[GRASS-SVN] r42437 - grass/trunk/scripts/r.colors.stddev
svn_grass at osgeo.org
Wed Jun 2 06:15:20 EDT 2010
Author: martinl
Date: 2010-06-02 06:15:19 -0400 (Wed, 02 Jun 2010)
New Revision: 42437
grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
fix r42436
Modified: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py 2010-06-02 10:08:55 UTC (rev 42436)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py 2010-06-02 10:15:19 UTC (rev 42437)
@@ -52,12 +52,12 @@
global tmpmap
tmpmap = None
- input = options['input']
+ map = options['map']
zero = flags['z']
bands = flags['b']
if not zero:
- s = grass.read_command('r.univar', flags = 'g', map = input)
+ s = grass.read_command('r.univar', flags = 'g', map = map)
kv = grass.parse_key_val(s)
global mean, stddev
mean = float(kv['mean'])
@@ -75,7 +75,7 @@
# banded free floating black/red/yellow/green/yellow/red/black
# reclass with labels only works for category (integer) based maps
- #r.reclass input="$GIS_OPT_INPUT" output="${GIS_OPT_INPUT}.stdevs" << EOF
+ #r.reclass map="$GIS_OPT_MAP" output="${GIS_OPT_MAP}.stdevs" << EOF
# >3 S.D. outliers colored black so they show up in d.histogram w/ white background
rules = '\n'.join([
@@ -95,14 +95,14 @@
"100% black"])
else:
tmpmap = "r_col_stdev_abs_%d" % os.getpid()
- grass.mapcalc("$tmp = abs($input)", tmp = tmpmap, input = input)
+ grass.mapcalc("$tmp = abs($map)", tmp = tmpmap, map = map)
# data centered on 0 (e.g. map of deviations)
info = grass.raster_info(tmpmap)
maxv = info['max']
# current r.univar truncates percentage to the base integer
- s = grass.read_command('r.univar', flags = 'eg', map = input, percentile = [95.45,68.2689,99.7300])
+ s = grass.read_command('r.univar', flags = 'eg', map = map, percentile = [95.45,68.2689,99.7300])
stddev1 = float(kv['percentile_68'])
@@ -138,7 +138,7 @@
"%f black" % maxv,
- grass.write_command('r.colors', map = input, rules = '-', stdin = rules)
+ grass.write_command('r.colors', map = map, rules = '-', stdin = rules)
if __name__ == "__main__":
options, flags = grass.parser()
