+	t = y;
+	b = y + height - 1;
+	break;
+    case 2:			/* top-right */
+	l = x - width + 1;
+	r = x;
+	t = y;
+	break;
+    case 3:			/* bottom-left */
+	l = x;
+	t = y - height + 1;
+	b = y;
+	break;
+    case 4:			/* bottom-right */
+	r = x;
+	b = y;
+	break;
+    default:
+	l = t = 0;
+	r = b = 1;
+	break;
+    l = l < 0 ? 0 : l;
+    r = r >= sx ? sx - 1 : r;
+    t = t < 0 ? 0 : t;
+    b = b >= sy ? sy - 1 : b;
+    /* fill buffer */
+    for (j = t; j <= b; j++) {
+	for (i = l; i <= r; i++) {
+	    buffer[j * sx + i] = 1;
-	l = l < 0 ? 0 : l;
-	r = r >= sx ? sx - 1 : r;
-	t = t < 0 ? 0 : t;
-	b = b >= sy ? sy - 1 : b;
-	/* fill buffer */
-	for(j = t; j <= b; j++) {
-		for(i = l; i <= r; i++) {
-			buffer[j * sx + i] = 1;
Modified: grass-addons/raster/r.pi/r.pi.rectangle/local_proto.h
--- grass-addons/raster/r.pi/r.pi.rectangle/local_proto.h	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.rectangle/local_proto.h	2010-07-30 08:30:00 UTC (rev 42954)
@@ -11,6 +11,7 @@
 #include <time.h>
 /* buffer.c */
-void set_buffer(CELL* buffer, int x, int y, int width, int height, int sx, int sy, int align);
+		int sy, int align);
Modified: grass-addons/raster/r.pi/r.pi.rectangle/main.c
--- grass-addons/raster/r.pi/r.pi.rectangle/main.c	2010-07-29 19:46:31 UTC (rev 42953)
+++ grass-addons/raster/r.pi/r.pi.rectangle/main.c	2010-07-30 08:30:00 UTC (rev 42954)
@@ -1,250 +1,263 @@
-	r.pi.rectangle programming.
+   r.pi.rectangle programming.
 struct alignment
-	int index;
+    int index;
-static struct alignment alignments[] =
-	{"center", "Key pixel will be the center of the buffer.", 0},
- 	{"top-left", "Key pixel will be top-left of the buffer.", 1},
- 	{"top-right", "Key pixel will be the top-right of the buffer.", 2},
- 	{"bottom-left", "Key pixel will be the bottom-left of the buffer.", 3},
- 	{"bottom-right", "Key pixel will be the bottom-right of the buffer.", 4},
- 	{0,0,0}
+static struct alignment alignments[] = {
+    {"center", "Key pixel will be the center of the buffer.", 0},
+    {"top-left", "Key pixel will be top-left of the buffer.", 1},
+    {"top-right", "Key pixel will be the top-right of the buffer.", 2},
+    {"bottom-left", "Key pixel will be the bottom-left of the buffer.", 3},
+    {"bottom-right", "Key pixel will be the bottom-right of the buffer.", 4},
+    {0, 0, 0}
-	/* input */
-	char *oldname, *oldmapset;
-	/* input */
-	char *newname, *newmapset;
-	int in_fd;
-	int out_fd;
-	/* parameters */
-	int keyval;
-	int x, y;
-	int align;
-	int sx, sy;
-	/* maps */
-	CELL *map, *newmap;
-	/* other parameters */
-	char *title;
-	/* helper variables */
-	int row, col;
-	CELL *result;
-	char* str;
-	int n, i;
-	struct
-		struct Option *keyval, *x, *y;
-		struct Option *alignment;
-	} parm;
+    /* input */
+    char *oldname, *oldmapset;
+    /* input */
+    char *newname, *newmapset;
-		_("Generates a rectangle based on a corner coordinate.");
+    int in_fd;
-	parm.input->description= _("raster file with single pixels representing sampling points") ;
+    int out_fd;
-	parm.output->gisprompt  = "new,cell,raster,output" ;
-	parm.output->description= _("Name for the output raster file") ;
+    /* parameters */
+    int keyval;
-	parm.keyval->description= _("Pixel value in the input raster to be used") ;
