[GRASS-SVN] r42591 - grass-addons/gui/wxpython/wx.path
Sat Jun 19 12:52:53 EDT 2010
Author: rashadkm
Date: 2010-06-19 16:52:53 +0000 (Sat, 19 Jun 2010)
New Revision: 42591
Removed:
   grass-addons/gui/wxpython/wx.path/mapdisplay_window.py
   grass-addons/gui/wxpython/wx.path/wx.path.py
updated to work a single file
Deleted: grass-addons/gui/wxpython/wx.path/mapdisplay_window.py
--- grass-addons/gui/wxpython/wx.path/mapdisplay_window.py	2010-06-19 14:25:42 UTC (rev 42590)
+++ grass-addons/gui/wxpython/wx.path/mapdisplay_window.py	2010-06-19 16:52:53 UTC (rev 42591)
@@ -1,1684 +0,0 @@
- at package mapdisp_window.py
- at brief GIS map display canvas, buffered window.
-Classes:
- - MapWindow
- - BufferedWindow
-(C) 2006-2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Michael Barton
- at author Jachym Cepicky
- at author Martin Landa <landa.martin gmail.com>
-import os
-import time
-import math
-import sys
-import tempfile
-import traceback
-import wx
-import grass.script as grass
-import dbm
-import dbm_dialogs
-import gdialogs
-import gcmd
-import utils
-import globalvar
-import gselect
-from debug import Debug
-from preferences import globalSettings as UserSettings
-from units import ConvertValue as UnitsConvertValue
-from mapdisp_window import MapWindow
-class BufferedWindow(MapWindow, wx.Window):
-    A Buffered window class.
-    When the drawing needs to change, you app needs to call the
-    UpdateMap() method. Since the drawing is stored in a bitmap, you
-    can also save the drawing to file by calling the
-    SaveToFile(self,file_name,file_type) method.
-    def __init__(self, parent, id,
-                 pos = wx.DefaultPosition,
-                 size = wx.DefaultSize,
-                 style=wx.NO_FULL_REPAINT_ON_RESIZE,
-                 Map=None, tree=None, lmgr=None):
-        MapWindow.__init__(self, parent, id, pos, size, style,
-                           Map, tree, lmgr)
-        wx.Window.__init__(self, parent, id, pos, size, style)
-        self.Map = Map
-        self.tree = tree
-        self.lmgr = lmgr    # Layer Manager
-        self.counter =0
-        self.points = []
-        # Flags
-        self.resize = False # indicates whether or not a resize event has taken place
-        self.dragimg = None # initialize variable for map panning
-        # Variable for drawing on DC
-        self.pen = None      # pen for drawing zoom boxes, etc.
-        self.polypen = None  # pen for drawing polylines (measurements, profiles, etc)
-        # List of wx.Point tuples defining a polyline (geographical coordinates)
-        self.polycoords = []
-        # ID of rubber band line
-        self.lineid = None
-        # ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
-        self.plineid = None
-        # Event bindings
-        self.Bind(wx.EVT_PAINT,        self.OnPaint)
-        self.Bind(wx.EVT_SIZE,         self.OnSize)
-        self.Bind(wx.EVT_IDLE,         self.OnIdle)
-        self.Bind(wx.EVT_MOTION,       self.MouseActions)
-        self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
-        self.processMouse = True
-        # Render output objects
-        self.mapfile = None   # image file to be rendered
-        self.img = ""         # wx.Image object (self.mapfile)
-        # used in digitization tool (do not redraw vector map)
-        self.imgVectorMap = None
-        # decoration overlays
-        self.overlays = {}
-        # images and their PseudoDC ID's for painting and dragging
-        self.imagedict = {}
-        self.select = {}      # selecting/unselecting decorations for dragging
-        self.textdict = {}    # text, font, and color indexed by id
-        self.currtxtid = None # PseudoDC id for currently selected text
-        self.flag =False
-        # Zoom objects
-        self.zoomhistory = [] # list of past zoom extents
-        self.currzoom = 0 # current set of extents in zoom history being used
-        self.zoomtype = 1   # 1 zoom in, 0 no zoom, -1 zoom out
-        self.hitradius = 10 # distance for selecting map decorations
-        self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
-        # OnSize called to make sure the buffer is initialized.
-        # This might result in OnSize getting called twice on some
-        # platforms at initialization, but little harm done.
-        ### self.OnSize(None)
-        self.DefinePseudoDC()
-        # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
-        self.redrawAll = True
-        # will store an off screen empty bitmap for saving to file
-        self._buffer = ''
-        self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
-        self.Bind(wx.EVT_KEY_DOWN , self.OnKeyDown)
-        # vars for handling mouse clicks
-        self.dragid   = -1
-        self.lastpos  = (0, 0)
-    def OnButtonDClick(self,event):
-        precision = int(UserSettings.Get(group = 'projection', key = 'format',
-                                             subkey = 'precision'))
-        try:
-            e, n = self.Pixel2Cell(event.GetPositionTuple())
-        except AttributeError:
-            return
-        self.counter = self.counter + 1
-        self.flag=True
-        point =("%.*f|%.*f" %  (precision, e, precision, n))
-        self.points.append(point + '|point')
-        if self.counter == 2:
-            f =open("tmp1",'w')
-            for p in self.points:
-                f.write("%s\n" % p)
-            f.close()
-            f =open("tmp2",'w')
-            f.write("%d %d %d\n" %(1,1,2) )
-            f.close()
-            command =["g.remove",'vect=vnet_out,startend,tmp_vnet_path']
-            gcmd.CommandThread(command,stdout=None,stderr=None).run()
-            command =["v.in.ascii",'input=tmp1','output=startend']
-            command=["v.net", "input=myroads",'points=startend', 'out=vnet_out', 'op=connect', 'thresh=200']
-            command=["v.net.path", 'vnet_out','afcol=forward', 'abcol=backward', 'out=tmp_vnet_path','file=tmp2']
-            self.mapname = 'tmp_vnet_path@' + grass.gisenv()['MAPSET']
-            self.cmd= ['d.vect', str("map=" + self.mapname),'col=red','width=2']
-            self.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
-            self.UpdateMap(render=True)
-            self.counter =0
-            self.points=[]
-            #os.remove("tmp1")
-            #os.remove("tmp2")
-    def DefinePseudoDC(self, vdigit = False):
-        """!Define PseudoDC class to use
-        @vdigit True to use PseudoDC from vdigit
-        # create PseudoDC used for background map, map decorations like scales and legends
-        self.pdc = self.PseudoDC(vdigit)
-        # used for digitization tool
-        self.pdcVector = None
-        # decorations (region box, etc.)
-        self.pdcDec = self.PseudoDC(vdigit)
-        # pseudoDC for temporal objects (select box, measurement tool, etc.)
-        self.pdcTmp = self.PseudoDC(vdigit)
-    def PseudoDC(self, vdigit = False):
-        """!Create PseudoDC instance"""
-        if vdigit:
-            PseudoDC = VDigitPseudoDC
-        else:
-            PseudoDC = wx.PseudoDC
-        return PseudoDC()
-    def CheckPseudoDC(self):
-        """!Try to draw background
-        @return True on success
-        @return False on failure
-        try:
-            self.pdc.BeginDrawing()
-            self.pdc.SetBackground(wx.Brush(self.GetBackgroundColour()))
-        except StandardError, e:
-            traceback.print_exc(file = sys.stderr)
-            return False
-        return True
-    def Draw(self, pdc, img=None, drawid=None, pdctype='image', coords=[0, 0, 0, 0]):
-        Draws map and overlay decorations
-        if drawid == None:
-            if pdctype == 'image' and img:
-                drawid = self.imagedict[img]
-            elif pdctype == 'clear':
-                drawid == None
-            else:
-                drawid = wx.NewId()
-        if img and pdctype == 'image':
-            # self.imagedict[img]['coords'] = coords
-            self.select[self.imagedict[img]['id']] = False # ?
