[GRASS-SVN] r42512 -
grass/branches/develbranch_6/scripts/r.regression.line
svn_grass at osgeo.org
Tue Jun 8 12:47:41 EDT 2010
Author: hamish
Date: 2010-06-08 12:47:40 -0400 (Tue, 08 Jun 2010)
New Revision: 42512
grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line
rename variable from italian so it doesn't get confused with median, add F-test to key
Modified: grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line
--- grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line 2010-06-08 14:24:29 UTC (rev 42511)
+++ grass/branches/develbranch_6/scripts/r.regression.line/r.regression.line 2010-06-08 16:47:40 UTC (rev 42512)
@@ -112,10 +112,10 @@
END {B=(sumXY - sumX*sumY/tot)/(sumsqX - sumX*sumX/tot);\
R= (sumXY - sumX*sumY/tot)/((sumsqX - sumX^2/tot)*(sumsqY - sumY^2/tot))^0.5;\
-mediaX=sumX/tot;sumsqX=sumsqX/tot;varX=sumsqX-(mediaX^2);sdX=varX^0.5;\
-mediaY=sumY/tot;sumsqY=sumsqY/tot;varY=sumsqY-(mediaY^2);sdY=varY^0.5;\
-A=mediaY - B*mediaX; F= R^2/(1-R^2/tot-2);\
-print A, B, R, tot, F, mediaX, sdX, mediaY, sdY}' "$TEMPFILE" > "$TEMPFILE"b
+meanX=sumX/tot; sumsqX=sumsqX/tot; varX=sumsqX-(meanX^2); sdX=varX^0.5;\
+meanY=sumY/tot; sumsqY=sumsqY/tot; varY=sumsqY-(meanY^2); sdY=varY^0.5;\
+A=meanY - B*meanX; F= R^2/(1-R^2/tot-2);\
+print A, B, R, tot, F, meanX, sdX, meanY, sdY}' "$TEMPFILE" > "$TEMPFILE"b
echo "a b R N F medX sdX medY sdY" | tr -s ' ' '\n' > "$TEMPFILE"d
cat "$TEMPFILE"b | tr -s ' ' '\n' > "$TEMPFILE"e
@@ -131,6 +131,7 @@
echo " b: gain"
echo " R: sumXY - sumX*sumY/tot"
echo " N: number of elements"
+ echo " F: significance"
echo " medX, medY: Means"
echo " sdX, sdY: Standard deviations"
@@ -146,6 +147,7 @@
echo " b: gain" >> "$TEMPFILE"c
echo " R: sumXY - sumX*sumY/tot" >> "$TEMPFILE"c
echo " N: number of elements" >> "$TEMPFILE"c
+ echo " F: significance" >> "$TEMPFILE"c
echo " medX, medY: Means" >> "$TEMPFILE"c
echo " sdX, sdY: Standard deviations" >> "$TEMPFILE"c
echo "a b R N F medX sdX medY sdY" >> "$TEMPFILE"c
