[GRASS-SVN] r42428 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jun 1 16:34:57 EDT 2010
Author: martinl
Date: 2010-06-01 16:34:56 -0400 (Tue, 01 Jun 2010)
New Revision: 42428
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI: interactive input allowed (file, rules, etc.)
(merge r42425 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-06-01 20:32:41 UTC (rev 42427)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-06-01 20:34:56 UTC (rev 42428)
@@ -57,6 +57,7 @@
from threading import Thread
import Queue
import shlex
+import tempfile
### i18N
import gettext
@@ -420,7 +421,9 @@
for p in self.params:
if p.get('value', '') == '' and p.get('required', 'no') != 'no':
if p.get('default', '') == '':
- desc = p.get('label', p['description'])
+ desc = p.get('label', '')
+ if not desc:
+ desc = p['description']
errorList.append(_("Parameter '%(name)s' (%(desc)s) is missing.") % \
{'name' : p['name'], 'desc' : desc })
@@ -1435,10 +1438,23 @@
fbb.SetValue(p['value']) # parameter previously set
which_sizer.Add(item=fbb, proportion=0,
flag=wx.EXPAND | wx.RIGHT, border=5)
+ # widget for interactive input
+ ifbb = wx.TextCtrl(parent = which_panel, id = wx.ID_ANY,
+ style = wx.TE_MULTILINE,
+ size = (-1, 75))
+ ifbb.Bind(wx.EVT_TEXT, self.OnFileText)
+ which_sizer.Add(item = wx.StaticText(parent = which_panel, id = wx.ID_ANY,
+ label = _('or enter values interactively')),
+ proportion=0,
+ flag=wx.EXPAND | wx.RIGHT | wx.LEFT | wx.BOTTOM, border=5)
+ which_sizer.Add(item=ifbb, proportion=0,
+ flag=wx.EXPAND | wx.RIGHT | wx.LEFT, border=5)
# A file browse button is a combobox with two children:
# a textctl and a button;
# we have to target the button here
- p['wxId'] = [ fbb.GetChildren()[1].GetId(), ]
+ p['wxId'] = [ fbb.GetChildren()[1].GetId(), ifbb.GetId() ]
if self.parent.GetName() == 'MainFrame' and self.parent.modeler:
parChk = wx.CheckBox(parent = which_panel, id = wx.ID_ANY,
@@ -1564,6 +1580,28 @@
self.Bind(EVT_DIALOG_UPDATE, self.OnUpdateDialog)
+ def OnFileText(self, event):
+ """File input interactively entered"""
+ text = event.GetString()
+ p = self.task.get_param(value = event.GetId(), element = 'wxId', raiseError = False)
+ if not p:
+ return # should not happen
+ win = self.FindWindowById(p['wxId'][0])
+ if text:
+ filename = win.GetValue()
+ if not filename:
+ # outFile = tempfile.NamedTemporaryFile(mode='w+b')
+ filename = grass.tempfile()
+ win.SetValue(filename)
+ f = open(filename, "w")
+ try:
+ f.write(text)
+ finally:
+ f.close()
+ else:
+ win.SetValue('')
def OnUpdateDialog(self, event):
for fn, kwargs in event.data.iteritems():
fn(**kwargs)