-        pdc.BeginDrawing()
-        if drawid != 99:
-            bg = wx.TRANSPARENT_BRUSH
-        else:
-            bg = wx.Brush(self.GetBackgroundColour())
-        pdc.SetBackground(bg)
-        ### pdc.Clear()
-        Debug.msg (5, "BufferedWindow.Draw(): id=%s, pdctype=%s, coord=%s" % \
-                       (drawid, pdctype, coords))
-        # set PseudoDC id
-        if drawid is not None:
-            pdc.SetId(drawid)
-        if pdctype == 'clear': # erase the display
-            bg = wx.WHITE_BRUSH
-            # bg = wx.Brush(self.GetBackgroundColour())
-            pdc.RemoveAll()
-            pdc.Clear()
-            pdc.EndDrawing()
-            self.Refresh()
-            return
-        if pdctype == 'image': # draw selected image
-            bitmap = wx.BitmapFromImage(img)
-            w,h = bitmap.GetSize()
-            pdc.DrawBitmap(bitmap, coords[0], coords[1], True) # draw the composite map
-            pdc.SetIdBounds(drawid, wx.Rect(coords[0],coords[1], w, h))
-        elif pdctype == 'box': # draw a box on top of the map
-            if self.pen:
-                pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
-                pdc.SetPen(self.pen)
-                x2 = max(coords[0],coords[2])
-                x1 = min(coords[0],coords[2])
-                y2 = max(coords[1],coords[3])
-                y1 = min(coords[1],coords[3])
-                rwidth = x2-x1
-                rheight = y2-y1
-                rect = wx.Rect(x1, y1, rwidth, rheight)
-                pdc.DrawRectangleRect(rect)
-                pdc.SetIdBounds(drawid, rect)
-        elif pdctype == 'line': # draw a line on top of the map
-            if self.pen:
-                pdc.DrawLinePoint(wx.Point(coords[0], coords[1]),wx.Point(coords[2], coords[3]))
-                pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], coords[2], coords[3]))
-                # self.ovlcoords[drawid] = coords
-        elif pdctype == 'polyline': # draw a polyline on top of the map
-            if self.polypen:
-                pdc.SetPen(self.polypen)
-                ### pdc.DrawLines(coords)
-                if (len(coords) < 2):
-                    return
-                i = 1
-                while i < len(coords):
-                    pdc.DrawLinePoint(wx.Point(coords[i-1][0], coords[i-1][1]),
-                                      wx.Point(coords[i][0], coords[i][1]))
-                    i += 1
-                # get bounding rectangle for polyline
-                xlist = []
-                ylist = []
-                if len(coords) > 0:
-                    for point in coords:
-                        x,y = point
-                        xlist.append(x)
-                        ylist.append(y)
-                    x1=min(xlist)
-                    x2=max(xlist)
-                    y1=min(ylist)
-                    y2=max(ylist)
-                    pdc.SetIdBounds(drawid, wx.Rect(x1,y1,x2,y2))
-                    # self.ovlcoords[drawid] = [x1,y1,x2,y2]
-        elif pdctype == 'point': # draw point
-            if self.pen:
-                pdc.DrawPoint(coords[0], coords[1])
-                coordsBound = (coords[0] - 5,
-                               coords[1] - 5,
-                               coords[0] + 5,
-                               coords[1] + 5)
-                pdc.SetIdBounds(drawid, wx.Rect(coordsBound))
-        elif pdctype == 'text': # draw text on top of map
-            if not img['active']:
-                return #only draw active text
-            if img.has_key('rotation'):
-                rotation = float(img['rotation'])
-            else:
-                rotation = 0.0
-            w, h = self.GetFullTextExtent(img['text'])[0:2]
-            pdc.SetFont(img['font'])
-            pdc.SetTextForeground(img['color'])
-            coords, w, h = self.TextBounds(img)
-            if rotation == 0:
-                pdc.DrawText(img['text'], coords[0], coords[1])
-            else:
-                pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
-            pdc.SetIdBounds(drawid, wx.Rect(coords[0], coords[1], w, h))
-        pdc.EndDrawing()
-        self.Refresh()
-        return drawid
-    def TextBounds(self, textinfo):
-        Return text boundary data
-        @param textinfo text metadata (text, font, color, rotation)
-        @param coords reference point
-        if textinfo.has_key('rotation'):
-            rotation = float(textinfo['rotation'])
-        else:
-            rotation = 0.0
-        coords = textinfo['coords']
-        Debug.msg (4, "BufferedWindow.TextBounds(): text=%s, rotation=%f" % \
-                   (textinfo['text'], rotation))
-        self.Update()
-        ### self.Refresh()
-        self.SetFont(textinfo['font'])
-        w, h = self.GetTextExtent(textinfo['text'])
-        if rotation == 0:
-            coords[2], coords[3] = coords[0] + w, coords[1] + h
-            return coords, w, h
-        boxh = math.fabs(math.sin(math.radians(rotation)) * w) + h
-        boxw = math.fabs(math.cos(math.radians(rotation)) * w) + h
-        coords[2] = coords[0] + boxw
-        coords[3] = coords[1] + boxh
-        return coords, boxw, boxh
-    def OnPaint(self, event):
-        Draw PseudoDC's to buffered paint DC
-        self.pdc for background and decorations
-        self.pdcVector for vector map which is edited
-        self.pdcTmp for temporaly drawn objects (self.polycoords)
-        If self.redrawAll is False on self.pdcTmp content is re-drawn
-        Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
-        dc = wx.BufferedPaintDC(self, self.buffer)
-        ### dc.SetBackground(wx.Brush("White"))
-        dc.Clear()
-        # use PrepareDC to set position correctly
-        self.PrepareDC(dc)
-        # create a clipping rect from our position and size
-        # and update region
-        rgn = self.GetUpdateRegion().GetBox()
-        dc.SetClippingRect(rgn)
-        switchDraw = False
-        if self.redrawAll is None:
-            switchDraw = True
-        if self.redrawAll: # redraw pdc and pdcVector
-            # draw to the dc using the calculated clipping rect
-            self.pdc.DrawToDCClipped(dc, rgn)
-            # draw vector map layer
-            if self.pdcVector:
-                # decorate with GDDC (transparency)
-                try:
-                    gcdc = wx.GCDC(dc)
-                    self.pdcVector.DrawToDCClipped(gcdc, rgn)
-                except NotImplementedError, e:
-                    print >> sys.stderr, e
-                    self.pdcVector.DrawToDCClipped(dc, rgn)
-            self.bufferLast = None
-        else: # do not redraw pdc and pdcVector
-            if self.bufferLast is None:
-                # draw to the dc
-                self.pdc.DrawToDC(dc)
-                    try:
-                        self.pdcVector.DrawToDC(gcdc)
-                        self.pdcVector.DrawToDC(dc)
-                # store buffered image
-                # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
-                self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
-            pdcLast = self.PseudoDC(vdigit = False)
-            pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
-            pdcLast.DrawToDC(dc)
-        # draw decorations (e.g. region box)
-        try:
-            self.pdcDec.DrawToDC(gcdc)
-            self.pdcDec.DrawToDC(dc)
-        # draw temporary object on the foreground
-        ### self.pdcTmp.DrawToDCClipped(dc, rgn)
-        self.pdcTmp.DrawToDC(dc)
-        if switchDraw:
-            self.redrawAll = False
-    def OnSize(self, event):
-        """!Scale map image so that it is the same size as the Window
-        Debug.msg(3, "BufferedWindow.OnSize():")
-        # set size of the input image
-        self.Map.ChangeMapSize(self.GetClientSize())
-        # align extent based on center point and display resolution
-        # this causes that image is not resized when display windows is resized
-        ### self.Map.AlignExtentFromDisplay()
-        # Make new off screen bitmap: this bitmap will always have the
-        # current drawing in it, so it can be used to save the image to
-        # a file, or whatever.
