[GRASS-SVN] r41405 -
grass/branches/releasebranch_6_4/lib/db/dbmi_base
svn_grass at osgeo.org
Fri Mar 12 09:33:13 EST 2010
Author: martinl
Date: 2010-03-12 09:33:12 -0500 (Fri, 12 Mar 2010)
New Revision: 41405
grass/branches/releasebranch_6_4/lib/db/dbmi_base/default_name.c
doxygen update
Modified: grass/branches/releasebranch_6_4/lib/db/dbmi_base/default_name.c
--- grass/branches/releasebranch_6_4/lib/db/dbmi_base/default_name.c 2010-03-12 14:24:07 UTC (rev 41404)
+++ grass/branches/releasebranch_6_4/lib/db/dbmi_base/default_name.c 2010-03-12 14:33:12 UTC (rev 41405)
@@ -1,3 +1,17 @@
+ \file db/dbmi_base/default_name.c
+ \brief DBMI Library (base) - default settings
+ (C) 1999-2010 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Joel Jones (CERL/UIUC)
+ \author Upgraded to GRASS 5.7 by Radim Blazek
#include <stdlib.h>
#include <string.h>
#include <grass/gis.h>
@@ -2,8 +16,10 @@
#include <grass/dbmi.h>
+#include <grass/glocale.h>
- \fn const char * db_get_default_driver_name ( void )
- \brief returns pointer to default driver name
- \return returns pointer to default driver name or NULL if not set
+ \brief Get default driver name
+ \return pointer to default driver name
+ \return NULL if not set
const char *db_get_default_driver_name(void)
@@ -19,10 +35,11 @@
- \fn const char * db_get_default_database_name ( void )
- \brief returns pointer to default database name
- \return returns pointer to default database name or NULL if not set
+ \brief Get default database name
+ \return pointer to default database name
const char *db_get_default_database_name(void)
const char *drv;
@@ -34,10 +51,11 @@
- \fn const char * db_get_default_schema_name ( void )
- \brief returns pointer to default schema name
- \return returns pointer to default schema name or NULL if not set
+ \brief Get default schema name
+ \return pointer to default schema name
const char *db_get_default_schema_name(void)
const char *sch;
@@ -49,10 +67,11 @@
- \fn const char * db_get_default_group_name ( void )
- \brief returns pointer to default group name
- \return returns pointer to default group name or NULL if not set
+ \brief Get default group name
+ \return pointer to default group name
const char *db_get_default_group_name(void)
const char *gr;
@@ -63,13 +82,13 @@
return NULL;
+ \brief Sets up database connection settings using GRASS default from dbmi.h
+ \todo DB_OK on success, DB_* error code on fail
- \fn int db_set_default_connection(void)
- \brief sets up database connection settings using GRASS default from dbmi.h
- \return returns DB_OK (TODO: DB_OK on success, DB_* error code on fail)
+ \return returns DB_OK
dbConnection connection;
@@ -105,7 +124,7 @@
db_set_connection(&connection);
else
- G_fatal_error("Programmer error");
+ G_fatal_error(_("Programmer error"));
return DB_OK;
