[GRASS-SVN] r42494 - in grass/trunk/gui/wxpython: gui_modules xml
svn_grass at osgeo.org
Mon Jun 7 08:55:47 EDT 2010
Author: martinl
Date: 2010-06-07 08:55:47 -0400 (Mon, 07 Jun 2010)
New Revision: 42494
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/xml/grass-gxm.dtd
wxGUI/modeler: fix relation names
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-06-07 08:09:08 UTC (rev 42493)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-06-07 12:55:47 UTC (rev 42494)
@@ -1,7 +1,7 @@
@package gmodeler.py
- at brief Graphical modeler to create edit, and manage models
+ at brief Graphical modeler to create, edit, and manage models
Classes:
- Model
@@ -45,7 +45,7 @@
if not os.getenv("GRASS_WXBUNDLED"):
globalvar.CheckForWx()
import wx
-import wx.lib.ogl as ogl
+import wx.lib.ogl as ogl
import wx.lib.flatnotebook as FN
import wx.lib.colourselect as csel
@@ -71,8 +71,8 @@
self.actions = list() # list of recorded actions
self.data = list() # list of recorded data items
# model properties
- self.properties = { 'name' : '',
- 'description' : '',
+ self.properties = { 'name' : _("model"),
+ 'description' : _("Script generated by wxGUI Graphical Modeler."),
'author' : getpass.getuser() }
self.canvas = canvas
@@ -186,7 +186,6 @@
y = data['pos'][1],
width = data['size'][0],
height = data['size'][1],
- name = data['name'],
prompt = data['prompt'],
value = data['value'])
dataItem.SetIntermediate(data['intermediate'])
@@ -194,14 +193,13 @@
for rel in data['rels']:
actionItem = self.FindAction(rel['id'])
if rel['dir'] == 'from':
- relation = ModelRelation(dataItem, actionItem)
- relation.SetControlPoints(rel['points'])
- dataItem.AddRelation(relation, direction = 'from')
+ relation = ModelRelation(dataItem, actionItem, rel['name'])
else:
- relation = ModelRelation(actionItem, dataItem)
- dataItem.AddRelation(relation, direction = 'to')
+ relation = ModelRelation(actionItem, dataItem, rel['name'])
+ relation.SetControlPoints(rel['points'])
+ dataItem.AddRelation(relation, direction = rel['dir'])
+ dataItem.Update()
self.data.append(dataItem)
actionItem.AddData(dataItem)
@@ -464,12 +462,14 @@
"""!Model properties dialog"""
dlg = PropertiesDialog(parent = self)
dlg.CentreOnParent()
- dlg.Init(self.model.GetProperties())
+ properties = self.model.GetProperties()
+ dlg.Init(properties)
if dlg.ShowModal() == wx.ID_OK:
self.ModelChanged()
- self.properties = dlg.GetValues()
+ for key, value in dlg.GetValues().iteritems():
+ properties[key] = value
for action in self.model.GetActions():
- action.GetTask().set_flag('overwrite', self.properties['overwrite'])
+ action.GetTask().set_flag('overwrite', properties['overwrite'])
dlg.Destroy()
@@ -829,12 +829,7 @@
def _writePython(self, fd):
"""!Write model to file"""
- if self.properties:
- properties = self.properties
- else:
- properties = { 'name' : _("Graphical modeler script"),
- 'description' : _("Script generated by wxGUI Graphical Modeler"),
- 'author' : getpass.getuser() }
fd.write(
r"""#!/usr/bin/env python
@@ -859,15 +854,15 @@
r"""
import sys
import os
+import atexit
import grass.script as grass
-import atexit
# cleanup()
rast, vect, rast3d, msg = self.model.GetIntermediateData()
fd.write(
r"""
def cleanup():
if rast:
@@ -1052,23 +1047,24 @@
data = layer.FindData(p.get('name', ''))
if data:
data.SetValue(p.get('value', ''))
+ data.Update()
continue
data = self.model.FindData(p.get('value', ''),
p.get('prompt', ''))
if data:
if p.get('age', 'old') == 'old':
- rel = ModelRelation(data, layer)
+ rel = ModelRelation(data, layer, p.get('name', ''))
data.AddRelation(rel, direction = 'from')
self.AddLine(rel)
else:
- rel = ModelRelation(layer, data)
+ rel = ModelRelation(layer, data, p.get('name', ''))
data.AddRelation(rel, direction = 'to')
self.AddLine(rel)
+ data.Update()
continue
- data = ModelData(self, name = p.get('name', ''),
- value = p.get('value', ''),
+ data = ModelData(self, value = p.get('value', ''),
prompt = p.get('prompt', ''),
x = x.pop(), y = height/2)
layer.AddData(data)
@@ -1079,13 +1075,15 @@
self.model.AddData(data)
self.AddLine(rel)
else:
self.AddLine(rel)
+ data.Update()