-        self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
-        # get the image to be rendered
-        self.img = self.GetImage()
-        # update map display
-        if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
-            self.img = self.img.Scale(self.Map.width, self.Map.height)
-            if len(self.Map.GetListOfLayers()) > 0:
-                self.UpdateMap()
-        # re-render image on idle
-        self.resize = True
-    def OnIdle(self, event):
-        """!Only re-render a composite map image from GRASS during
-        idle time instead of multiple times during resizing.
-        if self.resize:
-        event.Skip()
-    def GetOverlay(self):
-        Converts rendered overlay files to wx.Image
-        Updates self.imagedict
-        @return list of images
-        imgs = []
-        for overlay in self.Map.GetListOfLayers(l_type="overlay", l_active=True):
-            if os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
-                img = wx.Image(overlay.mapfile, wx.BITMAP_TYPE_ANY)
-                self.imagedict[img] = { 'id' : overlay.id,
-                                        'layer' : overlay }
-                imgs.append(img)
-        return imgs
-    def GetImage(self):
-        """!Converts redered map files to wx.Image
-        Updates self.imagedict (id=99)
-        @return wx.Image instance (map composition)
-        imgId = 99
-        if self.Map.mapfile and os.path.isfile(self.Map.mapfile) and \
-                os.path.getsize(self.Map.mapfile):
-            img = wx.Image(self.Map.mapfile, wx.BITMAP_TYPE_ANY)
-        else:
-            img = None
-        self.imagedict[img] = { 'id': imgId }
-        return img
-    def UpdateMap(self, render=True, renderVector=True):
-        Updates the canvas anytime there is a change to the
-        underlaying images or to the geometry of the canvas.
-        @param render re-render map composition
-        @param renderVector re-render vector map layer enabled for editing (used for digitizer)
-        start = time.clock()
-        # if len(self.Map.GetListOfLayers()) == 0:
-        #    return False
-        if self.img is None:
-            render = True
-        # initialize process bar (only on 'render')
-        # render background image if needed
-        # update layer dictionary if there has been a change in layers
-        if self.tree and self.tree.reorder == True:
-            self.tree.ReorderLayers()
-        # reset flag for auto-rendering
-        if self.tree:
-            self.tree.rerender = False
-        if render:
-            # update display size
-            windres = True
-            self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
-                                           windres=windres)
-        else:
-            self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
-        self.img = self.GetImage() # id=99
-        # clear pseudoDcs
-        for pdc in (self.pdc,
-                    self.pdcDec,
-                    self.pdcTmp):
-            pdc.Clear()
-            pdc.RemoveAll()
-        # draw background map image to PseudoDC
-        if not self.img:
-            self.Draw(self.pdc, pdctype='clear')
-        else:
-            try:
-                id = self.imagedict[self.img]['id']
-            except:
-                return False
-            self.Draw(self.pdc, self.img, drawid=id)
-        # render vector map layer
-        # render overlays
-        for img in self.GetOverlay():
-            # draw any active and defined overlays
-            if self.imagedict[img]['layer'].IsActive():
-                id = self.imagedict[img]['id']
-                self.Draw(self.pdc, img=img, drawid=id,
-                          pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
-        for id in self.textdict.keys():
-            self.Draw(self.pdc, img=self.textdict[id], drawid=id,
-                      pdctype='text', coords=[10, 10, 10, 10])
-        # optionally draw computational extent box
-        #self.DrawCompRegionExtent()
-        # redraw pdcTmp if needed
-        if len(self.polycoords) > 0:
-            self.DrawLines(self.pdcTmp)
-        stop = time.clock()
-        return True
-    def IsInRegion(self, region, refRegion):
-        Test if 'region' is inside of 'refRegion'
-        @param region input region
-        @param refRegion reference region (e.g. computational region)
-        @return True if region is inside of refRegion
-        @return False
-        if region['s'] >= refRegion['s'] and \
-                region['n'] <= refRegion['n'] and \
-                region['w'] >= refRegion['w'] and \
-                region['e'] <= refRegion['e']:
-            return True
-        return False
-    def EraseMap(self):
-        Erase the canvas
-            self.Draw(self.pdcVector, pdctype='clear')
-        self.Draw(self.pdcDec, pdctype='clear')
-        self.Draw(self.pdcTmp, pdctype='clear')
-    def DragMap(self, moveto):
-        Drag the entire map image for panning.
-        @param moveto dx,dy
-        dc = wx.BufferedDC(wx.ClientDC(self))
-        dc.SetBackground(wx.Brush("White"))
-        dc.Clear()
-        self.dragimg = wx.DragImage(self.buffer)
-        self.dragimg.BeginDrag((0, 0), self)
-        self.dragimg.GetImageRect(moveto)
-        self.dragimg.Move(moveto)
-        self.dragimg.DoDrawImage(dc, moveto)
-        self.dragimg.EndDrag()
-    def DragItem(self, id, event):
-        Drag an overlay decoration item
-        if id == 99 or id == '' or id == None: return
-        Debug.msg (5, "BufferedWindow.DragItem(): id=%d" % id)
-        x, y = self.lastpos
-        dx = event.GetX() - x
-        dy = event.GetY() - y
-        r = self.pdc.GetIdBounds(id)
-        ### FIXME in vdigit/pseudodc.i
-        if type(r) is list:
-            r = wx.Rect(r[0], r[1], r[2], r[3])
-        if id > 100: # text dragging
-            rtop = (r[0],r[1]-r[3],r[2],r[3])
-            r = r.Union(rtop)
-            rleft = (r[0]-r[2],r[1],r[2],r[3])
-            r = r.Union(rleft)
-        self.pdc.TranslateId(id, dx, dy)
-        r2 = self.pdc.GetIdBounds(id)
-        if type(r2) is list:
-            r2 = wx.Rect(r[0], r[1], r[2], r[3])
-            self.textdict[id]['coords'] = r2
-        r = r.Union(r2)
-        r.Inflate(4,4)
-        self.RefreshRect(r, False)
-        self.lastpos = (event.GetX(), event.GetY())
-    def MouseDraw(self, pdc=None, begin=None, end=None):
-        Mouse box or line from 'begin' to 'end'
-        If not given from self.mouse['begin'] to self.mouse['end'].
