[GRASS-SVN] r42541 - in grass/trunk/gui/wxpython: gui_modules icons
svn_grass at osgeo.org
Sun Jun 13 05:14:22 EDT 2010
Author: martinl
Date: 2010-06-10 10:27:07 +0000 (Thu, 10 Jun 2010)
New Revision: 42541
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
grass/trunk/gui/wxpython/icons/icon.py
wxGUI/model: run model with variables
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-06-10 06:56:53 UTC (rev 42540)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2010-06-10 10:27:07 UTC (rev 42541)
@@ -37,6 +37,7 @@
import textwrap
import tempfile
import copy
+import re
try:
import xml.etree.ElementTree as etree
@@ -171,6 +172,7 @@
height = action['size'][1],
task = action['task'],
id = action['id'])
if action['disabled']:
actionItem.Enable(False)
@@ -193,6 +195,7 @@
actionItem.SetValid(valid)
actionItem.SetParameterized(parameterized)
+ actionItem.GetLog() # substitute variables (-> valid/invalid)
# load data & relations
for data in gxmXml.data:
@@ -305,6 +308,33 @@
"""!Return parameterized options"""
result = dict()
idx = 0
+ if self.variables:
+ params = list()
+ result[_("Variables")] = { 'flags' : list(),
+ 'params' : params,
+ 'idx' : idx }
+ for name, values in self.variables.iteritems():
+ params.append({ 'gisprompt' : False,
+ 'multiple' : 'no',
+ 'description' : values.get('description', ''),
+ 'guidependency' : '',
+ 'default' : values.get('value', ''),
+ 'age' : None,
+ 'required' : 'yes',
+ 'value' : '',
+ 'label' : '',
+ 'guisection' : '',
+ 'key_desc' : '',
+ 'values' : list(),
+ 'parameterized' : False,
+ 'values_desc' : list(),
+ 'prompt' : None,
+ 'element' : None,
+ 'type' : values.get('type', 'string'),
+ 'name' : name })
+ idx += 1
for action in self.actions:
if not action.IsEnabled():
continue
@@ -1374,6 +1404,19 @@
def GetLog(self, string = True):
"""!Get logging info"""
cmd = self.task.getCmd(ignoreErrors = True)
+ # substitute variables
+ variables = self.parent.GetVariables()
+ for variable in variables:
+ pattern= re.compile('%' + variable)
+ value = variables[variable].get('value', '')
+ for idx in range(len(cmd)):
+ if pattern.search(cmd[idx]):
+ if value:
+ cmd[idx] = pattern.sub(value, cmd[idx])
+ else:
+ self.isValid = False
+ break
+ idx += 1
if string:
if cmd is None:
return ''
@@ -2840,7 +2883,10 @@
def _createPage(self, name, params):
"""!Define notebook page"""
- task = menuform.grassTask(name)
+ if name in globalvar.grassCmd['all']:
+ task = menuform.grassTask(name)
+ else:
+ task = menuform.grassTask()
task.flags = params['flags']
task.params = params['params']
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2010-06-10 06:56:53 UTC (rev 42540)
+++ grass/trunk/gui/wxpython/icons/icon.py 2010-06-10 10:27:07 UTC (rev 42541)
@@ -362,9 +362,9 @@
"modelRelation" : MetaIcon (img=Icons["modelRelation"],
label=_("Define relation between data and action items")),
"modelRun" : MetaIcon (img=Icons["modelRun"],
- label=_("Run entire model")),
+ label=_("Run model")),
"modelValidate" : MetaIcon (img=Icons["modelValidate"],
- label=_("Validate entire model")),
+ label=_("Validate model")),
"modelSettings" : MetaIcon (img=Icons["settings"],
label=_("Show modeler settings")),
"modelProperties" : MetaIcon (img=Icons["modelProperties"],
