[GRASS-SVN] r41383 - grass/trunk/vector/v.db.connect
svn_grass at osgeo.org
Thu Mar 11 16:51:28 EST 2010
Author: martinl
Date: 2010-03-11 16:51:26 -0500 (Thu, 11 Mar 2010)
New Revision: 41383
grass/trunk/vector/v.db.connect/main.c
v.db.connect: more GUI sections
Modified: grass/trunk/vector/v.db.connect/main.c
--- grass/trunk/vector/v.db.connect/main.c 2010-03-11 20:15:13 UTC (rev 41382)
+++ grass/trunk/vector/v.db.connect/main.c 2010-03-11 21:51:26 UTC (rev 41383)
@@ -7,12 +7,11 @@
* PURPOSE: sets/prints DB connection for a given vector map
- * COPYRIGHT: (C) 2002-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2010 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
* TODO: - fix -o flag (needs fix in Vect lib)
@@ -58,9 +57,11 @@
dbdriver = G_define_standard_option(G_OPT_DB_DRIVER);
dbdriver->options = db_list_drivers();
dbdriver->answer = G_store(db_get_default_driver_name());
+ dbdriver->guisection = _("Settings");
dbdatabase = G_define_standard_option(G_OPT_DB_DATABASE);
dbdatabase->answer = G_store(db_get_default_database_name());
+ dbdatabase->guisection = _("Settings");
dbtable = G_define_standard_option(G_OPT_DB_TABLE);
@@ -75,10 +76,13 @@
field_opt->gisprompt = "new_layer,layer,layer";
sep_opt = G_define_standard_option(G_OPT_F_SEP);
+ sep_opt->description = _("Field separator for shell script style output");
+ sep_opt->guisection = _("Print");
print = G_define_flag();
print->key = 'p';
print->description = _("Print all map connection parameters and exit");
+ print->guisection = _("Print");
shell_print = G_define_flag();
shell_print->key = 'g';
@@ -86,12 +90,14 @@
"in shell script style");
shell_print->description =
_("Format: layer[/layer name] table key database driver");
+ shell_print->guisection = _("Print");
columns = G_define_flag();
columns->key = 'c';
columns->description =
_("Print types/names of table columns for specified "
"layer and exit");
+ columns->guisection = _("Print");
overwrite = G_define_flag();
overwrite->key = 'o';
