[GRASS-SVN] r42631 - in grass/trunk: gui/wxpython/gui_modules lib/nviz visualization/nviz2/cmd
Tue Jun 22 12:51:49 EDT 2010
Author: martinl
Date: 2010-06-22 16:51:49 +0000 (Tue, 22 Jun 2010)
New Revision: 42631
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
   grass/trunk/gui/wxpython/gui_modules/wxnviz.py
   grass/trunk/lib/nviz/change_view.c
   grass/trunk/lib/nviz/exag.c
   grass/trunk/lib/nviz/lights.c
   grass/trunk/visualization/nviz2/cmd/main.c
wxGUI/nviz: temp fix (problem with ctypes)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-06-22 15:36:21 UTC (rev 42630)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2010-06-22 16:51:49 UTC (rev 42631)
@@ -119,6 +119,7 @@
         self.view = copy.deepcopy(UserSettings.Get(group = 'nviz', key = 'view')) # copy
         self.iview = UserSettings.Get(group = 'nviz', key = 'view', internal = True)
         self.nvizDefault = NvizDefault()
         self.light = copy.deepcopy(UserSettings.Get(group = 'nviz', key = 'light')) # copy
@@ -758,6 +759,7 @@
             self.iview['height']['value'], \
             self.iview['height']['min'], \
             self.iview['height']['max'] = self._display.SetViewDefault()
         self.view['z-exag']['min'] = 0
         self.view['z-exag']['max'] = self.view['z-exag']['value'] * 10
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2010-06-22 15:36:21 UTC (rev 42630)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2010-06-22 16:51:49 UTC (rev 42631)
@@ -1143,8 +1143,8 @@
         gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Color:")),
                       pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL)
         color = csel.ColourSelect(panel, id = wx.ID_ANY,
-                                  colour = UserSettings.Get(group = 'nviz', key = 'settings',
-                                                            subkey = ['light', 'color']),
+                                  colour = UserSettings.Get(group = 'nviz', key = 'light',
+                                                            subkey = 'color'),
                                   size = globalvar.DIALOG_COLOR_SIZE)
         color.Bind(csel.EVT_COLOURSELECT, self.OnLightColor)
         gridSizer.Add(item = color, pos = (0, 2))
@@ -2271,7 +2271,7 @@
             zmin = self.mapWindow.view['z-exag']['min']
             zmax = self.mapWindow.view['z-exag']['max']
             zval = self.mapWindow.view['z-exag']['value']
-            print hmin, hmax, hval
             for control in ('spin', 'slider'):
                 self.FindWindowById(self.win['view']['height'][control]).SetRange(hmin,
        hmax)
Modified: grass/trunk/gui/wxpython/gui_modules/wxnviz.py
--- grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-06-22 15:36:21 UTC (rev 42630)
+++ grass/trunk/gui/wxpython/gui_modules/wxnviz.py	2010-06-22 16:51:49 UTC (rev 42631)
@@ -92,9 +92,12 @@
         hmax = c_float()
         Nviz_get_exag_height(byref(hdef), byref(hmin), byref(hmax))
-        Debug.msg(3, "Nviz::SetViewDefault(): hdef=%f, hmin=%f, hmax=%f",
+        Debug.msg(1, "Nviz::SetViewDefault(): hdef=%f, hmin=%f, hmax=%f",
                   hdef.value, hmin.value, hmax.value)
+        hdef.value = 805
+        hmin.value = -2944.302979
+        hmax.value = 4555.696777
         return (z_exag, hdef.value, hmin.value, hmax.value)
     def SetView(self, x, y, height, persp, twist):
@@ -104,10 +107,10 @@
         @param persp perpective
         @param twist
-        Nviz_set_viewpoint_height(self.data, height)
-        Nviz_set_viewpoint_position(self.data, x, y)
-        Nviz_set_viewpoint_twist(self.data, twist)
-        Nviz_set_viewpoint_persp(self.data, persp)
+        Nviz_set_viewpoint_height(height)
+        Nviz_set_viewpoint_position(x, y)
+        Nviz_set_viewpoint_twist(twist)
+        Nviz_set_viewpoint_persp(persp)
         Debug.msg(3, "Nviz::SetView(): x=%f, y=%f, height=%f, persp=%f, twist=%f",
@@ -162,7 +165,7 @@
         # initialize view, lights
         Nviz_init_view(self.data)
         # clear window
         GS_clear(self.data.bgcolor)
Modified: grass/trunk/lib/nviz/change_view.c
--- grass/trunk/lib/nviz/change_view.c	2010-06-22 15:36:21 UTC (rev 42630)
+++ grass/trunk/lib/nviz/change_view.c	2010-06-22 16:51:49 UTC (rev 42631)
@@ -36,6 +36,7 @@
 	ret = 0;
+    G_debug(1, "Nviz_resize_window(): width = %d height = %d", width, height);
     GS_set_viewport(0, width, 0, height);
     /*   GS_clear(0x0000FF); causes red flash - debug only */
@@ -105,7 +106,7 @@
 		  xpos, 1.0 - ypos);
-    G_debug(3, "Nviz_set_viewpoint_position(): x = %f y = %f", x_pos, y_pos);
+    G_debug(1, "Nviz_set_viewpoint_position(): x = %f y = %f", x_pos, y_pos);
     GS_get_from(from);
     tempx = xpos * RANGE - RANGE_OFFSET;
@@ -136,6 +137,8 @@
     float from[3];
+    G_debug(1, "Nviz_set_viewpoint_height(): value = %f", height);
     GS_get_from_real(from);
     if (height != from[Z]) {
@@ -166,6 +169,8 @@
     int fov;
+    G_debug(1, "Nviz_set_viewpoint_persp(): value = %d", persp);
     fov = (int)(10 * persp);
     GS_set_fov(fov);
@@ -184,6 +189,7 @@
 int Nviz_set_viewpoint_twist(int twist)
+    G_debug(1, "Nviz_set_viewpoint_twist(): value = %d", twist);
     GS_set_twist(10 * twist);
     /* Nviz_draw_quick(data); */
@@ -203,6 +209,7 @@
     double temp;
+    G_debug(1, "Nviz_change_exag(): value = %f", exag);
     temp = GS_global_exag();
     if (exag != temp) {
Modified: grass/trunk/lib/nviz/exag.c
--- grass/trunk/lib/nviz/exag.c	2010-06-22 15:36:21 UTC (rev 42630)
+++ grass/trunk/lib/nviz/exag.c	2010-06-22 16:51:49 UTC (rev 42631)
@@ -60,6 +60,9 @@
     if (max)
 	*max = fmax;
+    G_debug(1, "Nviz_get_exag_height(): value = %f min = %f max = %f",
+	    *val, min ? *min : 0.0 , max ? *max : 0.0);
     return 1;
@@ -91,5 +94,6 @@
     if (nsurfs > 0)
 	G_free(surf_list);
+    G_debug(1, "Nviz_get_exag(): value = %f", exag);
     return exag;
Modified: grass/trunk/lib/nviz/lights.c
--- grass/trunk/lib/nviz/lights.c	2010-06-22 15:36:21 UTC (rev 42630)
+++ grass/trunk/lib/nviz/lights.c	2010-06-22 16:51:49 UTC (rev 42631)
@@ -35,7 +35,7 @@
     ypos = (ypos < 0) ? 0 : (ypos > 1.0) ? 1.0 : ypos;
     if (x < 0.0 || x > 1.0 || y < 0.0 || y > 1.0) {
-	G_debug(0, "Invalid light position coordinates (%f,%f), using %f,%f",
+	G_debug(1, "Invalid light position coordinates (%f,%f), using %f,%f",
 		x, y, xpos, 1.0 - ypos);
@@ -46,7 +46,7 @@
     data->light[num].z = z;
     data->light[num].w = w;
-    G_debug(0, "Nviz_set_light_position(): num = %d x = %f y = %f z = %f w = %f",
+    G_debug(1, "Nviz_set_light_position(): num = %d x = %f y = %f z = %f w = %f",
 	    num + 1, x, y, z, w);
     GS_setlight_position(num + 1, x, y, z, w);
@@ -71,7 +71,7 @@
     g = data->light[num].g * data->light[num].brt;
     b = data->light[num].b * data->light[num].brt;
-    G_debug(0, "Nviz_set_light_bright(): num = %d value = %f r = %f g = %f b = %f",
+    G_debug(1, "Nviz_set_light_bright(): num = %d value = %f r = %f g = %f b = %f",
 	    num + 1, value, r, g, b);
     GS_setlight_color(num + 1, r, g, b);
@@ -99,7 +99,7 @@
-    G_debug(0, "Nviz_set_light_color(): num = %d r = %d/%f g = %d/%f b = %d/%f",
+    G_debug(1, "Nviz_set_light_color(): num = %d r = %d/%f g = %d/%f b = %d/%f",
 	    num + 1, red, r, green, g, blue, b);
@@ -120,7 +120,7 @@
     data->light[num].ag = value;
     data->light[num].ab = value;
-    G_debug(0, "Nviz_set_light_ambient(): num = %d value = %f",
+    G_debug(1, "Nviz_set_light_ambient(): num = %d value = %f",
 	    num + 1, value);
     GS_setlight_ambient(num + 1, value, value, value);
Modified: grass/trunk/visualization/nviz2/cmd/main.c
--- grass/trunk/visualization/nviz2/cmd/main.c	2010-06-22 15:36:21 UTC (rev 42630)
+++ grass/trunk/visualization/nviz2/cmd/main.c	2010-06-22 16:51:49 UTC (rev 42631)
@@ -90,21 +90,6 @@
     /* init view, lights */
     Nviz_init_view(&data);
-    /* set lights */
-    Nviz_set_light_position(&data, 1,
-			    atof(params->light_pos->answers[0]),
-			    atof(params->light_pos->answers[1]),
-			    atof(params->light_pos->answers[2]),
-			    0.0);
-    Nviz_set_light_bright(&data, 1,
-			  atoi(params->light_bright->answer) / 100.0);
-    if(G_str_to_color(params->light_color->answer, &red, &grn, &blu) != 1) {
-	red = grn = blu = 255;
-    Nviz_set_light_color(&data, 1, red, grn, blu);
-    Nviz_set_light_ambient(&data, 1,
-			   atof(params->light_ambient->answer) / 100.0);
     /* load raster maps (surface topography) & set attributes (map/constant) */
     load_rasters(params, &data);
     /* set draw mode of loaded surfaces */
@@ -153,7 +138,8 @@
 	vp_height = atof(params->height->answer);
     else {
-	Nviz_get_exag_height(&vp_height, NULL, NULL);
+	double min, max;
+	Nviz_get_exag_height(&vp_height, &min, &max);
 	G_verbose_message(_("Viewpoint height not given, using calculated "
 			    "value %.0f"),
 			  vp_height);
@@ -165,6 +151,21 @@
     Nviz_set_viewpoint_twist(atoi(params->twist->answer));
     Nviz_set_viewpoint_persp(atoi(params->persp->answer));
+    /* set lights */
+    Nviz_set_light_position(&data, 1,
+			    atof(params->light_pos->answers[0]),
+			    atof(params->light_pos->answers[1]),
+			    atof(params->light_pos->answers[2]),
+			    0.0);
+    Nviz_set_light_bright(&data, 1,
+			  atoi(params->light_bright->answer) / 100.0);
+    if(G_str_to_color(params->light_color->answer, &red, &grn, &blu) != 1) {
+	red = grn = blu = 255;
+    Nviz_set_light_color(&data, 1, red, grn, blu);
+    Nviz_set_light_ambient(&data, 1,
+			   atof(params->light_ambient->answer) / 100.0);
     GS_clear(data.bgcolor);
     /* draw */
