[GRASS-SVN] r42607 - in grass/trunk: include lib/nviz visualization/nviz2/cmd
Sun Jun 20 15:02:52 EDT 2010
Author: martinl
Date: 2010-06-20 19:02:52 +0000 (Sun, 20 Jun 2010)
New Revision: 42607
   grass/trunk/include/nviz.h
   grass/trunk/lib/nviz/change_view.c
   grass/trunk/lib/nviz/draw.c
   grass/trunk/lib/nviz/exag.c
   grass/trunk/lib/nviz/lights.c
   grass/trunk/lib/nviz/map_obj.c
   grass/trunk/lib/nviz/position.c
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/local_proto.h
   grass/trunk/visualization/nviz2/cmd/main.c
minor clean up of nvizlib
lights settings implemented in nviz_cmd
Modified: grass/trunk/include/nviz.h
--- grass/trunk/include/nviz.h	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/include/nviz.h	2010-06-20 19:02:52 UTC (rev 42607)
@@ -141,11 +141,11 @@
 /* change_view.c */
 int Nviz_resize_window(int, int);
 int Nviz_update_ranges(nv_data *);
-int Nviz_set_viewpoint_position(nv_data *, float, float);
-int Nviz_set_viewpoint_height(nv_data *, float);
-int Nviz_set_viewpoint_persp(nv_data *, int);
-int Nviz_set_viewpoint_twist(nv_data *, int);
-int Nviz_change_exag(nv_data *, float);
+int Nviz_set_viewpoint_position(double, double);
+int Nviz_set_viewpoint_height(double);
+int Nviz_set_viewpoint_persp(int);
+int Nviz_set_viewpoint_twist(int);
+int Nviz_change_exag(nv_data *, double);
 /* cplanes_obj.c */
 int Nviz_new_cplane(nv_data *, int);
@@ -154,27 +154,27 @@
 /* draw.c */
 int Nviz_draw_all_surf(nv_data *);
-int Nviz_draw_all_vect(nv_data *);
-int Nviz_draw_all_site(nv_data *);
-int Nviz_draw_all_vol(nv_data *);
+int Nviz_draw_all_vect();
+int Nviz_draw_all_site();
+int Nviz_draw_all_vol();
 int Nviz_draw_all(nv_data *);
 int Nviz_draw_quick(nv_data *, int);
 /* exag.c */
-int Nviz_get_exag_height(float *, float *, float *);
-float Nviz_get_exag();
+int Nviz_get_exag_height(double *, double *, double *);
+double Nviz_get_exag();
 /* lights.c */
-int Nviz_set_light_position(nv_data *, int, float, float, float, float);
-int Nviz_set_light_bright(nv_data *, int, float);
-int Nviz_set_light_color(nv_data *, int, float, float, float);
-int Nviz_set_light_ambient(nv_data *, int, float, float, float);
+int Nviz_set_light_position(nv_data *, int, double, double, double, double);
+int Nviz_set_light_bright(nv_data *, int, double);
+int Nviz_set_light_color(nv_data *, int, int, int, int);
+int Nviz_set_light_ambient(nv_data *, int, double, double, double);
 int Nviz_init_light(nv_data *, int);
 int Nviz_new_light(nv_data *);
 /* map_obj.c */
-int Nviz_new_map_obj(int, const char *, float, nv_data *);
-int Nviz_set_attr(int, int, int, int, const char *, float, nv_data *);
+int Nviz_new_map_obj(int, const char *, double, nv_data *);
+int Nviz_set_attr(int, int, int, int, const char *, double, nv_data *);
 void Nviz_set_surface_attr_default();
 int Nviz_set_vpoint_attr_default();
 int Nviz_set_volume_attr_default();
@@ -186,7 +186,7 @@
 int Nviz_color_from_str(const char *);
 /* position.c */
-void Nviz_init_view();
+void Nviz_init_view(nv_data *);
 int Nviz_set_focus_state(int);
 int Nviz_set_focus_map(int, int);
Modified: grass/trunk/lib/nviz/change_view.c
--- grass/trunk/lib/nviz/change_view.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/lib/nviz/change_view.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -90,7 +90,7 @@
    \return 1
-int Nviz_set_viewpoint_position(nv_data * data, float x_pos, float y_pos)
+int Nviz_set_viewpoint_position(double x_pos, double y_pos)
     float xpos, ypos, from[3];
     float tempx, tempy;
@@ -132,7 +132,7 @@
    \return 1
-int Nviz_set_viewpoint_height(nv_data * data, float height)
+int Nviz_set_viewpoint_height(double height)
     float from[3];
@@ -162,7 +162,7 @@
    \return 1
-int Nviz_set_viewpoint_persp(nv_data * data, int persp)
+int Nviz_set_viewpoint_persp(int persp)
     int fov;
