[GRASS-SVN] r41292 - grass/trunk/scripts/d.shadedmap
Thu Mar 4 20:56:46 EST 2010
Author: cmbarton
Date: 2010-03-04 20:56:46 -0500 (Thu, 04 Mar 2010)
New Revision: 41292
   grass/trunk/scripts/d.shadedmap/d.shadedmap.py
Bug fix: h_map = drapemap -> h_map = drape_map
Modified: grass/trunk/scripts/d.shadedmap/d.shadedmap.py
--- grass/trunk/scripts/d.shadedmap/d.shadedmap.py	2010-03-05 01:55:59 UTC (rev 41291)
+++ grass/trunk/scripts/d.shadedmap/d.shadedmap.py	2010-03-05 01:56:46 UTC (rev 41292)
@@ -46,7 +46,7 @@
     drape_map = options['drapemap']
     relief_map = options['reliefmap']
     brighten = options['brighten']
-    ret = grass.run_command("d.his", h_map = drapemap,  i_map = relief_map, brighten = brighten)
+    ret = grass.run_command("d.his", h_map = drape_map,  i_map = relief_map, brighten = brighten)
     sys.exit(ret)
 if __name__ == "__main__":
