[GRASS-SVN] r42587 - in grass-addons/gui/wxpython: . wx.path
svn_grass at osgeo.org
Sat Jun 19 07:55:19 EDT 2010
Author: rashadkm
Date: 2010-06-19 11:55:19 +0000 (Sat, 19 Jun 2010)
New Revision: 42587
Added:
grass-addons/gui/wxpython/wx.path/
grass-addons/gui/wxpython/wx.path/mapdisplay_window.py
grass-addons/gui/wxpython/wx.path/wx.path.py
created an interface for v.net.path
Added: grass-addons/gui/wxpython/wx.path/mapdisplay_window.py
--- grass-addons/gui/wxpython/wx.path/mapdisplay_window.py (rev 0)
+++ grass-addons/gui/wxpython/wx.path/mapdisplay_window.py 2010-06-19 11:55:19 UTC (rev 42587)
@@ -0,0 +1,1679 @@
+ at package mapdisp_window.py
+ at brief GIS map display canvas, buffered window.
+Classes:
+ - MapWindow
+ - BufferedWindow
+(C) 2006-2009 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Michael Barton
+ at author Jachym Cepicky
+ at author Martin Landa <landa.martin gmail.com>
+import os
+import time
+import math
+import sys
+import tempfile
+import traceback
+import wx
+import grass.script as grass
+import dbm
+import dbm_dialogs
+import gdialogs
+import gcmd
+import utils
+import globalvar
+import gselect
+from debug import Debug
+from preferences import globalSettings as UserSettings
+from units import ConvertValue as UnitsConvertValue
+from mapdisp_window import MapWindow
+class BufferedWindow(MapWindow, wx.Window):
+ A Buffered window class.
+ When the drawing needs to change, you app needs to call the
+ UpdateMap() method. Since the drawing is stored in a bitmap, you
+ can also save the drawing to file by calling the
+ SaveToFile(self,file_name,file_type) method.
+ def __init__(self, parent, id,
+ pos = wx.DefaultPosition,
+ size = wx.DefaultSize,
+ style=wx.NO_FULL_REPAINT_ON_RESIZE,
+ Map=None, tree=None, lmgr=None):
+ MapWindow.__init__(self, parent, id, pos, size, style,
+ Map, tree, lmgr)
+ wx.Window.__init__(self, parent, id, pos, size, style)
+ self.Map = Map
+ self.tree = tree
+ self.lmgr = lmgr # Layer Manager
+ self.counter =0
+ self.points = []
+ # Flags
+ self.resize = False # indicates whether or not a resize event has taken place
+ self.dragimg = None # initialize variable for map panning
+ # Variable for drawing on DC
+ self.pen = None # pen for drawing zoom boxes, etc.
+ self.polypen = None # pen for drawing polylines (measurements, profiles, etc)
+ # List of wx.Point tuples defining a polyline (geographical coordinates)
+ self.polycoords = []
+ # ID of rubber band line
+ self.lineid = None
+ # ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
+ self.plineid = None
+ # Event bindings
+ self.Bind(wx.EVT_PAINT, self.OnPaint)
+ self.Bind(wx.EVT_SIZE, self.OnSize)
+ self.Bind(wx.EVT_IDLE, self.OnIdle)
+ self.Bind(wx.EVT_MOTION, self.MouseActions)
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
+ self.processMouse = True
+ # Render output objects
+ self.mapfile = None # image file to be rendered
+ self.img = "" # wx.Image object (self.mapfile)
+ # used in digitization tool (do not redraw vector map)
+ self.imgVectorMap = None
+ # decoration overlays
+ self.overlays = {}
+ # images and their PseudoDC ID's for painting and dragging
+ self.imagedict = {}
+ self.select = {} # selecting/unselecting decorations for dragging
+ self.textdict = {} # text, font, and color indexed by id
+ self.currtxtid = None # PseudoDC id for currently selected text
+ # Zoom objects
+ self.zoomhistory = [] # list of past zoom extents
+ self.currzoom = 0 # current set of extents in zoom history being used
+ self.zoomtype = 1 # 1 zoom in, 0 no zoom, -1 zoom out
+ self.hitradius = 10 # distance for selecting map decorations
+ self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
+ # OnSize called to make sure the buffer is initialized.
+ # This might result in OnSize getting called twice on some
+ # platforms at initialization, but little harm done.
+ ### self.OnSize(None)
+ self.DefinePseudoDC()
+ # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
+ self.redrawAll = True
+ # will store an off screen empty bitmap for saving to file
+ self._buffer = ''
+ self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
+ self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown)
+ # vars for handling mouse clicks
+ self.dragid = -1
+ self.lastpos = (0, 0)
+ def OnButtonDClick(self,event):
+ precision = int(UserSettings.Get(group = 'projection', key = 'format',
+ subkey = 'precision'))
+ try:
+ e, n = self.Pixel2Cell(event.GetPositionTuple())
+ except AttributeError:
+ return
+ self.counter = self.counter + 1
+ point =("%.*f|%.*f" % (precision, e, precision, n))
+ self.points.append(point + '|point')
+ if self.counter == 2:
+ f =open("tmp1",'w')
+ for p in self.points:
+ f.write("%s\n" % p)
+ f.close()
+ f =open("tmp2",'w')
+ f.write("%d %d %d\n" %(1,1,2) )
+ f.close()
+ command =["g.remove",'vect=vnet_out,startend,tmp_vnet_path']
+ gcmd.CommandThread(command,stdout=None,stderr=None).run()
+ command =["v.in.ascii",'input=tmp1','output=startend']
+ command=["v.net", "input=myroads",'points=startend', 'out=vnet_out', 'op=connect', 'thresh=200']
+ command=["v.net.path", 'vnet_out','afcol=forward', 'abcol=backward', 'out=tmp_vnet_path','file=tmp2']
+ self.mapname = 'tmp_vnet_path@' + grass.gisenv()['MAPSET']
+ self.cmd= ['d.vect', str("map=" + self.mapname),'col=red','width=2']
+ self.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
+ self.UpdateMap(render=True)
+ self.counter =0
+ def DefinePseudoDC(self, vdigit = False):
+ """!Define PseudoDC class to use
+ @vdigit True to use PseudoDC from vdigit
+ # create PseudoDC used for background map, map decorations like scales and legends
+ self.pdc = self.PseudoDC(vdigit)
+ # used for digitization tool
+ self.pdcVector = None
+ # decorations (region box, etc.)
+ self.pdcDec = self.PseudoDC(vdigit)
+ # pseudoDC for temporal objects (select box, measurement tool, etc.)