@@ -182,7 +182,7 @@
    \return 1
-int Nviz_set_viewpoint_twist(nv_data * data, int twist)
+int Nviz_set_viewpoint_twist(int twist)
     GS_set_twist(10 * twist);
@@ -199,9 +199,9 @@
    \return 1
-int Nviz_change_exag(nv_data * data, float exag)
+int Nviz_change_exag(nv_data * data, double exag)
-    float temp;
+    double temp;
     temp = GS_global_exag();
Modified: grass/trunk/lib/nviz/draw.c
--- grass/trunk/lib/nviz/draw.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/lib/nviz/draw.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -111,11 +111,9 @@
    \brief Draw all loaded vector sets (lines)
-   \param dc nviz data
    \return 1
-int Nviz_draw_all_vect(nv_data * dc)
     // GS_set_cancel(0);
@@ -138,11 +136,9 @@
    \brief Draw all loaded vector point sets
    \return 1
-int Nviz_draw_all_site(nv_data * dc)
     int i;
     int *site_list, nsites;
@@ -168,12 +164,10 @@
    \brief Draw all loaded volume sets
    \return 1
-int Nviz_draw_all_vol(nv_data * dc)
     int *vol_list, nvols, i;
@@ -205,8 +199,6 @@
 int Nviz_draw_all(nv_data * data)
     int draw_surf, draw_vect, draw_site, draw_vol;
-    int draw_north_arrow, arrow_x, draw_label, draw_legend;
-    int draw_fringe, draw_scalebar, draw_bar_x;
     draw_surf = 1;
     draw_vect = 1;
Modified: grass/trunk/lib/nviz/exag.c
--- grass/trunk/lib/nviz/exag.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/lib/nviz/exag.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -25,7 +25,7 @@
    \return 1
-int Nviz_get_exag_height(float *val, float *min, float *max)
+int Nviz_get_exag_height(double *val, double *min, double *max)
     float longdim, exag, texag, hmin, hmax, fmin, fmax;
     int nsurfs, i, *surf_list;
@@ -70,7 +70,7 @@
    \return value
     float exag, texag;
Modified: grass/trunk/lib/nviz/lights.c
--- grass/trunk/lib/nviz/lights.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/lib/nviz/lights.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -25,17 +25,17 @@
    \return 1
 int Nviz_set_light_position(nv_data * data, int num,
-			    float x, float y, float z, float w)
+			    double x, double y, double z, double w)
-    float xpos, ypos;
+    double xpos, ypos;
     xpos = x;
     xpos = (xpos < 0) ? 0 : (xpos > 1.0) ? 1.0 : xpos;
     ypos = 1.0 - y;
     ypos = (ypos < 0) ? 0 : (ypos > 1.0) ? 1.0 : ypos;
     if (x < 0.0 || x > 1.0 || y < 0.0 || y > 1.0) {
-	G_debug(3, "Invalid view position coordinates, using %f,%f",
-		  xpos, 1.0 - ypos);
+	G_debug(0, "Invalid light position coordinates (%f,%f), using %f,%f",
+		x, y, xpos, 1.0 - ypos);
     num--;
@@ -45,7 +45,7 @@
     data->light[num].z = z;
     data->light[num].w = w;
-    G_debug(3, "Nviz_set_light_position(): num = %d x = %f y = %f z = %f w = %f",
+    G_debug(0, "Nviz_set_light_position(): num = %d x = %f y = %f z = %f w = %f",
 	    num + 1, x, y, z, w);
     GS_setlight_position(num + 1, x, y, z, w);
@@ -59,9 +59,9 @@
    \param num light num (starts at 1)
    \param value brightness value
-int Nviz_set_light_bright(nv_data * data, int num, float value)
+int Nviz_set_light_bright(nv_data * data, int num, double value)
-    float r, g, b;
+    double r, g, b;
     num--;
     data->light[num].brt = value;
@@ -70,8 +70,8 @@
     g = data->light[num].g * data->light[num].brt;
     b = data->light[num].b * data->light[num].brt;
-    G_debug(3, "Nviz_set_light_bright(): num = %d r = %f g = %f b = %f",
-	    num + 1, r, g, b);
+    G_debug(0, "Nviz_set_light_bright(): num = %d value = %f r = %f g = %f b = %f",
+	    num + 1, value, r, g, b);
     GS_setlight_color(num + 1, r, g, b);
     return 1;
@@ -82,23 +82,23 @@
    \param data nviz data
-   \param red,green,blue rGB values (0-1)
+   \param red,green,blue RGB values (0-255)
 int Nviz_set_light_color(nv_data * data, int num,
-			 float red, float green, float blue)