-#        self.redrawAll = False
-        if not pdc:
-            return
-        if begin is None:
-            begin = self.mouse['begin']
-        if end is None:
-            end   = self.mouse['end']
-        Debug.msg (5, "BufferedWindow.MouseDraw(): use=%s, box=%s, begin=%f,%f, end=%f,%f" % \
-                       (self.mouse['use'], self.mouse['box'],
-                        begin[0], begin[1], end[0], end[1]))
-        if self.mouse['box'] == "box":
-            boxid = wx.ID_NEW
-            mousecoords = [begin[0], begin[1],
-                           end[0], end[1]]
-            r = pdc.GetIdBounds(boxid)
-            r.Inflate(4, 4)
-            try:
-                pdc.ClearId(boxid)
-            except:
-                pass
-            pdc.SetId(boxid)
-            self.Draw(pdc, drawid=boxid, pdctype='box', coords=mousecoords)
-        elif self.mouse['box'] == "line" or self.mouse['box'] == 'point':
-            self.lineid = wx.ID_NEW
-            mousecoords = [begin[0], begin[1], \
-                           end[0], end[1]]
-            x1=min(begin[0],end[0])
-            x2=max(begin[0],end[0])
-            y1=min(begin[1],end[1])
-            y2=max(begin[1],end[1])
-            r = wx.Rect(x1,y1,x2-x1,y2-y1)
-            r.Inflate(4,4)
-            try:
-                pdc.ClearId(self.lineid)
-            except:
-                pass
-            pdc.SetId(self.lineid)
-            self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=mousecoords)
-    def DrawLines(self, pdc=None, polycoords=None):
-        Draw polyline in PseudoDC
-        Set self.pline to wx.NEW_ID + 1
-        polycoords - list of polyline vertices, geographical coordinates
-        (if not given, self.polycoords is used)
-        if not pdc:
-            pdc = self.pdcTmp
-        if not polycoords:
-            polycoords = self.polycoords
-        if len(polycoords) > 0:
-            self.plineid = wx.ID_NEW + 1
-            # convert from EN to XY
-            coords = []
-            for p in polycoords:
-                coords.append(self.Cell2Pixel(p))
-            self.Draw(pdc, drawid=self.plineid, pdctype='polyline', coords=coords)
-            Debug.msg (4, "BufferedWindow.DrawLines(): coords=%s, id=%s" % \
-                           (coords, self.plineid))
-            return self.plineid
-        return -1
-    def DrawCross(self, pdc, coords, size, rotation=0,
-                  text=None, textAlign='lr', textOffset=(5, 5)):
-        """!Draw cross in PseudoDC
-        @todo implement rotation
-        @param pdc PseudoDC
-        @param coord center coordinates
-        @param rotation rotate symbol
-        @param text draw also text (text, font, color, rotation)
-        @param textAlign alignment (default 'lower-right')
-        @textOffset offset for text (from center point)
-        Debug.msg(4, "BufferedWindow.DrawCross(): pdc=%s, coords=%s, size=%d" % \
-                  (pdc, coords, size))
-        coordsCross = ((coords[0] - size, coords[1], coords[0] + size, coords[1]),
-                       (coords[0], coords[1] - size, coords[0], coords[1] + size))
-        self.lineid = wx.NewId()
-        for lineCoords in coordsCross:
-            self.Draw(pdc, drawid=self.lineid, pdctype='line', coords=lineCoords)
-        if not text:
-            return self.lineid
-        if textAlign == 'ul':
-            coord = [coords[0] - textOffset[0], coords[1] - textOffset[1], 0, 0]
-        elif textAlign == 'ur':
-            coord = [coords[0] + textOffset[0], coords[1] - textOffset[1], 0, 0]
-        elif textAlign == 'lr':
-            coord = [coords[0] + textOffset[0], coords[1] + textOffset[1], 0, 0]
-        else:
-            coord = [coords[0] - textOffset[0], coords[1] + textOffset[1], 0, 0]
-        self.Draw(pdc, img=text,
-                  pdctype='text', coords=coord)
-    def MouseActions(self, event):
-        Mouse motion and button click notifier
-        if not self.processMouse:
-            return
-        # zoom with mouse wheel
-        if event.GetWheelRotation() != 0:
-            self.OnMouseWheel(event)
-        # left mouse button pressed
-        elif event.LeftDown():
-            self.OnLeftDown(event)
-        # left mouse button released
-        elif event.LeftUp():
-            self.OnLeftUp(event)
-        # dragging
-        elif event.Dragging():
-            self.OnDragging(event)
-        # double click
-        elif event.ButtonDClick():
-            self.OnButtonDClick(event)
-    def OnMouseWheel(self, event):
-        Mouse wheel moved
-        self.processMouse = False
-        current  = event.GetPositionTuple()[:]
-        wheel = event.GetWheelRotation()
-        Debug.msg (5, "BufferedWindow.MouseAction(): wheel=%d" % wheel)
-        # zoom 1/2 of the screen, centered to current mouse position (TODO: settings)
-        begin = (current[0] - self.Map.width / 4,
-                 current[1] - self.Map.height / 4)
-        end   = (current[0] + self.Map.width / 4,
-                 current[1] + self.Map.height / 4)
-        if wheel > 0:
-            zoomtype = 1
-        else:
-            zoomtype = -1
-        # zoom
-        self.Zoom(begin, end, zoomtype)
-        # redraw map
-        self.UpdateMap()
-        ### self.OnPaint(None)
-        # update statusbar
-#        self.parent.StatusbarUpdate()
-        self.Refresh()
-#        event.Skip()
-    def OnDragging(self, event):
-        Mouse dragging with left button down
-        Debug.msg (5, "BufferedWindow.MouseAction(): Dragging")
-        previous = self.mouse['begin']
-        move = (current[0] - previous[0],
-                current[1] - previous[1])
-        digitToolbar = self.parent.toolbars['vdigit']
-        # dragging or drawing box with left button
-        if self.mouse['use'] == 'pan' or \
-                event.MiddleIsDown():
-            self.DragMap(move)
-        # dragging decoration overlay item
-        elif (self.mouse['use'] == 'pointer' and
-                not digitToolbar and
-                self.dragid != None):
-            self.DragItem(self.dragid, event)
-        # dragging anything else - rubber band box or line
-        else:
-            if (self.mouse['use'] == 'pointer' and
-                not digitToolbar): return
-            self.mouse['end'] = event.GetPositionTuple()[:]
-#            digitClass = self.parent.digit
-            if (event.LeftIsDown()):
-                # draw box only when left mouse button is pressed
-                self.MouseDraw(pdc=self.pdcTmp)
-        # event.Skip()
-    def OnLeftDown(self, event):
-        Left mouse button pressed
-        Debug.msg (5, "BufferedWindow.OnLeftDown(): use=%s" % \
-                   self.mouse["use"])
-        self.mouse['begin'] = event.GetPositionTuple()[:]
-        if self.mouse["use"] in ["measure", "profile"]:
-            # measure or profile
-            if len(self.polycoords) == 0:
-                self.mouse['end'] = self.mouse['begin']
-                self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
-                self.ClearLines(pdc=self.pdcTmp)
-            else:
-                self.mouse['begin'] = self.mouse['end']
-        elif self.mouse['use'] == 'zoom':
-            pass
-        # vector digizer
-        elif self.mouse["use"] == "pointer" and \
-                self.parent.toolbars['vdigit']:
-            digitClass   = self.parent.digit
-            try:
-                mapLayer = digitToolbar.GetLayer().GetName()
-            except:
-                wx.MessageBox(parent=self,
-                              message=_("No vector map selected for editing."),
-                              caption=_("Vector digitizer"),
-                              style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
-                event.Skip()
-                return
-            if digitToolbar.GetAction() not in ("moveVertex",
-                                                "addVertex",
-                                                "removeVertex",
-                                                "editLine"):
-                # set pen
-                self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
-                self.polypen = wx.Pen(colour='dark green', width=2, style=wx.SOLID)
-            if digitToolbar.GetAction() in ("addVertex",
-                                            "removeVertex",
-                                            "splitLines"):
-                # unselect
-                digitClass.driver.SetSelected([])
-            if digitToolbar.GetAction() == "addLine":
-                self.OnLeftDownVDigitAddLine(event)
-            elif digitToolbar.GetAction() == "editLine" and \
-                    hasattr(self, "vdigitMove"):
-                self.OnLeftDownVDigitEditLine(event)
-            elif digitToolbar.GetAction() in ("moveLine",
-                                              "moveVertex",
-                                              "editLine") and \
-                    not hasattr(self, "vdigitMove"):
-                self.OnLeftDownVDigitMoveLine(event)
-            elif digitToolbar.GetAction() in ("displayAttrs"
-                                              "displayCats"):
-                self.OnLeftDownVDigitDisplayCA(event)
-            elif digitToolbar.GetAction() in ("copyCats",
-                                              "copyAttrs"):
-                self.OnLeftDownVDigitCopyCA(event)