+ self.pdcTmp = self.PseudoDC(vdigit)
+ def PseudoDC(self, vdigit = False):
+ """!Create PseudoDC instance"""
+ if vdigit:
+ PseudoDC = VDigitPseudoDC
+ else:
+ PseudoDC = wx.PseudoDC
+ return PseudoDC()
+ def CheckPseudoDC(self):
+ """!Try to draw background
+ @return True on success
+ @return False on failure
+ try:
+ self.pdc.BeginDrawing()
+ self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
+ except StandardError, e:
+ traceback.print_exc(file = sys.stderr)
+ return False
+ return True
+ def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
+ Draws map and overlay decorations
+ if drawid == None:
+ if pdctype == 'image' and img:
+ drawid = self.imagedict[img]
+ elif pdctype == 'clear':
+ drawid == None
+ else:
+ drawid = wx.NewId()
+ if img and pdctype == 'image':
+ # self.imagedict[img]['coords'] = coords
+ self.select[self.imagedict[img]['id']] = False # ?
+ pdc.BeginDrawing()
+ if drawid != 99:
+ bg = wx.TRANSPARENT_BRUSH
+ else:
+ bg = wx.Brush(self.GetBackgroundColour())
+ pdc.SetBackground(bg)
+ ### pdc.Clear()
+ Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
+ (drawid, pdctype, coords))
+ # set PseudoDC id
+ if drawid is not None:
+ pdc.SetId(drawid)
+ if pdctype == 'clear': # erase the display
+ bg = wx.WHITE_BRUSH
+ # bg = wx.Brush(self.GetBackgroundColour())
+ pdc.RemoveAll()
+ pdc.Clear()
+ pdc.EndDrawing()
+ self.Refresh()
+ return
+ if pdctype == 'image': # draw selected image
+ bitmap = wx.BitmapFromImage(img)
+ w,h = bitmap.GetSize()
+ pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
+ elif pdctype == 'box': # draw a box on top of the map
+ if self.pen:
+ pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
+ pdc.SetPen(self.pen)
+ x2 = max(coords[0],coords[2])
+ x1 = min(coords[0],coords[2])
+ y2 = max(coords[1],coords[3])
+ y1 = min(coords[1],coords[3])
+ rwidth = x2-x1
+ rheight = y2-y1
+ rect = wx.Rect(x1, y1, rwidth, rheight)
+ pdc.DrawRectangleRect(rect)
+ pdc.SetIdBounds(drawid, rect)
+ elif pdctype == 'line': # draw a line on top of the map
+ if self.pen:
+ pdc.DrawLinePoint(wx.Point(coords[0], coords[1]),wx.Point(coords[2], coords[3]))
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], coords[2], coords[3]))
+ # self.ovlcoords[drawid] = coords
+ elif pdctype == 'polyline': # draw a polyline on top of the map
+ if self.polypen:
+ pdc.SetPen(self.polypen)
+ ### pdc.DrawLines(coords)
+ if (len(coords) < 2):
+ return
+ i = 1
+ while i < len(coords):
+ pdc.DrawLinePoint(wx.Point(coords[i-1][0], coords[i-1][1]),
+ wx.Point(coords[i][0], coords[i][1]))
+ i += 1
+ # get bounding rectangle for polyline
+ xlist = []
+ ylist = []
+ if len(coords) > 0:
+ for point in coords:
+ x,y = point
+ xlist.append(x)
+ ylist.append(y)
+ x1=min(xlist)
+ x2=max(xlist)
+ y1=min(ylist)
+ y2=max(ylist)
+ pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
+ # self.ovlcoords[drawid] = [x1,y1,x2,y2]
+ elif pdctype == 'point': # draw point
+ if self.pen:
+ pdc.DrawPoint(coords[0], coords[1])
+ coordsBound = (coords[0] - 5,
+ coords[1] - 5,
+ coords[0] + 5,
+ coords[1] + 5)
+ pdc.SetIdBounds(drawid, wx.Rect(coordsBound))
+ elif pdctype == 'text': # draw text on top of map
+ if not img['active']:
+ return #only draw active text
+ if img.has_key('rotation'):
+ rotation = float(img['rotation'])
+ else:
+ rotation = 0.0
+ w, h = self.GetFullTextExtent(img['text'])[0:2]
+ pdc.SetFont(img['font'])
+ pdc.SetTextForeground(img['color'])
+ coords, w, h = self.TextBounds(img)
+ if rotation == 0:
+ pdc.DrawText(img['text'], coords[0], coords[1])
+ else:
+ pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
+ pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], w, h))
+ pdc.EndDrawing()
+ self.Refresh()
+ return drawid
+ def TextBounds(self, textinfo):
+ Return text boundary data
+ @param textinfo text metadata (text, font, color, rotation)
+ @param coords reference point
+ if textinfo.has_key('rotation'):
+ rotation = float(textinfo['rotation'])
+ else:
+ rotation = 0.0
+ coords = textinfo['coords']
+ Debug.msg (4, "BufferedWindow.TextBounds(): text=%s, rotation=%f" % \
+ (textinfo['text'], rotation))
+ self.Update()
+ ### self.Refresh()
+ self.SetFont(textinfo['font'])
+ w, h = self.GetTextExtent(textinfo['text'])
+ if rotation == 0:
+ coords[2], coords[3] = coords[0] + w, coords[1] + h
+ return coords, w, h
+ boxh = math.fabs(math.sin(math.radians(rotation)) * w) + h
+ boxw = math.fabs(math.cos(math.radians(rotation)) * w) + h
+ coords[2] = coords[0] + boxw
+ coords[3] = coords[1] + boxh
+ return coords, boxw, boxh
+ def OnPaint(self, event):
+ Draw PseudoDC's to buffered paint DC
+ self.pdc for background and decorations
+ self.pdcVector for vector map which is edited
+ self.pdcTmp for temporaly drawn objects (self.polycoords)
+ If self.redrawAll is False on self.pdcTmp content is re-drawn
+ Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
+ dc = wx.BufferedPaintDC(self, self.buffer)
+ ### dc.SetBackground(wx.Brush("White"))
+ dc.Clear()
+ # use PrepareDC to set position correctly
+ self.PrepareDC(dc)
+ # create a clipping rect from our position and size
+ # and update region
+ rgn = self.GetUpdateRegion().GetBox()
+ dc.SetClippingRect(rgn)
+ switchDraw = False
+ if self.redrawAll is None:
+ switchDraw = True
+ if self.redrawAll: # redraw pdc and pdcVector
+ # draw to the dc using the calculated clipping rect
+ self.pdc.DrawToDCClipped(dc, rgn)
+ # draw vector map layer
+ if self.pdcVector:
+ # decorate with GDDC (transparency)
+ try:
+ gcdc = wx.GCDC(dc)
+ self.pdcVector.DrawToDCClipped(gcdc, rgn)
+ except NotImplementedError, e:
+ print >> sys.stderr, e
+ self.pdcVector.DrawToDCClipped(dc, rgn)
+ self.bufferLast = None
+ else: # do not redraw pdc and pdcVector
+ if self.bufferLast is None:
+ # draw to the dc
+ self.pdc.DrawToDC(dc)
+ try:
+ self.pdcVector.DrawToDC(gcdc)
+ self.pdcVector.DrawToDC(dc)
+ # store buffered image
+ # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
+ self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
+ pdcLast = self.PseudoDC(vdigit = False)
+ pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
+ pdcLast.DrawToDC(dc)
+ # draw decorations (e.g. region box)
+ try:
+ self.pdcDec.DrawToDC(gcdc)
+ self.pdcDec.DrawToDC(dc)
+ # draw temporary object on the foreground
+ ### self.pdcTmp.DrawToDCClipped(dc, rgn)
+ self.pdcTmp.DrawToDC(dc)
+ if switchDraw:
+ self.redrawAll = False
+ def OnSize(self, event):
+ """!Scale map image so that it is the same size as the Window
+ Debug.msg(3, "BufferedWindow.OnSize():")
+ # set size of the input image
+ self.Map.ChangeMapSize(self.GetClientSize())
+ # align extent based on center point and display resolution
+ # this causes that image is not resized when display windows is resized
+ ### self.Map.AlignExtentFromDisplay()
+ # Make new off screen bitmap: this bitmap will always have the
+ # current drawing in it, so it can be used to save the image to
+ # a file, or whatever.
