[GRASS-SVN] r42416 - in grass/trunk: . locale/po
svn_grass at osgeo.org
Tue Jun 1 08:05:00 EDT 2010
Author: neteler
Date: 2010-06-01 08:05:00 -0400 (Tue, 01 Jun 2010)
New Revision: 42416
grass/trunk/locale/po/grasslibs_it.po
grass/trunk/translators.csv
Andrea Giacomelli : cont'ed
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po 2010-06-01 12:04:31 UTC (rev 42415)
+++ grass/trunk/locale/po/grasslibs_it.po 2010-06-01 12:05:00 UTC (rev 42416)
@@ -1,25 +1,26 @@
# translation of grasslibs_it.po to Italian
# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2005, 2006, 2007 GRASS Development Team
+# Copyright (C) 2005, 2006, 2007, 2010 GRASS Development Team
# Maurizio Napolitano <napo at itc.it>, 2005.
# Markus Neteler <neteler at itc.it>, 2005.
# Luciano Montanaro <mikelima at cirulla.net>, 2006.
# Giuseppe Patti <gpatt at tiscali.it>, 2006.
# Tobias Vigl <vigltobias at icqmail.com>, 2007.
+# Andrea Giacomelli <pibinko at gmail.com>, 2010.
msgid ""
msgstr ""
"Project-Id-Version: grasslibs_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2010-02-26 19:45+0100\n"
"PO-Revision-Date: 2007-11-21 12:41+0100\n"
-"Last-Translator: Tobias Vigl <vigltobias at icqmail.com>\n"
+"Last-Translator: Andrea Giacomelli <pibinko at gmail.com>\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
"X-Generator: KBabel 1.11.4\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../lib/gpde/test/test_arrays.c:48
msgid ""
@@ -297,16 +298,16 @@
#: ../lib/gpde/N_arrays_io.c:281 ../lib/gpde/N_arrays_io.c:423
#, c-format
msgid "Error opening g3d map <%s>"
-msgstr ""
+msgstr "Errore nell'apertura della mappa g3d <%s>"
#: ../lib/gpde/N_arrays_io.c:309
#, c-format
msgid "Read g3d map <%s> into the memory"
-msgstr ""
+msgstr "Mappa g3d <%s> caricata in memoria"
#: ../lib/gpde/N_arrays_io.c:364 ../lib/gpde/N_arrays_io.c:464
msgid "Error closing g3d file"
-msgstr ""
+msgstr "Errore nella chiusura del file g3d"
#: ../lib/gpde/N_arrays_io.c:425
#, c-format
@@ -4768,7 +4769,7 @@
#: ../lib/gmath/la.c:266 ../lib/gmath/la.c:331
msgid "Matrix order does not match"
-msgstr ""
+msgstr "L'ordine delle matrici non corrisponde"
#: ../lib/gmath/la.c:272
#, fuzzy
@@ -4794,11 +4795,11 @@
#: ../lib/gmath/la.c:464
msgid "Could not allocate space for solution matrix"
-msgstr ""
+msgstr "Impossibile allocare lo spazio per la matrice della soluzione"
#: ../lib/gmath/la.c:470 ../lib/gmath/la.c:478
msgid "Could not allocate space for working matrix"
-msgstr ""
+msgstr "Impossibile allocare lo spazio per la matrice di lavoro"
#: ../lib/gmath/la.c:531
msgid "Matrix (or submatrix is singular). Solution undetermined"
@@ -4885,7 +4886,7 @@
#: ../lib/gmath/la.c:1002
msgid "Vectors have differing dimensions"
-msgstr ""
+msgstr "I vettori hanno dimensioni differenti"
#: ../lib/gmath/la.c:1008
msgid "Output vector has incorrect dimension"
@@ -4905,7 +4906,7 @@
#: ../lib/gmath/la.c:1395 ../lib/gmath/la.c:1403 ../lib/gmath/la.c:1408
msgid "Input format error"
-msgstr ""
+msgstr "Errore nel formato di input"
#: ../lib/gmath/solvers_direct.c:45
msgid "Starting direct gauss elimination solver"
@@ -5001,7 +5002,7 @@
#: ../lib/rst/interp_float/vinput2d.c:76
msgid "Loading data from attribute table ..."
