[GRASS-SVN] r42564 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Jun 14 09:57:44 EDT 2010
Author: martinl
Date: 2010-06-14 13:57:44 +0000 (Mon, 14 Jun 2010)
New Revision: 42564
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI/modeler: fix runing model with variables
(merge r42563 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-06-14 13:49:22 UTC (rev 42563)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2010-06-14 13:57:44 UTC (rev 42564)
@@ -84,6 +84,7 @@
'author' : getpass.getuser() }
# model variables
self.variables = dict()
+ self.variablesParams = dict()
self.canvas = canvas
@@ -103,8 +104,11 @@
"""!Get model properties"""
return self.properties
- def GetVariables(self):
+ def GetVariables(self, params = False):
"""!Get model variables"""
+ if params:
+ return self.variablesParams
def SetVariables(self, data):
@@ -317,12 +321,12 @@
def IsParameterized(self):
"""!Return True if model is parameterized"""
- if self.Parametrize():
+ if self.Parameterize():
return True
return False
- def Parametrize(self):
+ def Parameterize(self):
"""!Return parameterized options"""
result = dict()
idx = 0
@@ -332,23 +336,37 @@
'params' : params,
'idx' : idx }
for name, values in self.variables.iteritems():
- params.append({ 'gisprompt' : False,
+ gtype = values.get('type', 'string')
+ if gtype in ('raster', 'vector'):
+ gisprompt = True
+ prompt = gtype
+ if gtype == 'raster':
+ element = 'cell'
+ else:
+ element = 'vector'
+ ptype = 'string'
+ else:
+ gisprompt = False
+ prompt = None
+ element = None
+ ptype = gtype
+ params.append({ 'gisprompt' : gisprompt,
'multiple' : 'no',
'description' : values.get('description', ''),
'guidependency' : '',
- 'default' : values.get('value', ''),
+ 'default' : '',
'age' : None,
'required' : 'yes',
- 'value' : '',
+ 'value' : values.get('value', ''),
'label' : '',
'guisection' : '',
'key_desc' : '',
'values' : list(),
'parameterized' : False,
'values_desc' : list(),
- 'prompt' : None,
- 'element' : None,
- 'type' : values.get('type', 'string'),
+ 'prompt' : prompt,
+ 'element' : element,
+ 'type' : ptype,
'name' : name })
idx += 1
@@ -373,6 +391,8 @@
'idx' : idx }
result[name]['params'].append(p)
idx += 1
+ self.variablesParams = result # record parameters
return result
@@ -748,7 +768,7 @@
return
# parametrization
- params = self.model.Parametrize()
+ params = self.model.Parameterize()
if params:
dlg = ModelParamDialog(parent = self,
params = params)
@@ -759,6 +779,12 @@
dlg.Destroy()
return
+ err = dlg.GetErrors()
+ if err:
+ GMessage(parent = self,
+ message = unicode('\n'.join(err)))
+ return
self.goutput.cmdThread.SetId(-1)
for action in self.model.GetActions():
if not action.IsEnabled():
@@ -1445,17 +1471,32 @@
cmd = self.task.getCmd(ignoreErrors = True)
# substitute variables
variables = self.parent.GetVariables()
+ fparams = self.parent.GetVariables(params = True)
+ params = None
+ for values in fparams.itervalues():
+ params = values['params']
+ break
for variable in variables:
pattern= re.compile('%' + variable)
- value = variables[variable].get('value', '')
+ value = None
+ if params:
+ for p in params:
+ if variable == p.get('name', ''):
+ value = p.get('value', '')
+ break
+ if not value:
+ value = variables[variable].get('value', '')
for idx in range(len(cmd)):
if pattern.search(cmd[idx]):
if value:
cmd[idx] = pattern.sub(value, cmd[idx])
else:
self.isValid = False
- break
+ break
idx += 1
if string:
if cmd is None:
return ''
@@ -2912,6 +2953,7 @@
self.parent = parent
self.params = params
+ self.tasks = list() # list of tasks/pages
wx.Dialog.__init__(self, parent = parent, id = id, title = title, style = style, **kwargs)
@@ -2981,9 +3023,18 @@
task.params = params['params']
panel = menuform.cmdPanel(parent = self, id = wx.ID_ANY, task = task)
+ self.tasks.append(task)
return panel
+ def GetErrors(self):
+ """!Check for errors, get list of messages"""
+ errList = list()
+ for task in self.tasks:
+ errList += task.getCmdError()
+ return errList
class VariablesDialog(wx.Dialog, listmix.ColumnSorterMixin):
def __init__(self, parent, id = wx.ID_ANY, title = _("Manage model variables"),
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
@@ -3020,7 +3071,9 @@
self.type = wx.Choice(parent = self, id = wx.ID_ANY,
choices = [_("integer"),
_("float"),
- _("string")])
+ _("string"),
+ _("raster"),
+ _("vector")])
self.value = wx.TextCtrl(parent = self, id = wx.ID_ANY, size = (150, -1))
self.desc = wx.TextCtrl(parent = self, id = wx.ID_ANY, size = (350, -1))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-06-14 13:49:22 UTC (rev 42563)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2010-06-14 13:57:44 UTC (rev 42564)
@@ -1501,7 +1501,7 @@
title_txt.SetToolTipString(tooltip)
if p == first_param:
- if type(p['wxId']) == type(1):
+ if p.has_key('wxId') and len(p['wxId']) > 0:
self.FindWindowById(p['wxId'][0]).SetFocus()
@@ -1748,7 +1748,7 @@
porf['parameterized'] = me.IsChecked()
else:
porf['value'] = me.GetValue()
self.OnUpdateValues(event)
event.Skip()
@@ -1756,6 +1756,10 @@
def OnUpdateSelection(self, event):
"""!Update dialog (layers, tables, columns, etc.)
+ if not hasattr(self.parent, "updateThread"):
+ if event:
+ event.Skip()
+ return
if event:
self.parent.updateThread.Update(UpdateDialog,
self,
