[GRASS-SVN] r42472 - in grass/trunk/gui/wxpython: gui_modules xml
svn_grass at osgeo.org
Thu Jun 3 15:01:51 EDT 2010
Author: martinl
Date: 2010-06-03 15:01:47 -0400 (Thu, 03 Jun 2010)
New Revision: 42472
grass/trunk/gui/wxpython/gui_modules/ghelp.py
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/xml/grass-gxm.dtd
wxGUI/gmodeler: enable/disable actions
Modified: grass/trunk/gui/wxpython/gui_modules/ghelp.py
--- grass/trunk/gui/wxpython/gui_modules/ghelp.py 2010-06-03 17:43:30 UTC (rev 42471)
+++ grass/trunk/gui/wxpython/gui_modules/ghelp.py 2010-06-03 19:01:47 UTC (rev 42472)
@@ -69,7 +69,7 @@
self._searchDict = { _('description') : 'description',
_('command') : 'command',
_('keywords') : 'keywords' }
self.box = wx.StaticBox(parent = self, id = wx.ID_ANY,
label=" %s " % _("Find module(s)"))
@@ -159,7 +159,7 @@
if self.cmdPrompt.CheckKey(text, data['keywords']):
found = True
else: # command
- if text in module:
+ if module[:len(text)] == text:
found = True
if found:
@@ -172,7 +172,7 @@
if not modules.has_key(group):
modules[group] = list()
modules[group].append(name)
self.cmdPrompt.SetFilter(modules)
self.searchChoice.SetItems(self.cmdPrompt.GetCommandItems())
if self.showTip:
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-06-03 17:43:30 UTC (rev 42471)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-06-03 19:01:47 UTC (rev 42472)
@@ -157,7 +157,9 @@
height = action['size'][1],
task = action['task'])
actionItem.SetId(action['id'])
+ if action['disabled']:
+ actionItem.Enable(False)
self.actions.append(actionItem)
task = actionItem.GetTask()
@@ -225,9 +227,11 @@
def Run(self, log, onDone):
"""!Run model"""
for action in self.actions:
+ if not action.IsEnabled():
+ continue
log.RunCmd(command = action.GetLog(string = False),
onDone = onDone)
def DeleteIntermediateData(self, log):
"""!Detele intermediate data"""
rast, vect, rast3d, msg = self.GetIntermediateData()
@@ -289,6 +293,8 @@
result = dict()
idx = 0
+ continue
name = action.GetName()
params = action.GetParams()
for f in params['flags']:
@@ -400,14 +406,18 @@
"""!Get model"""
return self.model
- def ModelChanged(self):
+ def ModelChanged(self, changed = True):
"""!Update window title"""
- if not self.modelChanged:
- self.modelChanged = True
+ self.modelChanged = changed
if self.modelFile:
- self.SetTitle(self.baseTitle + " - " + os.path.basename(self.modelFile) + '*')
+ if self.modelChanged:
+ self.SetTitle(self.baseTitle + " - " + os.path.basename(self.modelFile) + '*')
+ else:
+ self.SetTitle(self.baseTitle + " - " + os.path.basename(self.modelFile))
+ else:
+ self.SetTitle(self.baseTitle)
def OnRemoveItem(self, event):
"""!Remove shape
@@ -415,6 +425,31 @@
def OnCloseWindow(self, event):
"""!Close window"""
+ if self.modelChanged and \
+ UserSettings.Get(group='manager', key='askOnQuit', subkey='enabled'):
+ if self.modelFile:
+ message = _("Do you want to save changes in the model?")
+ else:
+ message = _("Do you want to store current model settings "
+ "to model file?")