-msgstr ""
+msgstr "Caricamento dati dalla tabella degli attributi in corso..."
#: ../lib/rst/interp_float/vinput2d.c:97
#: ../lib/rst/interp_float/vinput2d.c:110
@@ -5018,7 +5019,7 @@
#: ../lib/rst/interp_float/vinput2d.c:270
#, c-format
msgid "Database record for cat %d not found"
-msgstr ""
+msgstr "Non trovo il record database per la cat %d"
#: ../lib/rst/interp_float/vinput2d.c:171
#: ../lib/rst/interp_float/vinput2d.c:288
@@ -5249,386 +5250,386 @@
"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
-#~ msgid "quantization file [%s] in mapset [%s] %s"
-#~ msgstr "quantization file [%s] nel mapset [%s] %s"
#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Keywords:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Parole chiave:\n"
+msgid ""
+"\n"
+"Keywords:\n"
+msgstr ""
+"\n"
+"Parole chiave:\n"
-#~ msgid ""
-#~ "\n"
-#~ "Flags:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Flags:\n"
-#~ msgid ""
-#~ "\n"
-#~ "Parameters:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Parametri:\n"
#, fuzzy
-#~ msgid "Raster map <%s> - unable to write row %d"
-#~ msgstr "mappa [%s] - impossibile scrivere nella riga %d"
+msgid "Raster map <%s> - unable to write row %d"
+msgstr "mappa [%s] - impossibile scrivere nella riga %d"
#, fuzzy
-#~ msgid "Error writing floating point format file for map <%s>"
-#~ msgstr "Errore scrivendo file di formato virgola mobile per mappa %s"
+msgid "Error writing floating point format file for map <%s>"
+msgstr "Errore scrivendo file di formato virgola mobile per mappa %s"
#, fuzzy
-#~ msgid "Unable to write feature, OGR layer not defined"
-#~ msgstr "Non riesco a scrivere la linea, la mappa non è aperta"
+msgid "Unable to write feature, OGR layer not defined"
+msgstr "Non riesco a scrivere la linea, la mappa non è aperta"
#, fuzzy
-#~ msgid "Unable to create a new process!"
-#~ msgstr "impossibile creare un nuovo processo"
+msgid "Unable to create a new process!"
+msgstr "impossibile creare un nuovo processo"
#, fuzzy
-#~ msgid ""
-#~ "Region for current mapset %s. Run \"g.region\" to fix the current region."
-#~ msgstr ""
-#~ "regione del mapset in uso %s\n"
-#~ "esegui \"g.region\""
+msgid ""
+"Region for current mapset %s. Run \"g.region\" to fix the current region."
+msgstr ""
+"regione del mapset in uso %s\n"
+"esegui \"g.region\""
#, fuzzy
-#~ msgid "Default region %s"
-#~ msgstr "regione predefinita %s"
+msgid "Default region %s"
+msgstr "regione predefinita %s"
#, fuzzy
-#~ msgid "Unable to set region"
-#~ msgstr "Impossibile aprire %s"
+msgid "Unable to set region"
+msgstr "Impossibile aprire %s"
#, fuzzy
-#~ msgid "Failed writing raster map"
-#~ msgstr "problemi leggendo il file di cellule raster"
+msgid "Failed writing raster map"
+msgstr "problemi leggendo il file di cellule raster"
#, fuzzy
-#~ msgid "Unable to write color file of raster map <%s>"
-#~ msgstr "Impossibile creare il file di intestazione per [%s in %s]"
+msgid "Unable to write color file of raster map <%s>"
+msgstr "Impossibile creare il file di intestazione per [%s in %s]"
#, fuzzy
-#~ msgid "Registering points"
-#~ msgstr "Linee registrate: "
+msgid "Registering points"
+msgstr "Linee registrate: "
#, fuzzy
-#~ msgid "Registered points"
+msgid "Registered points"
#, fuzzy
-#~ msgid "Registered points (unique coordinates)"
+msgid "Registered points (unique coordinates)"
#, fuzzy
-#~ msgid "Duplicates"
-#~ msgstr "duplicato campo est"
+msgid "Duplicates"
+msgstr "duplicato campo est"
-#~ msgid "Type"
-#~ msgstr "Tipo"
+msgid "Type"
+msgstr "Tipo"
-#~ msgid "G_malloc: out of memory"
-#~ msgstr "G_malloc: fuori memoria"
+msgid "G_malloc: out of memory"
+msgstr "G_malloc: fuori memoria"
-#~ msgid "G_calloc: out of memory"
-#~ msgstr "G_calloc: fuori memoria"
+msgid "G_calloc: out of memory"
+msgstr "G_calloc: fuori memoria"
-#~ msgid "G_realloc: out of memory"
-#~ msgstr "G_realloc: fuori memoria"
+msgid "G_realloc: out of memory"
+msgstr "G_realloc: fuori memoria"
#, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "Non posso cancellare la linea"
+msgid "Cannot get layer info"
+msgstr "Non posso cancellare la linea"
#, fuzzy
-#~ msgid "Cannot open database %s"
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgid "Cannot open database %s"
+msgstr "Non posso scrivere i collegamenti del database"
#, fuzzy
-#~ msgid "Unable to query drawable"
-#~ msgstr "Impossibile aprire il file %s in %s"
+msgid "Unable to query drawable"
+msgstr "Impossibile aprire il file %s in %s"
#, fuzzy
-#~ msgid "Failed to initialize Xlib surface"
+msgid "Failed to initialize Xlib surface"
#, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot describe table <%s>"
#, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
+msgid "Cannot read topo for line [%d]"
+msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "Il nome '%s' in output non è un nome di raster valido."
+msgid "Output name '%s' is not valid rast name."
+msgstr "Il nome '%s' in output non è un nome di raster valido."
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "La mappa '%s' in output è utilizzata come input"
+msgid "Output map '%s' is used as input"
+msgstr "La mappa '%s' in output è utilizzata come input"
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "impossibile aprire un raster [%s in %s]"
+msgid "unable to open raster map [%s in %s]"
+msgstr "impossibile aprire un raster [%s in %s]"
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "Non riesco a leggere il file di intestazione per [%s in %s]\n"
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "Non riesco a leggere il file di intestazione per [%s in %s]\n"
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "Non riesco ad aprire il file di intestazione per [%s in %s]"
+msgid "Can't open header file for [%s in %s]"
+msgstr "Non riesco ad aprire il file di intestazione per [%s in %s]"
#, fuzzy
-#~ msgid "Cannot get field info"
+msgid "Cannot get field info"
#, fuzzy
-#~ msgid "Cannot open database"
+msgid "Cannot open database"
-#~ msgid "Building topology ...\n"
-#~ msgstr "Creazione topologia...\n"
+msgid "Building topology ...\n"
+msgstr "Creazione topologia...\n"
-#~ msgid ""
-#~ "\r%d areas built \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d aree create \n"
-#~ "%d isole create\n"
+msgid ""
+"\r%d areas built \n"
+"%d isles built\n"
+msgstr ""
+"\r%d aree create \n"
+"%d isole create\n"
#, fuzzy
-#~ msgid "Cannot get column info"
+msgid "Cannot get column info"
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "Vect_rewrite_line() non supportato per questo formato/livello"
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "Vect_rewrite_line() non supportato per questo formato/livello"
-#~ msgid "Vect_delete_line() for this format/level not supported"
-#~ msgstr "Vect_delete_line() non supportato per questo formato/livello"
+msgid "Vect_delete_line() for this format/level not supported"
+msgstr "Vect_delete_line() non supportato per questo formato/livello"
#, fuzzy
-#~ msgid "Cannot delete line"
-#~ msgstr "Non riesco a riscrivere la linea"
+msgid "Cannot delete line"
+msgstr "Non riesco a riscrivere la linea"
-#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr "Il nome '%s' in output non è valido per un vettore."
+msgid "Output name '%s' is not valid vector name."
+msgstr "Il nome '%s' in output non è valido per un vettore."