+ self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
+ # get the image to be rendered
+ self.img = self.GetImage()
+ # update map display
+ if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
+ self.img = self.img.Scale(self.Map.width, self.Map.height)
+ if len(self.Map.GetListOfLayers()) > 0:
+ self.UpdateMap()
+ # re-render image on idle
+ self.resize = True
+ def OnIdle(self, event):
+ """!Only re-render a composite map image from GRASS during
+ idle time instead of multiple times during resizing.
+ if self.resize:
+ event.Skip()
+ def GetOverlay(self):
+ Converts rendered overlay files to wx.Image
+ Updates self.imagedict
+ @return list of images
+ imgs = []
+ for overlay in self.Map.GetListOfLayers(l_type="overlay", l_active=True):
+ if os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
+ img = wx.Image(overlay.mapfile, wx.BITMAP_TYPE_ANY)
+ self.imagedict[img] = { 'id' : overlay.id,
+ 'layer' : overlay }
+ imgs.append(img)
+ return imgs
+ def GetImage(self):
+ """!Converts redered map files to wx.Image
+ Updates self.imagedict (id=99)
+ @return wx.Image instance (map composition)
+ imgId = 99
+ if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
+ os.path.getsize(self.Map.mapfile):
+ img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
+ else:
+ img = None
+ self.imagedict[img] = { 'id': imgId }
+ return img
+ def UpdateMap(self, render=True, renderVector=True):
+ Updates the canvas anytime there is a change to the
+ underlaying images or to the geometry of the canvas.
+ @param render re-render map composition
+ @param renderVector re-render vector map layer enabled for editing (used for digitizer)
+ start = time.clock()
+ # if len(self.Map.GetListOfLayers()) == 0:
+ # return False
+ if self.img is None:
+ render = True
+ # initialize process bar (only on 'render')
+ # render background image if needed
+ # update layer dictionary if there has been a change in layers
+ if self.tree and self.tree.reorder == True:
+ self.tree.ReorderLayers()
+ # reset flag for auto-rendering
+ if self.tree:
+ self.tree.rerender = False
+ if render:
+ # update display size
+ windres = True
+ self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
+ windres=windres)
+ else:
+ self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+ self.img = self.GetImage() # id=99
+ # clear pseudoDcs
+ for pdc in (self.pdc,
+ self.pdcDec,
+ self.pdcTmp):
+ pdc.Clear()
+ pdc.RemoveAll()
+ # draw background map image to PseudoDC
+ if not self.img:
+ self.Draw(self.pdc, pdctype='clear')
+ else:
+ try:
+ id = self.imagedict[self.img]['id']
+ except:
+ return False
+ self.Draw(self.pdc, self.img, drawid=id)
+ # render vector map layer
+ # render overlays
+ for img in self.GetOverlay():
+ # draw any active and defined overlays
+ if self.imagedict[img]['layer'].IsActive():
+ id = self.imagedict[img]['id']
+ self.Draw(self.pdc, img=img, drawid=id,
+ pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
+ for id in self.textdict.keys():
+ self.Draw(self.pdc, img=self.textdict[id], drawid=id,
+ pdctype='text', coords=[10, 10, 10, 10])
+ # optionally draw computational extent box
+ #self.DrawCompRegionExtent()
+ # redraw pdcTmp if needed
+ if len(self.polycoords) > 0:
+ self.DrawLines(self.pdcTmp)
+ stop = time.clock()
+ return True
+ def IsInRegion(self, region, refRegion):
+ Test if 'region' is inside of 'refRegion'
+ @param region input region
+ @param refRegion reference region (e.g. computational region)
+ @return True if region is inside of refRegion
+ @return False
+ if region['s'] >= refRegion['s'] and \
+ region['n'] <= refRegion['n'] and \
+ region['w'] >= refRegion['w'] and \
+ region['e'] <= refRegion['e']:
+ return True
+ return False
+ def EraseMap(self):
+ Erase the canvas
+ self.Draw(self.pdcVector, pdctype='clear')
+ self.Draw(self.pdcDec, pdctype='clear')
+ self.Draw(self.pdcTmp, pdctype='clear')
+ def DragMap(self, moveto):
+ Drag the entire map image for panning.
+ @param moveto dx,dy
+ dc = wx.BufferedDC(wx.ClientDC(self))
+ dc.SetBackground(wx.Brush("White"))
+ dc.Clear()
+ self.dragimg = wx.DragImage(self.buffer)
+ self.dragimg.BeginDrag((0, 0), self)
+ self.dragimg.GetImageRect(moveto)
+ self.dragimg.Move(moveto)
+ self.dragimg.DoDrawImage(dc, moveto)
+ self.dragimg.EndDrag()
+ def DragItem(self, id, event):
+ Drag an overlay decoration item
+ if id == 99 or id == '' or id == None: return
+ Debug.msg (5, "BufferedWindow.DragItem(): id=%d" % id)
+ x, y = self.lastpos
+ dx = event.GetX() - x
+ dy = event.GetY() - y
+ r = self.pdc.GetIdBounds(id)
+ ### FIXME in vdigit/pseudodc.i
+ if type(r) is list:
+ r = wx.Rect(r[0], r[1], r[2], r[3])
+ if id > 100: # text dragging
+ rtop = (r[0],r[1]-r[3],r[2],r[3])
+ r = r.Union(rtop)
+ rleft = (r[0]-r[2],r[1],r[2],r[3])
+ r = r.Union(rleft)
+ self.pdc.TranslateId(id, dx, dy)
+ r2 = self.pdc.GetIdBounds(id)
+ if type(r2) is list:
+ r2 = wx.Rect(r[0], r[1], r[2], r[3])
+ self.textdict[id]['coords'] = r2
+ r = r.Union(r2)
+ r.Inflate(4,4)
+ self.RefreshRect(r, False)
+ self.lastpos = (event.GetX(), event.GetY())
+ def MouseDraw(self, pdc=None, begin=None, end=None):
+ Mouse box or line from 'begin' to 'end'
+ If not given from self.mouse['begin'] to self.mouse['end'].
