[GRASS-SVN] r42499 - in grass/branches/develbranch_6/gui:
icons/grass2 wxpython/gui_modules wxpython/icons
svn_grass at osgeo.org
Mon Jun 7 12:55:26 EDT 2010
Author: martinl
Date: 2010-06-07 12:55:24 -0400 (Mon, 07 Jun 2010)
New Revision: 42499
Added:
grass/branches/develbranch_6/gui/icons/grass2/zoom-extent.png
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
grass/branches/develbranch_6/gui/wxpython/icons/grass2_icons.py
grass/branches/develbranch_6/gui/wxpython/icons/grass_icons.py
grass/branches/develbranch_6/gui/wxpython/icons/icon.py
grass/branches/develbranch_6/gui/wxpython/icons/silk_icons.py
wxGUI: zoom to selected map available directly from map toolbar
(merge r42498 from trunk)
Copied: grass/branches/develbranch_6/gui/icons/grass2/zoom-extent.png (from rev 42498, grass/trunk/gui/icons/grass2/zoom-extent.png)
(Binary files differ)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -273,7 +273,7 @@
if ltype in ('raster', 'vector', 'rgb'):
self.popupMenu.Append(self.popupID9, text=_("Zoom to selected map(s)"))
- self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToMap, id=self.popupID9)
+ self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToMap, id=self.popupID9)
self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map(s)"))
self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id=self.popupID10)
if numSelected > 1:
@@ -350,7 +350,7 @@
elif mltype and mltype == "raster":
self.popupMenu.Append(self.popupID12, text=_("Zoom to selected map(s) (ignore NULLs)"))
- self.Bind(wx.EVT_MENU, self.mapdisplay.MapWindow.OnZoomToRaster, id=self.popupID12)
+ self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToRaster, id=self.popupID12)
self.popupMenu.Append(self.popupID13, text=_("Set computational region from selected map(s) (ignore NULLs)"))
self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id=self.popupID13)
self.popupMenu.AppendSeparator()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -1918,42 +1918,79 @@
self.params[type] = params
self.propwin[type] = propwin
+ def OnZoomToMap(self, event):
+ Set display extents to match selected raster (including NULLs)
+ or vector map.
+ self.MapWindow.ZoomToMap()
+ def OnZoomToRaster(self, event):
+ Set display extents to match selected raster map (ignore NULLs)
+ self.MapWindow.ZoomToMap(ignoreNulls = True)
+ def OnZoomToWind(self, event):
+ """!Set display geometry to match computational region
+ settings (set with g.region)
+ self.MapWindow.ZoomToWind()
+ def OnZoomToDefault(self, event):
+ """!Set display geometry to match default region settings
+ self.MapWindow.ZoomToDefault()
+ def OnZoomToSaved(self, event):
+ """!Set display geometry to match extents in
+ saved region file
+ self.MapWindow.ZoomToSaved()
+ def OnDisplayToWind(self, event):
+ """!Set computational region (WIND file) to match display
+ extents
+ self.MapWindow.DisplayToWind()
+ def SaveDisplayRegion(self, event):
+ """!Save display extents to named region file.
+ self.MapWindow.SaveDisplayRegion()
def OnZoomMenu(self, event):
+ """!Popup Zoom menu
- Zoom menu
point = wx.GetMousePosition()
zoommenu = wx.Menu()
# Add items to the menu
- zoommap = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to selected map(s)'))
- zoommenu.AppendItem(zoommap)
- self.Bind(wx.EVT_MENU, self.MapWindow.OnZoomToMap, zoommap)
zoomwind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to computational region (set with g.region)'))
zoommenu.AppendItem(zoomwind)
- self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToWind, zoomwind)
+ self.Bind(wx.EVT_MENU, self.OnZoomToWind, zoomwind)
zoomdefault = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to default region'))
zoommenu.AppendItem(zoomdefault)
- self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToDefault, zoomdefault)
+ self.Bind(wx.EVT_MENU, self.OnZoomToDefault, zoomdefault)
zoomsaved = wx.MenuItem(zoommenu, wx.ID_ANY, _('Zoom to saved region'))
zoommenu.AppendItem(zoomsaved)
- self.Bind(wx.EVT_MENU, self.MapWindow.ZoomToSaved, zoomsaved)
+ self.Bind(wx.EVT_MENU, self.OnZoomToSaved, zoomsaved)
savewind = wx.MenuItem(zoommenu, wx.ID_ANY, _('Set computational region from display'))
zoommenu.AppendItem(savewind)
- self.Bind(wx.EVT_MENU, self.MapWindow.DisplayToWind, savewind)
+ self.Bind(wx.EVT_MENU, self.OnDisplayToWind, savewind)
savezoom = wx.MenuItem(zoommenu, wx.ID_ANY, _('Save display geometry to named region'))
zoommenu.AppendItem(savezoom)
- self.Bind(wx.EVT_MENU, self.MapWindow.SaveDisplayRegion, savezoom)
+ self.Bind(wx.EVT_MENU, self.SaveDisplayRegion, savezoom)
- # Popup the menu. If an item is selected then its handler
+ # Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.PopupMenu(zoommenu)
zoommenu.Destroy()
def SetProperties(self, render=False, mode=0, showCompExtent=False,
constrainRes=False, projection=False):
"""!Set properies of map display window"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -2627,18 +2627,6 @@
"""!Reset zoom history"""
self.zoomhistory = list()
- def OnZoomToMap(self, event):
- Set display extents to match selected raster (including NULLs)
- or vector map.