-            elif digitToolbar.GetAction() == "copyLine":
-                self.OnLeftDownVDigitCopyLine(event)
-            elif digitToolbar.GetAction() == "zbulkLine":
-                self.OnLeftDownVDigitBulkLine(event)
-        elif self.mouse['use'] == 'pointer':
-            # get decoration or text id
-            self.idlist = []
-            self.dragid = ''
-            self.lastpos = self.mouse['begin']
-            idlist = self.pdc.FindObjects(self.lastpos[0], self.lastpos[1],
-                                          self.hitradius)
-            if 99 in idlist:
-                idlist.remove(99)
-            if idlist != []:
-                self.dragid = idlist[0] #drag whatever is on top
-        else:
-            pass
-        event.Skip()
-    def OnLeftUp(self, event):
-        Left mouse button released
-        Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
-        if self.mouse['use'] in ["zoom", "pan"]:
-            # set region in zoom or pan
-            if self.mouse['use'] == 'zoom':
-                # set region for click (zero-width box)
-                if begin[0] - end[0] == 0 or \
-                        begin[1] - end[1] == 0:
-                    # zoom 1/2 of the screen (TODO: settings)
-                    begin = (end[0] - self.Map.width / 4,
-                             end[1] - self.Map.height / 4)
-                    end   = (end[0] + self.Map.width / 4,
-                             end[1] + self.Map.height / 4)
-            self.Zoom(begin, end, self.zoomtype)
-            # redraw map
-                self.dragid >= 0):
-            # end drag of overlay decoration
-            if self.dragid < 99 and self.overlays.has_key(self.dragid):
-                self.overlays[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
-            elif self.dragid > 100 and self.textdict.has_key(self.dragid):
-                self.textdict[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
-            else:
-                pass
-            self.dragid = None
-    def OnRightDown(self, event):
-        Right mouse button pressed
-        Debug.msg (5, "BufferedWindow.OnRightDown(): use=%s" % \
-        if digitToolbar:
-            # digitization tool (confirm action)
-            if digitToolbar.GetAction() in ("moveLine",
-                                            "moveVertex") and \
-                pFrom = self.vdigitMove['begin']
-                pTo = self.Pixel2Cell(event.GetPositionTuple())
-                move = (pTo[0] - pFrom[0],
-                        pTo[1] - pFrom[1])
-                if digitToolbar.GetAction() == "moveLine":
-                    # move line
-                    if digitClass.MoveSelectedLines(move) < 0:
-                        return
-                elif digitToolbar.GetAction() == "moveVertex":
-                    # move vertex
-                    fid = digitClass.MoveSelectedVertex(pFrom, move)
-                    if fid < 0:
-                        return
-                    self.__geomAttrbUpdate([fid,])
-                del self.vdigitMove
-        event.Skip()
-    def OnRightUp(self, event):
-        Right mouse button released
-        Debug.msg (5, "BufferedWindow.OnRightUp(): use=%s" % \
-        if digitToolbar:
-            if digitToolbar.GetAction() == "addLine" and \
-                    digitToolbar.GetAction('type') in ["line", "boundary"]:
-                # -> add new line / boundary
-                try:
-                    map = digitToolbar.GetLayer().GetName()
-                except:
-                    map = None
-                                  caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-                if map:
-                    # mapcoords = []
-                    # xy -> EN
-                    # for coord in self.polycoords:
-                    #    mapcoords.append(self.Pixel2Cell(coord))
-                    if digitToolbar.GetAction('type') == 'line':
-                        line = True
-                    else:
-                        line = False
-                    if len(self.polycoords) < 2: # ignore 'one-point' lines
-                        return
-                    fid = digitClass.AddLine(map, line, self.polycoords)
-                    if fid < 0:
-                        return
-                    position = self.Cell2Pixel(self.polycoords[-1])
-                    self.UpdateMap(render=False)
-                    self.Refresh()
-                    # add new record into atribute table
-                    if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled') and \
-                            (line is True or \
-                                 (not line and fid > 0)):
-                        posWindow = self.ClientToScreen((position[0] + self.dialogOffset,
-                                                         position[1] + self.dialogOffset))
-                        # select attributes based on layer and category
-                        cats = { fid : {
-                                UserSettings.Get(group='vdigit', key="layer", subkey='value') :
-                                    (UserSettings.Get(group='vdigit', key="category", subkey='value'), )
-                        addRecordDlg = dbm_dialogs.DisplayAttributesDialog(parent=self, map=map,
-        cats=cats,
-        pos=posWindow,
-        action="add")
-                        self.__geomAttrb(fid, addRecordDlg, 'length', digitClass,
-                                         digitToolbar.GetLayer())
-                        # auto-placing centroid
-                        self.__geomAttrb(fid, addRecordDlg, 'area', digitClass,
-                        self.__geomAttrb(fid, addRecordDlg, 'perimeter', digitClass,
-                        if addRecordDlg.mapDBInfo and \
-                               addRecordDlg.ShowModal() == wx.ID_OK:
-                            sqlfile = tempfile.NamedTemporaryFile(mode="w")
-                            for sql in addRecordDlg.GetSQLString():
-                                sqlfile.file.write(sql + ";\n")
-                            sqlfile.file.flush()
-                            gcmd.RunCommand('db.execute',
-                                            parent = True,
-                                            quiet = True,
-                                            input = sqlfile.name)
-                        if addRecordDlg.mapDBInfo:
-                            self.__updateATM()
-            elif digitToolbar.GetAction() == "deleteLine":
-                # -> delete selected vector features
-                if digitClass.DeleteSelectedLines() < 0:
-                    return
-            elif digitToolbar.GetAction() == "splitLine":
-                # split line
-                if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
-                    return
-            elif digitToolbar.GetAction() == "addVertex":
-                # add vertex
-                fid = digitClass.AddVertex(self.Pixel2Cell(self.mouse['begin']))
-                if fid < 0:
-                    return
-            elif digitToolbar.GetAction() == "removeVertex":
-                # remove vertex
-                fid = digitClass.RemoveVertex(self.Pixel2Cell(self.mouse['begin']))
-                if fid < 0:
-                    return
-            elif digitToolbar.GetAction() in ("copyCats", "copyAttrs"):
-                try:
-                    if digitToolbar.GetAction() == 'copyCats':
-                        if digitClass.CopyCats(self.copyCatsList,
-                                               self.copyCatsIds, copyAttrb=False) < 0:
-                            return
-                    else:
-                                               self.copyCatsIds, copyAttrb=True) < 0:
-                            return
-                    del self.copyCatsList
-                    del self.copyCatsIds
-                    pass
-                line = digitClass.driver.GetSelected()
-                if digitClass.EditLine(line, self.polycoords) < 0:
-                    return
-            elif digitToolbar.GetAction() == "flipLine":
-                if digitClass.FlipLine() < 0:
-                    return
-            elif digitToolbar.GetAction() == "mergeLine":
-                if digitClass.MergeLine() < 0:
-                    return
-            elif digitToolbar.GetAction() == "breakLine":
-                if digitClass.BreakLine() < 0:
-                    return
-            elif digitToolbar.GetAction() == "snapLine":
-                if digitClass.SnapLine() < 0:
-                    return
-            elif digitToolbar.GetAction() == "connectLine":
-                if len(digitClass.driver.GetSelected()) > 1:
-                    if digitClass.ConnectLine() < 0:
-                        return
-                if digitClass.CopyLine(self.copyIds) < 0:
-                    return
-                del self.copyIds
-                if self.layerTmp:
-                    self.Map.DeleteLayer(self.layerTmp)
-                    self.UpdateMap(render=True, renderVector=False)
-                del self.layerTmp
-            elif digitToolbar.GetAction() == "zbulkLine" and len(self.polycoords) == 2:
-                pos1 = self.polycoords[0]
-                pos2 = self.polycoords[1]
-                selected = digitClass.driver.GetSelected()
-                dlg = VDigitZBulkDialog(parent=self, title=_("Z bulk-labeling dialog"),
-                                        nselected=len(selected))