-	parm.x = G_define_option() ;
-	parm.x->key        = "x" ;
-	parm.x->type       = TYPE_INTEGER ;
-	parm.x->required   = YES ;
-	parm.x->description= _("extent of generated area on the x axis (width) in pixel") ;
+    int x, y;
-	parm.y = G_define_option() ;
-	parm.y->key        = "y" ;
-	parm.y->type       = TYPE_INTEGER ;
-	parm.y->required   = YES ;
-	parm.y->description= _("extent of generated area on the y axis (height) in pixel") ;
-	parm.alignment = G_define_option() ;
-	parm.alignment->key        = "alignment" ;
-	parm.alignment->type       = TYPE_STRING ;
-	parm.alignment->required   = YES ;
-	str = parm.alignment->options  = G_malloc(1024);
-	for (n = 0; alignments[n].name; n++)
-		if (n)
-			strcat (str, ",");
-		else
-			*str = 0;
-		strcat (str, alignments[n].name);
-	parm.alignment->description= _("alignment of the rectangle relative to the input pixel. options: center, top-left, top-right, bottom") ;
+    int align;
+    int sx, sy;
+    /* maps */
+    CELL *map, *newmap;
-	/* get name of input file */
+    /* other parameters */
+    char *title;
-	/* test input files existence */
-	if( (oldmapset = G_find_cell2(oldname,"")) == NULL )
-		G_warning ( _("%s: <%s> raster file not found\n"), G_program_name(), oldname);
-		G_usage();
-		G_warning("%s: <%s> illegal file name\n", G_program_name(), newname);
-	/* read keyval */
-	/* read x */
-	sscanf(parm.x->answer, "%d", &x);
-	/* read y */
-	sscanf(parm.y->answer, "%d", &y);
-	/* get size */
-	sx = G_window_cols();
-	sy = G_window_rows();
-	/* find alignment */
-	for (n = 0; (str = alignments[n].name); n++)
-		if (strcmp(str, parm.alignment->answer) == 0)
-			break;
-	if (str) {
-		align = alignments[n].index;
-	} else {
-				   parm.alignment->key, parm.alignment->answer, parm.alignment->key);
-		G_usage();
+    /* helper variables */
+    int row, col;
-	/* allocate map buffers */
-	map = (CELL*) G_malloc (sx * sy * sizeof(CELL));
-	newmap = (CELL*) G_malloc(sx * sy * sizeof(CELL));
-	result = G_allocate_c_raster_buf();
-	/* fill newmap with null */
-	G_set_c_null_value(newmap, sx * sy);
-	/* open map */
-		G_fatal_error ( _("can't open cell file <%s> in mapset %s\n"), oldname, oldmapset);
-		G_usage();
+    CELL *result;
+    char *str;
+    int n, i;
+    struct
+	struct Option *keyval, *x, *y;
+	struct Option *alignment;
+    } parm;
+	_("Generates a rectangle based on a corner coordinate.");
+	_("raster file with single pixels representing sampling points");
+    parm.output->gisprompt = "new,cell,raster,output";
+    parm.output->description = _("Name for the output raster file");
+	_("Pixel value in the input raster to be used");
+    parm.x = G_define_option();
+    parm.x->key = "x";
+    parm.x->type = TYPE_INTEGER;
+    parm.x->required = YES;
+    parm.x->description =
+	_("extent of generated area on the x axis (width) in pixel");
+    parm.y = G_define_option();
+    parm.y->key = "y";
+    parm.y->type = TYPE_INTEGER;
+    parm.y->required = YES;
+    parm.y->description =
+	_("extent of generated area on the y axis (height) in pixel");
+    parm.alignment = G_define_option();
+    parm.alignment->key = "alignment";
+    parm.alignment->type = TYPE_STRING;
+    parm.alignment->required = YES;
+    str = parm.alignment->options = G_malloc(1024);