- self.ZoomToMap()
- def OnZoomToRaster(self, event):
- Set display extents to match selected raster map (ignore NULLs)
- self.ZoomToMap(ignoreNulls = True)
def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
@@ -2687,10 +2675,9 @@
self.parent.StatusbarUpdate()
- def ZoomToWind(self, event):
- Set display geometry to match computational
- region settings (set with g.region)
+ def ZoomToWind(self):
self.Map.region = self.Map.GetRegion()
### self.Map.SetRegion(windres=True)
@@ -2702,9 +2689,8 @@
- def ZoomToDefault(self, event):
- Set display geometry to match default region settings
+ def ZoomToDefault(self):
self.Map.region = self.Map.GetRegion(default=True)
self.Map.AdjustRegion() # aling region extent to the display
@@ -2716,10 +2702,9 @@
- def DisplayToWind(self, event):
- Set computational region (WIND file) to
- match display extents
+ def DisplayToWind(self):
+ extents
tmpreg = os.getenv("GRASS_REGION")
if tmpreg:
@@ -2741,7 +2726,7 @@
if tmpreg:
os.environ["GRASS_REGION"] = tmpreg
- def ZoomToSaved(self, event):
+ def ZoomToSaved(self):
saved region file
@@ -2772,11 +2757,9 @@
self.UpdateMap()
- def SaveDisplayRegion(self, event):
- Save display extents to named region file.
+ def SaveDisplayRegion(self):
dlg = gdialogs.SavedRegion(parent = self,
title = _("Save display extents to region file"),
loadsave='save')
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -213,6 +213,7 @@
self.zoomout = wx.NewId()
self.zoomback = wx.NewId()
self.zoommenu = wx.NewId()
+ self.zoomextent = wx.NewId()
self.analyze = wx.NewId()
self.dec = wx.NewId()
self.savefile = wx.NewId()
@@ -245,6 +246,9 @@
(self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
self.parent.OnZoomOut),
+ (self.zoomextent, "zoom_extent", Icons["zoom_extent"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoom_extent"].GetLabel(), Icons["zoom_extent"].GetDesc(),
+ self.parent.OnZoomToMap),
(self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
self.parent.OnZoomBack),
Modified: grass/branches/develbranch_6/gui/wxpython/icons/grass2_icons.py
--- grass/branches/develbranch_6/gui/wxpython/icons/grass2_icons.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/icons/grass2_icons.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -22,10 +22,11 @@
"printmap" : 'print.png',
"pan" : 'pan.png',
# zoom (mapdisplay)
- "zoom_in" : 'zoom-in.png',
- "zoom_out" : 'zoom-out.png',
- "zoom_back" : 'zoom-last.png',
- "zoommenu" : 'zoom-more.png',
+ "zoom_in" : 'zoom-in.png',
+ "zoom_out" : 'zoom-out.png',
+ "zoom_back" : 'zoom-last.png',
+ "zoommenu" : 'zoom-more.png',
+ "zoom_extent" : 'zoom-extent.png',
# analyze raster (mapdisplay)
"analyze" : 'layer-raster-analyze.png',
"measure" : 'measure-length.png',
Modified: grass/branches/develbranch_6/gui/wxpython/icons/grass_icons.py
--- grass/branches/develbranch_6/gui/wxpython/icons/grass_icons.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/icons/grass_icons.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -23,6 +23,7 @@
"query" : 'gui-query.gif',
"zoom_back" : 'gui-zoom_back.gif',
"zoommenu" : 'gui-mapzoom.gif',
+ "zoom_extent" : wx.ART_ERROR, # FIXME
"savefile" : 'file-save.gif',
"printmap" : 'file-print.gif',
"overlay" : 'gui-overlay.gif',
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -164,6 +164,8 @@
"zoommenu" : MetaIcon (img=Icons["zoommenu"],
label=_("Zoom options"),
desc=_("Display zoom management")),
+ "zoom_extent" : MetaIcon (img=Icons["zoom_extent"],
+ label=_("Zoom to selected map layer(s)")),
"overlay" : MetaIcon (img=Icons["overlay"],
label=_("Add map elements"),
desc=_("Overlay elements like scale and legend onto map")),
Modified: grass/branches/develbranch_6/gui/wxpython/icons/silk_icons.py
--- grass/branches/develbranch_6/gui/wxpython/icons/silk_icons.py 2010-06-07 16:41:46 UTC (rev 42498)
+++ grass/branches/develbranch_6/gui/wxpython/icons/silk_icons.py 2010-06-07 16:55:24 UTC (rev 42499)
@@ -29,6 +29,7 @@
"zoom_out" : 'zoom_out.png',
"zoom_back" : 'zoom_back.png',
"zoommenu" : 'zoom.png',
"analyze" : 'application_lightning.png',
"measure" : 'sum.png',
Property changes on: grass/branches/develbranch_6/gui/wxpython/icons/silk_icons.py
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/branches/releasebranch_6_4/gui/wxpython/icons/silk_icons.py:42375
/grass/trunk/gui/wxpython/icons/silk_icons.py:41584,41586-41587,41590-41592,41594,41596,41598,41600,41806,41884,41888,42350,42372,42377
+ /grass/branches/releasebranch_6_4/gui/wxpython/icons/silk_icons.py:42375
/grass/trunk/gui/wxpython/icons/silk_icons.py:41584,41586-41587,41590-41592,41594,41596,41598,41600,41806,41884,41888,42350,42372,42377,42498