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "Non posso copiare il vettore '%s' nel '%s'"
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "Non posso copiare il vettore '%s' nel '%s'"
#, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "Non posso cancellare il vettoriale %s"
+msgid "Cannot open existing vector map <%s>"
+msgstr "Non posso cancellare il vettoriale %s"
#, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "Non posso aprire il nuovo vettoriale %s"
+msgid "Cannot open new vector %s"
+msgstr "Non posso aprire il nuovo vettoriale %s"
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
+msgid "Cannot open history file for vector '%s'"
+msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
-#~ msgid "Could not stat file '%s'"
-#~ msgstr "Non riesco a trovare il file \"%s\""
+msgid "Could not stat file '%s'"
+msgstr "Non riesco a trovare il file \"%s\""
#, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "Non riesco ad aprire il vecchio vettoriale %s"
+msgid "Can't open directory %s"
+msgstr "Non riesco ad aprire il vecchio vettoriale %s"
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** nome illegale **"
+msgid "%s - ** illegal name **"
+msgstr "%s - ** nome illegale **"
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "Non trovo un monitor grafico per <%s>.\n"
+msgid "No such graphics monitor as <%s>.\n"
+msgstr "Non trovo un monitor grafico per <%s>.\n"
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr ""
-#~ "Per piacere avvia \"d.mon\" per selezionare un monitor grafico valido.\n"
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgstr ""
+"Per piacere avvia \"d.mon\" per selezionare un monitor grafico valido.\n"
#, fuzzy
-#~ msgid "Can't stat %s\n"
-#~ msgstr "Non è possibile trovare %s\n"
+msgid "Can't stat %s\n"
+msgstr "Non è possibile trovare %s\n"
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Errore - Monitor <%s> in uso.\n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "Errore - Monitor <%s> in uso.\n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "Errore - il Monitor <%s> è in uso da %s.\n"
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr "Errore - il Monitor <%s> è in uso da %s.\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr ""
-#~ "Errore - non riesco a completare il blocco del processo per il monitor <%"
-#~ "s>.\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr ""
+"Errore - non riesco a completare il blocco del processo per il monitor <%"
+"s>.\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Errore - non riesco a creare una pipe al dispositivo grafico.\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "Errore - non riesco a creare una pipe al dispositivo grafico.\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Errore -il monitor grafico <%s> non è stato avviato!\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "Errore -il monitor grafico <%s> non è stato avviato!\n"
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "Per piacere avvia il monitor grafico <%s>.\n"
+msgid "Please start graphics monitor <%s>.\n"
+msgstr "Per piacere avvia il monitor grafico <%s>.\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "Non connesso...\n"
+msgid "Not connected...\n"
+msgstr "Non connesso...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "Non riesco a collegarmi al monitor. Provo a farlo ancora.\n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr "Non riesco a collegarmi al monitor. Provo a farlo ancora.\n"
#, fuzzy
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr "Dimensione della cella delle mappe in fp = %d\n"
+msgid "Size of cell in fp maps = %d"
+msgstr "Dimensione della cella delle mappe in fp = %d\n"
#, fuzzy
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr "per mappe raster presenti %d\n"
+msgid "type for writing floating maps = %d"
+msgstr "per mappe raster presenti %d\n"
#, fuzzy
-#~ msgid "current window = %p"
