[GRASS-SVN] r41273 - grass-addons/raster/r.fuzzy
svn_grass at osgeo.org
Wed Mar 3 01:53:32 EST 2010
Author: jarekj71
Date: 2010-03-03 01:53:31 -0500 (Wed, 03 Mar 2010)
New Revision: 41273
Added:
grass-addons/raster/r.fuzzy/Makefile
grass-addons/raster/r.fuzzy/boundary.png
grass-addons/raster/r.fuzzy/description.html
grass-addons/raster/r.fuzzy/fuzzy.c
grass-addons/raster/r.fuzzy/local_proto.h
grass-addons/raster/r.fuzzy/main.c
grass-addons/raster/r.fuzzy/set.png
grass-addons/raster/r.fuzzy/shape.png
r.fuzzy.file
Added: grass-addons/raster/r.fuzzy/Makefile
--- grass-addons/raster/r.fuzzy/Makefile (rev 0)
+++ grass-addons/raster/r.fuzzy/Makefile 2010-03-03 06:53:31 UTC (rev 41273)
@@ -0,0 +1,16 @@
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+MODULE_TOPDIR = ../..
+PGM = r.fuzzy
+LIBES = $(VECTLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/raster/r.fuzzy/Makefile
___________________________________________________________________
Added: svn:executable
Added: grass-addons/raster/r.fuzzy/boundary.png
(Binary files differ)
Property changes on: grass-addons/raster/r.fuzzy/boundary.png
Added: svn:mime-type
+ application/octet-stream
Added: grass-addons/raster/r.fuzzy/description.html
--- grass-addons/raster/r.fuzzy/description.html (rev 0)
+++ grass-addons/raster/r.fuzzy/description.html 2010-03-03 06:53:31 UTC (rev 41273)
@@ -0,0 +1,128 @@
+<h2>OPTIONS</h2>
+<p>
+<DT><b>input</b></DT>
+<DD>Name of input raster map to be fuzified. This map may be of any type and may require null values.
+</DD>
+<p>
+<DT><b>points</b></DT>
+<DD>A list containing 4 (A,B,C,D) or 2 A,B) points defining set boundaries. Points must not to be in map range, but it may lead to only 0 o 1 membership for the whole map. For "both" side parameters range between A and D defines base, but range between B and C core of the fuzzy set. Between A and B and C and D are set's boundaries. If side is "both" it require 4 points, else 2 points.</DD>
+<p>
+<center>
+<h3>Fuzzy set definition:<h3>
+<img src=set.png border=1><br>
+</center>
+<DT><b>side</b></DT>
+<DD>Option indicat if set is fuzzified ob both side s (both), left or right side. See description for details.</DD>
+<p>
+<h2>OUTPUTS</h2>
+<DT><b>output</b></DT>
+<DD>Map containing membership value of original map. Map is alvays of type FCELLS and contains values from 0 (no membership) to 1 (full membership). Values between 0 and 1 indicate partial membership</DD>
+<p>
+<h2>FUZZY SET PARAMETERS</h2>
+<DT><b>boundary</b></DT>
+<DD>Parameter definied the shape of the fuzzy boundary. The default and most popular is S-shaped, linear, J-shaped and G-shaped boundaries are also available. The same boundaires are appled to the both sides.</DD>
+<p>
+<center>
+<h3>Boundary definition:<h3>
+<img src=boundary.png border=1><br>
+</center
+<DT><b>shape</b></DT>
+<DD>Optional shape modifier. Range from -1 to 1. The default value is 0 and shoud not be changed in most of the time. The negative values indicate more dilatant set, the positive values more concentrate set. See description for details.</DD>
+<p>
+<center>
+<h3>Impact of shape parameter on shape boundary:<h3>
+<img src=shape.png border=1><br>
+</center
+<DT><b>height</b></DT>
+<DD>Optional height modifier. Range from 0 to 1. The default value is 1 and indicate full membership beteen points B and C. If height is lesser than one the maximum memebrship is equal to height. See image: Fuzzy set definition.</DD>
+<p>
+</DL>
+<h2>DESCRIPTION</h2>
+<P>
+<H4>Definition of fuzzy set</H4>
+Fuzzy sets are sets whose elements have degrees of membership. Zadeh (1965) introduced Fuzzy sets as an extension of the classical notion of set. Classical membership of elements in a set are binary terms: an element either belongs or does not belong to the set. Fuzzy set theory use the gradual assessment of the membership of elements in a set. A membership function valued in the real unit interval [0, 1]. Classical sets, are special cases of the membership functions of fuzzy sets, if the latter only take values 0 or 1. Classical sets are in fuzzy set theory usually called crisp sets. The fuzzy set theory can be used in a wide range of domains in which information is imprecise, such as most of the GIS operations.
