[GRASS-SVN] r42505 - grass-addons/raster/r.stream.basins
svn_grass at osgeo.org
Tue Jun 8 06:58:02 EDT 2010
Author: mmetz
Date: 2010-06-08 06:58:02 -0400 (Tue, 08 Jun 2010)
New Revision: 42505
grass-addons/raster/r.stream.basins/catchment.c
fix for fifo error message, final fix
Modified: grass-addons/raster/r.stream.basins/catchment.c
--- grass-addons/raster/r.stream.basins/catchment.c 2010-06-08 07:34:36 UTC (rev 42504)
+++ grass-addons/raster/r.stream.basins/catchment.c 2010-06-08 10:58:02 UTC (rev 42505)
@@ -1,6 +1,6 @@
#include "global.h"
-static int tail, head, has_point;
+static int tail, head, fifo_count;
Link: a channel between junction
@@ -137,7 +137,7 @@
tail = 0;
head = -1;
- has_point = 0;
+ fifo_count = 0;
r = outlet.r;
c = outlet.c;
val = outlet.val;
@@ -176,18 +176,20 @@
/* fifo functions */
+/* insertion point: tail -> tail must always be unused */
+/* removal point: head + 1 */
+/* head == tail if last point removed or if only one free slot left */
int fifo_insert(POINT point)
+ if (fifo_count == fifo_max)
+ G_fatal_error("fifo queue: circular buffer too small");
+ fifo_outlet[tail++] = point;
if (tail > fifo_max) {
G_debug(1, "tail > fifo_max");
tail = 0;
- if (has_point && tail == head + 1)
- G_fatal_error("fifo queue: circular buffer too small");
- /* allow tail to become fifomax + 1 */
- fifo_outlet[tail++] = point;
- has_point = 1;
+ fifo_count++;
return 0;
@@ -197,10 +199,7 @@
G_debug(1, "head >= fifo_max");
head = -1;
- /* max value for ++head: fifomax */
- /* max value for tail: fifomax + 1 */
- if (++head == tail - 1)
- has_point = 0;
+ fifo_count--;
- return fifo_outlet[head];
+ return fifo_outlet[++head];