-#~ msgstr "finestra corrente = %p\n"
+msgid "current window = %p"
+msgstr "finestra corrente = %p\n"
#, fuzzy
-#~ msgid "Flag: window set? %d"
-#~ msgstr "Flag: finestra scelta? %d\n"
+msgid "Flag: window set? %d"
+msgstr "Flag: finestra scelta? %d\n"
#, fuzzy
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "Descrizione del file per la maschera automatica %d\n"
+msgid "File descriptor for automatic mask %d"
+msgstr "Descrizione del file per la maschera automatica %d\n"
#, fuzzy
-#~ msgid "Flag denoting automatic masking %d"
+msgid "Flag denoting automatic masking %d"
#, fuzzy
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "CELL maschera del buffer %p\n"
+msgid "CELL mask buffer %p"
+msgstr "CELL maschera del buffer %p\n"
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "buffer di lettura delle righe vuote %p"
+msgid "buffer for reading null rows %p"
+msgstr "buffer di lettura delle righe vuote %p"
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "Buffer di dati pre/post compressi %p"
+msgid "Pre/post compressed data buffer %p"
+msgstr "Buffer di dati pre/post compressi %p"
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "dimensione del compressed_buf %d"
+msgid "sizeof compressed_buf %d"
+msgstr "dimensione del compressed_buf %d"
-#~ msgid "work data buffer %p"
-#~ msgstr "work data buffer %p"
+msgid "work data buffer %p"
+msgstr "work data buffer %p"
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "dimensione del work_buf %d"
+msgid "sizeof work_buf %d"
+msgstr "dimensione del work_buf %d"
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "dimensione null_buf %d"
+msgid "sizeof null_buf %d"
+msgstr "dimensione null_buf %d"
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "dimensione mask_buf %d"
+msgid "sizeof mask_buf %d"
+msgstr "dimensione mask_buf %d"
-#~ msgid "Histogram request %d"
-#~ msgstr "Istogramma richiesto %d"
+msgid "Histogram request %d"
+msgstr "Istogramma richiesto %d"
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: file #%d"
+msgid "G_dump: file #%d"
+msgstr "G_dump: file #%d"
-#~ msgid "open mode = %d"
-#~ msgstr "modalità di apertura = %d"
+msgid "open mode = %d"
+msgstr "modalità di apertura = %d"
-#~ msgid "Cell header %p"
-#~ msgstr "Intestazione cella %p"
+msgid "Cell header %p"
+msgstr "Intestazione cella %p"
#, fuzzy
-#~ msgid "Table reclass %p"
-#~ msgstr "Tabella di riclassificazione %p\n"
+msgid "Table reclass %p"
+msgstr "Tabella di riclassificazione %p\n"
#, fuzzy
-#~ msgid "Cell stats %p"
-#~ msgstr "Intestazione cella %p\n"
+msgid "Cell stats %p"
+msgstr "Intestazione cella %p\n"
#, fuzzy
-#~ msgid "Range structure %p"
-#~ msgstr "Struttura intervallo %p\n"
+msgid "Range structure %p"
+msgstr "Struttura intervallo %p\n"
#, fuzzy
-#~ msgid "float Range structure %p"
+msgid "float Range structure %p"
#, fuzzy
-#~ msgid "want histogram? %d"
-#~ msgstr "vuoi un istogramma? %d\n"
+msgid "want histogram? %d"
+msgstr "vuoi un istogramma? %d\n"
#, fuzzy
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "nbyte per cella nella riga corrente %d\n"
+msgid "nbytes per cell for current row %d"
+msgstr "nbyte per cella nella riga corrente %d\n"
#, fuzzy
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "Buffer di dati decompresso %s\n"
+msgid "Decompressed data buffer %s"
+msgstr "Buffer di dati decompresso %s\n"
#, fuzzy
-#~ msgid "bytes per cell %d"
-#~ msgstr "byte per cella %d\n"
+msgid "bytes per cell %d"
+msgstr "byte per cella %d\n"
#, fuzzy
-#~ msgid "type: int, float or double map %d"
-#~ msgstr "tipi: mappa int, float o double %d\n"
+msgid "type: int, float or double map %d"
+msgstr "tipi: mappa int, float o double %d\n"
#, fuzzy
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "Nome temporaneo per NUOVI file %s\n"
+msgid "Temporary name for NEW files %s"
+msgstr "Nome temporaneo per NUOVI file %s\n"
#, fuzzy
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "Nome temporaneo per NUOVI file VUOTI %s\n"