+			 int red, int green, int blue)
-    float r, g, b;
+    double r, g, b;
     num--;
-    data->light[num].r = red;
-    data->light[num].g = green;
-    data->light[num].b = blue;
+    data->light[num].r = red / 255.;
+    data->light[num].g = green / 255.;
+    data->light[num].b = blue / 255.;
     r = data->light[num].r * data->light[num].brt;
-    G_debug(3, "Nviz_set_light_color(): num = %d r = %f g = %f b = %f",
+    G_debug(0, "Nviz_set_light_color(): num = %d r = %f g = %f b = %f",
 	    num + 1, r, g, b);
@@ -113,14 +113,14 @@
 int Nviz_set_light_ambient(nv_data * data, int num,
+			   double red, double green, double blue)
     num--;
     data->light[num].ar = red;
     data->light[num].ag = green;
     data->light[num].ab = blue;
-    G_debug(3, "Nviz_set_light_ambient(): num = %d r = %f g = %f b = %f",
+    G_debug(0, "Nviz_set_light_ambient(): num = %d r = %f g = %f b = %f",
 	    num + 1, red, green, blue);
     GS_setlight_ambient(num + 1, red, green, blue);
@@ -179,3 +179,4 @@
     return 1;
Modified: grass/trunk/lib/nviz/map_obj.c
--- grass/trunk/lib/nviz/map_obj.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/lib/nviz/map_obj.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -41,7 +41,7 @@
    \return map object id
    \return -1 on error
-int Nviz_new_map_obj(int type, const char *name, float value, nv_data * data)
+int Nviz_new_map_obj(int type, const char *name, double value, nv_data * data)
     int new_id, i;
     int num_surfs, *surf_list;
@@ -203,16 +203,16 @@
    \param desc attribute descriptor
    \param src attribute source
    \param str_value attribute value as string (if NULL, check for <i>num_value</i>)
-   \param num_value attribute value as float
+   \param num_value attribute value as double
    \return 1 on success
    \return 0 on failure
 int Nviz_set_attr(int id, int type, int desc, int src,
-		  const char *str_value, float num_value, nv_data * data)
+		  const char *str_value, double num_value, nv_data * data)
     int ret;
-    float value;
+    double value;
     switch (type) {
     case (MAP_OBJ_SURF):{
@@ -225,7 +225,7 @@
 		 * Note that we require the constant to be an integer
 		if (str_value)
-		    value = (float)atof(str_value);
+		    value = (double)atof(str_value);
 		else
 		    value = num_value;
@@ -328,7 +328,6 @@
 int Nviz_set_vpoint_attr_default(int id)
-    int i;
     geosite *gp;
     gp = gp_get_site(id);
Modified: grass/trunk/lib/nviz/position.c
--- grass/trunk/lib/nviz/position.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/lib/nviz/position.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -16,15 +16,25 @@
 #include <grass/nviz.h>
-   Initialize view and position settings (focus)
+   Initialize view, position, lighting settings (focus)
    Set position to center of view
+void Nviz_init_view(nv_data *data)
     GS_init_view();
     Nviz_set_focus_state(1);	/* center of view */
+    /* set default lights (1 & 2) */
+    Nviz_set_light_position(data, 1, 0.68, 0.68, 0.80, 0.0);
+    Nviz_set_light_bright(data,   1, 0.8);
+    Nviz_set_light_color(data,    1, 1.0, 1.0, 1.0);
+    Nviz_set_light_ambient(data,  1, 0.2, 0.2, 0.2);
+    Nviz_set_light_position(data, 2, 0.0, 0.0, 1.0, 0.0);
+    Nviz_set_light_bright(data,   2, 0.5);
+    Nviz_set_light_color(data,    2, 1.0, 1.0, 1.0);
+    Nviz_set_light_ambient(data,  2, 0.3, 0.3, 0.3);
     return;
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -29,6 +29,7 @@
 static void args_vpoint(struct GParams *);
 static void args_viewpoint(struct GParams *);
 static void args_volume(struct GParams *);
+static void args_lighting(struct GParams *);
   \brief Parse command
@@ -66,11 +67,14 @@
     /*** viewpoint ***/
     args_viewpoint(params);
+    /*** lighting ***/
+    args_lighting(params);
     /*** output image ***/
