[GRASS-SVN] r41397 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Mar 12 08:21:51 EST 2010
Author: martinl
Date: 2010-03-12 08:21:51 -0500 (Fri, 12 Mar 2010)
New Revision: 41397
grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
bugfix #995
(merge r41390, 41393, 41395, 41396 from relber64)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2010-03-12 13:19:45 UTC (rev 41396)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py 2010-03-12 13:21:51 UTC (rev 41397)
@@ -134,6 +134,18 @@
class Popen(subprocess.Popen):
"""!Subclass subprocess.Popen"""
+ def __init__(self, *args, **kwargs):
+ if subprocess.mswindows:
+ try:
+ kwargs['args'] = map(utils.EncodeString, kwargs['args'])
+ except KeyError:
+ if len(args) > 0:
+ targs = list(args)
+ targs[0] = map(utils.EncodeString, args[0])
+ args = tuple(targs)
+ subprocess.Popen.__init__(self, *args, **kwargs)
def recv(self, maxsize=None):
return self._recv('stdout', maxsize)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py 2010-03-12 13:19:45 UTC (rev 41396)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py 2010-03-12 13:21:51 UTC (rev 41397)
@@ -1681,8 +1681,8 @@
projdesc = self.parent.projpage.projdesc
ellipsedesc = self.parent.ellipsepage.ellipsedesc
datumdesc = self.parent.datumpage.datumdesc
- self.ldatabase.SetLabel(str(database))
- self.llocation.SetLabel(str(location))
+ self.ldatabase.SetLabel(database)
+ self.llocation.SetLabel(location)
label = ''
if coordsys == 'epsg':
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-03-12 13:19:45 UTC (rev 41396)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2010-03-12 13:21:51 UTC (rev 41397)
@@ -17,6 +17,7 @@
import platform
import string
import glob
+import locale
import globalvar
grassPath = os.path.join(globalvar.ETCDIR, "python")
@@ -467,7 +468,7 @@
return path[1].upper() + ':\\' + path[3:].replace('/', '\\')
return path
def ReadEpsgCodes(path):
"""!Read EPSG code from the file
@@ -611,3 +612,16 @@
return list()
return ret.splitlines()
+def EncodeString(string):
+ """!Return encoded string
+ @param string string to be encoded
+ @return encoded string
+ enc = locale.getdefaultlocale()[1]
+ if enc:
+ return string.encode(enc)
+ return string
