[GRASS-SVN] r42507 - grass/trunk/display/d.rast
Tue Jun 8 09:07:03 EDT 2010
Author: hamish
Date: 2010-06-08 09:07:03 -0400 (Tue, 08 Jun 2010)
New Revision: 42507
   grass/trunk/display/d.rast/d.rast.html
   grass/trunk/display/d.rast/main.c
merge vallist option into catlist option, small msg cleanup
Modified: grass/trunk/display/d.rast/d.rast.html
--- grass/trunk/display/d.rast/d.rast.html	2010-06-08 12:30:14 UTC (rev 42506)
+++ grass/trunk/display/d.rast/d.rast.html	2010-06-08 13:07:03 UTC (rev 42507)
@@ -1,22 +1,23 @@
 <h2>DESCRIPTION</h2>
-<em>d.rast</em> displays raster map layer(s) <em>name</em>
+<em>d.rast</em> displays the specified raster map layer
 in the active display frame on the graphics monitor.
-<h2>NOTES</h2>
+<!-- specify format of values=1,3,5,7,12-34,101-inf  -->
-To overlay raster maps option (<b>-o</b>) may be used.
 <h2>SEE ALSO</h2>
 <em><a HREF="d.erase.html">d.erase</a></em><br>
 <em><a HREF="d.vect.html">d.vect</a></em><br>
-<em><a HREF="d.what.rast.html">d.what.rast</a></em><br>
+<!-- <em><a HREF="d.what.rast.html">d.what.rast</a></em><br> -->
 <h2>AUTHOR</h2>
 James Westervelt,
 U.S. Army Construction Engineering
 Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c	2010-06-08 12:30:14 UTC (rev 42506)
+++ grass/trunk/display/d.rast/main.c	2010-06-08 13:07:03 UTC (rev 42507)
@@ -40,7 +40,6 @@
     int invert, fp;
     struct GModule *module;
     struct Option *map;
-    struct Option *catlist;
     struct Option *vallist;
     struct Option *bg;
     struct Flag *flag_n;
@@ -52,36 +51,24 @@
     module = G_define_module();
     G_add_keyword(_("display"));
     G_add_keyword(_("raster"));
-    module->description = _("Displays raster map layer in the active map display window.");
+    module->description = _("Displays raster map layer.");
     /* set up command line */
     map = G_define_standard_option(G_OPT_R_MAP);
     map->description = _("Raster map to be displayed");
-    catlist = G_define_option();
-    catlist->key = "catlist";
-    catlist->key_desc = "cat[-cat]";
-    catlist->type = TYPE_STRING;
-    catlist->required = NO;
-    catlist->multiple = YES;
-    catlist->description = _("List of categories to be displayed (INT maps)");
-    catlist->guisection = _("Selection");
     vallist = G_define_option();
-    vallist->key = "vallist";
-    vallist->key_desc = "val[-val]";
+    vallist->key = "values";
+    vallist->key_desc = "value[,value[-value]]";
     vallist->type = TYPE_STRING;
     vallist->required = NO;
     vallist->multiple = YES;
-    vallist->description = _("List of values to be displayed (FP maps)");
+    vallist->description = _("List of categories or values to be displayed");
     vallist->guisection = _("Selection");
-    bg = G_define_option();
-    bg->key = "bg";
+    bg = G_define_standard_option(G_OPT_C_BG);
     bg->key_desc = "color";
-    bg->type = TYPE_STRING;
     bg->gisprompt = "old_color,color,color";
-    bg->required = NO;
     bg->description = _("Background color (for null)");
     flag_n = G_define_flag();
@@ -90,7 +77,7 @@
     flag_i = G_define_flag();
     flag_i->key = 'i';
-    flag_i->description = _("Invert catlist");
+    flag_i->description = _("Invert value list");
     flag_i->guisection = _("Selection");
     if (G_parser(argc, argv))
@@ -104,18 +91,12 @@
 	G_fatal_error(_("No graphics device selected"));
     fp = Rast_map_is_fp(name, "");
-    if (catlist->answer) {
+    if (vallist->answer) {
 	if (fp)
-	    G_warning(_("Ignoring catlist: map is floating point (please use 'val=')"));
+	    parse_vallist(vallist->answers, &d_mask);
 	else
 	    parse_catlist(catlist->answers, &mask);
-    if (vallist->answer) {
-	if (!fp)
-	    G_warning(_("Ignoring vallist: map is integer (please use 'cat=')"));
-	else
-	    parse_vallist(vallist->answers, &d_mask);
     /* use DCELL even if the map is FCELL */
@@ -218,7 +199,7 @@
 	if (where)
 	    fprintf(stderr, "%s: ", where);
 	G_usage();
-	G_fatal_error("%s: illegal category spec", catlist);
+	G_fatal_error(_("[%s]: illegal category specified"), catlist);
     return 0;
@@ -249,7 +230,7 @@
 	if (where)
 	G_usage();
-	G_fatal_error("%s: illegal value spec", vallist);
+	G_fatal_error(_("[%s]: illegal value specified"), vallist);
     return 0;
