[GRASS-SVN] r42543 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Jun 13 05:14:22 EDT 2010
Author: martinl
Date: 2010-06-10 14:21:36 +0000 (Thu, 10 Jun 2010)
New Revision: 42543
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/wxnviz.py
wxGUI/nviz: progress in lighting
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2010-06-10 10:34:06 UTC (rev 42542)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2010-06-10 14:21:36 UTC (rev 42543)
@@ -127,7 +127,7 @@
self.iview = UserSettings.Get(group = 'nviz', key = 'view', internal = True)
self.nvizDefault = NvizDefault()
self.light = copy.deepcopy(UserSettings.Get(group = 'nviz', key = 'light')) # copy
self.size = None
self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
self.Bind(wx.EVT_SIZE, self.OnSize)
@@ -262,7 +262,9 @@
"""!Change light settings"""
data = self.light
self._display.SetLight(x = data['pos']['x'], y = data['pos']['y'],
- z = data['pos']['z'])
+ z = data['pos']['z'], color = data['color'],
+ bright = data['bright'] / 100.,
+ ambient = data['ambient'] / 100.)
self._display.DrawLightingModel()
def UpdateMap(self, render = True):
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2010-06-10 10:34:06 UTC (rev 42542)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2010-06-10 14:21:36 UTC (rev 42543)
@@ -129,7 +129,7 @@
# perspective
# set initial defaults here (or perhaps in a default values file), not in user settings
- self._createControl(panel, dict = self.win['view'], name = 'persp',
+ self._createControl(panel, data = self.win['view'], name = 'persp',
range = (1,100),
bind = (self.OnViewChange, self.OnViewChanged, self.OnViewChangedSpin))
gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Perspective:")),
@@ -139,7 +139,7 @@
flag = wx.ALIGN_CENTER)
# twist
- self._createControl(panel, dict = self.win['view'], name = 'twist',
+ self._createControl(panel, data = self.win['view'], name = 'twist',
range = (-180,180),
gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Twist:")),
@@ -149,11 +149,11 @@
# height + z-exag
- self._createControl(panel, dict = self.win['view'], name = 'height', sliderHor = False,
+ self._createControl(panel, data = self.win['view'], name = 'height', sliderHor = False,
range = (0, 1),
- self._createControl(panel, dict = self.win['view'], name = 'z-exag', sliderHor = False,
+ self._createControl(panel, data = self.win['view'], name = 'z-exag', sliderHor = False,
range = (0, 5),
self.FindWindowById(self.win['view']['z-exag']['slider']).SetValue(1)
@@ -529,7 +529,7 @@
gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
# position
- self._createControl(panel, dict = self.win['surface'], name = 'position',
+ self._createControl(panel, data = self.win['surface'], name = 'position',
range = (-10000, 10000),
bind = (self.OnSurfacePosition, self.OnSurfacePosition, self.OnSurfacePosition))
@@ -678,7 +678,7 @@
pos = (2, 3), span = (1, 6),
flag = wx.ALIGN_CENTER_VERTICAL)
- self._createControl(panel, dict = self.win['vector']['lines'], name = 'height', size = 300,
+ self._createControl(panel, data = self.win['vector']['lines'], name = 'height', size = 300,
range = (0, 1000),
bind = (self.OnVectorHeight, self.OnVectorHeightFull, self.OnVectorHeightSpin))
self.FindWindowById(self.win['vector']['lines']['height']['slider']).SetValue(0)
@@ -796,7 +796,7 @@
pos = (2, 3), span = (1, 5),
- self._createControl(panel, dict = self.win['vector']['points'], name = 'height', size = 300,
+ self._createControl(panel, data = self.win['vector']['points'], name = 'height', size = 300,
range = (0, 1000),
@@ -1109,7 +1109,7 @@
gridSizer.Add(item = posSizer, pos = (0, 0))
# height
- self._createControl(panel, dict = self.win['light'], name = 'z', sliderHor = False,
+ self._createControl(panel, data = self.win['light'], name = 'z', sliderHor = False,
range = (0, 100),
bind = (self.OnLightChange, None, self.OnLightChange))
@@ -1142,13 +1142,14 @@
colour = UserSettings.Get(group = 'nviz', key = 'settings',
subkey = ['light', 'color']),
size = globalvar.DIALOG_COLOR_SIZE)
+ color.Bind(csel.EVT_COLOURSELECT, self.OnLightColor)
gridSizer.Add(item = color, pos = (0, 2))
gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Brightness:")),
pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL)
- self._createControl(panel, dict = self.win['light'], name = 'bright', size = 300,
- range = (0, 1000),
