[GRASS-SVN] r41385 -
grass/branches/releasebranch_6_4/vector/v.db.connect
svn_grass at osgeo.org
Thu Mar 11 17:12:00 EST 2010
Author: martinl
Date: 2010-03-11 17:11:59 -0500 (Thu, 11 Mar 2010)
New Revision: 41385
grass/branches/releasebranch_6_4/vector/v.db.connect/main.c
v.db.connect: more GUI sections
(merge r41383 from trunk)
Modified: grass/branches/releasebranch_6_4/vector/v.db.connect/main.c
--- grass/branches/releasebranch_6_4/vector/v.db.connect/main.c 2010-03-11 21:58:39 UTC (rev 41384)
+++ grass/branches/releasebranch_6_4/vector/v.db.connect/main.c 2010-03-11 22:11:59 UTC (rev 41385)
@@ -7,12 +7,11 @@
* PURPOSE: sets/prints DB connection for a given vector map
- * COPYRIGHT: (C) 2002-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002-2010 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
* TODO: - fix -o flag (needs fix in Vect lib)
@@ -58,10 +57,12 @@
dbdriver->options = db_list_drivers();
if ((drv = G__getenv2("DB_DRIVER", G_VAR_MAPSET)))
dbdriver->answer = G_store(drv);
+ dbdriver->guisection = _("Settings");
dbdatabase = G_define_standard_option(G_OPT_DATABASE);
if ((db = G__getenv2("DB_DATABASE", G_VAR_MAPSET)))
dbdatabase->answer = G_store(db);
+ dbdatabase->guisection = _("Settings");
dbtable = G_define_standard_option(G_OPT_TABLE);
@@ -75,11 +76,14 @@
field_opt->gisprompt = "new_layer,layer,layer";
sep_opt = G_define_standard_option(G_OPT_F_SEP);
+ sep_opt->description = _("Field separator for shell script style output");
sep_opt->answer = " ";
+ sep_opt->guisection = _("Print");
print = G_define_flag();
print->key = 'p';
print->description = _("Print all map connection parameters and exit");
+ print->guisection = _("Print");
shell_print = G_define_flag();
shell_print->key = 'g';
@@ -87,6 +91,7 @@
"in shell script style");
shell_print->description =
_("Format: layer[/layer name] table key database driver");
+ shell_print->guisection = _("Print");
/* This should be changed in GRASS 7.
Printing options shouldn't ignore layer=%d option.
@@ -102,6 +107,7 @@
columns->description =
_("Print types/names of table columns for specified "
"layer and exit");
+ columns->guisection = _("Print");
overwrite = G_define_flag();
overwrite->key = 'o';