+# self.redrawAll = False
+ if not pdc:
+ return
+ if begin is None:
+ begin = self.mouse['begin']
+ if end is None:
+ end = self.mouse['end']
+ Debug.msg (5, "BufferedWindow.MouseDraw(): use=%s, box=%s, begin=%f,%f, end=%f,%f" % \
+ (self.mouse['use'], self.mouse['box'],
+ begin[0], begin[1], end[0], end[1]))
+ if self.mouse['box'] == "box":
+ boxid = wx.ID_NEW
+ mousecoords = [begin[0], begin[1],
+ end[0], end[1]]
+ r = pdc.GetIdBounds(boxid)
+ r.Inflate(4, 4)
+ try:
+ pdc.ClearId(boxid)
+ except:
+ pass
+ pdc.SetId(boxid)
+ self.Draw(pdc, drawid=boxid, pdctype='box', coords=mousecoords)
+ elif self.mouse['box'] == "line" or self.mouse['box'] == 'point':
+ self.lineid = wx.ID_NEW
+ mousecoords = [begin[0], begin[1], \
+ end[0], end[1]]
+ x1=min(begin[0],end[0])
+ x2=max(begin[0],end[0])
+ y1=min(begin[1],end[1])
+ y2=max(begin[1],end[1])
+ r = wx.Rect(x1,y1,x2-x1,y2-y1)
+ r.Inflate(4,4)
+ try:
+ pdc.ClearId(self.lineid)
+ except:
+ pass
+ pdc.SetId(self.lineid)
+ self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
+ def DrawLines(self, pdc=None, polycoords=None):
+ Draw polyline in PseudoDC
+ Set self.pline to wx.NEW_ID + 1
+ polycoords - list of polyline vertices, geographical coordinates
+ (if not given, self.polycoords is used)
+ if not pdc:
+ pdc = self.pdcTmp
+ if not polycoords:
+ polycoords = self.polycoords
+ if len(polycoords) > 0:
+ self.plineid = wx.ID_NEW + 1
+ # convert from EN to XY
+ coords = []
+ for p in polycoords:
+ coords.append(self.Cell2Pixel(p))
+ self.Draw(pdc, drawid=self.plineid, pdctype='polyline', coords=coords)
+ Debug.msg (4, "BufferedWindow.DrawLines(): coords=%s, id=%s" % \
+ (coords, self.plineid))
+ return self.plineid
+ return -1
+ def DrawCross(self, pdc, coords, size, rotation=0,
+ text=None, textAlign='lr', textOffset=(5, 5)):
+ """!Draw cross in PseudoDC
+ @todo implement rotation
+ @param pdc PseudoDC
+ @param coord center coordinates
+ @param rotation rotate symbol
+ @param text draw also text (text, font, color, rotation)
+ @param textAlign alignment (default 'lower-right')
+ @textOffset offset for text (from center point)
+ Debug.msg(4, "BufferedWindow.DrawCross(): pdc=%s, coords=%s, size=%d" % \
+ (pdc, coords, size))
+ coordsCross = ((coords[0] - size, coords[1], coords[0] + size, coords[1]),
+ (coords[0], coords[1] - size, coords[0], coords[1] + size))
+ self.lineid = wx.NewId()
+ for lineCoords in coordsCross:
+ self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=lineCoords)
+ if not text:
+ return self.lineid
+ if textAlign == 'ul':
+ coord = [coords[0] - textOffset[0], coords[1] - textOffset[1], 0, 0]
+ elif textAlign == 'ur':
+ coord = [coords[0] + textOffset[0], coords[1] - textOffset[1], 0, 0]
+ elif textAlign == 'lr':
+ coord = [coords[0] + textOffset[0], coords[1] + textOffset[1], 0, 0]
+ else:
+ coord = [coords[0] - textOffset[0], coords[1] + textOffset[1], 0, 0]
+ self.Draw(pdc, img=text,
+ pdctype='text', coords=coord)
+ def MouseActions(self, event):
+ Mouse motion and button click notifier
+ if not self.processMouse:
+ return
+ # zoom with mouse wheel
+ if event.GetWheelRotation() != 0:
+ self.OnMouseWheel(event)
+ # left mouse button pressed
+ elif event.LeftDown():
+ self.OnLeftDown(event)
+ # left mouse button released
+ elif event.LeftUp():
+ self.OnLeftUp(event)
+ # dragging
+ elif event.Dragging():
+ self.OnDragging(event)
+ # double click
+ elif event.ButtonDClick():
+ self.OnButtonDClick(event)
+ def OnMouseWheel(self, event):
+ Mouse wheel moved
+ self.processMouse = False
+ current = event.GetPositionTuple()[:]
+ wheel = event.GetWheelRotation()
+ Debug.msg (5, "BufferedWindow.MouseAction(): wheel=%d" % wheel)
+ # zoom 1/2 of the screen, centered to current mouse position (TODO: settings)
+ begin = (current[0] - self.Map.width / 4,
+ current[1] - self.Map.height / 4)
+ end = (current[0] + self.Map.width / 4,
+ current[1] + self.Map.height / 4)
+ if wheel > 0:
+ zoomtype = 1
+ else:
+ zoomtype = -1
+ # zoom
+ self.Zoom(begin, end, zoomtype)
+ # redraw map
+ self.UpdateMap()
+ ### self.OnPaint(None)
+ # update statusbar
+ self.parent.StatusbarUpdate()
+ self.Refresh()
+# event.Skip()
+ def OnDragging(self, event):
+ Mouse dragging with left button down
+ Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
+ previous = self.mouse['begin']
+ move = (current[0] - previous[0],
+ current[1] - previous[1])
+ digitToolbar = self.parent.toolbars['vdigit']
+ # dragging or drawing box with left button
+ if self.mouse['use'] == 'pan' or \
+ event.MiddleIsDown():
+ self.DragMap(move)
+ # dragging decoration overlay item
+ elif (self.mouse['use'] == 'pointer' and
+ not digitToolbar and
+ self.dragid != None):
+ self.DragItem(self.dragid, event)
+ # dragging anything else - rubber band box or line
+ else:
+ if (self.mouse['use'] == 'pointer' and
+ not digitToolbar): return
+ self.mouse['end'] = event.GetPositionTuple()[:]
+# digitClass = self.parent.digit
+ if (event.LeftIsDown()):
+ # draw box only when left mouse button is pressed
+ self.MouseDraw(pdc=self.pdcTmp)
+ # event.Skip()
+ def OnLeftDown(self, event):
+ Left mouse button pressed
+ Debug.msg (5, "BufferedWindow.OnLeftDown(): use=%s" % \
+ self.mouse["use"])
+ self.mouse['begin'] = event.GetPositionTuple()[:]
+ if self.mouse["use"] in ["measure", "profile"]:
+ # measure or profile
+ if len(self.polycoords) == 0:
+ self.mouse['end'] = self.mouse['begin']
+ self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
+ self.ClearLines(pdc=self.pdcTmp)
+ else:
+ self.mouse['begin'] = self.mouse['end']
+ elif self.mouse['use'] == 'zoom':
+ pass
+ # vector digizer
+ elif self.mouse["use"] == "pointer" and \
+ self.parent.toolbars['vdigit']:
+ digitClass = self.parent.digit
+ try:
+ mapLayer = digitToolbar.GetLayer().GetName()
+ except:
+ wx.MessageBox(parent=self,
+ message=_("No vector map selected for editing."),
+ caption=_("Vector digitizer"),
+ style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ event.Skip()
+ return
+ if digitToolbar.GetAction() not in ("moveVertex",
+ "addVertex",
+ "removeVertex",
+ "editLine"):
+ # set pen
+ self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+ self.polypen = wx.Pen(colour='dark green', width=2, style=wx.SOLID)
+ if digitToolbar.GetAction() in ("addVertex",
+ "removeVertex",
+ "splitLines"):
+ # unselect
+ digitClass.driver.SetSelected([])
+ if digitToolbar.GetAction() == "addLine":
+ self.OnLeftDownVDigitAddLine(event)
+ elif digitToolbar.GetAction() == "editLine" and \
+ hasattr(self, "vdigitMove"):
+ self.OnLeftDownVDigitEditLine(event)
+ elif digitToolbar.GetAction() in ("moveLine",
+ "moveVertex",
+ "editLine") and \
+ not hasattr(self, "vdigitMove"):
+ self.OnLeftDownVDigitMoveLine(event)
+ elif digitToolbar.GetAction() in ("displayAttrs"
+ "displayCats"):
+ self.OnLeftDownVDigitDisplayCA(event)
+ elif digitToolbar.GetAction() in ("copyCats",
+ "copyAttrs"):
+ self.OnLeftDownVDigitCopyCA(event)
+ elif digitToolbar.GetAction() == "copyLine":
+ self.OnLeftDownVDigitCopyLine(event)
+ elif digitToolbar.GetAction() == "zbulkLine":
+ self.OnLeftDownVDigitBulkLine(event)
+ elif self.mouse['use'] == 'pointer':
+ # get decoration or text id
+ self.idlist = []
+ self.dragid = ''
+ self.lastpos = self.mouse['begin']
+ idlist = self.pdc.FindObjects(self.lastpos[0], self.lastpos[1],
+ self.hitradius)
+ if 99 in idlist:
+ idlist.remove(99)
+ if idlist != []:
+ self.dragid = idlist[0] #drag whatever is on top
+ else:
+ pass
+ event.Skip()
+ def OnLeftUp(self, event):
+ Left mouse button released
+ Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
+ if self.mouse['use'] in ["zoom", "pan"]:
+ # set region in zoom or pan
+ if self.mouse['use'] == 'zoom':
+ # set region for click (zero-width box)
+ if begin[0] - end[0] == 0 or \
+ begin[1] - end[1] == 0:
+ # zoom 1/2 of the screen (TODO: settings)
+ begin = (end[0] - self.Map.width / 4,
+ end[1] - self.Map.height / 4)
+ end = (end[0] + self.Map.width / 4,
+ end[1] + self.Map.height / 4)
+ self.Zoom(begin, end, self.zoomtype)
+ # redraw map
+# self.parent.StatusbarUpdate()
+ self.dragid >= 0):
+ # end drag of overlay decoration
+ if self.dragid < 99 and self.overlays.has_key(self.dragid):
+ self.overlays[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
+ elif self.dragid > 100 and self.textdict.has_key(self.dragid):
+ self.textdict[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
+ else:
+ pass
+ self.dragid = None
+ def OnRightDown(self, event):
+ Right mouse button pressed
+ Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
+ if digitToolbar:
+ # digitization tool (confirm action)
+ if digitToolbar.GetAction() in ("moveLine",
+ "moveVertex") and \
+ pFrom = self.vdigitMove['begin']
+ pTo = self.Pixel2Cell(event.GetPositionTuple())
+ move = (pTo[0] - pFrom[0],
+ pTo[1] - pFrom[1])
+ if digitToolbar.GetAction() == "moveLine":
+ # move line
+ if digitClass.MoveSelectedLines(move) < 0:
+ return
+ elif digitToolbar.GetAction() == "moveVertex":
+ # move vertex
+ fid = digitClass.MoveSelectedVertex(pFrom, move)
+ if fid < 0:
+ return
+ self.__geomAttrbUpdate([fid,])
+ del self.vdigitMove
+ event.Skip()
+ def OnRightUp(self, event):
+ Right mouse button released
+ Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
+ if digitToolbar:
+ if digitToolbar.GetAction() == "addLine" and \
+ digitToolbar.GetAction('type') in ["line", "boundary"]:
+ # -> add new line / boundary
+ try:
+ map = digitToolbar.GetLayer().GetName()
+ except:
+ map = None
+ caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ if map:
+ # mapcoords = []
+ # xy -> EN
+ # for coord in self.polycoords:
+ # mapcoords.append(self.Pixel2Cell(coord))
+ if digitToolbar.GetAction('type') == 'line':
+ line = True
+ else:
+ line = False
+ if len(self.polycoords) < 2: # ignore 'one-point' lines
+ return
+ fid = digitClass.AddLine(map, line, self.polycoords)
+ if fid < 0:
+ return
+ position = self.Cell2Pixel(self.polycoords[-1])
+ self.UpdateMap(render=False)
+ self.Refresh()
+ # add new record into atribute table
+ if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') and \
+ (line is True or \
+ (not line and fid > 0)):
+ posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
+ position[1] + self.dialogOffset))
+ # select attributes based on layer and category
+ cats = { fid : {
+ UserSettings.Get(group='vdigit', key="layer", subkey='value') :
+ (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
+ addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=map,
+ cats=cats,
+ pos=posWindow,
+ action="add")
+ self.__geomAttrb(fid, addRecordDlg, 'length', digitClass,
