[GRASS-SVN] r42527 - grass/branches/develbranch_6/scripts/d.correlate
Tue Jun 8 19:58:10 EDT 2010
Author: hamish
Date: 2010-06-08 19:58:08 -0400 (Tue, 08 Jun 2010)
New Revision: 42527
   grass/branches/develbranch_6/scripts/d.correlate/description.html
+ example
Modified: grass/branches/develbranch_6/scripts/d.correlate/description.html
--- grass/branches/develbranch_6/scripts/d.correlate/description.html	2010-06-08 23:03:48 UTC (rev 42526)
+++ grass/branches/develbranch_6/scripts/d.correlate/description.html	2010-06-08 23:58:08 UTC (rev 42527)
@@ -42,6 +42,14 @@
 If three or four map layers are specified, the correlation
 among each combination of two data layers is displayed.
+<H2>EXAMPLE</H2>
+North Carolina sample dataset:
+<div class="code"><pre>
+d.correlate -t layer1=lsat7_2002_10 layer2=lsat7_2002_20
+</pre></div>
 <H2>FILES</H2>
 This program is simply a shell script.  Users are
@@ -50,11 +58,6 @@
 <H2>SEE ALSO</H2>
-The UNIX <EM>awk</EM> command.
-<P>
 <EM>
 <A HREF="d.text.html">d.text</A>,
 <A HREF="d.graph.html">d.graph</A>,
@@ -63,11 +66,15 @@
 <A HREF="r.stats.html">r.stats</A>
 </EM>
 <H2>AUTHOR</H2>
 Michael Shapiro,
 <A HREF="http://www.cecer.army.mil/">U.S.Army Construction Engineering
 Research Laboratory</A>
 <p>
-Rewritten to GRASS 6 (from csh to sh) by Markus Neteler
-<p><i>Last changed: $Date$</i>
+Rewritten to GRASS 6 (from csh to sh) by Markus Neteler<BR>
+Trend line and model fix option added by Hamish Bowman
+<p>
+<i>Last changed: $Date$</i>