-                if dlg.ShowModal() == wx.ID_OK:
-                    if digitClass.ZBulkLines(pos1, pos2, dlg.value.GetValue(),
-                                             dlg.step.GetValue()) < 0:
-                        return
-                self.UpdateMap(render=False, renderVector=True)
-            elif digitToolbar.GetAction() == "typeConv":
-                # -> feature type conversion
-                # - point <-> centroid
-                # - line <-> boundary
-                if digitClass.TypeConvForSelectedLines() < 0:
-                    return
-            if digitToolbar.GetAction() != "addLine":
-                # unselect and re-render
-            self.Refresh()
-        event.Skip()
-    def OnMiddleDown(self, event):
-        Middle mouse button pressed
-        if self.mouse["use"] == "pointer" and digitToolbar:
-            if (digitToolbar.GetAction() == "addLine" and \
-                    digitToolbar.GetAction('type') in ["line", "boundary"]) or \
-                    digitToolbar.GetAction() == "editLine":
-                # add line or boundary -> remove last point from the line
-                try:
-                    removed = self.polycoords.pop()
-                    Debug.msg(4, "BufferedWindow.OnMiddleDown(): polycoords_poped=%s" % \
-                                  [removed,])
-                    self.mouse['begin'] = self.Cell2Pixel(self.polycoords[-1])
-                except:
-                    pass
-                if digitToolbar.GetAction() == "editLine":
-                    # remove last vertex & line
-                    if len(self.vdigitMove['id']) > 1:
-                        self.vdigitMove['id'].pop()
-                self.UpdateMap(render=False, renderVector=False)
-            elif digitToolbar.GetAction() in ["deleteLine", "moveLine", "splitLine",
-                                              "addVertex", "removeVertex", "moveVertex",
-                                              "copyCats", "flipLine", "mergeLine",
-                                              "snapLine", "connectLine", "copyLine",
-                                              "queryLine", "breakLine", "typeConv"]:
-                # varios tools -> unselected selected features
-                if digitToolbar.GetAction() in ["moveLine", "moveVertex", "editLine"] and \
-                elif digitToolbar.GetAction() == "copyCats":
-                    try:
-                        pass
-                    del self.copyIds
-                    if self.layerTmp:
-                    del self.layerTmp
-                self.UpdateMap(render=False) # render vector
-                # reset polyline
-    def OnMiddleUp(self, event):
-        Middle mouse button released
-        self.Zoom(begin, end, 0) # no zoom
-        # redraw map
-        self.parent.StatusbarUpdate()
-    def ClearLines(self, pdc=None):
-        Clears temporary drawn lines from PseudoDC
-        if not pdc:
-            pdc=self.pdcTmp
-        try:
-            pdc.RemoveId(self.lineid)
-        except:
-            pass
-        try:
-            pdc.ClearId(self.plineid)
-            pdc.RemoveId(self.plineid)
-        except:
-            pass
-        Debug.msg(4, "BufferedWindow.ClearLines(): lineid=%s, plineid=%s" %
-                  (self.lineid, self.plineid))
-        return True
-    def Pixel2Cell(self, (x, y)):
-        Convert image coordinates to real word coordinates
-        Input : int x, int y
-        Output: float x, float y
-        try:
-            x = int(x)
-            y = int(y)
-        except:
-            return None
-        if self.Map.region["ewres"] > self.Map.region["nsres"]:
-            res = self.Map.region["ewres"]
-        else:
-            res = self.Map.region["nsres"]
-        w = self.Map.region["center_easting"] - (self.Map.width / 2) * res
-        n = self.Map.region["center_northing"] + (self.Map.height / 2) * res
-        east  = w + x * res
-        north = n - y * res
-        # extent does not correspond with whole map canvas area...
-        # east  = self.Map.region['w'] + x * self.Map.region["ewres"]
-        # north = self.Map.region['n'] - y * self.Map.region["nsres"]
-        return (east, north)
-    def Cell2Pixel(self, (east, north)):
-        Convert real word coordinates to image coordinates
-        try:
-            east  = float(east)
-            north = float(north)
-        except:
-            return None
-        else:
-        # x = int((east  - w) / res)
-        # y = int((n - north) / res)
-        x = (east  - w) / res
-        y = (n - north) / res
-        return (x, y)
-    def Zoom(self, begin, end, zoomtype):
-        Calculates new region while (un)zoom/pan-ing
-        x1, y1 = begin
-        x2, y2 = end
-        newreg = {}
-        # threshold - too small squares do not make sense
-        # can only zoom to windows of > 5x5 screen pixels
-        if abs(x2-x1) > 5 and abs(y2-y1) > 5 and zoomtype != 0:
-            if x1 > x2:
-                x1, x2 = x2, x1
-            if y1 > y2:
-                y1, y2 = y2, y1
-            # zoom in
-            if zoomtype > 0:
-                newreg['w'], newreg['n'] = self.Pixel2Cell((x1, y1))
-                newreg['e'], newreg['s'] = self.Pixel2Cell((x2, y2))
-            # zoom out
-            elif zoomtype < 0:
-                newreg['w'], newreg['n'] = self.Pixel2Cell((-x1 * 2, -y1 * 2))
-                newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width  + 2 * \
-        (self.Map.width  - x2),
-                                                            self.Map.height + 2 * \
-        (self.Map.height - y2)))
-        # pan
-        elif zoomtype == 0:
-            dx = x1 - x2
-            dy = y1 - y2
-            newreg['w'], newreg['n'] = self.Pixel2Cell((dx, dy))
-            newreg['e'], newreg['s'] = self.Pixel2Cell((self.Map.width  + dx,
-                                                        self.Map.height + dy))
-        # if new region has been calculated, set the values
-        if newreg != {}:
-            # LL locations
-            if self.parent.Map.projinfo['proj'] == 'll':
-                if newreg['n'] > 90.0:
-                    newreg['n'] = 90.0
-                if newreg['s'] < -90.0:
-                    newreg['s'] = -90.0
-            ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
-            cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
-            if hasattr(self, "vdigitMove"):
-                # xo = self.Cell2Pixel((self.Map.region['center_easting'], self.Map.region['center_northing']))
-                # xn = self.Cell2Pixel(ce, cn))
-                tmp = self.Pixel2Cell(self.mouse['end'])
-            # calculate new center point and display resolution
-            self.Map.region['center_easting'] = ce
-            self.Map.region['center_northing'] = cn
-            self.Map.region["ewres"] = (newreg['e'] - newreg['w']) / self.Map.width
-            self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
-            self.Map.AlignExtentFromDisplay()
-                tmp1 = self.mouse['end']
-                tmp2 = self.Cell2Pixel(self.vdigitMove['begin'])
-                dx = tmp1[0] - tmp2[0]
-                dy = tmp1[1] - tmp2[1]
-                self.vdigitMove['beginDiff'] = (dx, dy)
-                for id in self.vdigitMove['id']:
-                    self.pdcTmp.RemoveId(id)
-            self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
-                             self.Map.region['e'], self.Map.region['w'])
-        if self.redrawAll is False:
-    def ZoomBack(self):
-        """!Zoom to previous extents in zoomhistory list
-        zoom = list()
-        if len(self.zoomhistory) > 1:
-            self.zoomhistory.pop()
-            zoom = self.zoomhistory[-1]
-        # disable tool if stack is empty
-        if len(self.zoomhistory) < 2: # disable tool
-            if self.parent.GetName() == 'MapWindow':
-                toolbar = self.parent.toolbars['map']
-            elif self.parent.GetName() == 'GRMapWindow':
-                toolbar = self.parent.toolbars['georect']
-            toolbar.Enable('zoomback', enable = False)
-        # zoom to selected region
-        self.Map.GetRegion(n = zoom[0], s = zoom[1],
-                           e = zoom[2], w = zoom[3],
-                           update = True)
-        # update map
-        self.UpdateMap()
-    def ZoomHistory(self, n, s, e, w):
-        Manages a list of last 10 zoom extents
-        @param n,s,e,w north, south, east, west
-        @return removed history item if exists (or None)
-        removed = None
-        self.zoomhistory.append((n,s,e,w))
-        if len(self.zoomhistory) > 10:
-            removed = self.zoomhistory.pop(0)
-        if removed:
-            Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s, removed=%s" %
-                      (self.zoomhistory, removed))
-        else:
-            Debug.msg(4, "BufferedWindow.ZoomHistory(): hist=%s" %
-                      (self.zoomhistory))
-        # update toolbar
-            enable = True
-        else:
-            enable = False
-        toolbar.Enable('zoomback', enable)
-        return removed
-    def ResetZoomHistory(self):
-        """!Reset zoom history"""
-        self.zoomhistory = list()
-    def ZoomToMap(self, layers = None, ignoreNulls = False, render = True):
-        Set display extents to match selected raster
-        or vector map(s).