+ digitToolbar.GetLayer())
+ # auto-placing centroid
+ self.__geomAttrb(fid, addRecordDlg, 'area', digitClass,
+ self.__geomAttrb(fid, addRecordDlg, 'perimeter', digitClass,
+ if addRecordDlg.mapDBInfo and \
+ addRecordDlg.ShowModal() == wx.ID_OK:
+ sqlfile = tempfile.NamedTemporaryFile(mode="w")
+ for sql in addRecordDlg.GetSQLString():
+ sqlfile.file.write(sql + ";\n")
+ sqlfile.file.flush()
+ gcmd.RunCommand('db.execute',
+ parent = True,
+ quiet = True,
+ input = sqlfile.name)
+ if addRecordDlg.mapDBInfo:
+ self.__updateATM()
+ elif digitToolbar.GetAction() == "deleteLine":
+ # -> delete selected vector features
+ if digitClass.DeleteSelectedLines() < 0:
+ return
+ elif digitToolbar.GetAction() == "splitLine":
+ # split line
+ if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
+ return
+ elif digitToolbar.GetAction() == "addVertex":
+ # add vertex
+ fid = digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
+ return
+ elif digitToolbar.GetAction() == "removeVertex":
+ # remove vertex
+ fid = digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
+ if fid < 0:
+ return
+ elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
+ try:
+ if digitToolbar.GetAction() == 'copyCats':
+ if digitClass.CopyCats(self.copyCatsList,
+ self.copyCatsIds, copyAttrb=False) < 0:
+ return
+ else:
+ self.copyCatsIds, copyAttrb=True) < 0:
+ return
+ del self.copyCatsList
+ del self.copyCatsIds
+ pass
+ line = digitClass.driver.GetSelected()
+ if digitClass.EditLine(line, self.polycoords) < 0:
+ return
+ elif digitToolbar.GetAction() == "flipLine":
+ if digitClass.FlipLine() < 0:
+ return
+ elif digitToolbar.GetAction() == "mergeLine":
+ if digitClass.MergeLine() < 0:
+ return
+ elif digitToolbar.GetAction() == "breakLine":
+ if digitClass.BreakLine() < 0:
+ return
+ elif digitToolbar.GetAction() == "snapLine":
+ if digitClass.SnapLine() < 0:
+ return
+ elif digitToolbar.GetAction() == "connectLine":
+ if len(digitClass.driver.GetSelected()) > 1:
+ if digitClass.ConnectLine() < 0:
+ return
+ if digitClass.CopyLine(self.copyIds) < 0:
+ return
+ del self.copyIds
+ if self.layerTmp:
+ self.Map.DeleteLayer(self.layerTmp)
+ self.UpdateMap(render=True, renderVector=False)
+ del self.layerTmp
+ elif digitToolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
+ pos1 = self.polycoords[0]
+ pos2 = self.polycoords[1]
+ selected = digitClass.driver.GetSelected()
+ dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
+ nselected=len(selected))
+ if dlg.ShowModal() == wx.ID_OK:
+ if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
+ dlg.step.GetValue()) < 0:
+ return
+ self.UpdateMap(render=False, renderVector=True)
+ elif digitToolbar.GetAction() == "typeConv":
+ # -> feature type conversion
+ # - point <-> centroid
+ # - line <-> boundary
+ if digitClass.TypeConvForSelectedLines() < 0:
+ return
+ if digitToolbar.GetAction() != "addLine":
+ # unselect and re-render
+ self.Refresh()
+ event.Skip()
+ def OnMiddleDown(self, event):
+ Middle mouse button pressed
+ if self.mouse["use"] == "pointer" and digitToolbar:
+ if (digitToolbar.GetAction() == "addLine" and \
+ digitToolbar.GetAction('type') in ["line", "boundary"]) or \
+ digitToolbar.GetAction() == "editLine":
+ # add line or boundary -> remove last point from the line
+ try:
+ removed = self.polycoords.pop()
+ Debug.msg(4, "BufferedWindow.OnMiddleDown(): polycoords_poped=%s" % \
+ [removed,])
+ self.mouse['begin'] = self.Cell2Pixel(self.polycoords[-1])
+ except:
+ pass
+ if digitToolbar.GetAction() == "editLine":
+ # remove last vertex & line
+ if len(self.vdigitMove['id']) > 1:
+ self.vdigitMove['id'].pop()
+ self.UpdateMap(render=False, renderVector=False)
+ elif digitToolbar.GetAction() in ["deleteLine", "moveLine", "splitLine",
+ "addVertex", "removeVertex", "moveVertex",
+ "copyCats", "flipLine", "mergeLine",
+ "snapLine", "connectLine", "copyLine",
+ "queryLine", "breakLine", "typeConv"]:
+ # varios tools -> unselected selected features
+ if digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
+ elif digitToolbar.GetAction() == "copyCats":
+ try:
+ pass
+ del self.copyIds
+ if self.layerTmp:
+ del self.layerTmp
+ self.UpdateMap(render=False) # render vector
+ # reset polyline
+ def OnMiddleUp(self, event):
+ Middle mouse button released
+ self.Zoom(begin, end, 0) # no zoom
+ # redraw map
+ def ClearLines(self, pdc=None):
+ Clears temporary drawn lines from PseudoDC
+ if not pdc:
+ pdc=self.pdcTmp
+ try:
+ pdc.RemoveId(self.lineid)
+ except:
+ pass
+ try:
+ pdc.ClearId(self.plineid)
+ pdc.RemoveId(self.plineid)
+ except:
+ pass
+ Debug.msg(4, "BufferedWindow.ClearLines(): lineid=%s, plineid=%s" %
+ (self.lineid, self.plineid))
+ return True
+ def Pixel2Cell(self, (x, y)):
+ Convert image coordinates to real word coordinates
+ Input : int x, int y
+ Output: float x, float y
+ try:
+ x = int(x)
+ y = int(y)
+ except:
+ return None
+ if self.Map.region["ewres"] > self.Map.region["nsres"]:
+ res = self.Map.region["ewres"]
+ else:
+ res = self.Map.region["nsres"]
+ w = self.Map.region["center_easting"] - (self.Map.width / 2) * res
+ n = self.Map.region["center_northing"] + (self.Map.height / 2) * res
+ east = w + x * res
+ north = n - y * res
+ # extent does not correspond with whole map canvas area...