# valid ?
valid = True
for p in params['params']:
@@ -1410,7 +1408,7 @@
def FindData(self, name):
"""!Find data item by name"""
for d in self.data:
- if d.GetName() == name:
+ if name in d.GetName():
return d
return None
@@ -1430,10 +1428,17 @@
ogl.RectangleShape.OnDraw(self, dc)
class ModelData(ogl.EllipseShape):
- """!Data item class"""
- def __init__(self, parent, x, y, name = '', value = '', prompt = '', width = None, height = None):
+ def __init__(self, parent, x, y, value = '', prompt = '', width = None, height = None):
+ """Data item class
+ @param parent window parent
+ @param x, y position of the shape
+ @param fname, tname list of parameter names from / to
+ @param value value
+ @param prompt type of GIS element
+ @param width, height dimension of the shape
self.parent = parent
- self.name = name
self.value = value
self.prompt = prompt
self.intermediate = False
@@ -1454,16 +1459,8 @@
self.SetPen(wx.BLACK_PEN)
self._setBrush()
- if name:
- self.AddText(name)
- else:
- self.AddText(_('unknown'))
- if value:
- self.AddText(value)
- else:
- self.AddText('\n')
+ self.AddText(value)
def IsIntermediate(self):
"""!Checks if data item is intermediate"""
return self.intermediate
@@ -1485,15 +1482,20 @@
def GetLog(self, string = True):
"""!Get logging info"""
- if self.name:
- return self.name + '=' + self.value + ' (' + self.prompt + ')'
+ if self.rels['from']:
+ name = self.rels['from'].GetName()
+ return name + '=' + self.value + ' (' + self.prompt + ')'
else:
return _('unknown')
def GetName(self):
- """!Get name"""
- return self.name
+ """!Get list of names"""
+ name = list()
+ for rel in self.rels['from'] + self.rels['to']:
+ name.append(rel.GetName())
+ return name
def GetPrompt(self):
"""!Get prompt"""
return self.prompt
@@ -1505,12 +1507,7 @@
def SetValue(self, value):
"""!Set value"""
self.value = value
- self.ClearText()
- self.AddText(self.name)
- if value:
- self.AddText(self.value)
- else:
+ self._setText()
for direction in ('from', 'to'):
for rel in self.rels[direction]:
if direction == 'from':
@@ -1520,7 +1517,7 @@
task = menuform.GUI().ParseCommand(cmd = action.GetLog(string = False),
show = None)
- task.set_param(self.name, self.value)
+ task.set_param(rel.GetName(), self.value)
action.SetParams(params = task.get_options())
def GetRelations(self, direction = None):
@@ -1537,6 +1534,14 @@
self.rels[direction].append(rel)
+ def AddName(self, name, direction):
+ """!Record new name (parameter)
+ @param direction direction - 'from' or 'to'
+ print direction, name
+ self.name[direction].append(name)
def GetPropDialog(self):
"""!Get properties dialog"""
return self.propWin
@@ -1568,11 +1573,21 @@
pen.SetWidth(1)
self.SetPen(pen)
+ def _setText(self):
+ """!Update text"""
+ self.ClearText()
+ name = []
+ for rel in self.rels['to'] + self.rels['from']:
+ self.AddText('/'.join(name))
+ self.AddText(self.value)
def Update(self):
"""!Update action"""
self._setBrush()
self._setPen()
+ self._setText()
class ModelDataDialog(ElementDialog):
"""!Data item properties dialog"""
def __init__(self, parent, shape, id = wx.ID_ANY, title = _("Data properties"),
@@ -1600,6 +1615,9 @@
self.PostInit()
+ if shape.GetValue():
+ self.btnOK.Enable()
self._layout()
self.SetMinSize(self.GetSize())
@@ -1614,6 +1632,7 @@
def OnOK(self, event):
"""!Ok pressed"""
self.shape.SetValue(self.GetElement())
+ self.shape.SetName()
