[GRASS-SVN] r41341 - grass/branches/releasebranch_6_4/vector/v.split
svn_grass at osgeo.org
Sun Mar 7 17:08:42 EST 2010
Author: martinl
Date: 2010-03-07 17:08:42 -0500 (Sun, 07 Mar 2010)
New Revision: 41341
grass/branches/releasebranch_6_4/vector/v.split/main.c
be more precise in testing if input is 3d
(merge r41337 from trunk)
Modified: grass/branches/releasebranch_6_4/vector/v.split/main.c
--- grass/branches/releasebranch_6_4/vector/v.split/main.c 2010-03-07 22:07:48 UTC (rev 41340)
+++ grass/branches/releasebranch_6_4/vector/v.split/main.c 2010-03-07 22:08:42 UTC (rev 41341)
@@ -80,7 +80,7 @@
Vect_set_open_level(2);
Vect_open_old(&In, in_opt->answer, "");
- Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&In));
+ Vect_open_new(&Out, out_opt->answer, Vect_is_3d(&In) ? WITH_Z : WITHOUT_Z);
Vect_copy_head_data(&In, &Out);
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