+ # east = self.Map.region['w'] + x * self.Map.region["ewres"]
+ # north = self.Map.region['n'] - y * self.Map.region["nsres"]
+ return (east, north)
+ def Cell2Pixel(self, (east, north)):
+ Convert real word coordinates to image coordinates
+ try:
+ east = float(east)
+ north = float(north)
+ except:
+ return None
+ else:
+ # x = int((east - w) / res)
+ # y = int((n - north) / res)
+ x = (east - w) / res
+ y = (n - north) / res
+ return (x, y)
+ def Zoom(self, begin, end, zoomtype):
+ Calculates new region while (un)zoom/pan-ing
+ x1, y1 = begin
+ x2, y2 = end
+ newreg = {}
+ # threshold - too small squares do not make sense
+ # can only zoom to windows of > 5x5 screen pixels
+ if abs(x2-x1) > 5 and abs(y2-y1) > 5 and zoomtype != 0:
+ if x1 > x2:
+ x1, x2 = x2, x1
+ if y1 > y2:
+ y1, y2 = y2, y1
+ # zoom in
+ if zoomtype > 0:
+ newreg['w'], newreg['n'] = self.Pixel2Cell((x1, y1))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((x2, y2))
+ # zoom out
+ elif zoomtype < 0:
+ newreg['w'], newreg['n'] = self.Pixel2Cell((-x1 * 2, -y1 * 2))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + 2 * \
+ (self.Map.width - x2),
+ self.Map.height + 2 * \
+ (self.Map.height - y2)))
+ # pan
+ elif zoomtype == 0:
+ dx = x1 - x2
+ dy = y1 - y2
+ newreg['w'], newreg['n'] = self.Pixel2Cell((dx, dy))
+ newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width + dx,
+ self.Map.height + dy))
+ # if new region has been calculated, set the values
+ if newreg != {}:
+ # LL locations
+ if self.parent.Map.projinfo['proj'] == 'll':
+ if newreg['n'] > 90.0:
+ newreg['n'] = 90.0
+ if newreg['s'] < -90.0:
+ newreg['s'] = -90.0
+ ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
+ cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
+ if hasattr(self, "vdigitMove"):
+ # xo = self.Cell2Pixel((self.Map.region['center_easting'], self.Map.region['center_northing']))
+ # xn = self.Cell2Pixel(ce, cn))
+ tmp = self.Pixel2Cell(self.mouse['end'])
+ # calculate new center point and display resolution
+ self.Map.region['center_easting'] = ce
+ self.Map.region['center_northing'] = cn
+ self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
+ self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
+ self.Map.AlignExtentFromDisplay()
+ tmp1 = self.mouse['end']
+ tmp2 = self.Cell2Pixel(self.vdigitMove['begin'])
+ dx = tmp1[0] - tmp2[0]
+ dy = tmp1[1] - tmp2[1]
+ self.vdigitMove['beginDiff'] = (dx, dy)
+ for id in self.vdigitMove['id']:
+ self.pdcTmp.RemoveId(id)
+ self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
+ self.Map.region['e'], self.Map.region['w'])
+ if self.redrawAll is False:
+ def ZoomBack(self):
+ """!Zoom to previous extents in zoomhistory list
+ zoom = list()
+ if len(self.zoomhistory) > 1:
+ self.zoomhistory.pop()
+ zoom = self.zoomhistory[-1]
+ # disable tool if stack is empty
+ if len(self.zoomhistory) < 2: # disable tool
+ if self.parent.GetName() == 'MapWindow':
+ toolbar = self.parent.toolbars['map']
+ elif self.parent.GetName() == 'GRMapWindow':
+ toolbar = self.parent.toolbars['georect']
+ toolbar.Enable('zoomback', enable = False)
+ # zoom to selected region
+ self.Map.GetRegion(n = zoom[0], s = zoom[1],
+ e = zoom[2], w = zoom[3],
+ update = True)
+ # update map
+ self.UpdateMap()
+ def ZoomHistory(self, n, s, e, w):
+ Manages a list of last 10 zoom extents
+ @param n,s,e,w north, south, east, west
+ @return removed history item if exists (or None)
+ removed = None
+ self.zoomhistory.append((n,s,e,w))
+ if len(self.zoomhistory) > 10:
+ removed = self.zoomhistory.pop(0)
+ if removed:
+ Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s, removed=%s" %
+ (self.zoomhistory, removed))
+ else:
+ Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s" %
+ (self.zoomhistory))
+ # update toolbar
+ enable = True
+ else:
+ enable = False
+ toolbar.Enable('zoomback', enable)
+ return removed
+ def ResetZoomHistory(self):
+ """!Reset zoom history"""
+ self.zoomhistory = list()
+ def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
+ Set display extents to match selected raster
+ or vector map(s).
+ @param layer list of layers to be zoom to
+ @param ignoreNulls True to ignore null-values
+ @param render True to re-render display
+ zoomreg = {}
+ if not layers:
+ layers = self.GetSelectedLayer(multi = True)
+ if not layers:
+ return
+ rast = []
+ vect = []
+ updated = False
+ for l in layers:
+ # only raster/vector layers are currently supported
+ if l.type == 'raster':
+ rast.append(l.name)
+ elif l.type == 'vector':
+ if digitToolbar and digitToolbar.GetLayer() == l:
+ w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
+ self.Map.GetRegion(n=n, s=s, w=w, e=e,
+ update=True)
+ updated = True
+ else:
+ vect.append(l.name)
+ if not updated:
+ self.Map.GetRegion(rast = rast,
+ vect = vect,
+ update = True)
+ if render:
+ self.UpdateMap()
Added: grass-addons/gui/wxpython/wx.path/wx.path.py
--- grass-addons/gui/wxpython/wx.path/wx.path.py (rev 0)
+++ grass-addons/gui/wxpython/wx.path/wx.path.py 2010-06-19 11:55:19 UTC (rev 42587)
@@ -0,0 +1,436 @@
+ at package wx.net.path.py
+ at brief Interface implementation of v.net.path.
+Inspired by http://grass.itc.it/gdp/html_grass64/v.net.path.html
+Hacked from mapdip and mapdisp_window from gui_modules
+Classes:
+- MapFrame
+- MapApp
+(C) 2006-2010 by the GRASS Development Team
+for details.
+ at author Mohammed Rashad K.M <rashadkm [at] gmail [dot] com>
+import os
+import sys
+import glob
+import math
+import tempfile
+import copy
+gbase = os.getenv("GISBASE")
+pypath = os.path.join(gbase,'etc','wxpython','gui_modules')
+sys.path.append(pypath)
+import globalvar
+if not os.getenv("GRASS_WXBUNDLED"):
+ globalvar.CheckForWx()
+import wx
+import wx.aui
+try:
+ import subprocess
+except:
+ CompatPath = os.path.join(globalvar.ETCWXDIR)
+ sys.path.append(CompatPath)
+ from compat import subprocess
+gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
+sys.path.append(gmpath)
+grassPath = os.path.join(globalvar.ETCDIR, "python")
+sys.path.append(grassPath)
+import render
+import toolbars
+from icon import Icons
+from mapdisp_command import Command
+from mapdisplay_window import BufferedWindow
+import images
+imagepath = images.__path__[0]
+sys.path.append(imagepath)
+class NetworkPath(wx.Frame):
+ def __init__(self, parent=None, id=wx.ID_ANY, title=_("v.net.path [vector, networking]"),
+ style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],Map=None,size=wx.DefaultSize):
+ self.Map = Map
+ # available cursors
+ self.cursors = {
+ # default: cross
+ # "default" : wx.StockCursor(wx.CURSOR_DEFAULT),
+ "default" : wx.StockCursor(wx.CURSOR_ARROW),
+ "cross" : wx.StockCursor(wx.CURSOR_CROSS),
+ "hand" : wx.StockCursor(wx.CURSOR_HAND),
+ "pencil" : wx.StockCursor(wx.CURSOR_PENCIL),
+ "sizenwse": wx.StockCursor(wx.CURSOR_SIZENWSE)
+ wx.Frame.__init__(self, parent, id, title, style = style)
+ self.SetName('MapWindow')
+ self.Maximize()
+ wx.MessageBox('Development has only started. currently works with spearfish data (myroads vector file). Kindly bear with me, Thankyou', 'Info')
+ # Fancy gui
+ # self._mgr = auimgr
+ self._mgr = wx.aui.AuiManager(self)
+ # Add toolbars
+ self.toolbars = { 'map' : None,
+ 'vdigit' : None,
+ 'georect' : None,
+ 'nviz' : None }
+ for toolb in toolbars:
+ self.AddToolbar(toolb)
+ # Add statusbar
+ self.statusbar = self.CreateStatusBar(number=1, style=0)
+ self.statusbar.SetStatusWidths([-5, -2, -1, -1])
+ # Init map display (buffered DC & set default cursor)
+ self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map)
+ # default is 2D display mode
+ self.MapWindow = self.MapWindow2D
+ self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+ # used by Nviz (3D display mode)
+ # initialize region values
+ self.__InitDisplay()
+ # Bind various events
+ #self.Bind(wx.EVT_CLOSE, self.OnCloseWindow)
+ # Update fancy gui style
+ self._mgr.AddPane(self.MapWindow, wx.aui.AuiPaneInfo().CentrePane().
