[GRASS-SVN] r42531 - in grass/branches/develbranch_6/gui/wxpython:
gui_modules xml
svn_grass at osgeo.org
Wed Jun 9 04:34:00 EDT 2010
Author: martinl
Date: 2010-06-09 04:33:58 -0400 (Wed, 09 Jun 2010)
New Revision: 42531
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd
wxGUI/modeler: read/write variables to the model file
(merge r42530 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-06-09 08:27:59 UTC (rev 42530)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-06-09 08:33:58 UTC (rev 42531)
@@ -160,6 +160,7 @@
# load properties
self.properties = gxmXml.properties
+ self.variables = gxmXml.variables
# load model.GetActions()
for action in gxmXml.actions:
@@ -491,7 +492,11 @@
"""!Manage (define) model variables"""
dlg = VariablesDialog(parent = self, data = self.model.GetVariables())
dlg.CentreOnParent()
- dlg.Show()
+ if dlg.ShowModal() == wx.ID_OK:
+ self.ModelChanged()
+ variables = dlg.GetValues()
+ self.GetModel().SetVariables(variables)
+ dlg.Destroy()
def OnDeleteData(self, event):
"""!Delete intermediate data"""
@@ -1205,7 +1210,8 @@
WriteModelFile(fd = tmpfile,
actions = self.model.GetActions(),
data = self.model.GetData(),
- properties = self.model.GetProperties())
+ properties = self.model.GetProperties(),
+ variables = self.model.GetVariables())
except StandardError:
GMessage(parent = self,
message = _("Writing current settings to model file failed."))
@@ -1566,7 +1572,6 @@
@param direction direction - 'from' or 'to'
- print direction, name
self.name[direction].append(name)
def GetPropDialog(self):
@@ -2026,6 +2031,7 @@
# list of actions, data
self.properties = dict()
+ self.variables = dict()
self.actions = list()
self.data = list()
@@ -2060,9 +2066,8 @@
node = self.root.find('properties')
if node is None:
return
- self._processProperty(node, 'name')
- self._processProperty(node, 'description')
- self._processProperty(node, 'author')
+ for key in ('name', 'description', 'author'):
+ self._processProperty(node, key)
for f in node.findall('flag'):
name = f.get('name', '')
@@ -2078,9 +2083,22 @@
self.properties[name] = ''
def _processVariables(self):
+ """!Process model variables"""
for node in self.root.findall('variable'):
- pass
+ name = node.get('name', '')
+ if not name:
+ continue # should not happen
+ self.variables[name] = { 'type' : node.get('type', 'string') }
+ for key in ('description', 'value'):
+ self._processVariable(node, name, key)
+ def _processVariable(self, pnode, name, key):
+ """!Process given variable"""
+ node = pnode.find(key)
+ if node is not None:
+ if node.text:
+ self.variables[name][key] = node.text
def _processActions(self):
"""!Process model file"""
for action in self.root.findall('action'):
@@ -2206,16 +2224,19 @@
class WriteModelFile:
"""!Generic class for writing model file"""
- def __init__(self, fd, actions, data, properties):
- self.fd = fd
- self.actions = actions
- self.data = data
+ def __init__(self, fd, actions, data, properties, variables):
+ self.fd = fd
+ self.actions = actions
+ self.data = data
self.properties = properties
+ self.variables = variables
self.indent = 0
self._header()
+ self._properties()
+ self._variables()
self._actions()
self._data()
@@ -2237,10 +2258,9 @@
def _footer(self):
"""!Write footer"""
self.fd.write('%s</gxm>\n' % (' ' * self.indent))
- def _actions(self):
- """!Write actions"""
- id = 1
+ def _properties(self):
+ """!Write model properties"""
self.indent += 4
self.fd.write('%s<properties>\n' % (' ' * self.indent))
self.indent += 4
@@ -2256,6 +2276,25 @@
self.fd.write('%s<flag name="overwrite" />\n' % (' ' * self.indent))
self.indent -= 4
self.fd.write('%s</properties>\n' % (' ' * self.indent))
+ def _variables(self):
+ """!Write model variables"""
+ for name, values in self.variables.iteritems():
+ self.fd.write('%s<variable name="%s" type="%s">\n' % \
+ (' ' * self.indent, name, values['type']))
+ self.indent += 4
+ if values.has_key('value'):
+ self.fd.write('%s<value>%s</value>\n' % \
+ (' ' * self.indent, values['value']))
+ if values.has_key('description'):
+ self.fd.write('%s<description>%s</description>\n' % \
+ (' ' * self.indent, values['description']))
+ self.indent -= 4
+ self.fd.write('%s</variable>\n' % (' ' * self.indent))
+ def _actions(self):
+ """!Write actions"""