- bind = (self.OnVectorHeight, self.OnVectorHeightFull, self.OnVectorHeightSpin))
+ self._createControl(panel, data = self.win['light'], name = 'bright', size = 300,
+ range = (0, 100),
+ bind = (self.OnLightValue, None, self.OnLightValue))
gridSizer.Add(item = self.FindWindowById(self.win['light']['bright']['slider']),
pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL)
gridSizer.Add(item = self.FindWindowById(self.win['light']['bright']['spin']),
@@ -1156,9 +1157,9 @@
gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Ambient:")),
pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL)
- self._createControl(panel, dict = self.win['light'], name = 'ambient', size = 300,
+ self._createControl(panel, data = self.win['light'], name = 'ambient', size = 300,
+ range = (0, 100),
gridSizer.Add(item = self.FindWindowById(self.win['light']['ambient']['slider']),
pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL)
gridSizer.Add(item = self.FindWindowById(self.win['light']['ambient']['spin']),
@@ -1188,9 +1189,21 @@
return panel
- def _createControl(self, parent, dict, name, range, bind, sliderHor = True, size = 200):
+ def OnScroll(self, event, win, data):
+ """!Generic scrolling handler"""
+ winName = self.__GetWindowName(win, event.GetId())
+ if not winName:
+ return
+ data[winName] = event.GetInt()
+ for w in win[winName].itervalues():
+ self.FindWindowById(w).SetValue(data[winName])
+ event.Skip()
+ def _createControl(self, parent, data, name, range, bind = (None, None, None),
+ sliderHor = True, size = 200):
"""!Add control (Slider + SpinCtrl)"""
- dict[name] = {}
+ data[name] = dict()
if sliderHor:
style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
wx.SL_BOTTOM
@@ -1199,47 +1212,40 @@
style = wx.SL_VERTICAL | wx.SL_AUTOTICKS | \
wx.SL_INVERSE
sizeW = (-1, size)
- try:
- val = self.mapWindow.view[name]['value']
- except KeyError:
- val = -1
slider = wx.Slider(parent = parent, id = wx.ID_ANY,
- value = val,
minValue = range[0],
maxValue = range[1],
style = style,
size = sizeW)
slider.SetName('slider')
- slider.Bind(wx.EVT_SCROLL, bind[0])
+ if bind[0]:
+ slider.Bind(wx.EVT_SCROLL, bind[0])
# slider.Bind(wx.EVT_SCROLL_THUMBRELEASE, bind[1])
if bind[1]:
slider.Bind(wx.EVT_SCROLL_CHANGED, bind[1]) # this only works in MSW
- dict[name]['slider'] = slider.GetId()
+ data[name]['slider'] = slider.GetId()
- slider.SetValue(val)
spin = wx.SpinCtrl(parent = parent, id = wx.ID_ANY, size = (65, -1),
- initial = val,
min = range[0],
max = range[1])
- spin.SetValue(val)
# no 'changed' event ... (FIXME)
spin.SetName('spin')
- spin.Bind(wx.EVT_SPINCTRL, bind[2])
+ if bind[2]:
+ spin.Bind(wx.EVT_SPINCTRL, bind[2])
- dict[name]['spin'] = spin.GetId()
+ data[name]['spin'] = spin.GetId()
- def __GetWindowName(self, dict, id):
- for name in dict.iterkeys():
- if type(dict[name]) is type({}):
- for win in dict[name].itervalues():
+ def __GetWindowName(self, data, id):
+ for name in data.iterkeys():
+ if type(data[name]) is type({}):
+ for win in data[name].itervalues():
if win == id:
return name
else:
- if dict[name] == id:
+ if data[name] == id:
return name
return None
@@ -1294,6 +1300,25 @@
event.Skip()
+ def OnLightColor(self, event):
+ """!Color of the light changed"""
+ self.mapWindow.light['color'] = event.GetValue()
+ event = wxUpdateLight()
+ wx.PostEvent(self.mapWindow, event)
+ event.Skip()
+ def OnLightValue(self, event):
+ """!Light brightness changed"""
+ data = self.mapWindow.light
+ self.OnScroll(event, self.win['light'], data)
+ event.Skip()
def OnBgColor(self, event):
"""!Background color changed"""
color = event.GetValue()
@@ -1312,7 +1337,7 @@
except IndexError:
return
- data = self.mapWindow.GetLayerData(type = 'raster', name = name)
+ data = self.mapWindow.GetLayerData(type = 'raster', name = name)['surface']
self.UpdateSurfacePage(layer, data, updateName = False)
def OnSetVector(self, event):
@@ -2258,12 +2283,14 @@
elif pageId == 'volume':
self.UpdateVectorPage(layer, data['vector'])
elif pageId == 'light':
- val = self.mapWindow.light['pos']['z'] * 100 # range 0.0 - 1.0
+ zval = self.mapWindow.light['pos']['z']
+ bval = self.mapWindow.light['bright']
+ aval = self.mapWindow.light['ambient']
for control in ('spin', 'slider'):
- self.FindWindowById(self.win['light']['z'][control]).SetRange(0,
- 100)
- self.FindWindowById(self.win['light']['z'][control]).SetValue(val)
+ self.FindWindowById(self.win['light']['z'][control]).SetValue(zval)
