[GRASS-SVN] r41276 - grass/branches/develbranch_6/scripts/v.colors
svn_grass at osgeo.org
Wed Mar 3 20:32:57 EST 2010
Author: hamish
Date: 2010-03-03 20:32:56 -0500 (Wed, 03 Mar 2010)
New Revision: 41276
grass/branches/develbranch_6/scripts/v.colors/v.colors
fix verbosity
Modified: grass/branches/develbranch_6/scripts/v.colors/v.colors
--- grass/branches/develbranch_6/scripts/v.colors/v.colors 2010-03-03 06:57:38 UTC (rev 41275)
+++ grass/branches/develbranch_6/scripts/v.colors/v.colors 2010-03-04 01:32:56 UTC (rev 41276)
@@ -112,9 +112,6 @@
fi
-GRASS_VERBOSE=0
-export GRASS_VERBOSE
cleanup()
if [ -n "$TEMPFILE" ] ; then
@@ -123,11 +120,11 @@
eval `g.findfile elem=windows file="tmp_vcolors.$$" | grep '^name='`
if [ -n "$name" ] ; then
unset WIND_OVERRIDE
- g.remove region="tmp_vcolors.$$"
+ g.remove region="tmp_vcolors.$$" --quiet
fi
eval `g.findfile elem=cell file="tmp_colr_$$" | grep '^name='`
- g.remove rast="tmp_colr_$$"
+ g.remove rast="tmp_colr_$$" --quiet
fi
trap "cleanup" 2 3 15
@@ -198,7 +195,7 @@
#### column checks
# check input data column
-NCOLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep -i "|$GIS_OPT_COLUMN$" | cut -f1 -d'|'`
+NCOLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" --quiet | grep -i "|$GIS_OPT_COLUMN$" | cut -f1 -d'|'`
if [ -z "$NCOLUMN_TYPE" ] ; then
g.message -e "Column <$GIS_OPT_COLUMN> not found"
exit 1
@@ -210,7 +207,7 @@
# check if GRASSRGB column exists, make it if it doesn't
TABLE=`v.db.connect -g map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" fs=";" | grep "^$GIS_OPT_LAYER;" | cut -f2 -d';'`
-COLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep -i "|$GIS_OPT_RGB_COLUMN$" | cut -f1 -d'|'`
+COLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" --quiet | grep -i "|$GIS_OPT_RGB_COLUMN$" | cut -f1 -d'|'`
if [ -z "$COLUMN_TYPE" ] ; then
# RGB Column not found, create it
g.message "Creating column <$GIS_OPT_RGB_COLUMN> ..."
@@ -241,7 +238,7 @@
MINVAL=`v.db.select map="$GIS_OPT_MAP" column="$GIS_OPT_COLUMN" layer="$GIS_OPT_LAYER" | sort -n | grep '^[-0-9]' | head -n 1`
MAXVAL=`v.db.select map="$GIS_OPT_MAP" column="$GIS_OPT_COLUMN" layer="$GIS_OPT_LAYER" | sort -n | grep '^[-0-9]' | tail -n 1`
fi
-g.message message=" min=[$MINVAL] max=[$MAXVAL]"
+g.message -v message=" min=[$MINVAL] max=[$MAXVAL]"
if [ -z "$MINVAL" ] || [ -z "$MAXVAL" ] ; then
g.message -e "Scanning data range"
exit 1
@@ -274,7 +271,7 @@
else
FLIP_FLAG=""
fi
-r.colors map="tmp_colr_$$" "$COLOR_CMD" $FLIP_FLAG
+r.colors map="tmp_colr_$$" "$COLOR_CMD" $FLIP_FLAG --quiet
@@ -318,7 +315,7 @@
if [ $GIS_FLAG_S -eq 1 ] ; then
- g.rename rast="tmp_colr_$$","vcolors_$$"
+ g.rename rast="tmp_colr_$$","vcolors_$$" --quiet
g.message "Raster map containing color rules saved to <vcolors_$$>"
# TODO save full v.colors command line history
r.support map="vcolors_$$" history="" \
@@ -329,7 +326,7 @@
r.support map="vcolors_$$" \
history="RGB saved into <$GIS_OPT_RGB_COLUMN> using <$GIS_OPT_COLOR$GIS_OPT_RASTER$GIS_OPT_RULES>"
else
fi
cleanup
