[GRASS-SVN] r41298 - grass/trunk/scripts/v.db.update
Fri Mar 5 13:42:39 EST 2010
Author: martinl
Date: 2010-03-05 13:42:37 -0500 (Fri, 05 Mar 2010)
New Revision: 41298
   grass/trunk/scripts/v.db.update/v.db.update.py
bugfix #985 (patch provided by fpacheco)
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py	2010-03-05 18:25:25 UTC (rev 41297)
+++ grass/trunk/scripts/v.db.update/v.db.update.py	2010-03-05 18:42:37 UTC (rev 41298)
@@ -105,7 +105,7 @@
 	if not value:
 	    grass.fatal(_('Either value= or qcolumn= must be given'))
 	# we insert a value
-	if coltype.upper() not in ["INTEGER", "DOUBLE PRECISION"]:
+	if coltype['type'].upper() not in ["INTEGER", "DOUBLE PRECISION"]:
 	    value = "'%s'" % value
     cmd = "UPDATE %s SET %s=%s" % (table, column, value)