+msgid "Temporary name for NEW NULL files %s"
+msgstr "Nome temporaneo per NUOVI file VUOTI %s\n"
#, fuzzy
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Mapset del file d'aprire%s\n"
+msgid "Mapset of open file %s"
+msgstr "Mapset del file d'aprire%s\n"
#, fuzzy
-#~ msgid "io error warning given %d"
-#~ msgstr "attenzione ho ricevuto un errore di i/o %d\n"
+msgid "io error warning given %d"
+msgstr "attenzione ho ricevuto un errore di i/o %d\n"
#, fuzzy
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "NULL_ROWS array[%d] = %p\n"
+msgid "NULL_ROWS array[%d] = %p"
+msgstr "NULL_ROWS array[%d] = %p\n"
#, fuzzy
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "buffer di lettura delle righe vuote %p\n"
+msgid "data buffer for reading null rows %p"
+msgstr "buffer di lettura delle righe vuote %p\n"
#, fuzzy
-#~ msgid "G_dump: end"
-#~ msgstr "G_dump: file #%d\n"
+msgid "G_dump: end"
+msgstr "G_dump: file #%d\n"
#, fuzzy
-#~ msgid "Current window not settable"
+msgid "Current window not settable"
#, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
#, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
-#~ msgid "Too many open raster maps"
-#~ msgstr "Troppi file raster aperti"
+msgid "Too many open raster maps"
+msgstr "Troppi file raster aperti"
-#~ msgid "Too many open files"
-#~ msgstr "Troppi file aperti"
+msgid "Too many open files"
+msgstr "Troppi file aperti"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "ERRORE: GISBASE non definito\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "ERRORE: GISBASE non definito\n"
-#~ msgid "unable to find [%s] in [%s]"
-#~ msgstr "impossibile trovare [%s] in [%s]"
+msgid "unable to find [%s] in [%s]"
+msgstr "impossibile trovare [%s] in [%s]"
+#~ msgid "quantization file [%s] in mapset [%s] %s"
+#~ msgstr "quantization file [%s] nel mapset [%s] %s"
+#~ msgid ""
+#~ "\n"
+#~ "Flags:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Flags:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Parameters:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Parametri:\n"
#, fuzzy
#~ msgid "Unable to open raster map <%s>"
#~ msgstr "impossibile cambiare la directory %s"
@@ -5683,7 +5684,6 @@
#~ msgid "Feature: "
#~ msgstr "Tipo di "
-#, fuzzy
#~ msgid "Too many arguments"
#~ msgstr "troppi argomenti"
@@ -6313,3 +6313,46 @@
#, fuzzy
#~ msgid "Unable to create raster map <%s>"
+#~ msgid "The floating data range for %s@%s is empty"
+#~ msgstr "Il valore floating per l'intervallo %s@%s è vuoto"
+#~ msgid "The integer data range for %s@%s is empty"
+#~ msgstr "Il valore intero per l'intervallo %s@%s è vuoto"
+#~ msgid ""
+#~ "\n"
+#~ "Description:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Descrizione:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Keywords:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Parole chiave:\n"
+#~ msgid ""
+#~ "\n"
+#~ "Usage:\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Uso:\n"
+#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
+#~ msgstr ""
+#~ "Impossibile trovare la colonna z <%s> (si prega di verificarne il nome "
+#~ "con v.info)"
+#~ msgid "Reading lines from vector map ... "
+#~ msgstr "Lettura linee dalla mappa vettorialie..."
+#~ msgid "Reading nodes from vector map ... "
+#~ msgstr "Lettura nodi dalla mappa vettoriale..."
+#~ msgid "ignoring %d points -- too dense"
+#~ msgstr "Ignorati %d punti -- densità eccessiva"
Modified: grass/trunk/translators.csv
--- grass/trunk/translators.csv 2010-06-01 12:04:31 UTC (rev 42415)
+++ grass/trunk/translators.csv 2010-06-01 12:05:00 UTC (rev 42416)
@@ -27,6 +27,7 @@
Firman Hadi,<jalmiburung gmail.com>,ID
Lorenzo Moretti,<lorenzo.moretti bologna.enea.it>,IT
Luca Delucchi,<lucadeluge gmail.com>,IT
+Andrea Giacomelli,<pibinko gmail.com>,IT
Luciano Montanaro,<mikelima cirulla.net>,IT
Tobias Vigl,<vigltobias icqmail.com>,IT
Stefano Costa,<steko iosa.it>,IT