+ self.FindWindowById(self.win['light']['bright'][control]).SetValue(bval)
+ self.FindWindowById(self.win['light']['ambient'][control]).SetValue(aval)
self.Update()
self.pageChanging = False
@@ -2311,35 +2338,35 @@
# draw
- for control, dict in data['draw'].iteritems():
+ for control, data in data['draw'].iteritems():
if control == 'all': # skip 'all' property
continue
if control == 'resolution':
- self.FindWindowById(self.win['surface']['draw']['res-coarse']).SetValue(dict['coarse'])
- self.FindWindowById(self.win['surface']['draw']['res-fine']).SetValue(dict['fine'])
+ self.FindWindowById(self.win['surface']['draw']['res-coarse']).SetValue(data['coarse'])
+ self.FindWindowById(self.win['surface']['draw']['res-fine']).SetValue(data['fine'])
continue
if control == 'mode':
- if dict['desc']['mode'] == 'coarse':
+ if data['desc']['mode'] == 'coarse':
self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(0)
- elif dict['desc']['mode'] == 'fine':
+ elif data['desc']['mode'] == 'fine':
self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(1)
else: # both
self.FindWindowById(self.win['surface']['draw']['mode']).SetSelection(2)
- if dict['desc']['style'] == 'wire':
+ if data['desc']['style'] == 'wire':
self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(0)
else: # surface
self.FindWindowById(self.win['surface']['draw']['style']).SetSelection(1)
- if dict['desc']['shading'] == 'flat':
+ if data['desc']['shading'] == 'flat':
self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(0)
else: # gouraud
self.FindWindowById(self.win['surface']['draw']['shading']).SetSelection(1)
continue
- value = dict['value']
+ value = data['value']
win = self.FindWindowById(self.win['surface']['draw'][control])
name = win.GetName()
@@ -2488,7 +2515,7 @@
# draw
continue
@@ -2500,7 +2527,7 @@
else:
value = 1
else:
if win.GetName() == "selection":
win.SetSelection(value)
@@ -3089,7 +3116,7 @@
continue
else:
for otherkey, otheritem in self.win[subgroup][subkey].iteritems():
- if type(otheritem) == dict:
+ if type(otheritem) == data:
for endkey, enditem in otheritem.iteritems():
if endkey == subvalue:
paramwin = self.FindWindowById(enditem)
@@ -3131,9 +3158,7 @@
nvsettings = UserSettings.Get(group = 'nviz')
for subgroup, key in nvsettings.iteritems(): # view, surface, vector...
- print subgroup, key
for subkey, value in key.iteritems():
- print subkey, value
if subkey == 'height': continue
for subvalue in value.keys():
if subvalue == 'step':
@@ -3149,7 +3174,7 @@
nvsettings[subgroup][subkey][subvalue] = True
else:
if self.FindWindowById(enditem).GetClassName() == 'wxChoice':
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-06-10 10:34:06 UTC (rev 42542)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2010-06-10 14:21:36 UTC (rev 42543)
@@ -517,8 +517,11 @@
'pos' : {
'x' : 0.68,
'y' : 0.68,
- 'z' : 0.80,
+ 'z' : 80,
+ 'color' : (255, 255, 255, 255), # white
+ 'bright' : 80,
+ 'ambient' : 20,
'modeler' : {
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2010-06-10 10:34:06 UTC (rev 42542)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py 2010-06-10 14:21:36 UTC (rev 42543)
@@ -184,23 +184,29 @@
# first
Nviz_set_light_position(self.data, 1, 0.68, -0.68, 0.80, 0.0)
Nviz_set_light_bright(self.data, 1, 0.8)
- Nviz_set_light_color(self.data, 1, 1.0, 1.0, 1.0)
+ Nviz_set_light_color(self.data, 1, 255, 255, 255)
Nviz_set_light_ambient(self.data, 1, 0.2, 0.2, 0.2)
# second
Nviz_set_light_position(self.data, 2, 0.0, 0.0, 1.0, 0.0)
Nviz_set_light_bright(self.data, 2, 0.5)
- Nviz_set_light_color(self.data, 2, 1.0, 1.0, 1.0)
+ Nviz_set_light_color(self.data, 2, 255, 255, 255)
Nviz_set_light_ambient(self.data, 2, 0.3, 0.3, 0.3)
Debug.msg(3, "Nviz::SetLightsDefault()")
- def SetLight(self, x, y, z, w = 0, lid = 1):
+ def SetLight(self, x, y, z, color, bright, ambient, w = 0, lid = 1):
"""!Change lighting settings
@param x,y,z position
+ @param color light color (as string)
+ @param bright light brightness
+ @param ambient light ambient
@param w local coordinate (default to 0)
Nviz_set_light_position(self.data, lid, x, y, z, w)
+ Nviz_set_light_color(self.data, lid, color[0], color[1], color[2])
+ Nviz_set_light_bright(self.data, lid, bright)
+ Nviz_set_light_ambient(self.data, lid, ambient, ambient, ambient)
def LoadSurface(self, name, color_name, color_value):
"""!Load raster map (surface)