+<h2>NOTES</H2>
+<H4>Calculation of boundary shape</H4>
+Depending on type of the boundary different equation are used to determine its shape:
+<P>
+<B>Linear:</B> the membership is calculated according following equation:<br>
+<pre><code>
+value <= A -> x = 0
+A< value > B -> x = (value-A)/(B-A)
+B <= value >= C -> x = 1
+C< value > D -> x = (D-value)/(D-C)
+value >= D -> x = 0
+where x: membership
+</code></pre>
+<P>
+<B>S-shaped:</B> it use following equation:
+<pre><code>
+sin(x * Pi/2)^m (for positive shape parameter)
+1-cos(x * Pi/2)^m (for nagative shape parameter)
+where x: membership, and
+m = 2^exp(2,shape) (for positive shape parameter)
+m = 2^(1+shape) (for negative shape parameter)
+where m: shape parameter.
+</code></pre>
+For default shape parameter = 0 m is = 2 whcich is most common parameter for that equation.
+<P>
+<B>G-shaped and J shaped:</B> it use following equations:
+<pre><code>
+tan(x * Pi/4)^m (for J-shaped)
+tan(x * Pi/4)^1/m (for G-shaped)
+</code></pre>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.fuzzy.logic.html">r.fuzzy.logic</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+</em>
+<h2>REFERENCES</h2>
+Zadeh, L.A. (1965). "Fuzzy sets". Information and Control 8 (3): 338–353. doi:10.1016/S0019-9958(65)90241-X. ISSN 0019-9958.<P>
+Novák, Vilém (1989). Fuzzy Sets and Their Applications. Bristol: Adam Hilger. ISBN 0-85274-583-4.<P>
+Klir, George J.; Yuan, Bo (1995). Fuzzy sets and fuzzy logic: theory and applications. Upper Saddle River, NJ: Prentice Hall PTR. ISBN 0-13-101171-5.<P>
+Klir, George J.; St Clair, Ute H.; Yuan, Bo (1997). Fuzzy set theory: foundations and applications. Englewood Cliffs, NJ: Prentice Hall. ISBN 0133410587.<P>
+Meyer D, Hornik K (2009a). \Generalized and Customizable Sets in R." Journal of Statistical Software, 31(2), 1{27. URL http://www.jstatsoft.org/v31/i02/.<P>
+Meyer D, Hornik K (2009b). sets: Sets, Generalized Sets, and Customizable Sets. R~package version~1.0, URL http://CRAN.R-project.org/package=sets.<P>
+<h2>AUTHOR</h2>
+Jarek Jasiewicz
Property changes on: grass-addons/raster/r.fuzzy/description.html
Added: grass-addons/raster/r.fuzzy/fuzzy.c
--- grass-addons/raster/r.fuzzy/fuzzy.c (rev 0)
+++ grass-addons/raster/r.fuzzy/fuzzy.c 2010-03-03 06:53:31 UTC (rev 41273)
@@ -0,0 +1,52 @@
+#include <grass/glocale.h>
+#include "local_proto.h"
+float fuzzy (FCELL cell) {
+ float x, m;
+ if (!side) { /* both left and right */
+ if (cell <= p[0] || cell >= p[3])
+ return 0.;
+ if (cell >= p[1] && cell <= p[2])
+ return 1.;
+ x = (cell<p[1]) ? (cell-p[0])/(p[1]-p[0])
+ : (p[3]-cell)/(p[3]-p[2]);
+ if (side) { /* left: 1 OR right: 2 */
+ if (cell <= p[0])
+ return (side == 1) ? 0. : 1.;
+ if (cell >= p[1])
+ return (side == 1) ? 1. : 0.;
+ x = (side == 1) ? (cell-p[0])/(p[1]-p[0])
+ : (p[1]-cell)/(p[1]-p[0]);
+ if (type == LINEAR)
+ return x;
+ if (type == JSHAPE) {
+ m = (shape < 0) ? pow(2,1+shape)
+ : pow(2,exp(2*shape));
+ return pow(tan(x * PI4),m);
+ if (type == GSHAPE) {
+ m = (shape > 0) ? pow(2,1-shape)
+ : pow(2,exp(-2*shape));
+ return pow(tan(x * PI4),1/m);
+ if(type==SSHAPE) {
+ m = pow(2,exp(2*abs(shape)));
+ return (shape < 0) ? pow(1-cos(x*PI2),m)
+ : pow(sin(x*PI2),m);
+return -1; /* error */
Property changes on: grass-addons/raster/r.fuzzy/fuzzy.c
Added: grass-addons/raster/r.fuzzy/local_proto.h
--- grass-addons/raster/r.fuzzy/local_proto.h (rev 0)
+++ grass-addons/raster/r.fuzzy/local_proto.h 2010-03-03 06:53:31 UTC (rev 41273)
@@ -0,0 +1,35 @@
+#include <stdlib.h>
+#include <string.h>
+#include <stdio.h>
+#include <math.h>
+#include <grass/gis.h>
