[GRASS-SVN] r42554 - in grass/trunk/gui/wxpython: . gui_modules
Sun Jun 13 05:14:23 EDT 2010
Author: martinl
Date: 2010-06-13 15:36:52 +0000 (Sun, 13 Jun 2010)
New Revision: 42554
   grass/trunk/gui/wxpython/gui_modules/globalvar.py
   grass/trunk/gui/wxpython/gui_modules/layertree.py
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/gui/wxpython/wxgui.py
fix r42549 (agwStyle available in wxPython 2.8.11+)
Modified: grass/trunk/gui/wxpython/gui_modules/globalvar.py
--- grass/trunk/gui/wxpython/gui_modules/globalvar.py	2010-06-13 15:32:33 UTC (rev 42553)
+++ grass/trunk/gui/wxpython/gui_modules/globalvar.py	2010-06-13 15:36:52 UTC (rev 42554)
@@ -33,6 +33,14 @@
 # wxversion.select() called once at the beginning
 check = True
+def CheckWxVersion(version = [2, 8, 11, 0]):
+    """!Check wx version"""
+    ver = wx.version().split(' ')[0]
+    if map(int, ver.split('.')) < version:
+        return False
+    return True
 def CheckForWx():
     """!Try to import wx module and check its version"""
     global check
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py	2010-06-13 15:32:33 UTC (rev 42553)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py	2010-06-13 15:36:52 UTC (rev 42554)
@@ -25,18 +25,18 @@
 import wx
 try:
     import wx.lib.agw.customtreectrl as CT
-    hasAgw = True
 except ImportError:
     import wx.lib.customtreectrl as CT
-    hasAgw = False
 import wx.combo
 import wx.lib.newevent
 import wx.lib.buttons  as  buttons
+import globalvar
+hasAgw = globalvar.CheckWxVersion()
 from grass.script import core as grass
 import gdialogs
-import globalvar
 import menuform
 import toolbars
 import mapdisp
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-06-13 15:32:33 UTC (rev 42553)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2010-06-13 15:36:52 UTC (rev 42554)
@@ -71,10 +71,9 @@
 import wx.html
 try:
     import wx.lib.agw.flatnotebook as FN
-    hasAgw = True
 except ImportError:
     import wx.lib.flatnotebook as FN
-    hasAgw = False
 import wx.lib.colourselect as csel
 import wx.lib.filebrowsebutton as filebrowse
 from wx.lib.expando import ExpandoTextCtrl, EVT_ETC_LAYOUT_NEEDED
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2010-06-13 15:32:33 UTC (rev 42553)
+++ grass/trunk/gui/wxpython/wxgui.py	2010-06-13 15:36:52 UTC (rev 42554)
@@ -53,11 +53,10 @@
 try:
-    hasAgw = True
 except ImportError:
-    hasAgw = False
 sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