-        @param layer list of layers to be zoom to
-        @param ignoreNulls True to ignore null-values
-        @param render True to re-render display
-        zoomreg = {}
-        if not layers:
-            layers = self.GetSelectedLayer(multi = True)
-        if not layers:
-            return
-        rast = []
-        vect = []
-        updated = False
-        for l in layers:
-            # only raster/vector layers are currently supported
-            if l.type == 'raster':
-                rast.append(l.name)
-            elif l.type == 'vector':
-                if digitToolbar and digitToolbar.GetLayer() == l:
-                    w, s, b, e, n, t = self.parent.digit.driver.GetMapBoundingBox()
-                    self.Map.GetRegion(n=n, s=s, w=w, e=e,
-                                       update=True)
-                    updated = True
-                else:
-                    vect.append(l.name)
-        if not updated:
-            self.Map.GetRegion(rast = rast,
-                               vect = vect,
-                               update = True)
-        if render:
-            self.UpdateMap()
Modified: grass-addons/gui/wxpython/wx.path/wx.path.py
--- grass-addons/gui/wxpython/wx.path/wx.path.py	2010-06-19 14:25:42 UTC (rev 42590)
+++ grass-addons/gui/wxpython/wx.path/wx.path.py	2010-06-19 16:52:53 UTC (rev 42591)
@@ -3,11 +3,11 @@
 @brief Interface implementation of v.net.path.
 Inspired by http://grass.itc.it/gdp/html_grass64/v.net.path.html
-Hacked from mapdip and mapdisp_window from gui_modules
+Hacked from mapdisp and mapdisp_window from gui_modules
 Classes:
-- MapFrame
-- MapApp
+- NetworkPath
+- NetApp
 (C) 2006-2010 by the GRASS Development Team
@@ -53,18 +53,22 @@
 sys.path.append(grassPath)
 import render
-import toolbars
+from toolbars import MapToolbar
 from icon  import Icons
 from mapdisp_command import Command
-from mapdisplay_window import BufferedWindow
+from mapdisp_window import BufferedWindow
+from mapdisp import MapFrame
 import images
+import gcmd
+from grass.script import core as grass
 imagepath = images.__path__[0]
 sys.path.append(imagepath)
-class NetworkPath(wx.Frame):
+class NetworkPath(MapFrame):
     def __init__(self, parent=None, id=wx.ID_ANY, title=_("v.net.path [vector, networking]"),
                  style=wx.DEFAULT_FRAME_STYLE, toolbars=["map"],Map=None,size=wx.DefaultSize):
@@ -87,21 +91,27 @@
         wx.Frame.__init__(self, parent, id, title, style = style)
+        # set the size & system icon
+        self.SetClientSize(self.GetSize())
+        self.iconsize = (16, 16)
+        self.SetName("MapWindow")
-        self.SetName('MapWindow')
+        self.counter = 0
+        self.points =[]
-        self.Maximize()
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
-        wx.MessageBox('Development has only started. currently works with spearfish data (myroads vector file given in folder). Kindly bear with me, Thankyou', 'Info')
         # Fancy gui
         # self._mgr = auimgr
         self._mgr = wx.aui.AuiManager(self)
+        self._layerManager = None
+        self.georectifying =None
         # Add toolbars
@@ -112,20 +122,108 @@
         for toolb in toolbars:
             self.AddToolbar(toolb)
         # Add statusbar
-        self.statusbar = self.CreateStatusBar(number=1, style=0)
+        self.statusbar = self.CreateStatusBar(number=4, style=0)
         self.statusbar.SetStatusWidths([-5, -2, -1, -1])
+        self.statusbarWin = dict()
+        self.statusbarWin['toggle'] = wx.Choice(self.statusbar, wx.ID_ANY,
+                                                choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+        self.statusbarWin['toggle'].SetSelection(UserSettings.Get(group='display',
+        key='statusbarMode',
+        subkey='selection'))
+        self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
+        # auto-rendering checkbox
+        self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                  label=_("Render"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
+        self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
+                                                              key='autoRendering',
+                                                              subkey='enabled'))
+        self.statusbarWin['render'].SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
+        # show region
+        self.statusbarWin['region'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                  label=_("Show computational extent"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.statusbarWin['region'])
+        self.statusbarWin['region'].SetValue(False)
+        self.statusbarWin['region'].Hide()
+        self.statusbarWin['region'].SetToolTip(wx.ToolTip (_("Show/hide computational "
+                                                             "region extent (set with g.region). "
+                                                             "Display region drawn as a blue box inside the "
+                                                             "computational region, "
+                                                             "computational region inside a display region "
+                                                             "as a red box).")))
+        # set resolution
+        self.statusbarWin['resolution'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                      label=_("Constrain display resolution to computational settings"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.statusbarWin['resolution'])
+        self.statusbarWin['resolution'].SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+        self.statusbarWin['resolution'].Hide()
+        self.statusbarWin['resolution'].SetToolTip(wx.ToolTip (_("Constrain display resolution "
+        "to computational region settings. "
+        "Default value for new map displays can "
+        "be set up in 'User GUI settings' dialog.")))
+        # map scale
+        self.statusbarWin['mapscale'] = wx.ComboBox(parent = self.statusbar, id = wx.ID_ANY,
+                                                    style = wx.TE_PROCESS_ENTER,
+                                                    size=(150, -1))
+        self.statusbarWin['mapscale'].SetItems(['1:1000',
+                                                '1:5000',
+                                                '1:10000',
+                                                '1:25000',
+                                                '1:50000',
+                                                '1:100000',
+                                                '1:1000000'])
+        self.statusbarWin['mapscale'].Hide()
+        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+        self.statusbar.Bind(wx.EVT_COMBOBOX, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+        # go to
+        self.statusbarWin['goto'] = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
+                                                value="", style=wx.TE_PROCESS_ENTER,
+                                                size=(300, -1))
+        self.statusbarWin['goto'].Hide()
+        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
+        # projection
+        self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                      label=_("Use defined projection"))
+        self.statusbarWin['projection'].SetValue(False)
+        size = self.statusbarWin['projection'].GetSize()
+        self.statusbarWin['projection'].SetMinSize((size[0] + 150, size[1]))
+        self.statusbarWin['projection'].SetToolTip(wx.ToolTip (_("Reproject coordinates displayed "
+        "in the statusbar. Projection can be "
+        "defined in GUI preferences dialog "
+        "(tab 'Display')")))
+        self.statusbarWin['projection'].Hide()
+        # mask
+        self.statusbarWin['mask'] = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
+                                                  label = '')
+        self.statusbarWin['mask'].SetForegroundColour(wx.Colour(255, 0, 0))
+        # on-render gauge
+        self.statusbarWin['progress'] = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
+                                      range=0, style=wx.GA_HORIZONTAL)
+        self.statusbarWin['progress'].Hide()
+        self.StatusbarReposition() # reposition statusbar
         # Init map display (buffered DC & set default cursor)
-        self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY, Map=self.Map)
+        self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,Map=self.Map)
         # default is 2D display mode
         self.MapWindow = self.MapWindow2D
         self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+        self.MapWindow.SetCursor(self.cursors["default"])
+        self.MapWindow.Bind(wx.EVT_LEFT_DCLICK,self.OnButtonDClick)
         # used by Nviz (3D display mode)
+        self.MapWindow3D = None
         # initialize region values
@@ -135,8 +233,9 @@
         # Bind various events
-        #self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
+        #self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
+        self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
+       # self.Bind(render.EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
         # Update fancy gui style
@@ -148,6 +247,13 @@
         self._mgr.Update()
+        # Initialization of digitization tool
+        self.digit = None
         # Init zoom history
         self.MapWindow.ZoomHistory(self.Map.region['n'],
@@ -155,256 +261,79 @@
+        # Re-use dialogs
+        self.dialogs = {}
+        self.dialogs['attributes'] = None
+        self.dialogs['category'] = None
+        self.dialogs['barscale'] = None
+        self.dialogs['legend'] = None
+        self.decorationDialog = None # decoration/overlays
-    def AddToolbar(self, name):
-        self.toolbars['map'] = MapToolbar(self, self.Map)
-        self._mgr.AddPane(self.toolbars['map'],
-                              wx.aui.AuiPaneInfo().