+ # ask user to save current settings
+ dlg = wx.MessageDialog(self,
+ message = message,
+ caption=_("Quit Graphical Modeler"),
+ style = wx.YES_NO | wx.YES_DEFAULT |
+ wx.CANCEL | wx.ICON_QUESTION | wx.CENTRE)
+ ret = dlg.ShowModal()
+ if ret == wx.ID_YES:
+ if not self.modelFile:
+ self.OnWorkspaceSaveAs()
+ else:
+ self.WriteModelFile(self.modelFile)
+ elif ret == wx.ID_CANCEL:
+ dlg.Destroy()
+ return
+ dlg.Destroy()
self.Destroy()
def OnPreferences(self, event):
@@ -648,6 +683,8 @@
self.goutput.cmdThread.SetId(-1)
for action in self.model.GetActions():
+ continue
if params.has_key(name):
paramsOrig = action.GetParams(dcopy = True)
@@ -929,7 +966,9 @@
# add action to canvas
width, height = self.canvas.GetSize()
action = ModelAction(self, cmd = cmd, x = width/2, y = height/2)
- action.GetTask().set_flag('overwrite', self.properties['overwrite'])
+ overwrite = self.model.GetProperties().get('overwrite', None)
+ if overwrite is not None:
+ action.GetTask().set_flag('overwrite', overwrite)
self.canvas.diagram.AddShape(action)
action.Show(True)
@@ -1140,6 +1179,7 @@
@return True on success
@return False on failure
+ self.ModelChanged(False)
tmpfile = tempfile.TemporaryFile(mode='w+b')
try:
WriteModelFile(fd = tmpfile,
@@ -1229,6 +1269,7 @@
self.isValid = False
self.isParameterized = False
+ self.isEnabled = True
if self.parent.GetCanvas():
ogl.RectangleShape.__init__(self, width, height)
@@ -1237,32 +1278,35 @@
self.SetX(x)
self.SetY(y)
self.SetPen(wx.BLACK_PEN)
- self._setPen(False)
- self._setBrush(False)
+ self._setPen()
+ self._setBrush()
cmd = self.task.getCmd(ignoreErrors = True)
if cmd and len(cmd) > 0:
self.AddText(cmd[0])
else:
self.AddText('<<%s>>' % _("module"))
- def _setBrush(self, isvalid):
+ def _setBrush(self, running = False):
"""!Set brush"""
- if isvalid is None:
+ if running:
color = UserSettings.Get(group='modeler', key='action',
subkey=('color', 'running'))
- elif isvalid:
+ elif not self.isEnabled:
+ subkey=('color', 'disabled'))
+ elif self.isValid:
+ color = UserSettings.Get(group='modeler', key='action',
subkey=('color', 'valid'))
else:
subkey=('color', 'invalid'))
wxColor = wx.Color(color[0], color[1], color[2])
self.SetBrush(wx.Brush(wxColor))
- def _setPen(self, isparameterized):
+ def _setPen(self):
"""!Set pen"""
- self.isParameterized = isparameterized
- if isparameterized:
+ if self.isParameterized:
width = int(UserSettings.Get(group='modeler', key='action',
subkey=('width', 'parameterized')))
else:
@@ -1271,7 +1315,16 @@
pen = self.GetPen()
pen.SetWidth(width)
self.SetPen(pen)
+ def Enable(self, enabled = True):
+ """!Enable/disable action"""
+ self.isEnabled = enabled
+ self.Update()
+ def IsEnabled(self):
+ """!Get True if action is enabled, otherwise False"""
+ return self.isEnabled
def GetId(self):
"""!Get id"""
return self.id
@@ -1339,11 +1392,12 @@
def SetValid(self, isvalid):
"""!Set instance to be valid/invalid"""
self.isValid = isvalid
- self._setBrush(isvalid)
+ self._setBrush()
def SetParameterized(self, isparameterized):
"""!Set action parameterized"""
- self._setPen(isparameterized)
+ self.isParameterized = isparameterized
+ self._setPen()
def AddData(self, item):
"""!Register new data item"""
@@ -1361,15 +1415,15 @@
def Update(self, running = False):
"""!Update action"""
if running:
- self._setBrush(None)
+ self._setBrush(running = True)
else:
- self._setBrush(self.isValid)
- self._setPen(self.isParameterized)
+ self._setBrush()
+ self._setPen()
def OnDraw(self, dc):
"""!Draw action in canvas"""
+ self._setBrush()
+ self._setPen()
ogl.RectangleShape.OnDraw(self, dc)
class ModelData(ogl.EllipseShape):
@@ -1651,6 +1705,13 @@
popupMenu = wx.Menu()
popupMenu.Append(self.popupID1, text=_('Remove'))
self.frame.Bind(wx.EVT_MENU, self.OnRemove, id = self.popupID1)
+ if isinstance(shape, ModelAction):
+ if shape.IsEnabled():
+ popupMenu.Append(self.popupID3, text=_('Disable'))
+ self.frame.Bind(wx.EVT_MENU, self.OnDisable, id = self.popupID3)
+ else:
+ popupMenu.Append(self.popupID3, text=_('Enable'))
+ self.frame.Bind(wx.EVT_MENU, self.OnEnable, id = self.popupID3)
if isinstance(shape, ModelRelation):
popupMenu.AppendSeparator()
@@ -1678,6 +1739,20 @@
self.frame.PopupMenu(popupMenu)
popupMenu.Destroy()
+ def OnDisable(self, event):
+ """!Disable action"""
+ action = self.GetShape()
+ action.Enable(False)
