[GRASS-SVN] r42621 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Jun 21 15:16:07 EDT 2010
Author: martinl
Date: 2010-06-21 19:16:07 +0000 (Mon, 21 Jun 2010)
New Revision: 42621
grass/trunk/lib/init/grass.py
os.uname() is not available on Windows, replaced by platform.node()
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2010-06-21 11:01:15 UTC (rev 42620)
+++ grass/trunk/lib/init/grass.py 2010-06-21 19:16:07 UTC (rev 42621)
@@ -29,6 +29,7 @@
import string
import subprocess
import re
+import platform
# Variables substituted during build process
# Set the GISBASE variable
@@ -886,7 +887,7 @@
# Set the global grassrc file
batch_job = os.getenv('GRASS_BATCH_JOB')
if batch_job:
- gisrcrc = os.path.join(grass_config_dir, "rc.%s" % os.uname()[1])
+ gisrcrc = os.path.join(grass_config_dir, "rc.%s" % platform.node())
if not os.access(gisrcrc, os.R_OK):
gisrcrc = os.path.join(grass_config_dir, "rc")
else:
