[GRASS-SVN] r41261 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Tue Mar 2 05:57:16 EST 2010
Author: hamish
Date: 2010-03-02 05:57:15 -0500 (Tue, 02 Mar 2010)
New Revision: 41261
grass/trunk/display/d.vect/main.c
opt descr
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2010-03-02 10:42:04 UTC (rev 41260)
+++ grass/trunk/display/d.vect/main.c 2010-03-02 10:57:15 UTC (rev 41261)
@@ -223,7 +223,7 @@
size_opt->guisection = _("Symbols");
size_opt->label = _("Symbol size");
size_opt->description =
- _("When used with the size_column option this is the scale factor");
+ _("When used with the size_column option this becomes the scale factor");
sizecolumn_opt = G_define_standard_option(G_OPT_DB_COLUMN);
sizecolumn_opt->key = "size_column";
@@ -360,7 +360,9 @@
sqrt_flag = G_define_flag();
sqrt_flag->key = 'r';
sqrt_flag->label = _("Use square root of the value of size_column");
- sqrt_flag->description = _("Use this if you want to make the surface instead of the height of circles proportionate to size_column");
+ sqrt_flag->description =
+ _("This makes circle areas proportionate to the size_column values "
+ "instead of circle radius");
sqrt_flag->guisection = _("Symbols");
/* Check command line */