self.parent.canvas.Refresh()
self.parent.SetStatusText('', 0)
self.OnCancel(event)
@@ -1905,9 +1924,10 @@
class ModelRelation(ogl.LineShape):
"""!Data - action relation"""
- def __init__(self, fromShape, toShape):
+ def __init__(self, fromShape, toShape, param = ''):
self.fromShape = fromShape
self.toShape = toShape
+ self.param = param
self._points = None
@@ -1921,6 +1941,10 @@
"""!Get id of 'to' shape"""
return self.toShape
+ def GetName(self):
+ """!Get parameter name"""
+ return self.param
def ResetShapes(self):
"""!Reset related objects"""
self.fromShape.ResetControlPoints()
@@ -2056,9 +2080,8 @@
for data in self.root.findall('data'):
pos, size = self._getDim(data)
param = data.find('data-parameter')
- name = prompt = value = None
+ prompt = value = None
if param is not None:
- name = param.get('name', None)
prompt = param.get('prompt', None)
value = self._filterValue(self._getNodeText(param, 'value'))
@@ -2070,7 +2093,8 @@
rels = list()
for rel in data.findall('relation'):
defrel = { 'id' : int(rel.get('id', -1)),
- 'dir' : rel.get('dir', 'to') }
+ 'dir' : rel.get('dir', 'to'),
+ 'name' : rel.get('name', '') }
points = list()
for point in rel.findall('point'):
x = self._filterValue(self._getNodeText(point, 'x'))
@@ -2081,7 +2105,6 @@
self.data.append({ 'pos' : pos,
'size': size,
- 'name' : name,
'prompt' : prompt,
'value' : value,
'intermediate' : intermediate,
@@ -2237,8 +2260,8 @@
(' ' * self.indent, data.GetX(), data.GetY(),
data.GetWidth(), data.GetHeight()))
self.indent += 4
- self.fd.write('%s<data-parameter name="%s" prompt="%s">\n' % \
- (' ' * self.indent, data.GetName(), data.GetPrompt()))
+ self.fd.write('%s<data-parameter prompt="%s">\n' % \
+ (' ' * self.indent, data.GetPrompt()))
self.indent += 4
self.fd.write('%s<value>%s</value>\n' %
(' ' * self.indent, self._filterValue(data.GetValue())))
@@ -2255,8 +2278,8 @@
aid = rel.GetTo().GetId()
else:
aid = rel.GetFrom().GetId()
- self.fd.write('%s<relation dir="%s" id="%d">\n' % \
- (' ' * self.indent, ft, aid))
+ self.fd.write('%s<relation dir="%s" id="%d" name="%s">\n' % \
+ (' ' * self.indent, ft, aid, rel.GetName()))
self.indent += 4
for point in rel.GetLineControlPoints()[1:-1]:
self.fd.write('%s<point>\n' % (' ' * self.indent))
@@ -2656,11 +2679,11 @@
def GetValues(self):
"""!Get values"""
- return { 'name' : self.name.GetValue(),
- 'description' : self.desc.GetValue(),
- 'author' : self.author.GetValue(),
- 'overwrite' : self.overwrite.IsChecked() }
+ return { 'name' : self.name.GetValue(),
+ 'description' : self.desc.GetValue(),
+ 'author' : self.author.GetValue(),
+ 'overwrite' : self.overwrite.IsChecked() }
def Init(self, prop):
"""!Initialize dialog"""
self.name.SetValue(prop['name'])
Modified: grass/trunk/gui/wxpython/xml/grass-gxm.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxm.dtd 2010-06-07 08:09:08 UTC (rev 42493)
+++ grass/trunk/gui/wxpython/xml/grass-gxm.dtd 2010-06-07 12:55:47 UTC (rev 42494)
@@ -62,7 +62,6 @@
<!-- a data-parameter defines data items properties
<!ELEMENT data-parameter (value)>
-<!ATTLIST data-parameter name CDATA #REQUIRED>
<!ATTLIST data-parameter prompt CDATA #REQUIRED>
<!-- a data intermediate?
@@ -74,6 +73,7 @@
<!ELEMENT relation (point*)>
<!ATTLIST relation id CDATA #REQUIRED>
<!ATTLIST relation dir (from | to) #REQUIRED>
+<!ATTLIST relation name CDATA #REQUIRED>
<!-- a point defines control point of linear shape
