[GRASS-SVN] r41318 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sun Mar 7 06:21:17 EST 2010
Author: martinl
Date: 2010-03-07 06:21:16 -0500 (Sun, 07 Mar 2010)
New Revision: 41318
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI/loc_wiz: bugfix #987
(merge r41316 from relbr64)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2010-03-07 11:10:27 UTC (rev 41317)
+++ grass/trunk/gui/wxpython/gis_set.py 2010-03-07 11:21:16 UTC (rev 41318)
@@ -396,7 +396,8 @@
def OnWizard(self, event):
"""!Location wizard started"""
from gui_modules import location_wizard
- gWizard = location_wizard.LocationWizard(self, self.tgisdbase.GetValue())
+ gWizard = location_wizard.LocationWizard(parent = self,
+ grassdatabase = self.tgisdbase.GetValue())
if gWizard.location != None:
self.OnSetDatabase(event)
self.UpdateMapsets(os.path.join(self.gisdbase, gWizard.location))
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-03-07 11:10:27 UTC (rev 41317)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2010-03-07 11:21:16 UTC (rev 41318)
@@ -65,14 +65,6 @@
global wizerror
global translist
-coordsys = ''
-north = ''
-south = ''
-east = ''
-west = ''
-resolution = ''
-transformlist = []
class BaseClass(wx.Object):
"""!Base class providing basic methods"""
def __init__(self):
@@ -268,6 +260,7 @@
"PROJ.4 parameters"))
self.radio6 = wx.RadioButton(parent=self, id=wx.ID_ANY,
label=_("Create an arbitrary non-earth coordinate system (XY)"))
# layout
self.sizer.AddGrowableCol(1)
self.sizer.SetVGap(10)
@@ -1302,13 +1295,13 @@
style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
# text input
epsgdir = utils.PathJoin(os.environ["GRASS_PROJSHARE"], 'epsg')
- self.tfile = self.MakeTextCtrl(text=epsgdir, size=(200,-1))
+ self.tfile = self.MakeTextCtrl(text=epsgdir, size=(200,-1),
+ style = wx.TE_PROCESS_ENTER)
self.tcode = self.MakeTextCtrl(size=(200,-1))
# buttons
self.bbrowse = self.MakeButton(_("Browse"))
-# self.bbcodes = self.MakeButton(_("Reload EPSG Codes"))
# search box
self.searchb = wx.SearchCtrl(self, size=(200,-1),
style=wx.TE_PROCESS_ENTER)
@@ -1342,11 +1335,7 @@
flag=wx.ALIGN_LEFT |
wx.ALIGN_CENTER_VERTICAL |
wx.ALL, border=5, pos=(3, 3))
-# self.sizer.Add(item=self.bbcodes,
-# flag=wx.ALIGN_LEFT |
-# wx.ALIGN_CENTER_VERTICAL |
-# wx.ALL, border=5, pos=(3, 4))
self.sizer.AddGrowableRow(4)
self.sizer.Add(item=self.epsglist,
flag=wx.ALIGN_LEFT | wx.EXPAND, pos=(4, 1),
@@ -1354,7 +1343,7 @@
# events
self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
-# self.bbcodes.Bind(wx.EVT_BUTTON, self.OnBrowseCodes)
+ self.tfile.Bind(wx.EVT_TEXT_ENTER, self.OnBrowseCodes)
self.tcode.Bind(wx.EVT_TEXT, self.OnText)
self.tcode.Bind(wx.EVT_TEXT_ENTER, self.OnText)
self.epsglist.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
@@ -1454,15 +1443,15 @@
path = os.path.dirname(self.tfile.GetValue())
if not path:
path = os.getcwd()
dlg = wx.FileDialog(parent=self, message=_("Choose EPSG codes file"),
defaultDir=path, defaultFile="", wildcard="*", style=wx.OPEN)
if dlg.ShowModal() == wx.ID_OK:
path = dlg.GetPath()
self.tfile.SetValue(path)
self.OnBrowseCodes(None)
dlg.Destroy()
event.Skip()
@@ -1481,18 +1470,19 @@
def OnBrowseCodes(self, event, search=None):
"""!Browse EPSG codes"""
self.epsgCodeDict = utils.ReadEpsgCodes(self.tfile.GetValue())
- if type(self.epsgCodeDict) == type(''):
+ if type(self.epsgCodeDict) != dict:
wx.MessageBox(parent=self,
message=_("Unable to read EPGS codes: %s") % self.epsgCodeDict,
caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- self.epsglist.Populate([], update=True)
+ self.epsglist.Populate(list(), update=True)
return
- data = []
+ data = list()
for code, val in self.epsgCodeDict.iteritems():
if code is not None:
data.append((code, val[0], val[1]))
self.epsglist.Populate(data, update=True)
class CustomPage(TitledPage):
@@ -1729,23 +1719,22 @@
event.Skip()
class LocationWizard(wx.Object):
Start wizard here and finish wizard here
def __init__(self, parent, grassdatabase):
+ self.__cleanUp()
global coordsys
self.parent = parent
# define wizard image
- # file = "loc_wizard.png"
- file = "loc_wizard_qgis.png"
- imagePath = os.path.join(globalvar.ETCWXDIR, "images", file)
+ imagePath = os.path.join(globalvar.ETCWXDIR, "images", "loc_wizard_qgis.png")
wizbmp = wx.Image(imagePath, wx.BITMAP_TYPE_PNG)
- # wizbmp.Rescale(250,600)
wizbmp = wizbmp.ConvertToBitmap()
# get georeferencing information from tables in $GISBASE/etc
@@ -1865,12 +1854,34 @@
'err' : msg },
caption=_("Location wizard"),
- else:
- win = wx.MessageBox(parent=self.parent,
- message=_("Location wizard canceled. "
- "Location not created."),
- caption=_("Location wizard"))
+ else: # -> cancelled
+ self.wizard.Destroy()
+ wx.MessageBox(parent=self.parent,
+ message=_("Location wizard canceled. "
+ "Location not created."),
+ caption=_("Location wizard"),
+ style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ self.__cleanUp()
+ def __cleanUp(self):
+ global coordsys
+ global north
+ global south
+ global east
+ global west
+ global resolution
+ global wizerror
+ global translist
+ coordsys = None
+ north = None
+ south = None
+ east = None
+ west = None
+ resolution = None
+ transformlist = list()
def __readData(self):
"""!Get georeferencing information from tables in $GISBASE/etc"""
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2010-03-07 11:10:27 UTC (rev 41317)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2010-03-07 11:21:16 UTC (rev 41318)
@@ -476,7 +476,11 @@
epsgCodeDict = dict()
try:
- f = open(path, "r")
+ try:
+ f = open(path, "r")
+ except IOError:
+ return _("failed to open '%s'" % path)
i = 0
code = None
for line in f.readlines():
@@ -488,15 +492,19 @@
descr = line[1:].strip()
elif line[0] == '<':
code, params = line.split(" ", 1)
- code = int(code.replace('<', '').replace('>', ''))
+ try:
+ code = int(code.replace('<', '').replace('>', ''))
+ except ValueError:
+ return e
epsgCodeDict[code] = (descr, params)
code = None
i += 1
f.close()
except StandardError, e:
- return str(e)
+ return e
return epsgCodeDict