+ self.frame.ModelChanged()
+ self.frame.canvas.Refresh()
+ def OnEnable(self, event):
+ action.Enable(True)
def OnAddPoint(self, event):
"""!Add control point"""
@@ -1708,7 +1783,7 @@
self.frame.GetCanvas().RemoveSelected()
class ModelSearchDialog(wx.Dialog):
- def __init__(self, parent, id = wx.ID_ANY, title = _("Select GRASS module"),
+ def __init__(self, parent, id = wx.ID_ANY, title = _("Add new GRASS module to the model"),
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
"""!Graphical modeler module search window
@@ -1740,7 +1815,8 @@
self.btnOk.SetDefault()
self.btnOk.Enable(False)
- self.cmd_prompt.Bind(wx.EVT_KEY_UP, self.OnText)
+ self.cmd_prompt.Bind(wx.EVT_CHAR, self.OnText)
+ self.search.searchChoice.Bind(wx.EVT_CHOICE, self.OnText)
self.Bind(wx.EVT_BUTTON, self.OnOk, self.btnOk)
self._layout()
@@ -1802,11 +1878,17 @@
self.EndModal(wx.ID_OK)
def OnText(self, event):
+ """!Text entered"""
if self.cmd_prompt.AutoCompActive():
+ event.Skip()
return
- entry = self.cmd_prompt.GetTextLeft()
- if len(entry) > 0:
+ if isinstance(event, wx.KeyEvent):
+ entry = self.cmd_prompt.GetTextLeft() # FIXME
+ else:
+ entry = event.GetString()
+ if entry:
self.btnOk.Enable()
else:
@@ -1927,19 +2009,23 @@
"""!Process model file"""
for action in self.root.findall('action'):
pos, size = self._getDim(action)
+ disabled = False
task = action.find('task')
- if task:
+ if task is not None:
+ if task.find('disabled') is not None:
+ disabled = True
task = self._processTask(task)
else:
task = None
aId = int(action.get('id', -1))
- self.actions.append({ 'pos' : pos,
- 'size' : size,
- 'task' : task,
- 'id' : aId })
+ self.actions.append({ 'pos' : pos,
+ 'size' : size,
+ 'task' : task,
+ 'id' : aId,
+ 'disabled' : disabled })
def _getDim(self, node):
"""!Get position and size of shape"""
@@ -2103,6 +2189,8 @@
self.indent += 4
self.fd.write('%s<task name="%s">\n' % (' ' * self.indent, action.GetLog(string = False)[0]))
self.indent += 4
+ self.fd.write('%s<disabled />\n' % (' ' * self.indent))
for key, val in action.GetParams().iteritems():
if key == 'flags':
for f in val:
@@ -2261,6 +2349,23 @@
wx.ALIGN_CENTER_VERTICAL,
pos = (row, 1))
+ row += 1
+ gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = _("Disabled:")),
+ flag = wx.ALIGN_LEFT |
+ wx.ALIGN_CENTER_VERTICAL,
+ pos = (row, 0))
+ rColor = csel.ColourSelect(parent = panel, id = wx.ID_ANY,
+ colour = self.settings.Get(group='modeler', key='action', subkey=('color', 'disabled')),
+ size = globalvar.DIALOG_COLOR_SIZE)
+ rColor.SetName('GetColour')
+ self.winId['modeler:action:color:disabled'] = rColor.GetId()
+ gridSizer.Add(item = rColor,
+ flag = wx.ALIGN_RIGHT |
+ pos = (row, 1))
sizer.Add(item = gridSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 5)
border.Add(item = sizer, proportion = 0, flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 3)
@@ -2580,8 +2685,8 @@
wx.CallAfter(self.notebook.SetSelection, 0)
self.btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
- self.btnRun = wx.Button(parent = self, id = wx.ID_OK,
- label = _("&Run"))
+ self.btnRun = wx.Button(parent = self, id = wx.ID_OK,
+ label = _("&Run"))
self.btnRun.SetDefault()
self._layout()
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-06-03 17:43:30 UTC (rev 42471)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-06-03 19:01:47 UTC (rev 42472)
@@ -518,9 +518,10 @@
'modeler' : {
'action' : {
'color' : {
- 'valid' : (211, 211, 211, 255), # light grey
- 'invalid' : (255, 255, 255, 255), # white
- 'running' : (255, 0, 0), # running
+ 'valid' : (180, 234, 154, 255), # light green
+ 'invalid' : (255, 255, 255, 255), # white
+ 'running' : (255, 0, 0), # red
+ 'disabled' : (211, 211, 211, 255), # light grey
'size' : {
'width' : 100,
Modified: grass/trunk/gui/wxpython/xml/grass-gxm.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxm.dtd 2010-06-03 17:43:30 UTC (rev 42471)
+++ grass/trunk/gui/wxpython/xml/grass-gxm.dtd 2010-06-03 19:01:47 UTC (rev 42472)
@@ -27,9 +27,13 @@
<!-- a task describes the interface of a single
GRASS command
-<!ELEMENT task (flag*, parameter*)>
+<!ELEMENT task (flag*, parameter*, disabled?)>
<!ATTLIST task name CDATA #REQUIRED>
+<!-- defines task to be enabled/disabled
+<!ELEMENT disabled EMPTY>
<!-- a parameter must have a name and a value
<!ELEMENT parameter (value, parameterized?)>