+ Dockable(False).BestSize((-1,-1)).
+ CloseButton(False).DestroyOnClose(True).
+ Layer(0))
+ self._mgr.Update()
+ # Init zoom history
+ self.MapWindow.ZoomHistory(self.Map.region['n'],
+ self.Map.region['s'],
+ self.Map.region['w'])
+ def AddToolbar(self, name):
+ self.toolbars['map'] = MapToolbar(self, self.Map)
+ self._mgr.AddPane(self.toolbars['map'],
+ wx.aui.AuiPaneInfo().
+ Name("maptoolbar").Caption(_("Map Toolbar")).
+ ToolbarPane().Top().
+ LeftDockable(False).RightDockable(False).
+ BottomDockable(False).TopDockable(True).
+ CloseButton(False).Layer(2).
+ BestSize((self.toolbars['map'].GetSize())))
+ def __InitDisplay(self):
+ Initialize map display, set dimensions and map region
+ self.width, self.height = self.GetClientSize()
+ Debug.msg(2, "MapFrame.__InitDisplay():")
+ self.Map.region = self.Map.GetRegion() # g.region -upgc
+ # self.Map.SetRegion() # adjust region to match display window
+ def OnMotion(self, event):
+ Mouse moved
+ Track mouse motion and update status bar
+ # update statusbar if required
+ try:
+ e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
+ return
+ self.statusbar.SetStatusText("%.*f; %.*f" % (precision, e, precision, n), 0)
+ event.Skip()
+ def OnDraw(self, event):
+ Re-display current map composition
+ self.MapWindow.UpdateMap(render=False)
+ def OnPointer(self, event):
+ Pointer button clicked
+ self.MapWindow.SetCursor(self.cursors["default"])
+ def OnZoomIn(self, event):
+ Zoom in the map.
+ Set mouse cursor, zoombox attributes, and zoom direction
+ if self.toolbars['map']:
+ self.toolbars['map'].OnTool(event)
+ self.toolbars['map'].action['desc'] = ''
+ self.MapWindow.mouse['use'] = "zoom"
+ self.MapWindow.mouse['box'] = "box"
+ self.MapWindow.zoomtype = 1
+ self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
+ # change the cursor
+ self.MapWindow.SetCursor(self.cursors["cross"])
+ def OnZoomOut(self, event):
+ Zoom out the map.
+ self.MapWindow.zoomtype = -1
+ def OnZoomBack(self, event):
+ Zoom last (previously stored position)
+ self.MapWindow.ZoomBack()
+ def OnPan(self, event):
+ Panning, set mouse to drag
+ self.MapWindow.mouse['use'] = "pan"
+ self.MapWindow.mouse['box'] = "pan"
+ self.MapWindow.zoomtype = 0
+ self.MapWindow.SetCursor(self.cursors["hand"])
+ def OnErase(self, event):
+ Erase the canvas
+ self.MapWindow.EraseMap()
+ def OnZoomRegion(self, event):
+ Zoom to region
+ self.Map.getRegion()
+ self.Map.getResolution()
+ self.UpdateMap()
+ # event.Skip()
+ def GetRender(self):
+ """!Returns current instance of render.Map()
+ return self.Map
+ def GetWindow(self):
+ """!Get map window"""
+ return self.MapWindow
+ def GetOptData(self, dcmd, type, params, propwin):
+ Callback method for decoration overlay command generated by
+ dialog created in menuform.py
+ # Reset comand and rendering options in render.Map. Always render decoration.
+ # Showing/hiding handled by PseudoDC
+ self.Map.ChangeOverlay(ovltype=type, type='overlay', name='', command=dcmd,
+ l_active=True, l_render=False)
+ self.params[type] = params
+ self.propwin[type] = propwin
+ def OnZoomToMap(self, event):
+ Set display extents to match selected raster (including NULLs)
+ or vector map.
+ self.MapWindow.ZoomToMap()
+ def OnZoomToRaster(self, event):
+ Set display extents to match selected raster map (ignore NULLs)
+ self.MapWindow.ZoomToMap(ignoreNulls = True)
+# end of class MapFrame
+class MapToolbar(toolbars.AbstractToolbar):
+ """!Map Display toolbar
+ def __init__(self, parent, mapcontent):
+ """!Map Display constructor
+ @param parent reference to MapFrame
+ @param mapcontent reference to render.Map (registred by MapFrame)
+ self.mapcontent = mapcontent # render.Map
+ toolbars.AbstractToolbar.__init__(self, parent = parent) # MapFrame
+ self.InitToolbar(self.ToolbarData())
+ # optional tools
+ self.action = { 'id' : self.pointer }
+ self.defaultAction = { 'id' : self.pointer,
+ 'bind' : self.parent.OnPointer }
+ self.OnTool(None)
+ self.EnableTool(self.zoomback, False)
+ self.FixSize(width = 90)
+ def ToolbarData(self):
+ """!Toolbar data"""
+ self.pointer = wx.NewId()
+ self.pan = wx.NewId()
+ self.zoomin = wx.NewId()
+ self.zoomout = wx.NewId()
+ self.zoomback = wx.NewId()
+ self.zoommenu = wx.NewId()
+ self.zoomextent = wx.NewId()
+ # tool, label, bitmap, kind, shortHelp, longHelp, handler
+ return (
+ (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
+ self.parent.OnPointer),
+ (self.pan, "pan", Icons["pan"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
+ self.parent.OnPan),
+ (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
+ self.parent.OnZoomIn),
+ (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
+ wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
+ self.parent.OnZoomOut),
+ (self.zoomextent, "zoom_extent", Icons["zoom_extent"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoom_extent"].GetLabel(), Icons["zoom_extent"].GetDesc(),
+ self.parent.OnZoomToMap),
+ (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
+ wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
+ self.parent.OnZoomBack)
+class PathApp(wx.App):
+ MapApp class
+ def OnInit(self):
+ if __name__ == "__main__":
+ Map = render.Map()
+ else:
+ Map = None
+ self.mapname = 'roads at PERMANENT'
+ self.cmd= ['d.vect', str("map=" + self.mapname)]
+ Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
+ self.frame = NetworkPath(parent=None, id=wx.ID_ANY, Map=Map,
+ size=globalvar.MAP_WINDOW_SIZE)
+ self.frame.Show()
+ return 1
+# end of class
+if __name__ == "__main__":
+ gm_map = PathApp(0)
+ gm_map.MainLoop()
+ sys.exit(0)