+PI2= PI/2
+PI4= PI/4
+#ifndef PI2
+ #define PI2 (2*atan(1))
+#endif
+#ifndef PI4
+ #define PI4 (atan(1))
+#endif
+#define LINEAR 0
+#define SSHAPE 1
+#define JSHAPE 2
+#define GSHAPE 3
+#define BOTH 0
+#define LEFT 1
+#define RIGHT 2
+char *input, *output;
+float shape, height;
+int type, side;
+double p[4]; /* inflection points */
+int num_points;
+float fuzzy (FCELL cell);
Property changes on: grass-addons/raster/r.fuzzy/local_proto.h
Added: grass-addons/raster/r.fuzzy/main.c
--- grass-addons/raster/r.fuzzy/main.c (rev 0)
+++ grass-addons/raster/r.fuzzy/main.c 2010-03-03 06:53:31 UTC (rev 41273)
@@ -0,0 +1,246 @@
+ * MODULE: r.fuzzy
+ * AUTHOR(S): Jarek Jasiewicz <jarekj amu.edu.pl>
+ * PURPOSE: Calculate membership value of any raster map according user's rules
+ * COPYRIGHT: (C) 1999-2010 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#define MAIN
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct Option *par_input,
+ *par_output,
+ *par_points,
+ *par_side,
+ *par_type,
+ *par_height,
+ *par_shape;
+ struct Cell_head cellhd;
+ struct History history;
+ char *mapset;
+ int nrows, ncols;
+ int row, col;
+ int infd, outfd;
+ void *in_buf;
+ unsigned char *out_buf;
+ RASTER_MAP_TYPE raster_type;
+ FCELL tmp=0;
+ G_gisinit(argv[0]);
+ par_input = G_define_standard_option(G_OPT_R_INPUT);
+ par_input->description = _("Raster map to be fuzzified");
+ par_output = G_define_standard_option(G_OPT_R_OUTPUT);
+ par_output->description = _("Membership map");
+ par_points=G_define_option();
+ par_points->key = "points";
+ par_points->type = "TYPE_STRING";
+ par_points->answer = "a,b[,c,d]";
+ par_points->multiple = YES;
+ par_points->required = YES;
+ par_points->description = _("Inflection points: a,b[,c,d]");
+ par_side=G_define_option();
+ par_side->key = "side";
+ par_side->type = "TYPE_STRING";
+ par_side->options = "both,left,right";
+ par_side->answer = "both";
+ par_side->multiple = NO;
+ par_side->required = YES;
+ par_side->description = _("Fuzzy range");
+ par_type=G_define_option();
+ par_type->key = "boundary";
+ par_type->type = "TYPE_STRING";
+ par_type->options = "Linear,S-shaped,J-shaped,G-shaped";
+ par_type->answer = "S-shaped";
+ par_type->multiple = NO;
+ par_type->required = YES;
+ par_type->description = _("Type of fuzzy boundaries");
+ par_type->guisection = _("Default options");
+ par_shape=G_define_option();
+ par_shape->key = "shape";
+ par_shape->type = "TYPE_FLOAT";
+ par_shape->options = "-1 to 1";
+ par_shape->answer = "0.";
+ par_shape->multiple = NO;
+ par_shape->required = YES;
+ par_shape->description = _("Shape modifier: -1 to 1");
+ par_shape->guisection = _("Default options");
+ par_height=G_define_option();
+ par_height->key = "height";
+ par_height->type = "TYPE_FLOAT";
+ par_height->options = "0 to 1";
+ par_height->answer = "1";
+ par_height->multiple = NO;
+ par_height->required = YES;
+ par_height->description = _("Membership height: 0 to 1");
+ par_height->guisection = _("Default options");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ input=par_input->answer;
+ output=par_output->answer;
+ if (!strcmp(par_type->answer, "Linear"))
+ type=LINEAR;
+ else if (!strcmp(par_type->answer, "S-shaped"))
+ type=SSHAPE;
+ else if (!strcmp(par_type->answer, "J-shaped"))
+ type=JSHAPE;
+ else if (!strcmp(par_type->answer, "G-shaped"))
+ type=GSHAPE;
+ if (!strcmp(par_side->answer, "both"))
+ side=BOTH;
+ else if (!strcmp(par_side->answer, "left"))
+ side=LEFT;
+ else if (!strcmp(par_side->answer, "right"))
+ side=RIGHT;
+ shape = atof(par_shape->answer);
+ if(shape<-1. || shape>1.)