     /* output */
     params->output = G_define_standard_option(G_OPT_F_OUTPUT);
     params->output->description =
-	_("Name for output file (without extension)");
+	_("Name for output image file (without extension)");
     params->output->guisection = _("Image");
     /* format */
@@ -93,7 +97,7 @@
     params->size->type = TYPE_INTEGER;
     params->size->key_desc = "width,height";
     params->size->answer = "640,480";
-    params->size->description = _("Width and height of output image");
+    params->size->description = _("Size (width, height) of output image");
     params->size->required = YES;
     params->size->guisection = _("Image");
@@ -134,8 +138,6 @@
     params->color_const->multiple = YES;
     params->color_const->label = _("Color value(s)");
     params->color_const->guisection = _("Surfaces");
-    params->color_const->key = "color_value";
-    params->color_const->answer = NULL;
     /* mask */
     params->mask_map = G_define_standard_option(G_OPT_R_MAP);
@@ -284,7 +286,7 @@
     /* position */
     params->surface_pos = G_define_option();
-    params->surface_pos->key = "position";
+    params->surface_pos->key = "surface_position";
     params->surface_pos->key_desc = "x,y,z";
     params->surface_pos->type = TYPE_INTEGER;
     params->surface_pos->required = NO;
@@ -445,7 +447,7 @@
     params->pos->description =
 	_("Viewpoint position (x,y model coordinates)");
     params->pos->guisection = _("Viewpoint");
-    params->pos->answer = "0.85,0.85";
+    params->pos->answer = "0.84,0.16";
     /* height */
     params->height = G_define_option();
@@ -559,6 +561,46 @@
     return;
+void args_lighting(struct GParams *params)
+    params->light_pos = G_define_option();
+    params->light_pos->key = "light_position";
+    params->light_pos->key_desc = "x,y,z";
+    params->light_pos->type = TYPE_DOUBLE;
+    params->light_pos->required = NO;
+    params->light_pos->multiple = NO;
+    params->light_pos->description =
+	_("Light position (x,y,z model coordinates)");
+    params->light_pos->guisection = _("Lighting");
+    params->light_pos->answer = "0.68,0.68,0.80";
+    params->light_color = G_define_standard_option(G_OPT_C_FG);
+    params->light_color->key = "light_color";
+    params->light_color->label = _("Light color");
+    params->light_color->guisection = _("Lighting");
+    params->light_color->answer = "white";
+    params->light_bright = G_define_option();
+    params->light_bright->key = "light_brightness";
+    params->light_bright->type = TYPE_INTEGER;
+    params->light_bright->required = NO;
+    params->light_bright->multiple = NO;
+    params->light_bright->description =	_("Light brightness");
+    params->light_bright->guisection = _("Lighting");
+    params->light_bright->answer = "80";
+    params->light_bright->options="0-100";
+    params->light_ambient = G_define_option();
+    params->light_ambient->key = "light_ambient";
+    params->light_ambient->type = TYPE_INTEGER;
+    params->light_ambient->required = NO;
+    params->light_ambient->multiple = NO;
+    params->light_ambient->description = _("Light ambient");
+    params->light_ambient->guisection = _("Lighting");
+    params->light_ambient->answer = "20";
+    params->light_ambient->options="0-100";
    \brief Get number of answers of given option
Modified: grass/trunk/visualization/nviz2/cmd/local_proto.h
--- grass/trunk/visualization/nviz2/cmd/local_proto.h	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/visualization/nviz2/cmd/local_proto.h	2010-06-20 19:02:52 UTC (rev 42607)
@@ -11,22 +11,24 @@
     struct Option
     /* surface */
     *elev_map, *elev_const, *color_map, *color_const,
-      *mask_map, *transp_map, *transp_const, *shine_map, *shine_const,
-      *emit_map, *emit_const,
+	*mask_map, *transp_map, *transp_const, *shine_map, *shine_const,