-                              Name("maptoolbar").Caption(_("Map Toolbar")).
-                              ToolbarPane().Top().
-                              LeftDockable(False).RightDockable(False).
-                              BottomDockable(False).TopDockable(True).
-                              CloseButton(False).Layer(2).
-                              BestSize((self.toolbars['map'].GetSize())))
+        self.Maximize()
-        self._mgr.Update()
+    def OnButtonDClick(self,event):
-    def __InitDisplay(self):
-        Initialize map display, set dimensions and map region
-        self.width, self.height = self.GetClientSize()
-        Debug.msg(2, "MapFrame.__InitDisplay():")
-        self.Map.region = self.Map.GetRegion() # g.region -upgc
-        # self.Map.SetRegion() # adjust region to match display window
-    def OnMotion(self, event):
-        Mouse moved
-        Track mouse motion and update status bar
-        # update statusbar if required
         try:
-                e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
+            e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
-                return
-        self.statusbar.SetStatusText("%.*f; %.*f" %  (precision, e, precision, n), 0)
-        p = self.statusbar.GetStatusText()
-        self.statusbar.SetStatusText(p + "    Double Click to select Points")
-        event.Skip()
-    def OnDraw(self, event):
-        Re-display current map composition
-        self.MapWindow.UpdateMap(render=False)
+            return
+        self.counter = self.counter + 1
+        point =("%.*f|%.*f" %  (precision, e, precision, n))
+        self.points.append(point + '|point')
+        if self.counter == 2:
+            f =open("tmp1",'w')
+            for p in self.points:
+                f.write("%s\n" % p)
+            f.close()
+            f =open("tmp2",'w')
+            f.write("%d %d %d\n" %(1,1,2) )
+            f.close()
+            #print self.points
-    def OnPointer(self, event):
-        Pointer button clicked
-        self.MapWindow.SetCursor(self.cursors["default"])
+            command =["g.remove",'vect=vnet_out,startend,tmp_vnet_path']
+            gcmd.CommandThread(command,stdout=None,stderr=None).run()
-    def OnZoomIn(self, event):
-        Zoom in the map.
-        Set mouse cursor, zoombox attributes, and zoom direction
-        if self.toolbars['map']:
-            self.toolbars['map'].OnTool(event)
-            self.toolbars['map'].action['desc'] = ''
-        self.MapWindow.mouse['use'] = "zoom"
-        self.MapWindow.mouse['box'] = "box"
-        self.MapWindow.zoomtype = 1
-        self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
-        # change the cursor
-        self.MapWindow.SetCursor(self.cursors["cross"])
+            command =["v.in.ascii",'input=tmp1','output=startend']
-    def OnZoomOut(self, event):
-        Zoom out the map.
-        self.MapWindow.zoomtype = -1
+            command=["v.net", "input=myroads",'points=startend', 'out=vnet_out', 'op=connect', 'thresh=200']
-    def OnZoomBack(self, event):
-        Zoom last (previously stored position)
-        self.MapWindow.ZoomBack()
+            command=["v.net.path", 'vnet_out','afcol=forward', 'abcol=backward', 'out=tmp_vnet_path','file=tmp2']
-    def OnPan(self, event):
-        Panning, set mouse to drag
-        self.MapWindow.mouse['use'] = "pan"
-        self.MapWindow.mouse['box'] = "pan"
-        self.MapWindow.zoomtype = 0
-        self.MapWindow.SetCursor(self.cursors["hand"])
+            self.mapname = 'tmp_vnet_path@' + grass.gisenv()['MAPSET']
+            self.cmd= ['d.vect', str("map=" + self.mapname),'col=red','width=2']
+            self.Map.AddLayer(type='vector', name=self.mapname, command=self.cmd)
+            self.MapWindow.UpdateMap(render=True)
+            self.counter =0
+            self.points=[]
-    def OnErase(self, event):
-        Erase the canvas
-        self.MapWindow.EraseMap()
-    def OnZoomRegion(self, event):
+    def __InitDisplay(self):
-        Zoom to region
+        Initialize map display, set dimensions and map region
-        self.Map.getRegion()
-        self.Map.getResolution()
-        self.UpdateMap()
-        # event.Skip()
+        self.width, self.height = self.GetClientSize()
-    def GetRender(self):
-        """!Returns current instance of render.Map()
-        return self.Map
-    def GetWindow(self):
-        """!Get map window"""
-        return self.MapWindow
+        Debug.msg(2, "MapFrame.__InitDisplay():")
+        self.Map.ChangeMapSize(self.GetClientSize())
+        self.Map.region = self.Map.GetRegion() # g.region -upgc
+        # self.Map.SetRegion() # adjust region to match display window
+    def GetLayerManager(self):
+        return self
-    def GetOptData(self, dcmd, type, params, propwin):
-        Callback method for decoration overlay command generated by
-        dialog created in menuform.py
-        # Reset comand and rendering options in render.Map. Always render decoration.
-        # Showing/hiding handled by PseudoDC
-        self.Map.ChangeOverlay(ovltype=type, type='overlay', name='', command=dcmd,
-                               l_active=True, l_render=False)
-        self.params[type] = params
-        self.propwin[type] = propwin
-    def OnZoomToMap(self, event):
-        Set display extents to match selected raster (including NULLs)
-        or vector map.
-        self.MapWindow.ZoomToMap()
-    def OnZoomToRaster(self, event):
-        Set display extents to match selected raster map (ignore NULLs)
-        self.MapWindow.ZoomToMap(ignoreNulls = True)
-# end of class MapFrame
-class MapToolbar(toolbars.AbstractToolbar):
-    """!Map Display toolbar
-    def __init__(self, parent, mapcontent):
-        """!Map Display constructor
-        @param parent reference to MapFrame
-        @param mapcontent reference to render.Map (registred by MapFrame)
-        self.mapcontent = mapcontent # render.Map
-        toolbars.AbstractToolbar.__init__(self, parent = parent) # MapFrame
-        self.InitToolbar(self.ToolbarData())
-        # optional tools
-        self.action = { 'id' : self.pointer }
-        self.defaultAction = { 'id' : self.pointer,
-                               'bind' : self.parent.OnPointer }
-        self.OnTool(None)
-        self.EnableTool(self.zoomback, False)
-        self.FixSize(width = 90)
-    def ToolbarData(self):
-        """!Toolbar data"""
-        self.pointer = wx.NewId()
-        self.pan = wx.NewId()
-        self.zoomin = wx.NewId()
-        self.zoomout = wx.NewId()
-        self.zoomback = wx.NewId()
-        self.zoommenu = wx.NewId()
-        self.zoomextent = wx.NewId()
-        # tool, label, bitmap, kind, shortHelp, longHelp, handler
-        return (
-            (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
-             self.parent.OnPointer),
-            (self.pan, "pan", Icons["pan"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
-             self.parent.OnPan),
-            (self.zoomin, "zoom_in", Icons["zoom_in"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["zoom_in"].GetLabel(), Icons["zoom_in"].GetDesc(),
-             self.parent.OnZoomIn),
-            (self.zoomout, "zoom_out", Icons["zoom_out"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["zoom_out"].GetLabel(), Icons["zoom_out"].GetDesc(),
-             self.parent.OnZoomOut),
-            (self.zoomextent, "zoom_extent", Icons["zoom_extent"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["zoom_extent"].GetLabel(), Icons["zoom_extent"].GetDesc(),
-             self.parent.OnZoomToMap),
-            (self.zoomback, "zoom_back", Icons["zoom_back"].GetBitmap(),
-             wx.ITEM_NORMAL, Icons["zoom_back"].GetLabel(), Icons["zoom_back"].GetDesc(),
-             self.parent.OnZoomBack)
 class PathApp(wx.App):
     MapApp class