+ id = 1
for action in self.actions:
action.SetId(id)
self.fd.write('%s<action id="%d" name="%s" pos="%d,%d" size="%d,%d">\n' % \
@@ -2850,17 +2889,16 @@
self.desc = wx.TextCtrl(parent = self, id = wx.ID_ANY, size = (350, -1))
# buttons
+ self.btnAdd = wx.Button(parent = self, id = wx.ID_ADD)
+ self.btnAdd.SetToolTipString(_("Add new variable to the model"))
+ self.btnAdd.Enable(False)
self.btnCancel = wx.Button(parent = self, id = wx.ID_CANCEL)
self.btnCancel.SetToolTipString(_("Ignore changes and close dialog"))
self.btnOk = wx.Button(parent = self, id = wx.ID_OK)
self.btnOk.SetToolTipString(_("Apply changes and close dialog"))
self.btnOk.SetDefault()
- self.btnAdd = wx.Button(parent = self, id = wx.ID_ADD)
- self.btnAdd.SetToolTipString(_("Add new variable to the model"))
- self.btnAdd.Enable(False)
# bindings
- self.btnOk.Bind(wx.EVT_BUTTON, self.OnOK)
self.name.Bind(wx.EVT_TEXT, self.OnText)
self.value.Bind(wx.EVT_TEXT, self.OnText)
self.desc.Bind(wx.EVT_TEXT, self.OnText)
@@ -2869,9 +2907,6 @@
# list
self.list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnRightUp) #wxMSW
self.list.Bind(wx.EVT_RIGHT_UP, self.OnRightUp) #wxGTK
- # self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit, self.list)
- # self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit, self.list)
- # self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick, self.list)
self._layout()
@@ -2943,7 +2978,7 @@
self.btnAdd.Enable()
else:
def OnAdd(self, event):
"""!Add new variable to the list"""
msg = self.list.Append(self.name.GetValue(),
@@ -2989,11 +3024,19 @@
"""!Reload list of variables"""
self.list.Populate(self.parent.GetModel().GetVariables())
- def OnOK(self, event):
- """!Store variables to the model"""
- self.parent.GetModel().SetVariables(self.list.GetData())
- self.Destroy()
+ def GetValues(self):
+ """!Get dictionary of variables"""
+ variables = dict()
+ for values in self.list.GetData().itervalues():
+ name = values[0]
+ variables[name] = { 'type' : str(values[1]) }
+ if values[2]:
+ variables[name]['value'] = values[2]
+ if values[3]:
+ variables[name]['description'] = values[3]
+ return variables
class VariablesListCtrl(wx.ListCtrl,
listmix.ListCtrlAutoWidthMixin,
listmix.TextEditMixin):
@@ -3015,13 +3058,24 @@
self.itemData = {} # requested by sorter
self.itemCount = 0
+ self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnBeginEdit)
+ self.Bind(wx.EVT_LIST_END_LABEL_EDIT, self.OnEndEdit)
+ self.Bind(wx.EVT_LIST_COL_CLICK, self.OnColClick)
def GetData(self):
"""!Get list data"""
return self.itemData
def Populate(self, data):
"""!Populate the list"""
- self.itemData = copy.deepcopy(data)
+ self.itemData = dict()
+ i = 0
+ for name, values in data.iteritems():
+ self.itemData[i] = [name, values['type'],
+ values.get('value', ''),
+ values.get('description', '')]
+ i += 1
self.itemCount = len(self.itemData.keys())
self.DeleteAllItems()
i = 0
@@ -3052,7 +3106,7 @@
self.SetStringItem(index, 3, desc)
self.SetItemData(index, self.itemCount)
- self.itemData[self.itemCount] = (name, vtype, value, desc)
+ self.itemData[self.itemCount] = [name, vtype, value, desc]
self.itemCount += 1
return None
@@ -3070,7 +3124,26 @@
"""!Remove all variable(s) from the model"""
+ def OnBeginEdit(self, event):
+ """!Editing of item started"""
+ event.Allow()
+ def OnEndEdit(self, event):
+ """!Finish editing of item"""
+ itemIndex = event.GetIndex()
+ columnIndex = event.GetColumn()
+ nameOld = self.GetItem(itemIndex, 0).GetText()
+ if columnIndex == 0: # TODO
+ event.Veto()
+ self.itemData[itemIndex][columnIndex] = event.GetText()
+ def OnColClick(self, event):
+ """!Click on column header (order by)"""
+ event.Skip()
def main():
app = wx.PySimpleApp()
wx.InitAllImageHandlers()
Modified: grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd
--- grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd 2010-06-09 08:27:59 UTC (rev 42530)
+++ grass/branches/develbranch_6/gui/wxpython/xml/grass-gxm.dtd 2010-06-09 08:33:58 UTC (rev 42531)
@@ -90,5 +90,6 @@
<!-- a variable describes model variable
-<!ELEMENT variable (name, description?, value?)>
+<!ELEMENT variable (description?, value?)>
+<!ATTLIST variable name CDATA #REQUIRED>
<!ATTLIST variable type (integer | float | string) #REQUIRED>