+	*emit_map, *emit_const,
     /* surface draw mode */
-      *mode, *res_fine, *res_coarse, *style, *shade, *wire_color, *surface_pos,
+	*mode, *res_fine, *res_coarse, *style, *shade, *wire_color, *surface_pos,
     /* vector lines */
-      *vlines, *vline_width, *vline_color, *vline_mode, *vline_height, *vline_pos,
+	*vlines, *vline_width, *vline_color, *vline_mode, *vline_height, *vline_pos,
     /* vector points */
-      *vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width, *vpoint_pos,
+	*vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width, *vpoint_pos,
     /* volumes */
-      *volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
+	*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
     /* misc */
-      *exag, *bgcolor,
+	*exag, *bgcolor,
     /* viewpoint */
-      *pos, *height, *persp, *twist,
+	*pos, *height, *persp, *twist,
     /* output */
-      *output, *format, *size;
+	*output, *format, *size,
+    /* lighting */
+	*light_pos, *light_color, *light_bright, *light_ambient;
 /* args.c */
Modified: grass/trunk/visualization/nviz2/cmd/main.c
--- grass/trunk/visualization/nviz2/cmd/main.c	2010-06-20 19:00:37 UTC (rev 42606)
+++ grass/trunk/visualization/nviz2/cmd/main.c	2010-06-20 19:02:52 UTC (rev 42607)
@@ -19,6 +19,7 @@
 #include <string.h>
 #include <grass/gis.h>
+#include <grass/colors.h>
 #include <grass/glocale.h>
@@ -32,7 +33,9 @@
     struct GParams *params;
     int ret;
-    float vp_height, z_exag;	/* calculated viewpoint height, z-exag */
+    int red, grn, blu;
+    double vp_height, z_exag;	/* calculated viewpoint height, z-exag */
+    double light_ambient;
     int width, height;		/* output image size */
     char *output_name;
@@ -85,19 +88,25 @@
     /* set background color */
     Nviz_set_bgcolor(&data, Nviz_color_from_str(params->bgcolor->answer));
-    /* init view */
-    Nviz_init_view();
+    /* init view, lights */
+    Nviz_init_view(&data);
     /* set lights */
-    /* TODO: add options */
-    Nviz_set_light_position(&data, 0, 0.68, -0.68, 0.80, 0.0);
-    Nviz_set_light_bright(&data, 0, 0.8);
-    Nviz_set_light_color(&data, 0, 1.0, 1.0, 1.0);
-    Nviz_set_light_ambient(&data, 0, 0.2, 0.2, 0.2);
-    Nviz_set_light_position(&data, 1, 0.0, 0.0, 1.0, 0.0);
-    Nviz_set_light_bright(&data, 1, 0.5);
-    Nviz_set_light_color(&data, 1, 1.0, 1.0, 1.0);
-    Nviz_set_light_ambient(&data, 1, 0.3, 0.3, 0.3);
+    Nviz_set_light_position(&data, 1,
+			    atof(params->light_pos->answers[0]),
+			    atof(params->light_pos->answers[1]),
+			    atof(params->light_pos->answers[2]),
+			    0.0);
+    Nviz_set_light_bright(&data, 1,
+			  atoi(params->light_bright->answer) / 100.0);
+    if(G_str_to_color(params->light_color->answer, &red, &grn, &blu) != 1) {
+	red = grn = blu = 255;
+    Nviz_set_light_color(&data, 1, red, grn, blu);
+    light_ambient = atof(params->light_ambient->answer) / 100.0;
+    Nviz_set_light_ambient(&data, 1,
+			   light_ambient, light_ambient, light_ambient);
     /* load raster maps (surface topography) & set attributes (map/constant) */
     load_rasters(params, &data);
     /* set draw mode of loaded surfaces */
@@ -149,13 +158,12 @@
 	G_message(_("Viewpoint height not given, using calculated value %.0f"),
 		  vp_height);
-    Nviz_set_viewpoint_height(&data, vp_height);
+    Nviz_set_viewpoint_height(vp_height);
-    Nviz_set_viewpoint_position(&data,
-				atof(params->pos->answers[0]),
+    Nviz_set_viewpoint_position(atof(params->pos->answers[0]),
 				atof(params->pos->answers[1]));
-    Nviz_set_viewpoint_twist(&data, atoi(params->twist->answer));
-    Nviz_set_viewpoint_persp(&data, atoi(params->persp->answer));
+    Nviz_set_viewpoint_twist(atoi(params->twist->answer));
+    Nviz_set_viewpoint_persp(atoi(params->persp->answer));
     GS_clear(data.bgcolor);