+    for (n = 0; alignments[n].name; n++) {
+	if (n)
+	    strcat(str, ",");
+	else
+	    *str = 0;
+	strcat(str, alignments[n].name);
+    parm.alignment->description =
+	_("alignment of the rectangle relative to the input pixel. options: center, top-left, top-right, bottom");
+    /* get name of input file */
+    /* test input files existence */
+    if ((oldmapset = G_find_cell2(oldname, "")) == NULL) {
+	G_warning(_("%s: <%s> raster file not found\n"), G_program_name(),
+		  oldname);
+	G_usage();
+	G_warning("%s: <%s> illegal file name\n", G_program_name(), newname);
+    /* read keyval */
+    /* read x */
+    sscanf(parm.x->answer, "%d", &x);
+    /* read y */
+    sscanf(parm.y->answer, "%d", &y);
+    /* get size */
+    sx = G_window_cols();
+    sy = G_window_rows();
+    /* find alignment */
+    for (n = 0; (str = alignments[n].name); n++)
+	if (strcmp(str, parm.alignment->answer) == 0)
+	    break;
+    if (str) {
+	align = alignments[n].index;
+    else {
+		  parm.alignment->key, parm.alignment->answer,
+		  parm.alignment->key);
+	G_usage();
+    /* allocate map buffers */
+    map = (CELL *) G_malloc(sx * sy * sizeof(CELL));
+    newmap = (CELL *) G_malloc(sx * sy * sizeof(CELL));
+    result = G_allocate_c_raster_buf();
+    /* fill newmap with null */
+    G_set_c_null_value(newmap, sx * sy);
+    /* open map */
+	G_fatal_error(_("can't open cell file <%s> in mapset %s\n"), oldname,
+		      oldmapset);
+	G_usage();
+    /* read map */
+    G_message("Reading map file:\n");
+    for (row = 0; row < sy; row++) {
+	G_get_c_raster_row(in_fd, map + row * sx, row);
+	G_percent(row + 1, sy, 1);
+    /* create buffers */
+	for (col = 0; col < sx; col++) {
+	    if (map[row * sx + col] == keyval) {
+		set_buffer(newmap, col, row, x, y, sx, sy, align);
-	/* read map */
-	G_message("Reading map file:\n");
-	for (row = 0; row < sy; row++) {
-		G_get_c_raster_row (in_fd, map + row * sx, row);
-		G_percent (row + 1, sy, 1);
+    /* close map */
+    G_message("Writing output ... ");
+    /* open cell file */
+    /* open new cell file  */
+    out_fd = G_open_raster_new(newname, CELL_TYPE);
+    if (out_fd < 0) {
+	G_fatal_error("Can't create new cell file <%s> in mapset %s", newname,
+		      newmapset);
+    /* write output */
+	G_set_c_null_value(result, sx);
+	    result[col] = newmap[row * sx + col];
-	/* create buffers */
-	for(row = 0; row < sy; row++) {
-		for(col = 0; col < sx; col++) {
-			if(map[row * sx + col] == keyval) {
-				set_buffer(newmap, col, row, x, y, sx, sy, align);
-	/* close map */
-	G_close_cell(in_fd);
-	G_message("Writing output ... ");
+	G_put_c_raster_row(out_fd, result);
-	/* open cell file */
-	/* open new cell file  */
-	out_fd = G_open_raster_new (newname, CELL_TYPE);
-	if (out_fd < 0) {
-		G_fatal_error("Can't create new cell file <%s> in mapset %s", newname, newmapset);
-	/* write output */
-		G_set_c_null_value(result, sx);
-			result[col] = newmap[row * sx + col];
-		G_put_c_raster_row(out_fd, result);
-	/* close new file */
-	G_close_cell(out_fd);
-	/* free allocated resources */
-	G_free(map);
-	G_free(newmap);
-	G_free(result);
-	exit(EXIT_SUCCESS);
+    /* close new file */
+    /* free allocated resources */
+    G_free(map);
+    G_free(newmap);
+    G_free(result);
+    exit(EXIT_SUCCESS);