+ G_fatal_error(_("Shape modifier must be between -1 and 1"));
+ height = atof(par_height->answer);
+ if(height>1 || height<0)
+ G_fatal_error(_("Heght modifier must be between 0 and 1"));
+ num_points=sscanf(par_points->answer,
+ "%lf,%lf,%lf,%lf",
+ &p[0], &p[1], &p[2], &p[3]);
+ if(!side && num_points != 4)
+ G_fatal_error(_("Wrong number of values: got %d but need 4"),
+ num_points);
+ if(side && num_points != 2)
+ G_fatal_error(_("Wrong number of values: got %d but need 2"),
+ num_points);
+ if (num_points==2) {
+ if( p[0]>p[1])
+ G_fatal_error(_("Point sequence must be: a <= b"));
+ } else {
+ if( p[0]>p[1]
+ ||p[1]>p[2]
+ ||p[2]>p[3])
+ G_fatal_error(_("Point sequence must be: a <= b; b <= c; c <= d;"));
+ /* end of interface */
+ mapset = G_find_cell2(input, "");
+ if (mapset == NULL)
+ G_fatal_error(_("Raster map <%s> not found"), input);
+ if ((infd = G_open_cell_old(input, mapset)) < 0)
+ G_fatal_error(_("Unable to open raster map <%s>"), input);
+ if (G_get_cellhd(input, mapset, &cellhd) < 0)
+ G_fatal_error(_("Unable to read file header of <%s>"), input);
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ raster_type = G_get_raster_map_type(infd);
+ if ((outfd = G_open_raster_new(output, FCELL_TYPE)) < 0)
+ G_fatal_error(_("Unable to create raster map <%s>"), output);
+ in_buf = G_allocate_raster_buf(raster_type);
+ out_buf = G_allocate_raster_buf(FCELL_TYPE);
+ /* processing */
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ CELL c;
+ FCELL f;
+ DCELL d;
+ if (G_get_raster_row(infd, in_buf, row, raster_type)<0) {
+ G_close_cell(infd);
+ G_fatal_error(_("Cannot to read <%s> at row <%d>"), input,row);
+ for (col = 0; col < ncols; col++) {
+ switch (raster_type) {
+ case CELL_TYPE:
+ c = ((CELL *) in_buf)[col];
+ if(G_is_null_value(&c,CELL_TYPE))
+ G_set_f_null_value(&tmp, 1);
+ else {
+ if(0>(tmp = fuzzy ((FCELL) c)))
+ G_warning("Cannot determine memebership at row %d, col %d", row,col);
+ ((FCELL *) out_buf)[col] = tmp;
+ break;
+ case FCELL_TYPE:
+ f = ((FCELL *) in_buf)[col];
+ if(G_is_null_value(&f,FCELL_TYPE))
+ else {
+ tmp = fuzzy((FCELL) f);
+ if(0>(tmp = fuzzy((FCELL) f)))
+ break;
+ case DCELL_TYPE:
+ d = ((DCELL *) in_buf)[col];
+ if(G_is_null_value(&d,DCELL_TYPE))
+ else {
+ if(0>(tmp = fuzzy ((FCELL) d)))
+ break;
+ if (G_put_raster_row(outfd, out_buf, FCELL_TYPE) < 0)
+ G_fatal_error(_("Failed writing raster map <%s>"), output);
+ } /* end for */
+ G_free(in_buf);
+ G_free(out_buf);
+ G_close_cell(outfd);
+ G_short_history(output, "raster", &history);
+ G_command_history(&history);
+ G_write_history(output, &history);
+ exit(EXIT_SUCCESS);
Property changes on: grass-addons/raster/r.fuzzy/main.c
Added: grass-addons/raster/r.fuzzy/set.png
Property changes on: grass-addons/raster/r.fuzzy/set.png
Added: grass-addons/raster/r.fuzzy/shape.png
Property changes on: grass-addons/raster/r.fuzzy/shape.png
