[GRASS-SVN] r41353 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Mar 8 11:32:35 EST 2010
Author: martinl
Date: 2010-03-08 11:32:34 -0500 (Mon, 08 Mar 2010)
New Revision: 41353
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
wxGUI: bugfix when georectifier is started from LL location
(merge r41352 from relbr64 & some clean up)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2010-03-08 16:05:28 UTC (rev 41352)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2010-03-08 16:32:34 UTC (rev 41353)
@@ -370,98 +370,85 @@
#self.mapfile = self.gtemp + ".png"
class Map(object):
+ """!Map composition (stack of map layers and overlays)
- Map composition (stack of map layers and overlays)
- def __init__(self, gisrc=None):
+ def __init__(self, gisrc = None):
# region/extent settigns
- self.wind = {} # WIND settings (wind file)
- self.region = {} # region settings (g.region)
- self.width = 640 # map width
- self.height = 480 # map height
+ self.wind = dict() # WIND settings (wind file)
+ self.region = dict() # region settings (g.region)
+ self.width = 640 # map width
+ self.height = 480 # map height
# list of layers
- self.layers = [] # stack of available GRASS layer
+ self.layers = list() # stack of available GRASS layer
- self.overlays = [] # stack of available overlays
- self.ovlookup = {} # lookup dictionary for overlay items and overlays
+ self.overlays = list() # stack of available overlays
+ self.ovlookup = dict() # lookup dictionary for overlay items and overlays
# environment settings
# environment variables, like MAPSET, LOCATION_NAME, etc.
- self.env = {}
+ self.env = dict()
# path to external gisrc
self.gisrc = gisrc
# generated file for g.pnmcomp output for rendering the map
- #self.mapfile = utils.GetTempfile()
self.mapfile = tempfile.mkstemp(suffix='.ppm')[1]
# setting some initial env. variables
- self.InitGisEnv() # g.gisenv
- self.InitRegion()
+ self._initGisEnv() # g.gisenv
+ self.GetWindow()
# GRASS environment variable (for rendering)
os.environ["GRASS_TRANSPARENT"] = "TRUE"
os.environ["GRASS_BACKGROUNDCOLOR"] = "ffffff"
- self.projinfo = self.ProjInfo()
- def InitRegion(self):
- Initialize current region settings.
+ # projection info
+ self.projinfo = self._projInfo()
- Set up 'self.region' using g.region command and
- self.wind according to the wind file.
- Adjust self.region based on map window size.
- # setting region ('g.region -upg')
- ### not needed here (MapFrame.OnSize())
- # self.region = self.GetRegion()
- # read WIND file
- self.GetWindow()
- # setting resolution
- # not needed here (MapFrame.OnSize())
- # self.SetRegion()
- def InitGisEnv(self):
- Stores GRASS variables (g.gisenv) to self.env variable
- if not os.getenv("GISBASE"):
- print >> sys.stderr, _("GISBASE not set. You must be in GRASS GIS to run this program.")
- sys.exit(1)
+ def _runCommand(self, cmd, **kwargs):
+ """!Run command in environment defined by self.gisrc if
+ defined"""
# use external gisrc if defined
gisrc_orig = os.getenv("GISRC")
if self.gisrc:
os.environ["GISRC"] = self.gisrc
- self.env = grass.gisenv()
+ ret = cmd(**kwargs)
# back to original gisrc
if self.gisrc:
os.environ["GISRC"] = gisrc_orig
+ return ret
+ def _initGisEnv(self):
+ """!Stores GRASS variables (g.gisenv) to self.env variable
+ if not os.getenv("GISBASE"):
+ sys.exit(_("GISBASE not set. You must be in GRASS GIS to run this program."))
+ self.env = self._runCommand(grass.gisenv)
+ def _projInfo(self):
+ """!Return region projection and map units information
+ projinfo = dict()
+ ret = self._runCommand(gcmd.RunCommand, prog = 'g.proj',
+ read = True, flags = 'p')
+ if not ret:
+ return projinfo
+ for line in ret.splitlines():
+ if ':' in line:
+ key, val = line.split(':')
+ projinfo[key.strip()] = val.strip()
+ elif "XY location (unprojected)" in line:
+ projinfo['proj'] = 'xy'
+ projinfo['units'] = ''
+ break
+ return projinfo
def GetWindow(self):
"""!Read WIND file and set up self.wind dictionary"""
@@ -473,20 +460,16 @@
try:
windfile = open (filename, "r")
except IOError, e:
- sys.stderr.write("%s: %s <%s>: %s\n%s\n" % (_("Error"), _("Unable to open file"),
- filename, e,
- _("wxGUI closed.")))
- sys.exit(1)
+ sys.exit(_("Error: Unable to open '%s'. Reason: %s. wxGUI exited.\n") % \
+ filename, e)
for line in windfile.readlines():
line = line.strip()
- key, value = line.split(":",1)
- key = key.strip()
- value = value.strip()
- self.wind[key] = value
+ key, value = line.split(":", 1)
+ self.wind[key.strip()] = value.strip()
windfile.close()
return self.wind
def AdjustRegion(self):
@@ -759,33 +742,6 @@
except:
return None
- def ProjInfo(self):
- Return region projection and map units information
- projinfo = {}
- ret = gcmd.RunCommand('g.proj',
- read = True,
- flags = 'p')
- if not ret:
- return projinfo
- for line in ret.splitlines():
- if ':' in line:
- key,val = line.split(':')
- key = key.strip()
- val = val.strip()
- projinfo[key] = val
- elif "XY location (unprojected)" in line:
- projinfo['proj'] = "xy"
- projinfo['units'] = ''
- break
- return projinfo
def GetListOfLayers(self, l_type=None, l_mapset=None, l_name=None,
l_active=None, l_hidden=None):
